Date/Time: Thu, 27 Feb 2025 02:37:48 +0000
Data Feed
View Count: 808
[2021-06-14 14:01:35] |
User508912 - Posts: 22 |
All of a sudden I am not receiving realtime data feed
[2021-06-14 16:28:11] |
John - SC Support - Posts: 38222 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog -------------------- On a separate note, we see that you have activated multiple exchanges for the Denali Exchange Data Feed for the CME Group which are redundant to each other. For instance, you have the Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts which gives you all the data available, so you would not need any other exchange options. So you will want to determine what exactly you want to keep and deactivate the others. Note that the exchanges do not give refunds, so we are unable to refund the payments you made for the extra exchanges. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-14 16:39:54] |
Created the DTC Protocol server. | 2021-06-14 16:02:22.522 DTC Protocol Server listening on port 11099. | 2021-06-14 16:02:22.523 Reading Internal Order ID file. | 2021-06-14 16:02:22.524 Reading Trade Orders file. | 2021-06-14 16:02:22.608 Reading Trade Positions file. | 2021-06-14 16:02:22.614 Reading Trade Account Data files. | 2021-06-14 16:02:22.620 UDPListener (1624). Port 22904 | Listening on UDP port 22904. | 2021-06-14 16:02:22.649 Software version: 2273 64-bit | 2021-06-14 16:02:22.649 Primary Thread ID: 3636 | 2021-06-14 16:02:22.649 Usage end date: 2021-08-22 | 2021-06-14 16:02:22.649 Enabled for: Advanced Features 2. | 2021-06-14 16:02:22.649 Enabled for: Sierra Chart Historical Data Service. | 2021-06-14 16:02:22.649 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-06-14 16:02:22.649 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-14 16:02:22.649 Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-14 16:02:22.649 Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX) | 2021-06-14 16:02:22.649 Enabled for exchange: Euronext Equities Delayed | 2021-06-14 16:02:22.649 Enabled for exchange2: CME | 2021-06-14 16:02:22.649 Enabled for exchange2: CBOT | 2021-06-14 16:02:22.649 Enabled for exchange2: COMEX | 2021-06-14 16:02:22.649 Enabled for exchange2: NYMEX | 2021-06-14 16:02:22.649 Enabled for exchange2: EUREX EOBI | 2021-06-14 16:02:22.649 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-14 16:02:22.649 Current selected Data/Trading service: CQG WebAPI | 2021-06-14 16:02:22.649 Custom symbol settings values: enabled | 2021-06-14 16:02:22.649 Chart Update Interval: 500 | 2021-06-14 16:02:22.649 Intraday Data Storage Time Unit: 1 | 2021-06-14 16:02:22.649 Time Zone: +00:00:00 (UTC+00) | 2021-06-14 16:02:22.649 2021-06-14 16:02:22 Local computer time in UTC | 2021-06-14 16:02:22.649 2021-06-14 16:02:22 Local computer time in SC Time Zone | 2021-06-14 16:02:22.649 2021-06-14 16:02:21 Server time in UTC | 2021-06-14 16:02:22.649 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-06-14 16:02:22.649 Program path: C:\SierraChart\ | 2021-06-14 16:02:22.649 Data Files path: C:\SierraChart\Data\ | 2021-06-14 16:02:22.649 OS Version Number: 10.0 | 2021-06-14 16:02:22.649 Locale Setting: C | 2021-06-14 16:02:22.649 DLLs: UserContributedStudies_64.dll | 2021-06-14 16:02:22.652 Allowed protected custom studies: | 2021-06-14 16:02:22.652 Created the DTC Protocol historical data server. | 2021-06-14 16:02:22.679 HD Server Manager | Listening on port 11098. | 2021-06-14 16:02:22.679 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2021-06-14 16:02:22.680 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:02:22.726 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-06-14 16:02:22.859 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-06-14 16:02:22.859 Received 5 login tokens. | 2021-06-14 16:02:23.102 Symbol settings MD5 received. Request ID: 1. | 2021-06-14 16:02:23.369 Requested symbol settings for service code cqg. Request ID: 2. | 2021-06-14 16:02:23.369 Symbol settings received. Request ID: 2. | 2021-06-14 16:02:24.492 CQG WebAPI | Connecting to server api.cqg.com | 2021-06-14 16:02:29.322 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-06-14 16:02:29.322 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-06-14 16:02:29.372 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:02:29.372 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2021-06-14 16:02:29.372 CQG WebSocket | Opening WebSocket. | 2021-06-14 16:02:29.419 CQG WebSocket | Sending WebSocket handshake. | 2021-06-14 16:02:29.419 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-06-14 16:02:29.589 CQG WebSocket | Server header | Connection: upgrade | 2021-06-14 16:02:29.589 CQG WebSocket | Server header | Sec-WebSocket-Accept: f/xu2YiuMxDuUbACldWMhY2GPoU= | 2021-06-14 16:02:29.589 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-06-14 16:02:29.589 CQG WebSocket | Server header | Upgrade: websocket | 2021-06-14 16:02:29.589 CQG WebSocket | Server header | | 2021-06-14 16:02:29.589 CQG WebSocket | Web socket state is now open. | 2021-06-14 16:02:29.589 CQG WebAPI | WebSocket connected. | 2021-06-14 16:02:29.589 CQG WebAPI | Sending market data logon message. | 2021-06-14 16:02:29.591 CQG WebAPI | Base Time: 2021-06-13T01:52:24. 2021-06-13 01:52:24 | 2021-06-14 16:02:29.770 CQG WebAPI | Logon successful. Session Token = tEI1+t3nzbGkkPScd74gYnOT5ublDqBy9+qVAFwHnE0gQQZlceILRno0+KQEZgNbs/1oEYXKCbL | 2021-06-14 16:02:29.770 CQG WebAPI | Connected to server complete. | 2021-06-14 16:02:29.770 Triggering next historical data download in queue. | 2021-06-14 16:02:29.772 Triggering next historical data download in queue. | 2021-06-14 16:02:29.772 Triggering next historical data download in queue. | 2021-06-14 16:02:29.772 Triggering next historical data download in queue. | 2021-06-14 16:02:29.772 Updated verified funded futures trading account ending date to: 2021-07-14 16:02:29 | 2021-06-14 16:02:29.774 CQG WebAPI | Sending Trade Accounts request message. | 2021-06-14 16:02:29.774 No download requests in the queue to start downloads for. | 2021-06-14 16:02:29.774 No download requests in the queue to start downloads for. | 2021-06-14 16:02:29.774 No download requests in the queue to start downloads for. | 2021-06-14 16:02:29.774 No download requests in the queue to start downloads for. | 2021-06-14 16:02:29.774 CQG WebAPI | Brokerage name: AMP. Account Name: 141240 | 2021-06-14 16:02:29.870 CQG WebAPI | Sending collateral subscribe request. | 2021-06-14 16:02:29.870 CQG WebAPI | Sending positions subscribe request. RequestID: 486660 | 2021-06-14 16:02:34.761 CQG WebAPI | Sending orders subscribe request. RequestID: 486661 | 2021-06-14 16:02:34.761 F.US.EPM22 [C] #1 | Reloading chart. | 2021-06-14 16:03:28.086 Starting DelayedDownloadMonitoringTimer | 2021-06-14 16:03:28.099 Starting HDTimeoutTimer | 2021-06-14 16:03:28.099 Added historical Intraday data request for F.US.EPU21 to the queue. | 2021-06-14 16:03:28.099 Triggering next historical data download in queue. | 2021-06-14 16:03:28.099 Added historical Intraday data request for F.US.EPZ21 to the queue. | 2021-06-14 16:03:28.126 Added historical Intraday data request for F.US.EPH22 to the queue. | 2021-06-14 16:03:28.131 Added historical Intraday data request for F.US.EPM22 to the queue. | 2021-06-14 16:03:28.131 F.US.EPM22 [C] #1 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-06-14 16:03:28.131 F.US.EPM22 [C] #2 | Reloading chart. | 2021-06-14 16:03:28.166 F.US.EPM22 [C] #2 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-06-14 16:03:28.172 F.US.ENQM21 [C] #4 | Reloading chart. | 2021-06-14 16:03:28.190 F.US.RTYM21 [C] #5 | Reloading chart. | 2021-06-14 16:03:28.219 F.US.EPM22 [C] #3 | Reloading chart. | 2021-06-14 16:03:28.249 F.US.EPM22 [C] #3 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-06-14 16:03:28.251 F.US.CLEN21 [CB] #14 | Reloading chart. | 2021-06-14 16:03:28.269 Error loading: C:\SierraChart\Data\mpmBubbles.dll. May be missing SCDLLName line. | 2021-06-14 16:03:28.927 TICK-NYSE 5 Min #6 | Reloading chart. | 2021-06-14 16:03:28.958 UDVR-NYSE 5 Min #7 | Reloading chart. | 2021-06-14 16:03:29.011 F.US.MESM21 #8 | Reloading chart. | 2021-06-14 16:03:29.287 F.US.EPM21 [C] Daily #9 | Reloading chart. | 2021-06-14 16:03:29.325 + Loading additional symbol data. | 2021-06-14 16:03:29.443 + Loading additional symbol data. | 2021-06-14 16:03:29.579 + Loading additional symbol data. | 2021-06-14 16:03:29.711 + Loading additional symbol data. | 2021-06-14 16:03:29.853 MSFT [C] #12 | Reloading chart. | 2021-06-14 16:03:31.161 MSFT [C] #12 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-06-14 16:03:31.161 MSFT [C] #12 | There are no continuous futures contract symbols. Loading data normally. | 2021-06-14 16:03:31.161 TSLA [C] #11 | Reloading chart. | 2021-06-14 16:03:31.218 TSLA [C] #11 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-06-14 16:03:31.218 TSLA [C] #11 | There are no continuous futures contract symbols. Loading data normally. | 2021-06-14 16:03:31.218 AAPL [C] #10 | Reloading chart. | 2021-06-14 16:03:31.248 AAPL [C] #10 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-06-14 16:03:31.248 AAPL [C] #10 | There are no continuous futures contract symbols. Loading data normally. | 2021-06-14 16:03:31.248 F.US.EPM22 [C] #13 | Reloading chart. | 2021-06-14 16:03:31.284 F.US.EPM22 [C] #13 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-06-14 16:03:31.287 F.US.EPM22 [C] #15 | Reloading chart. | 2021-06-14 16:03:31.303 F.US.EPM22 [C] #15 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-06-14 16:03:31.305 Mapping F.US.EPU21 to ESU21. Service code: cme | 2021-06-14 16:03:31.347 HD Request # 1 | Downloading Intraday chart data for F.US.EPU21 to the file F.US.EPU21.scid. Service: cme | 2021-06-14 16:03:31.347 HD Request # 1 | Download start date-time: 2021-06-14 16:00:10.000000. File last date-time: 2021-06-14 16:00:10.089000 | 2021-06-14 16:03:31.347 HD Request # 1 | Using server: ds23.sierracharts.com port 10150 | 2021-06-14 16:03:31.347 F.US.MESM21 #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-14 16:03:31.352 Socket (2) | Creating socket. | 2021-06-14 16:03:31.472 Socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:03:31.472 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:03:31.472 SC DTC Data with Market Depth | Starting real-time market data updates for: UVOL-NYSE. ID: 2 Service code: statscalc | 2021-06-14 16:03:31.476 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2021-06-14 16:03:31.476 SC DTC Data with Market Depth | Requesting security definition data for: UVOL-NYSE. ID: 2 | 2021-06-14 16:03:31.476 Added historical Intraday data request for UVOL-NYSE to the queue. | 2021-06-14 16:03:31.476 Intraday data recording state for symbol UVOL-NYSE is set to download 'Pending'. | 2021-06-14 16:03:31.476 Triggering next historical data download in queue. | 2021-06-14 16:03:31.476 TICK-NYSE 5 Min #6 | Started historical data download for additional symbol UVOL-NYSE. Download ID: 5 | 2021-06-14 16:03:31.476 SC DTC Data with Market Depth | Starting real-time market data updates for: DVOL-NYSE. ID: 3 Service code: statscalc | 2021-06-14 16:03:31.476 SC DTC Data with Market Depth | Requesting security definition data for: DVOL-NYSE. ID: 3 | 2021-06-14 16:03:31.476 Added historical Intraday data request for DVOL-NYSE to the queue. | 2021-06-14 16:03:31.476 Intraday data recording state for symbol DVOL-NYSE is set to download 'Pending'. | 2021-06-14 16:03:31.476 TICK-NYSE 5 Min #6 | Started historical data download for additional symbol DVOL-NYSE. Download ID: 6 | 2021-06-14 16:03:31.476 SC DTC Data with Market Depth | Starting real-time market data updates for: DVOL-NASDAQ. ID: 4 Service code: statscalc | 2021-06-14 16:03:31.476 SC DTC Data with Market Depth | Requesting security definition data for: DVOL-NASDAQ. ID: 4 | 2021-06-14 16:03:31.476 Added historical Intraday data request for DVOL-NASDAQ to the queue. | 2021-06-14 16:03:31.477 Intraday data recording state for symbol DVOL-NASDAQ is set to download 'Pending'. | 2021-06-14 16:03:31.477 TICK-NYSE 5 Min #6 | Started historical data download for additional symbol DVOL-NASDAQ. Download ID: 7 | 2021-06-14 16:03:31.477 SC DTC Data with Market Depth | Starting real-time market data updates for: UVOL-NASDAQ. ID: 5 Service code: statscalc | 2021-06-14 16:03:31.477 SC DTC Data with Market Depth | Requesting security definition data for: UVOL-NASDAQ. ID: 5 | 2021-06-14 16:03:31.477 Added historical Intraday data request for UVOL-NASDAQ to the queue. | 2021-06-14 16:03:31.477 Intraday data recording state for symbol UVOL-NASDAQ is set to download 'Pending'. | 2021-06-14 16:03:31.477 TICK-NYSE 5 Min #6 | Started historical data download for additional symbol UVOL-NASDAQ. Download ID: 8 | 2021-06-14 16:03:31.477 DTC Client socket (3) | Creating socket. | 2021-06-14 16:03:31.513 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-14 16:03:31.513 DTC Client socket (3) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:03:31.513 HD Request # 1 | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:31.574 HD Request # 1 | Sending historical data logon request message. | 2021-06-14 16:03:31.574 