Date/Time: Thu, 27 Feb 2025 02:39:28 +0000
windows error 10053
View Count: 613
[2021-06-14 14:19:36]
User61576 - Posts: 445
DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-06-14 10:16:13.980 *
I got this error and then my connection to the server was disconnected
anything I can do to prevent this happen again?
[2021-06-14 16:30:33]
John - SC Support - Posts: 38222
Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
[2021-06-14 17:24:44]
how does this help?
i would expect some more info on the log and not just check your router
[2021-06-14 19:06:16]
That is really all we know. You had a network connection issue. We do not know why or where or how. Therefore, it is up to you to figure out what might have occurred.