SC DTC Data with Market Depth | Network connection to server complete. | 2021-06-14 16:03:31.847 SC DTC Data with Market Depth | Starting socket receive thread. | 2021-06-14 16:03:31.847 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:03:31.847 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:32.026 SC DTC Data with Market Depth | Sending logon request message. | 2021-06-14 16:03:32.026 HD Request # 1 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:10. Record interval: 1. Symbol: ESU21 | 2021-06-14 16:03:32.081 HD Request # 1 | Decompressing data. | 2021-06-14 16:03:32.142 HD Request # 1 | Receiving Intraday data for F.US.EPU21 starting at 2021-06-14 16:00:10.089000 | 2021-06-14 16:03:32.143 Socket (2) | CloseSocket call. | 2021-06-14 16:03:32.143 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:32.143 Socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:03:32.187 Socket (2) | Closed. | 2021-06-14 16:03:32.187 Historical data download thread signaled to stop. | 2021-06-14 16:03:32.313 HD Request # 1 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:10.089000 | 2021-06-14 16:03:32.313 HD Request # 1 | Received 86 records from 2021-06-14 16:00:10.089000 to 2021-06-14 16:03:28.106000 (3.3 minutes) and wrote 86 records for F.US.EPU21 | 2021-06-14 16:03:32.313 HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:03:28.106000 | 2021-06-14 16:03:32.320 HD Request # 1 | Completion time: 1s | 2021-06-14 16:03:32.320 HD Request # 1 | Intraday data download complete for F.US.EPU21. Unique request ID: 1 | 2021-06-14 16:03:32.320 Removing historical data download ID 1. | 2021-06-14 16:03:32.320 Real-time Intraday chart data file updates started for F.US.EPU21 | 2021-06-14 16:03:32.320 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPU21.scid. Thread ID: 3636 | 2021-06-14 16:03:32.320 Intraday chart data file opened for F.US.EPU21 | 2021-06-14 16:03:32.320 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:03:32.320 Triggering next historical data download in queue. | 2021-06-14 16:03:32.320 Mapping F.US.EPZ21 to ESZ21. Service code: cme | 2021-06-14 16:03:32.378 HD Request # 2 | Downloading Intraday chart data for F.US.EPZ21 to the file F.US.EPZ21.scid. Service: cme | 2021-06-14 16:03:32.378 HD Request # 2 | Download start date-time: 2021-06-14 13:41:12.000000. File last date-time: 2021-06-14 13:41:12.414000 | 2021-06-14 16:03:32.379 HD Request # 2 | Using server: ds21.sierracharts.com port 10149 | 2021-06-14 16:03:32.379 Socket (2) | Creating socket. | 2021-06-14 16:03:32.422 Socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:03:32.422 Socket (2) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:03:32.422 HD Request # 2 | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:32.509 HD Request # 2 | Sending historical data logon request message. | 2021-06-14 16:03:32.509 Mapping F.US.MESM21 to MESM21. Service code: cme | 2021-06-14 16:03:32.613 Mapping F.US.MESU21 to MESU21. Service code: cme | 2021-06-14 16:03:32.613 SC Data - All Services | Starting real-time market data updates for: F.US.MESU21 (MESU21). ID: 8 Service code: cme | 2021-06-14 16:03:32.613 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-06-14 16:03:32.613 CQG WebAPI | Sending symbol resolution request for F.US.MESU21. ID: 486662 | 2021-06-14 16:03:32.614 SC Data - All Services | Requesting security definition data for: F.US.MESU21 (MESU21). ID: 8 | 2021-06-14 16:03:32.614 SC Data - All Services | Starting real-time market data updates for: F.US.MESM21 (MESM21). ID: 7 Service code: cme | 2021-06-14 16:03:32.614 CQG WebAPI | Sending symbol resolution request for F.US.MESM21. ID: 486663 | 2021-06-14 16:03:32.614 SC Data - All Services | Requesting security definition data for: F.US.MESM21 (MESM21). ID: 7 | 2021-06-14 16:03:32.614 Requesting market depth updates for: F.US.MESM21 if supported. | 2021-06-14 16:03:32.614 Separate subscription for market depth updates not supported. F.US.MESM21 | 2021-06-14 16:03:32.614 DTC Client socket (5) | Creating socket. | 2021-06-14 16:03:32.614 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:03:32.614 DTC Client socket (5) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:03:32.614 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:03:32.676 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:03:32.676 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:03:32.676 CQG WebAPI | Received symbol resolution report for symbol F.US.MESU21. Search Symbol: F.US.MESU21. Request ID: 486662. Contract ID: 1. | 2021-06-14 16:03:32.677 Mapping F.US.ENQM21 to NQM21. Service code: cme | 2021-06-14 16:03:32.679 Mapping F.US.ENQU21 to NQU21. Service code: cme | 2021-06-14 16:03:32.679 SC Data - All Services | Starting real-time market data updates for: F.US.ENQU21 (NQU21). ID: 10 Service code: cme | 2021-06-14 16:03:32.679 CQG WebAPI | Sending symbol resolution request for F.US.ENQU21. ID: 486664 | 2021-06-14 16:03:32.679 SC Data - All Services | Requesting security definition data for: F.US.ENQU21 (NQU21). ID: 10 | 2021-06-14 16:03:32.679 SC Data - All Services | Starting real-time market data updates for: F.US.ENQM21 (NQM21). ID: 9 Service code: cme | 2021-06-14 16:03:32.679 CQG WebAPI | Sending symbol resolution request for F.US.ENQM21. ID: 486665 | 2021-06-14 16:03:32.679 SC Data - All Services | Requesting security definition data for: F.US.ENQM21 (NQM21). ID: 9 | 2021-06-14 16:03:32.679 Added historical Intraday data request for F.US.ENQM21 to the queue. | 2021-06-14 16:03:32.679 Intraday data recording state for symbol F.US.ENQM21 is set to download 'Pending'. | 2021-06-14 16:03:32.679 Triggering next historical data download in queue. | 2021-06-14 16:03:32.679 TSLA [C] #11 Record has been filtered due to large range while loading Intraday data for TSLA | 2021-06-14 16:03:32.695 * CQG WebAPI | Received symbol resolution report for symbol F.US.MESM21. Search Symbol: F.US.MESM21. Request ID: 486663. Contract ID: 2. | 2021-06-14 16:03:32.773 SC DTC Data with Market Depth | Received logon response. | 2021-06-14 16:03:32.773 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-06-14 16:03:32.773 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:03:32.773 SC DTC Data with Market Depth | Successfully connected. | 2021-06-14 16:03:32.773 SC DTC Data with Market Depth | Trading is not supported. | 2021-06-14 16:03:32.773 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DVOL-NASDAQ | 2021-06-14 16:03:32.774 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DVOL-NYSE | 2021-06-14 16:03:32.774 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UVOL-NASDAQ | 2021-06-14 16:03:32.774 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UVOL-NYSE | 2021-06-14 16:03:32.774 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:32.774 SC Data - All Services | Sending logon request message. | 2021-06-14 16:03:32.774 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU21. Search Symbol: F.US.ENQU21. Request ID: 486664. Contract ID: 3. | 2021-06-14 16:03:32.774 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQM21. Search Symbol: F.US.ENQM21. Request ID: 486665. Contract ID: 4. | 2021-06-14 16:03:32.774 SC DTC Data with Market Depth | Received security definition for symbol DVOL-NASDAQ | 2021-06-14 16:03:33.008 SC DTC Data with Market Depth | Received security definition for symbol DVOL-NYSE | 2021-06-14 16:03:33.008 SC DTC Data with Market Depth | Received security definition for symbol UVOL-NASDAQ | 2021-06-14 16:03:33.008 SC DTC Data with Market Depth | Received security definition for symbol UVOL-NYSE | 2021-06-14 16:03:33.008 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-06-14 13:41:12. Record interval: 1. Symbol: ESZ21 | 2021-06-14 16:03:33.009 HD Request # 2 | Decompressing data. | 2021-06-14 16:03:33.050 HD Request # 2 | Receiving Intraday data for F.US.EPZ21 starting at 2021-06-14 13:41:12.414000 | 2021-06-14 16:03:33.051 Socket (2) | CloseSocket call. | 2021-06-14 16:03:33.051 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:33.051 Historical data download thread signaled to stop. | 2021-06-14 16:03:33.051 HD Request # 2 | Timestamp of first Intraday data file record written: 2021-06-14 13:41:12.414000 | 2021-06-14 16:03:33.052 HD Request # 2 | Received 17 records from 2021-06-14 13:41:12.414000 to 2021-06-14 15:12:00.443000 (90.8 minutes) and wrote 17 records for F.US.EPZ21 | 2021-06-14 16:03:33.052 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2021-06-14 15:12:00.443000 | 2021-06-14 16:03:33.081 HD Request # 2 | Completion time: 1s | 2021-06-14 16:03:33.081 HD Request # 2 | Intraday data download complete for F.US.EPZ21. Unique request ID: 2 | 2021-06-14 16:03:33.081 Removing historical data download ID 2. | 2021-06-14 16:03:33.081 Real-time Intraday chart data file updates started for F.US.EPZ21 | 2021-06-14 16:03:33.081 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPZ21.scid. Thread ID: 3636 | 2021-06-14 16:03:33.081 Intraday chart data file opened for F.US.EPZ21 | 2021-06-14 16:03:33.081 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:03:33.081 Triggering next historical data download in queue. | 2021-06-14 16:03:33.081 Mapping F.US.EPH22 to ESH22. Service code: cme | 2021-06-14 16:03:33.081 HD Request # 3 | Downloading Intraday chart data for F.US.EPH22 to the file F.US.EPH22.scid. Service: cme | 2021-06-14 16:03:33.081 HD Request # 3 | Download start date-time: 2021-11-24 00:00:00.000000. File last date-time: 00:00:00.000000 | 2021-06-14 16:03:33.082 HD Request # 3 | Using server: ds23.sierracharts.com port 10150 | 2021-06-14 16:03:33.082 Socket (6) | Creating socket. | 2021-06-14 16:03:33.082 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:03:33.082 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:03:33.082 Mapping MSFT to MSFT. Service code: equities.us | 2021-06-14 16:03:33.085 SC Data - All Services | Starting real-time market data updates for: MSFT (MSFT). ID: 12 Service code: equities.us | 2021-06-14 16:03:33.085 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:03:33.085 CQG WebAPI | Sending symbol resolution request for MSFT. ID: 486666 | 2021-06-14 16:03:33.085 SC Data - All Services | Requesting security definition data for: MSFT (MSFT). ID: 12 | 2021-06-14 16:03:33.085 Added historical Intraday data request for MSFT to the queue. | 2021-06-14 16:03:33.085 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-06-14 16:03:33.085 Triggering next historical data download in queue. | 2021-06-14 16:03:33.085 Socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:03:33.097 Socket (2) | Closed. | 2021-06-14 16:03:33.097 Mapping F.US.RTYM21 to RTYM21. Service code: cme | 2021-06-14 16:03:33.116 Mapping F.US.RTYU21 to RTYU21. Service code: cme | 2021-06-14 16:03:33.116 SC Data - All Services | Starting real-time market data updates for: F.US.RTYU21 (RTYU21). ID: 14 Service code: cme | 2021-06-14 16:03:33.117 CQG WebAPI | Sending symbol resolution request for F.US.RTYU21. ID: 486667 | 2021-06-14 16:03:33.117 SC Data - All Services | Requesting security definition data for: F.US.RTYU21 (RTYU21). ID: 14 | 2021-06-14 16:03:33.117 SC Data - All Services | Starting real-time market data updates for: F.US.RTYM21 (RTYM21). ID: 13 Service code: cme | 2021-06-14 16:03:33.117 CQG WebAPI | Sending symbol resolution request for F.US.RTYM21. ID: 486668 | 2021-06-14 16:03:33.117 SC Data - All Services | Requesting security definition data for: F.US.RTYM21 (RTYM21). ID: 13 | 2021-06-14 16:03:33.117 Added historical Intraday data request for F.US.RTYM21 to the queue. | 2021-06-14 16:03:33.117 Intraday data recording state for symbol F.US.RTYM21 is set to download 'Pending'. | 2021-06-14 16:03:33.117 Triggering next historical data download in queue. | 2021-06-14 16:03:33.117 DTC Client socket (7) | Creating socket. | 2021-06-14 16:03:33.125 DTC Client socket (7) | New receive buffer size: 5242880 | 2021-06-14 16:03:33.125 DTC Client socket (7) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:03:33.125 CQG WebAPI | Received symbol resolution report for symbol S.US.MSFT. Search Symbol: MSFT. Request ID: 486666. Contract ID: 5. | 2021-06-14 16:03:33.152 Symbol Error - MSFT is unknown, unavailable, or improperly formatted. Exact match not found for symbol MSFT | 2021-06-14 16:03:33.152 HD Request # 3 | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:33.181 HD Request # 3 | Sending historical data logon request message. | 2021-06-14 16:03:33.182 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:03:33.184 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:03:33.184 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:03:33.184 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYU21. Search Symbol: F.US.RTYU21. Request ID: 486667. Contract ID: 6. | 2021-06-14 16:03:33.184 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYM21. Search Symbol: F.US.RTYM21. Request ID: 486668. Contract ID: 7. | 2021-06-14 16:03:33.184 Mapping TSLA to TSLA. Service code: equities.us | 2021-06-14 16:03:33.185 SC Data - All Services | Starting real-time market data updates for: TSLA (TSLA). ID: 15 Service code: equities.us | 2021-06-14 16:03:33.185 CQG WebAPI | Sending symbol resolution request for TSLA. ID: 486669 | 2021-06-14 16:03:33.185 SC Data - All Services | Requesting security definition data for: TSLA (TSLA). ID: 15 | 2021-06-14 16:03:33.185 Added historical Intraday data request for TSLA to the queue. | 2021-06-14 16:03:33.185 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2021-06-14 16:03:33.185 Triggering next historical data download in queue. | 2021-06-14 16:03:33.185 Mapping AAPL to AAPL. Service code: equities.us | 2021-06-14 16:03:33.187 SC Data - All Services | Starting real-time market data updates for: AAPL (AAPL). ID: 16 Service code: equities.us | 2021-06-14 16:03:33.187 CQG WebAPI | Sending symbol resolution request for AAPL. ID: 486670 | 2021-06-14 16:03:33.187 SC Data - All Services | Requesting security definition data for: AAPL (AAPL). ID: 16 | 2021-06-14 16:03:33.187 Added historical Intraday data request for AAPL to the queue. | 2021-06-14 16:03:33.187 Intraday data recording state for symbol AAPL is set to download 'Pending'. | 2021-06-14 16:03:33.187 Triggering next historical data download in queue. | 2021-06-14 16:03:33.187 Mapping F.US.CLEN21 to CLN21. Service code: nymex | 2021-06-14 16:03:33.188 Mapping F.US.CLEQ21 to CLQ21. Service code: nymex | 2021-06-14 16:03:33.188 SC Data - All Services | Starting real-time market data updates for: F.US.CLEQ21 (CLQ21). ID: 18 Service code: nymex | 2021-06-14 16:03:33.188 CQG WebAPI | Sending symbol resolution request for F.US.CLEQ21. ID: 486671 | 2021-06-14 16:03:33.188 SC Data - All Services | Requesting security definition data for: F.US.CLEQ21 (CLQ21). ID: 18 | 2021-06-14 16:03:33.189 SC Data - All Services | Starting real-time market data updates for: F.US.CLEN21 (CLN21). ID: 17 Service code: nymex | 2021-06-14 16:03:33.189 CQG WebAPI | Sending symbol resolution request for F.US.CLEN21. ID: 486672 | 2021-06-14 16:03:33.189 SC Data - All Services | Requesting security definition data for: F.US.CLEN21 (CLN21). ID: 17 | 2021-06-14 16:03:33.189 Added historical Intraday data request for F.US.CLEN21 to the queue. | 2021-06-14 16:03:33.189 Intraday data recording state for symbol F.US.CLEN21 is set to download 'Pending'. | 2021-06-14 16:03:33.189 Triggering next historical data download in queue. | 2021-06-14 16:03:33.189 HD Request # 3 | Requesting Intraday data. Start date-time: 2021-11-24 00:00:00. Record interval: 1. Symbol: ESH22 | 2021-06-14 16:03:33.221 CQG WebAPI | Received symbol resolution report for symbol S.US.TSLA. Search Symbol: TSLA. Request ID: 486669. Contract ID: 8. | 2021-06-14 16:03:33.262 Symbol Error - TSLA is unknown, unavailable, or improperly formatted. Exact match not found for symbol TSLA | 2021-06-14 16:03:33.262 CQG WebAPI | Received symbol resolution report for symbol X.US.AAPLA00. Search Symbol: AAPL. Request ID: 486670. Contract ID: 9. | 2021-06-14 16:03:33.262 Symbol Error - AAPL is unknown, unavailable, or improperly formatted. Exact match not found for symbol AAPL | 2021-06-14 16:03:33.262 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ21. Search Symbol: F.US.CLEQ21. Request ID: 486671. Contract ID: 10. | 2021-06-14 16:03:33.262 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN21. Search Symbol: F.US.CLEN21. Request ID: 486672. Contract ID: 11. | 2021-06-14 16:03:33.262 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:33.262 SC Data - All Services | Sending logon request message. | 2021-06-14 16:03:33.262 Added historical Intraday data request for F.US.MESM21 to the queue. | 2021-06-14 16:03:33.265 Intraday data recording state for symbol F.US.MESM21 is set to download 'Pending'. | 2021-06-14 16:03:33.265 Triggering next historical data download in queue. | 2021-06-14 16:03:33.265 Starting DelayedDownloadMonitoringTimer | 2021-06-14 16:03:33.267 Starting HDTimeoutTimer | 2021-06-14 16:03:33.267 Added historical Daily data request for F.US.EPM21 to the queue. | 2021-06-14 16:03:33.267 Triggering next historical data download in queue. | 2021-06-14 16:03:33.267 Mapping F.US.EPM21 to ESM21. Service code: cme | 2021-06-14 16:03:33.267 SC Data - All Services | Starting real-time market data updates for: F.US.EPU21 (ESU21). ID: 1 Service code: cme | 2021-06-14 16:03:33.267 CQG WebAPI | Sending symbol resolution request for F.US.EPU21. ID: 486673 | 2021-06-14 16:03:33.267 SC Data - All Services | Requesting security definition data for: F.US.EPU21 (ESU21). ID: 1 | 2021-06-14 16:03:33.267 SC Data - All Services | Starting real-time market data updates for: F.US.EPM21 (ESM21). ID: 19 Service code: cme | 2021-06-14 16:03:33.267 CQG WebAPI | Sending symbol resolution request for F.US.EPM21. ID: 486674 | 2021-06-14 16:03:33.267 SC Data - All Services | Requesting security definition data for: F.US.EPM21 (ESM21). ID: 19 | 2021-06-14 16:03:33.267 HD Request # 3 | Decompressing data. | 2021-06-14 16:03:33.268 Socket (6) | CloseSocket call. | 2021-06-14 16:03:33.269 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:33.269 HD Request # 4 | Downloading Historical Daily chart data for F.US.EPM21. Starting date: 2021-06-10. Service: cqg | 2021-06-14 16:03:33.290 Historical data download thread signaled to stop. | 2021-06-14 16:03:33.290 HD Request # 3 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.EPH22 | 2021-06-14 16:03:33.290 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2021-06-14 16:03:33.290 HD Request # 3 | Completion time: 0s | 2021-06-14 16:03:33.290 HD Request # 3 | Intraday data download complete for F.US.EPH22. Unique request ID: 3 | 2021-06-14 16:03:33.290 Removing historical data download ID 3. | 2021-06-14 16:03:33.290 Real-time Intraday chart data file updates started for F.US.EPH22 | 2021-06-14 16:03:33.290 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPH22.scid. Thread ID: 3636 | 2021-06-14 16:03:33.291 Intraday chart data file opened for F.US.EPH22 | 2021-06-14 16:03:33.291 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:03:33.291 Triggering next historical data download in queue. | 2021-06-14 16:03:33.291 Mapping F.US.EPM22 to ESM22. Service code: cme | 2021-06-14 16:03:33.291 HD Request # 5 | Downloading Intraday chart data for F.US.EPM22 to the file F.US.EPM22.scid. Service: cme | 2021-06-14 16:03:33.291 HD Request # 5 | Download start date-time: 2021-04-19 16:42:10.000000. File last date-time: 2021-04-19 16:42:10.679000 | 2021-06-14 16:03:33.291 HD Request # 5 | Using server: ds21.sierracharts.com port 10149 | 2021-06-14 16:03:33.291 Socket (8) | Creating socket. | 2021-06-14 16:03:33.291 Socket (8) | New receive buffer size: 5242880 | 2021-06-14 16:03:33.291 Socket (8) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:03:33.291 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 21 Service code: statscalc | 2021-06-14 16:03:33.307 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 21 | 2021-06-14 16:03:33.307 Added historical Intraday data request for TICK-NYSE to the queue. | 2021-06-14 16:03:33.307 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2021-06-14 16:03:33.307 Triggering next historical data download in queue. | 2021-06-14 16:03:33.307 SC DTC Data with Market Depth | Starting real-time market data updates for: UDVR-NYSE. ID: 22 Service code: statscalc | 2021-06-14 16:03:33.308 SC DTC Data with Market Depth | Requesting security definition data for: UDVR-NYSE. ID: 22 | 2021-06-14 16:03:33.308 Added historical Intraday data request for UDVR-NYSE to the queue. | 2021-06-14 16:03:33.308 Intraday data recording state for symbol UDVR-NYSE is set to download 'Pending'. | 2021-06-14 16:03:33.308 Triggering next historical data download in queue. | 2021-06-14 16:03:33.308 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:03:33.315 Socket (6) | Closed. | 2021-06-14 16:03:33.315 CQG WebAPI | Received symbol resolution report for symbol F.US.EPU21. Search Symbol: F.US.EPU21. Request ID: 486673. Contract ID: 12. | 2021-06-14 16:03:33.317 CQG WebAPI | Received symbol resolution report for symbol F.US.EPM21. Search Symbol: F.US.EPM21. Request ID: 486674. Contract ID: 13. | 2021-06-14 16:03:33.318 HD Request # 5 | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:33.384 HD Request # 5 | Sending historical data logon request message. | 2021-06-14 16:03:33.384 HD Request # 5 | Requesting Intraday data. Start date-time: 2021-04-19 16:42:10. Record interval: 1. Symbol: ESM22 | 2021-06-14 16:03:33.431 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2021-06-14 16:03:33.465 SC DTC Data with Market Depth | Received security definition for symbol UDVR-NYSE | 2021-06-14 16:03:33.465 HD Request # 5 | Decompressing data. | 2021-06-14 16:03:33.475 HD Request # 5 | Receiving Intraday data for F.US.EPM22 starting at 2021-04-19 16:42:10.679000 | 2021-06-14 16:03:33.475 Socket (8) | CloseSocket call. | 2021-06-14 16:03:33.476 Socket (8) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:33.476 Historical data download thread signaled to stop. | 2021-06-14 16:03:33.476 HD Request # 5 | Timestamp of first Intraday data file record written: 2021-04-19 16:42:10.679000 | 2021-06-14 16:03:33.476 HD Request # 5 | Received 1 record from 2021-04-19 16:42:10.679000 to 2021-04-19 16:42:10.679000 (0.0 seconds) and wrote 1 record for F.US.EPM22 | 2021-06-14 16:03:33.476 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2021-04-19 16:42:10.679000 | 2021-06-14 16:03:33.477 HD Request # 5 | Completion time: 0s | 2021-06-14 16:03:33.477 HD Request # 5 | Intraday data download complete for F.US.EPM22. Unique request ID: 4 | 2021-06-14 16:03:33.477 Removing historical data download ID 4. | 2021-06-14 16:03:33.477 Real-time Intraday chart data file updates started for F.US.EPM22 | 2021-06-14 16:03:33.477 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPM22.scid. Thread ID: 3636 | 2021-06-14 16:03:33.477 Intraday chart data file opened for F.US.EPM22 | 2021-06-14 16:03:33.477 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:03:33.477 Triggering next historical data download in queue. | 2021-06-14 16:03:33.478 Delaying start of download for UVOL-NYSE | 2021-06-14 16:03:33.478 F.US.EPM22 [C] #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-06-14 16:03:33.484 F.US.EPM22 [C] #15 | Reloading chart. | 2021-06-14 16:03:33.485 SC Data - All Services | Received logon response. | 2021-06-14 16:03:33.488 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:03:33.488 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:03:33.488 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:03:33.488 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:03:33.488 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:03:33.488 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:03:33.488 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:03:33.488 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:33.488 F.US.EPM22 [C] #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-06-14 16:03:33.490 F.US.EPM22 [C] #1 | Reloading chart. | 2021-06-14 16:03:33.515 Socket (8) | Socket gracefully closed by remote side. | 2021-06-14 16:03:33.517 Socket (8) | Closed. | 2021-06-14 16:03:33.517 F.US.EPM22 [C] #15 | Reloading chart. | 2021-06-14 16:03:33.524 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:03:33.536 DTC Client socket (5) | Closed. | 2021-06-14 16:03:33.536 F.US.EPM22 [C] #1 | Reloading chart. | 2021-06-14 16:03:33.558 SC Data - All Services | Starting real-time market data updates for: F.US.EPM22 (ESM22). ID: 20 Service code: cme | 2021-06-14 16:03:33.560 CQG WebAPI | Sending symbol resolution request for F.US.EPM22. ID: 486675 | 2021-06-14 16:03:33.560 SC Data - All Services | Requesting security definition data for: F.US.EPM22 (ESM22). ID: 20 | 2021-06-14 16:03:33.560 CQG WebAPI | Received symbol resolution report for symbol F.US.EPM22. Search Symbol: F.US.EPM22. Request ID: 486675. Contract ID: 14. | 2021-06-14 16:03:33.602 F.US.EPM22 [C] #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-06-14 16:03:33.656 F.US.EPM22 [C] #2 | Reloading chart. | 2021-06-14 16:03:33.657 F.US.EPM22 [C] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-06-14 16:03:33.734 F.US.EPM22 [C] #3 | Reloading chart. | 2021-06-14 16:03:33.735 F.US.EPM22 [C] #13 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-06-14 16:03:33.781 F.US.EPM22 [C] #13 | Reloading chart. | 2021-06-14 16:03:33.782 SC Data - All Services | Received logon response. | 2021-06-14 16:03:33.891 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:03:33.891 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:03:33.891 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:03:33.891 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:03:33.891 DTC Client socket (7) | CloseSocket call. | 2021-06-14 16:03:33.892 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:33.892 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:03:33.892 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:03:33.892 HD Request # 4 | Requesting historical Daily data for ESM21 starting at 2021-06-09. SC External HD service. | 2021-06-14 16:03:33.929 DTC Client socket (7) | Socket gracefully closed by remote side. | 2021-06-14 16:03:33.930 DTC Client socket (7) | Closed. | 2021-06-14 16:03:33.930 AAPL [C-D][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-14 16:03:33.940 F.US.EPM22 [C] #2 | Reloading chart. | 2021-06-14 16:03:34.263 F.US.EPM22 [C] #3 | Reloading chart. | 2021-06-14 16:03:34.269 F.US.EPM22 [C] #13 | Reloading chart. | 2021-06-14 16:03:34.324 HD Request # 4 | Receiving historical Daily data for F.US.EPM21 starting at 2021-06-10 | 2021-06-14 16:03:34.389 HD Request # 4 | Writing historical Daily data to the file F.US.EPM21.dly | 2021-06-14 16:03:34.390 HD Request # 4 | Bytes received: 236 | 2021-06-14 16:03:34.395 HD Request # 4 | Received 4 records from 2021-06-10 00:00:00 to 2021-06-14 00:00:00 (5.0 days) and wrote 3 records for F.US.EPM21 | 2021-06-14 16:03:34.395 HD Request # 4 | Completion time: 1s | 2021-06-14 16:03:34.395 HD Request # 4 | Daily data download complete for F.US.EPM21. Unique request ID: 16 | 2021-06-14 16:03:34.395 Removing historical data download ID 16. | 2021-06-14 16:03:34.395 Triggering next historical data download in queue. | 2021-06-14 16:03:34.396 No download requests in the queue to start downloads for. | 2021-06-14 16:03:34.396 F.US.EPM21 [C][M] Daily #9 | Reloading chart. | 2021-06-14 16:03:34.845 HD Request # 6 | Downloading Intraday chart data for UVOL-NYSE to the file UVOL-NYSE.scid. Service: statscalc | 2021-06-14 16:03:37.093 HD Request # 6 | Download start date-time: 2021-06-14 16:00:49.000000. File last date-time: 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:37.095 HD Request # 6 | Using server: ds12.sierracharts.com port 10150 | 2021-06-14 16:03:37.095 Socket (2) | Creating socket. | 2021-06-14 16:03:37.095 Socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:03:37.095 Socket (2) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:03:37.095 HD Request # 6 | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:37.223 HD Request # 6 | Sending historical data logon request message. | 2021-06-14 16:03:37.223 HD Request # 6 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:49. Record interval: 1. Symbol: UVOL-NYSE | 2021-06-14 16:03:37.812 HD Request # 6 | Decompressing data. | 2021-06-14 16:03:37.874 HD Request # 6 | Receiving Intraday data for UVOL-NYSE starting at 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:37.875 Socket (2) | CloseSocket call. | 2021-06-14 16:03:37.877 Historical data download thread signaled to stop. | 2021-06-14 16:03:37.877 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:37.877 HD Request # 6 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:37.878 HD Request # 6 | Received 168 records from 2021-06-14 16:00:49.000000 to 2021-06-14 16:03:36.000000 (2.8 minutes) and wrote 168 records for UVOL-NYSE | 2021-06-14 16:03:37.878 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:03:36.000000 | 2021-06-14 16:03:37.890 Added 1 Time and Sales records to Intraday data file for UVOL-NYSE after download. | 2021-06-14 16:03:37.890 HD Request # 6 | Completion time: 0s | 2021-06-14 16:03:37.891 HD Request # 6 | Intraday data download complete for UVOL-NYSE. Unique request ID: 5 | 2021-06-14 16:03:37.891 Removing historical data download ID 5. | 2021-06-14 16:03:37.891 Real-time Intraday chart data file updates started for UVOL-NYSE | 2021-06-14 16:03:37.891 Opened cached Intraday file: C:\SierraChart\Data\UVOL-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:03:37.897 Intraday chart data file opened for UVOL-NYSE | 2021-06-14 16:03:37.897 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:03:37.897 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol UVOL-NYSE with ID 5 has completed. | 2021-06-14 16:03:37.897 Triggering next historical data download in queue. | 2021-06-14 16:03:37.897 HD Request # 7 | Downloading Intraday chart data for DVOL-NYSE to the file DVOL-NYSE.scid. Service: statscalc | 2021-06-14 16:03:37.897 HD Request # 7 | Download start date-time: 2021-06-14 16:00:49.000000. File last date-time: 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:37.897 HD Request # 7 | Using server: ds4.sierracharts.com port 10149 | 2021-06-14 16:03:37.897 Socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:03:37.946 Socket (2) | Closed. | 2021-06-14 16:03:37.946 Socket (4) | Creating socket. | 2021-06-14 16:03:37.948 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:03:37.948 Socket (4) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:03:37.949 HD Request # 7 | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:38.063 HD Request # 7 | Sending historical data logon request message. | 2021-06-14 16:03:38.063 HD Request # 7 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:49. Record interval: 1. Symbol: DVOL-NYSE | 2021-06-14 16:03:38.661 HD Request # 7 | Decompressing data. | 2021-06-14 16:03:38.710 HD Request # 7 | Receiving Intraday data for DVOL-NYSE starting at 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:38.711 Socket (4) | CloseSocket call. | 2021-06-14 16:03:38.713 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:38.713 Historical data download thread signaled to stop. | 2021-06-14 16:03:38.713 HD Request # 7 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:38.714 HD Request # 7 | Received 169 records from 2021-06-14 16:00:49.000000 to 2021-06-14 16:03:37.000000 (2.8 minutes) and wrote 169 records for DVOL-NYSE | 2021-06-14 16:03:38.714 HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:03:37.000000 | 2021-06-14 16:03:38.726 Added 1 Time and Sales records to Intraday data file for DVOL-NYSE after download. | 2021-06-14 16:03:38.726 HD Request # 7 | Completion time: 1s | 2021-06-14 16:03:38.727 HD Request # 7 | Intraday data download complete for DVOL-NYSE. Unique request ID: 6 | 2021-06-14 16:03:38.727 Removing historical data download ID 6. | 2021-06-14 16:03:38.727 Real-time Intraday chart data file updates started for DVOL-NYSE | 2021-06-14 16:03:38.727 Opened cached Intraday file: C:\SierraChart\Data\DVOL-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:03:38.734 Intraday chart data file opened for DVOL-NYSE | 2021-06-14 16:03:38.735 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:03:38.735 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol DVOL-NYSE with ID 6 has completed. | 2021-06-14 16:03:38.735 Triggering next historical data download in queue. | 2021-06-14 16:03:38.735 HD Request # 8 | Downloading Intraday chart data for DVOL-NASDAQ to the file DVOL-NASDAQ.scid. Service: statscalc | 2021-06-14 16:03:38.735 HD Request # 8 | Download start date-time: 2021-06-14 16:00:49.000000. File last date-time: 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:38.735 HD Request # 8 | Using server: ds12.sierracharts.com port 10150 | 2021-06-14 16:03:38.735 Socket (2) | Creating socket. | 2021-06-14 16:03:38.735 Socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:03:38.736 Socket (2) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:03:38.736 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:03:38.764 Socket (4) | Closed. | 2021-06-14 16:03:38.764 HD Request # 8 | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:38.852 HD Request # 8 | Sending historical data logon request message. | 2021-06-14 16:03:38.852 HD Request # 8 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:49. Record interval: 1. Symbol: DVOL-NASDAQ | 2021-06-14 16:03:38.901 HD Request # 8 | Decompressing data. | 2021-06-14 16:03:38.951 HD Request # 8 | Receiving Intraday data for DVOL-NASDAQ starting at 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:38.954 Socket (2) | CloseSocket call. | 2021-06-14 16:03:38.954 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:38.954 Historical data download thread signaled to stop. | 2021-06-14 16:03:38.956 HD Request # 8 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:38.956 HD Request # 8 | Received 170 records from 2021-06-14 16:00:49.000000 to 2021-06-14 16:03:38.000000 (2.8 minutes) and wrote 170 records for DVOL-NASDAQ | 2021-06-14 16:03:38.956 HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:03:38.000000 | 2021-06-14 16:03:38.960 HD Request # 8 | Completion time: 0s | 2021-06-14 16:03:38.960 HD Request # 8 | Intraday data download complete for DVOL-NASDAQ. Unique request ID: 7 | 2021-06-14 16:03:38.960 Removing historical data download ID 7. | 2021-06-14 16:03:38.960 Real-time Intraday chart data file updates started for DVOL-NASDAQ | 2021-06-14 16:03:38.960 Opened cached Intraday file: C:\SierraChart\Data\DVOL-NASDAQ.scid. Thread ID: 3636 | 2021-06-14 16:03:38.960 Intraday chart data file opened for DVOL-NASDAQ | 2021-06-14 16:03:38.960 HD Request # 8 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:03:38.960 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol DVOL-NASDAQ with ID 7 has completed. | 2021-06-14 16:03:38.960 Triggering next historical data download in queue. | 2021-06-14 16:03:38.960 HD Request # 9 | Downloading Intraday chart data for UVOL-NASDAQ to the file UVOL-NASDAQ.scid. Service: statscalc | 2021-06-14 16:03:38.960 HD Request # 9 | Download start date-time: 2021-06-14 16:00:49.000000. File last date-time: 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:38.960 HD Request # 9 | Using server: ds4.sierracharts.com port 10149 | 2021-06-14 16:03:38.960 Socket (4) | Creating socket. | 2021-06-14 16:03:38.960 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:03:38.960 Socket (4) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:03:38.960 Socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:03:39.008 Socket (2) | Closed. | 2021-06-14 16:03:39.008 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:03:39.015 DTC Client socket (2) | Creating socket. | 2021-06-14 16:03:39.056 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:03:39.056 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:03:39.056 HD Request # 9 | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:39.078 HD Request # 9 | Sending historical data logon request message. | 2021-06-14 16:03:39.078 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:03:39.104 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:03:39.104 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:03:39.104 HD Request # 9 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:49. Record interval: 1. Symbol: UVOL-NASDAQ | 2021-06-14 16:03:39.133 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:39.174 SC Data - All Services | Sending logon request message. | 2021-06-14 16:03:39.174 HD Request # 9 | Decompressing data. | 2021-06-14 16:03:39.189 HD Request # 9 | Receiving Intraday data for UVOL-NASDAQ starting at 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:39.190 Socket (4) | CloseSocket call. | 2021-06-14 16:03:39.191 Historical data download thread signaled to stop. | 2021-06-14 16:03:39.192 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:39.192 HD Request # 9 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:49.000000 | 2021-06-14 16:03:39.192 HD Request # 9 | Received 169 records from 2021-06-14 16:00:49.000000 to 2021-06-14 16:03:37.000000 (2.8 minutes) and wrote 169 records for UVOL-NASDAQ | 2021-06-14 16:03:39.192 HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:03:37.000000 | 2021-06-14 16:03:39.200 Added 1 Time and Sales records to Intraday data file for UVOL-NASDAQ after download. | 2021-06-14 16:03:39.200 HD Request # 9 | Completion time: 1s | 2021-06-14 16:03:39.200 HD Request # 9 | Intraday data download complete for UVOL-NASDAQ. Unique request ID: 8 | 2021-06-14 16:03:39.200 Removing historical data download ID 8. | 2021-06-14 16:03:39.200 Real-time Intraday chart data file updates started for UVOL-NASDAQ | 2021-06-14 16:03:39.200 Opened cached Intraday file: C:\SierraChart\Data\UVOL-NASDAQ.scid. Thread ID: 3636 | 2021-06-14 16:03:39.203 Intraday chart data file opened for UVOL-NASDAQ | 2021-06-14 16:03:39.203 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:03:39.203 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol UVOL-NASDAQ with ID 8 has completed. | 2021-06-14 16:03:39.203 Triggering next historical data download in queue. | 2021-06-14 16:03:39.203 Delaying start of download for F.US.ENQM21 | 2021-06-14 16:03:39.203 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:03:39.242 Socket (4) | Closed. | 2021-06-14 16:03:39.242 SC Data - All Services | Received logon response. | 2021-06-14 16:03:39.805 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:03:39.805 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:03:39.805 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:03:39.805 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:03:39.805 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:03:39.806 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:03:39.806 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:03:39.806 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:39.806 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:03:39.844 DTC Client socket (2) | Closed. | 2021-06-14 16:03:39.844 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:03:44.795 DTC Client socket (2) | Creating socket. | 2021-06-14 16:03:44.795 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:03:44.795 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:03:44.795 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:03:44.839 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:03:44.839 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:03:44.839 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:44.892 SC Data - All Services | Sending logon request message. | 2021-06-14 16:03:44.892 SC Data - All Services | Received logon response. | 2021-06-14 16:03:45.036 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:03:45.036 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:03:45.036 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:03:45.036 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:03:45.036 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:03:45.037 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:03:45.037 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:03:45.037 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:45.037 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:03:45.077 DTC Client socket (2) | Closed. | 2021-06-14 16:03:45.077 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:03:50.027 DTC Client socket (2) | Creating socket. | 2021-06-14 16:03:50.029 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:03:50.029 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:03:50.029 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:03:50.078 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:03:50.078 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:03:50.079 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:50.152 SC Data - All Services | Sending logon request message. | 2021-06-14 16:03:50.152 SC Data - All Services | Received logon response. | 2021-06-14 16:03:50.309 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:03:50.309 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:03:50.310 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:03:50.310 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:03:50.310 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:03:50.311 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:03:50.311 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:03:50.311 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:50.311 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:03:50.346 DTC Client socket (2) | Closed. | 2021-06-14 16:03:50.346 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:03:55.307 DTC Client socket (2) | Creating socket. | 2021-06-14 16:03:55.309 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:03:55.309 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:03:55.309 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:03:55.353 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:03:55.353 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:03:55.353 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:03:55.424 SC Data - All Services | Sending logon request message. | 2021-06-14 16:03:55.424 SC Data - All Services | Received logon response. | 2021-06-14 16:03:55.542 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:03:55.542 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:03:55.542 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:03:55.542 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:03:55.542 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:03:55.542 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:03:55.542 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:03:55.542 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:03:55.542 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:03:55.581 DTC Client socket (2) | Closed. | 2021-06-14 16:03:55.581 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:04:00.541 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:00.542 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:00.542 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:04:00.542 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:00.587 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:00.587 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:00.587 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:00.642 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:00.642 SC Data - All Services | Received logon response. | 2021-06-14 16:04:00.769 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:00.769 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:00.769 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:00.769 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:00.769 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:00.769 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:00.770 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:00.770 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:00.770 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:00.810 DTC Client socket (2) | Closed. | 2021-06-14 16:04:00.810 HD Request # 10 | Downloading Intraday chart data for F.US.ENQM21 to the file F.US.ENQM21.scid. Service: cme | 2021-06-14 16:04:03.087 HD Request # 10 | Download start date-time: 2021-06-14 16:00:11.000000. File last date-time: 2021-06-14 16:00:11.417000 | 2021-06-14 16:04:03.088 HD Request # 10 | Using server: ds23.sierracharts.com port 10150 | 2021-06-14 16:04:03.088 Socket (2) | Creating socket. | 2021-06-14 16:04:03.089 Socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:03.089 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:04:03.089 HD Request # 10 | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:03.185 HD Request # 10 | Sending historical data logon request message. | 2021-06-14 16:04:03.185 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-06-14 16:04:03.478 DTC Client socket (4) | Creating socket. | 2021-06-14 16:04:03.522 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:04:03.522 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:04:03.522 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:03.587 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:03.587 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:03.587 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:03.667 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:03.667 HD Request # 10 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:11. Record interval: 1. Symbol: NQM21 | 2021-06-14 16:04:03.682 HD Request # 10 | Decompressing data. | 2021-06-14 16:04:03.732 HD Request # 10 | Receiving Intraday data for F.US.ENQM21 starting at 2021-06-14 16:00:11.417000 | 2021-06-14 16:04:03.733 Socket (2) | CloseSocket call. | 2021-06-14 16:04:03.734 Historical data download thread signaled to stop. | 2021-06-14 16:04:03.735 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:03.735 HD Request # 10 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:11.417000 | 2021-06-14 16:04:03.735 HD Request # 10 | Received 145 records from 2021-06-14 16:00:11.417000 to 2021-06-14 16:04:00.061000 (3.8 minutes) and wrote 145 records for F.US.ENQM21 | 2021-06-14 16:04:03.735 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:04:00.061000 | 2021-06-14 16:04:03.743 HD Request # 10 | Completion time: 0s | 2021-06-14 16:04:03.743 HD Request # 10 | Intraday data download complete for F.US.ENQM21. Unique request ID: 9 | 2021-06-14 16:04:03.743 Removing historical data download ID 9. | 2021-06-14 16:04:03.743 Real-time Intraday chart data file updates started for F.US.ENQM21 | 2021-06-14 16:04:03.744 Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQM21.scid. Thread ID: 3636 | 2021-06-14 16:04:03.744 Intraday chart data file opened for F.US.ENQM21 | 2021-06-14 16:04:03.744 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:04:03.744 Triggering next historical data download in queue. | 2021-06-14 16:04:03.744 HD Request # 11 | Downloading Intraday chart data for MSFT to the file MSFT.scid. Service: equities.us | 2021-06-14 16:04:03.744 HD Request # 11 | Download start date-time: 2021-06-14 16:00:11.000000. File last date-time: 2021-06-14 16:00:11.992000 | 2021-06-14 16:04:03.744 HD Request # 11 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2021-06-14 16:04:03.744 Socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:03.776 Socket (2) | Closed. | 2021-06-14 16:04:03.776 Socket (5) | Creating socket. | 2021-06-14 16:04:03.788 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:04:03.788 Socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:04:03.788 HD Request # 11 | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:03.880 HD Request # 11 | Sending historical data logon request message. | 2021-06-14 16:04:03.880 SC Data - All Services | Received logon response. | 2021-06-14 16:04:04.381 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:04.381 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:04.381 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:04.381 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:04.381 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:04:04.381 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:04.381 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:04:04.381 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:04.381 HD Request # 11 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:11. Record interval: 1. Symbol: MSFT | 2021-06-14 16:04:04.389 HD Request # 11 | Decompressing data. | 2021-06-14 16:04:04.431 HD Request # 11 | Receiving Intraday data for MSFT starting at 2021-06-14 16:00:11.992000 | 2021-06-14 16:04:04.431 Socket (5) | CloseSocket call. | 2021-06-14 16:04:04.432 Historical data download thread signaled to stop. | 2021-06-14 16:04:04.432 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:04.432 HD Request # 11 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:11.992000 | 2021-06-14 16:04:04.432 HD Request # 11 | Received 92 records from 2021-06-14 16:00:11.992000 to 2021-06-14 16:03:59.886000 (3.8 minutes) and wrote 92 records for MSFT | 2021-06-14 16:04:04.432 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:03:59.886000 | 2021-06-14 16:04:04.437 HD Request # 11 | Completion time: 1s | 2021-06-14 16:04:04.437 HD Request # 11 | Intraday data download complete for MSFT. Unique request ID: 10 | 2021-06-14 16:04:04.437 Removing historical data download ID 10. | 2021-06-14 16:04:04.437 Real-time Intraday chart data file updates started for MSFT | 2021-06-14 16:04:04.437 Opened cached Intraday file: C:\SierraChart\Data\MSFT.scid. Thread ID: 3636 | 2021-06-14 16:04:04.437 Intraday chart data file opened for MSFT | 2021-06-14 16:04:04.437 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:04:04.437 Triggering next historical data download in queue. | 2021-06-14 16:04:04.437 HD Request # 12 | Downloading Intraday chart data for F.US.RTYM21 to the file F.US.RTYM21.scid. Service: cme | 2021-06-14 16:04:04.437 HD Request # 12 | Download start date-time: 2021-06-14 16:00:06.000000. File last date-time: 2021-06-14 16:00:06.945000 | 2021-06-14 16:04:04.438 HD Request # 12 | Using server: ds23.sierracharts.com port 10150 | 2021-06-14 16:04:04.438 Socket (2) | Creating socket. | 2021-06-14 16:04:04.438 Socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:04.438 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:04:04.438 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:04:04.439 DTC Client socket (4) | Closed. | 2021-06-14 16:04:04.439 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:04:04.477 Socket (5) | Closed. | 2021-06-14 16:04:04.477 HD Request # 12 | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:04.540 HD Request # 12 | Sending historical data logon request message. | 2021-06-14 16:04:04.540 HD Request # 12 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:06. Record interval: 1. Symbol: RTYM21 | 2021-06-14 16:04:04.582 HD Request # 12 | Decompressing data. | 2021-06-14 16:04:04.627 HD Request # 12 | Receiving Intraday data for F.US.RTYM21 starting at 2021-06-14 16:00:06.945000 | 2021-06-14 16:04:04.627 Socket (2) | CloseSocket call. | 2021-06-14 16:04:04.629 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:04.629 Historical data download thread signaled to stop. | 2021-06-14 16:04:04.629 HD Request # 12 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:06.945000 | 2021-06-14 16:04:04.629 HD Request # 12 | Received 36 records from 2021-06-14 16:00:06.945000 to 2021-06-14 16:03:42.967000 (3.6 minutes) and wrote 36 records for F.US.RTYM21 | 2021-06-14 16:04:04.630 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:03:42.967000 | 2021-06-14 16:04:04.641 HD Request # 12 | Completion time: 0s | 2021-06-14 16:04:04.641 HD Request # 12 | Intraday data download complete for F.US.RTYM21. Unique request ID: 11 | 2021-06-14 16:04:04.641 Removing historical data download ID 11. | 2021-06-14 16:04:04.641 Real-time Intraday chart data file updates started for F.US.RTYM21 | 2021-06-14 16:04:04.641 Opened cached Intraday file: C:\SierraChart\Data\F.US.RTYM21.scid. Thread ID: 3636 | 2021-06-14 16:04:04.642 Intraday chart data file opened for F.US.RTYM21 | 2021-06-14 16:04:04.642 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:04:04.643 Triggering next historical data download in queue. | 2021-06-14 16:04:04.643 HD Request # 13 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2021-06-14 16:04:04.643 HD Request # 13 | Download start date-time: 2021-06-14 16:00:17.000000. File last date-time: 2021-06-14 16:00:17.147000 | 2021-06-14 16:04:04.643 HD Request # 13 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2021-06-14 16:04:04.644 Socket (4) | Creating socket. | 2021-06-14 16:04:04.644 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:04:04.644 Socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:04:04.644 Socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:04.673 Socket (2) | Closed. | 2021-06-14 16:04:04.673 HD Request # 13 | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:04.733 HD Request # 13 | Sending historical data logon request message. | 2021-06-14 16:04:04.733 HD Request # 13 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:17. Record interval: 1. Symbol: TSLA | 2021-06-14 16:04:04.773 HD Request # 13 | Decompressing data. | 2021-06-14 16:04:04.819 HD Request # 13 | Receiving Intraday data for TSLA starting at 2021-06-14 16:00:17.147000 | 2021-06-14 16:04:04.819 Socket (4) | CloseSocket call. | 2021-06-14 16:04:04.819 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:04.819 Historical data download thread signaled to stop. | 2021-06-14 16:04:04.820 HD Request # 13 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:17.147000 | 2021-06-14 16:04:04.820 HD Request # 13 | Received 102 records from 2021-06-14 16:00:17.147000 to 2021-06-14 16:04:00.592000 (3.7 minutes) and wrote 102 records for TSLA | 2021-06-14 16:04:04.820 HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:04:00.592000 | 2021-06-14 16:04:04.823 HD Request # 13 | Completion time: 0s | 2021-06-14 16:04:04.823 HD Request # 13 | Intraday data download complete for TSLA. Unique request ID: 12 | 2021-06-14 16:04:04.823 Removing historical data download ID 12. | 2021-06-14 16:04:04.823 Real-time Intraday chart data file updates started for TSLA | 2021-06-14 16:04:04.823 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 3636 | 2021-06-14 16:04:04.824 Intraday chart data file opened for TSLA | 2021-06-14 16:04:04.824 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:04:04.824 Triggering next historical data download in queue. | 2021-06-14 16:04:04.824 HD Request # 14 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2021-06-14 16:04:04.824 HD Request # 14 | Download start date-time: 2021-06-14 16:00:16.000000. File last date-time: 2021-06-14 16:00:16.096000 | 2021-06-14 16:04:04.824 HD Request # 14 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2021-06-14 16:04:04.824 Socket (2) | Creating socket. | 2021-06-14 16:04:04.862 Socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:04.862 Socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:04:04.862 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:04:04.863 Socket (4) | Closed. | 2021-06-14 16:04:04.863 HD Request # 14 | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:04.960 HD Request # 14 | Sending historical data logon request message. | 2021-06-14 16:04:04.960 HD Request # 14 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:16. Record interval: 1. Symbol: AAPL | 2021-06-14 16:04:05.477 HD Request # 14 | Decompressing data. | 2021-06-14 16:04:05.515 HD Request # 14 | Receiving Intraday data for AAPL starting at 2021-06-14 16:00:16.096000 | 2021-06-14 16:04:05.523 Socket (2) | CloseSocket call. | 2021-06-14 16:04:05.524 Historical data download thread signaled to stop. | 2021-06-14 16:04:05.524 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:05.524 HD Request # 14 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:16.096000 | 2021-06-14 16:04:05.524 HD Request # 14 | Received 201 records from 2021-06-14 16:00:16.096000 to 2021-06-14 16:04:03.101000 (3.8 minutes) and wrote 201 records for AAPL | 2021-06-14 16:04:05.524 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:04:03.101000 | 2021-06-14 16:04:05.528 HD Request # 14 | Completion time: 1s | 2021-06-14 16:04:05.528 HD Request # 14 | Intraday data download complete for AAPL. Unique request ID: 13 | 2021-06-14 16:04:05.528 Removing historical data download ID 13. | 2021-06-14 16:04:05.528 Real-time Intraday chart data file updates started for AAPL | 2021-06-14 16:04:05.528 Opened cached Intraday file: C:\SierraChart\Data\AAPL.scid. Thread ID: 3636 | 2021-06-14 16:04:05.528 Intraday chart data file opened for AAPL | 2021-06-14 16:04:05.528 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:04:05.528 Triggering next historical data download in queue. | 2021-06-14 16:04:05.528 HD Request # 15 | Downloading Intraday chart data for F.US.CLEN21 to the file F.US.CLEN21.scid. Service: nymex | 2021-06-14 16:04:05.528 HD Request # 15 | Download start date-time: 2021-06-14 16:00:14.000000. File last date-time: 2021-06-14 16:00:14.144000 | 2021-06-14 16:04:05.528 HD Request # 15 | Using server: ds21.sierracharts.com port 10149 | 2021-06-14 16:04:05.528 Socket (4) | Creating socket. | 2021-06-14 16:04:05.528 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:04:05.528 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:04:05.529 Socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:05.565 Socket (2) | Closed. | 2021-06-14 16:04:05.566 HD Request # 15 | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:05.624 HD Request # 15 | Sending historical data logon request message. | 2021-06-14 16:04:05.624 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:04:05.779 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:05.780 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:05.780 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:04:05.780 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:05.825 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:05.825 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:05.825 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:05.894 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:05.894 HD Request # 15 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:14. Record interval: 1. Symbol: CLN21 | 2021-06-14 16:04:06.124 HD Request # 15 | Decompressing data. | 2021-06-14 16:04:06.173 HD Request # 15 | Receiving Intraday data for F.US.CLEN21 starting at 2021-06-14 16:00:14.144000 | 2021-06-14 16:04:06.174 Socket (4) | CloseSocket call. | 2021-06-14 16:04:06.176 Historical data download thread signaled to stop. | 2021-06-14 16:04:06.176 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:06.176 HD Request # 15 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:14.144000 | 2021-06-14 16:04:06.177 HD Request # 15 | Received 80 records from 2021-06-14 16:00:14.144000 to 2021-06-14 16:04:02.288000 (3.8 minutes) and wrote 80 records for F.US.CLEN21 | 2021-06-14 16:04:06.177 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:04:02.288000 | 2021-06-14 16:04:06.184 HD Request # 15 | Completion time: 1s | 2021-06-14 16:04:06.184 HD Request # 15 | Intraday data download complete for F.US.CLEN21. Unique request ID: 14 | 2021-06-14 16:04:06.184 Removing historical data download ID 14. | 2021-06-14 16:04:06.184 Real-time Intraday chart data file updates started for F.US.CLEN21 | 2021-06-14 16:04:06.184 Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEN21.scid. Thread ID: 3636 | 2021-06-14 16:04:06.184 Intraday chart data file opened for F.US.CLEN21 | 2021-06-14 16:04:06.185 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:04:06.185 Triggering next historical data download in queue. | 2021-06-14 16:04:06.185 HD Request # 16 | Downloading Intraday chart data for F.US.MESM21 to the file F.US.MESM21.scid. Service: cme | 2021-06-14 16:04:06.185 HD Request # 16 | Download start date-time: 2021-06-14 16:00:13.000000. File last date-time: 2021-06-14 16:00:13.349000 | 2021-06-14 16:04:06.185 HD Request # 16 | Using server: ds23.sierracharts.com port 10150 | 2021-06-14 16:04:06.185 Socket (5) | Creating socket. | 2021-06-14 16:04:06.185 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:04:06.185 Socket (5) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:04:06.185 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:04:06.219 Socket (4) | Closed. | 2021-06-14 16:04:06.219 HD Request # 16 | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:06.282 HD Request # 16 | Sending historical data logon request message. | 2021-06-14 16:04:06.282 HD Request # 16 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:13. Record interval: 1. Symbol: MESM21 | 2021-06-14 16:04:06.325 HD Request # 16 | Decompressing data. | 2021-06-14 16:04:06.373 HD Request # 16 | Receiving Intraday data for F.US.MESM21 starting at 2021-06-14 16:00:13.349000 | 2021-06-14 16:04:06.373 Socket (5) | CloseSocket call. | 2021-06-14 16:04:06.373 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:06.374 Historical data download thread signaled to stop. | 2021-06-14 16:04:06.374 HD Request # 16 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:13.349000 | 2021-06-14 16:04:06.374 HD Request # 16 | Received 52 records from 2021-06-14 16:00:13.349000 to 2021-06-14 16:04:04.553000 (3.9 minutes) and wrote 52 records for F.US.MESM21 | 2021-06-14 16:04:06.374 HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:04:04.553000 | 2021-06-14 16:04:06.378 HD Request # 16 | Completion time: 0s | 2021-06-14 16:04:06.378 HD Request # 16 | Intraday data download complete for F.US.MESM21. Unique request ID: 15 | 2021-06-14 16:04:06.378 Removing historical data download ID 15. | 2021-06-14 16:04:06.378 Real-time Intraday chart data file updates started for F.US.MESM21 | 2021-06-14 16:04:06.378 Opened cached Intraday file: C:\SierraChart\Data\F.US.MESM21.scid. Thread ID: 3636 | 2021-06-14 16:04:06.379 Intraday chart data file opened for F.US.MESM21 | 2021-06-14 16:04:06.379 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:04:06.379 Triggering next historical data download in queue. | 2021-06-14 16:04:06.379 HD Request # 17 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2021-06-14 16:04:06.379 HD Request # 17 | Download start date-time: 2021-06-14 16:00:49.000000. File last date-time: 2021-06-14 16:00:49.000000 | 2021-06-14 16:04:06.379 HD Request # 17 | Using server: ds12.sierracharts.com port 10149 | 2021-06-14 16:04:06.379 Socket (4) | Creating socket. | 2021-06-14 16:04:06.379 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:04:06.379 Socket (4) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:04:06.379 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:04:06.421 Socket (5) | Closed. | 2021-06-14 16:04:06.421 SC Data - All Services | Received logon response. | 2021-06-14 16:04:06.504 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:06.505 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:06.505 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:06.505 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:06.505 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:06.505 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:06.505 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:06.505 HD Request # 17 | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:06.506 HD Request # 17 | Sending historical data logon request message. | 2021-06-14 16:04:06.506 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:06.506 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:06.543 DTC Client socket (2) | Closed. | 2021-06-14 16:04:06.543 HD Request # 17 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:49. Record interval: 1. Symbol: TICK-NYSE | 2021-06-14 16:04:07.098 HD Request # 17 | Decompressing data. | 2021-06-14 16:04:07.148 HD Request # 17 | Receiving Intraday data for TICK-NYSE starting at 2021-06-14 16:00:49.000000 | 2021-06-14 16:04:07.153 Socket (4) | CloseSocket call. | 2021-06-14 16:04:07.154 Historical data download thread signaled to stop. | 2021-06-14 16:04:07.154 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:07.154 HD Request # 17 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:49.000000 | 2021-06-14 16:04:07.154 HD Request # 17 | Received 198 records from 2021-06-14 16:00:49.000000 to 2021-06-14 16:04:06.000000 (3.3 minutes) and wrote 198 records for TICK-NYSE | 2021-06-14 16:04:07.154 HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:04:06.000000 | 2021-06-14 16:04:07.158 HD Request # 17 | Completion time: 1s | 2021-06-14 16:04:07.158 HD Request # 17 | Intraday data download complete for TICK-NYSE. Unique request ID: 17 | 2021-06-14 16:04:07.158 Removing historical data download ID 17. | 2021-06-14 16:04:07.158 Real-time Intraday chart data file updates started for TICK-NYSE | 2021-06-14 16:04:07.158 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:04:07.158 Intraday chart data file opened for TICK-NYSE | 2021-06-14 16:04:07.158 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:04:07.158 Triggering next historical data download in queue. | 2021-06-14 16:04:07.158 HD Request # 18 | Downloading Intraday chart data for UDVR-NYSE to the file UDVR-NYSE.scid. Service: statscalc | 2021-06-14 16:04:07.158 HD Request # 18 | Download start date-time: 2021-06-14 16:00:49.000000. File last date-time: 2021-06-14 16:00:49.000000 | 2021-06-14 16:04:07.158 HD Request # 18 | Using server: ds4.sierracharts.com port 10150 | 2021-06-14 16:04:07.158 Socket (2) | Creating socket. | 2021-06-14 16:04:07.158 Socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:07.159 Socket (2) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:04:07.159 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:04:07.217 Socket (4) | Closed. | 2021-06-14 16:04:07.217 HD Request # 18 | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:07.276 HD Request # 18 | Sending historical data logon request message. | 2021-06-14 16:04:07.276 HD Request # 18 | Requesting Intraday data. Start date-time: 2021-06-14 16:00:49. Record interval: 1. Symbol: UDVR-NYSE | 2021-06-14 16:04:07.858 HD Request # 18 | Decompressing data. | 2021-06-14 16:04:07.922 HD Request # 18 | Receiving Intraday data for UDVR-NYSE starting at 2021-06-14 16:00:49.000000 | 2021-06-14 16:04:07.924 Socket (2) | CloseSocket call. | 2021-06-14 16:04:07.926 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:07.926 Historical data download thread signaled to stop. | 2021-06-14 16:04:07.927 HD Request # 18 | Timestamp of first Intraday data file record written: 2021-06-14 16:00:49.000000 | 2021-06-14 16:04:07.927 HD Request # 18 | Received 199 records from 2021-06-14 16:00:49.000000 to 2021-06-14 16:04:07.000000 (3.3 minutes) and wrote 199 records for UDVR-NYSE | 2021-06-14 16:04:07.928 HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:04:07.000000 | 2021-06-14 16:04:07.935 HD Request # 18 | Completion time: 0s | 2021-06-14 16:04:07.935 HD Request # 18 | Intraday data download complete for UDVR-NYSE. Unique request ID: 18 | 2021-06-14 16:04:07.935 Removing historical data download ID 18. | 2021-06-14 16:04:07.935 Real-time Intraday chart data file updates started for UDVR-NYSE | 2021-06-14 16:04:07.935 Opened cached Intraday file: C:\SierraChart\Data\UDVR-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:04:07.936 Intraday chart data file opened for UDVR-NYSE | 2021-06-14 16:04:07.936 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:04:07.936 Triggering next historical data download in queue. | 2021-06-14 16:04:07.936 No download requests in the queue to start downloads for. | 2021-06-14 16:04:07.936 Socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:07.982 Socket (2) | Closed. | 2021-06-14 16:04:07.982 F.US.EPM22 [C][M] #13 | Reloading chart. | 2021-06-14 16:04:08.545 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:04:11.491 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:11.493 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:11.493 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:04:11.493 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:11.540 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:11.540 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:11.541 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:11.609 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:11.609 SC Data - All Services | Received logon response. | 2021-06-14 16:04:12.244 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:12.244 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:12.244 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:12.244 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:12.244 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:12.245 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:12.245 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:12.245 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:12.245 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:12.284 DTC Client socket (2) | Closed. | 2021-06-14 16:04:12.284 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:04:17.240 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:17.241 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:17.241 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:04:17.241 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:17.285 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:17.285 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:17.285 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:17.330 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:17.330 SC Data - All Services | Received logon response. | 2021-06-14 16:04:17.468 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:17.468 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:17.468 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:17.468 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:17.468 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:17.468 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:17.468 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:17.469 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:17.469 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:17.507 DTC Client socket (2) | Closed. | 2021-06-14 16:04:17.507 F.US.EPM22 [C][M] #13 | Reloading chart. | 2021-06-14 16:04:21.237 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:04:22.457 DTC Client socket (4) | Creating socket. | 2021-06-14 16:04:22.459 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:04:22.459 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:04:22.459 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:22.502 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:22.502 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:22.502 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:22.565 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:22.565 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:04:22.803 SC Data - All Services | Received logon response. | 2021-06-14 16:04:22.804 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:22.804 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:22.804 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:22.804 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:22.804 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:04:22.804 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:22.804 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:22.804 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-14 16:04:22.804 DTC Client socket (4) | Closed. | 2021-06-14 16:04:22.804 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:04:27.800 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:27.800 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:27.800 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:04:27.800 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:27.889 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:27.889 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:27.889 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:27.937 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:27.937 SC Data - All Services | Received logon response. | 2021-06-14 16:04:28.078 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:28.078 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:28.078 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:28.078 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:28.078 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:28.079 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:28.079 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:28.079 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:28.079 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:28.117 DTC Client socket (2) | Closed. | 2021-06-14 16:04:28.117 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:04:33.064 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:33.066 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:33.066 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:04:33.066 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:33.126 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:33.126 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:33.126 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:33.199 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:33.199 SC Data - All Services | Received logon response. | 2021-06-14 16:04:33.375 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:33.375 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:33.375 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:33.375 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:33.375 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:33.376 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:33.376 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:33.376 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:33.376 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:33.426 DTC Client socket (2) | Closed. | 2021-06-14 16:04:33.426 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-14 16:04:34.377 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:34.420 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:34.420 DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:04:34.420 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:34.479 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:34.479 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:34.479 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:34.552 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:34.552 SC Data - All Services | Received logon response. | 2021-06-14 16:04:35.331 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:35.331 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:35.331 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:35.331 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:35.331 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:35.332 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:35.332 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:04:35.332 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:35.332 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:35.382 DTC Client socket (2) | Closed. | 2021-06-14 16:04:35.382 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:04:38.360 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:38.361 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:38.361 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:04:38.361 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:38.407 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:38.407 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:38.407 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:38.467 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:38.467 SC Data - All Services | Received logon response. | 2021-06-14 16:04:39.079 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:39.079 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:39.079 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:39.079 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:39.079 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:39.080 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:39.080 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:39.080 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:39.080 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:39.121 DTC Client socket (2) | Closed. | 2021-06-14 16:04:39.121 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:04:44.077 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:44.079 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:44.079 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:04:44.079 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:44.121 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:44.121 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:44.121 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:44.165 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:44.165 SC Data - All Services | Received logon response. | 2021-06-14 16:04:44.761 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:44.761 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:44.761 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:44.761 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:44.761 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:44.762 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:44.762 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:44.762 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:44.762 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:44.805 DTC Client socket (2) | Closed. | 2021-06-14 16:04:44.805 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:04:49.748 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:49.749 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:49.749 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:04:49.749 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:49.798 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:49.798 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:49.798 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:49.876 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:49.876 SC Data - All Services | Received logon response. | 2021-06-14 16:04:50.017 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:50.017 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:50.017 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:50.017 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:50.017 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:50.017 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:50.018 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:50.018 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:50.018 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:50.058 DTC Client socket (2) | Closed. | 2021-06-14 16:04:50.059 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:04:55.012 DTC Client socket (2) | Creating socket. | 2021-06-14 16:04:55.013 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:04:55.013 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:04:55.013 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:04:55.059 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:04:55.059 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:04:55.059 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:04:55.119 SC Data - All Services | Sending logon request message. | 2021-06-14 16:04:55.119 SC Data - All Services | Received logon response. | 2021-06-14 16:04:55.259 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:04:55.259 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:04:55.259 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:04:55.259 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:04:55.259 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:04:55.260 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:04:55.260 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:04:55.260 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:04:55.260 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:04:55.303 DTC Client socket (2) | Closed. | 2021-06-14 16:04:55.304 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:05:00.245 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:00.246 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:00.246 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:05:00.246 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:00.297 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:00.297 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:00.297 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:00.347 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:00.347 SC Data - All Services | Received logon response. | 2021-06-14 16:05:00.505 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:00.505 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:00.505 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:00.505 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:00.505 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:00.505 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:00.505 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:00.505 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:00.505 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:00.546 DTC Client socket (2) | Closed. | 2021-06-14 16:05:00.546 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:05:05.323 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:05.324 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:05.324 DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:05:05.324 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:05.368 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:05.368 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:05.368 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:05.430 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:05.430 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:05:05.494 DTC Client socket (4) | Creating socket. | 2021-06-14 16:05:05.495 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:05:05.496 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:05:05.496 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:05.538 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:05.538 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:05.538 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:05.595 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:05.595 SC Data - All Services | Received logon response. | 2021-06-14 16:05:05.720 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:05.720 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:05.720 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:05.720 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:05.720 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:05:05.721 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:05.721 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:05.721 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:05.721 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:05:05.756 DTC Client socket (4) | Closed. | 2021-06-14 16:05:05.756 SC Data - All Services | Received logon response. | 2021-06-14 16:05:06.145 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:06.145 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:06.145 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:06.145 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:06.145 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:06.146 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:06.146 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:05:06.146 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:06.146 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:06.189 DTC Client socket (2) | Closed. | 2021-06-14 16:05:06.189 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:05:10.712 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:10.713 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:10.713 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:05:10.713 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:10.758 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:10.758 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:10.758 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:10.817 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:10.817 SC Data - All Services | Received logon response. | 2021-06-14 16:05:11.441 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:11.441 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:11.442 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:11.442 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:11.442 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:11.442 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:11.442 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:11.442 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:11.442 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:11.484 DTC Client socket (2) | Closed. | 2021-06-14 16:05:11.484 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:05:16.429 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:16.431 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:16.431 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:05:16.431 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:16.472 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:16.472 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:16.472 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:16.515 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:16.515 SC Data - All Services | Received logon response. | 2021-06-14 16:05:17.129 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:17.129 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:17.129 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:17.129 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:17.129 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:17.130 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:17.130 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:17.130 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:17.130 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:17.170 DTC Client socket (2) | Closed. | 2021-06-14 16:05:17.170 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:05:22.115 DTC Client socket (4) | Creating socket. | 2021-06-14 16:05:22.116 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:05:22.117 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:05:22.117 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:22.161 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:22.161 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:22.161 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:22.219 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:22.219 SC Data - All Services | Received logon response. | 2021-06-14 16:05:22.367 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:22.367 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:22.367 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:22.367 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:22.367 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:05:22.367 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:22.367 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:22.367 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:22.367 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:05:22.384 DTC Client socket (4) | Closed. | 2021-06-14 16:05:22.384 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:05:27.364 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:27.366 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:27.366 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:05:27.366 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:27.414 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:27.414 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:27.414 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:27.480 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:27.480 SC Data - All Services | Received logon response. | 2021-06-14 16:05:27.636 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:27.636 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:27.636 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:27.636 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:27.636 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:27.636 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:27.636 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:27.637 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:27.637 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:27.676 DTC Client socket (2) | Closed. | 2021-06-14 16:05:27.676 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:05:32.644 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:32.645 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:32.645 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:05:32.645 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:32.739 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:32.739 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:32.739 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:32.784 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:32.784 SC Data - All Services | Received logon response. | 2021-06-14 16:05:32.925 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:32.926 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:32.926 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:32.926 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:32.926 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:32.926 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:32.926 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:32.926 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:32.927 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:32.966 DTC Client socket (2) | Closed. | 2021-06-14 16:05:32.966 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-06-14 16:05:36.144 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:36.144 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:36.144 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:05:36.144 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:36.194 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:36.194 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:36.194 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:36.271 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:36.271 SC Data - All Services | Received logon response. | 2021-06-14 16:05:36.994 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:36.994 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:36.994 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:36.994 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:36.994 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:36.994 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:36.994 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:05:36.994 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:36.994 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:37.046 DTC Client socket (2) | Closed. | 2021-06-14 16:05:37.046 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:05:37.924 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:37.925 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:37.925 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:05:37.926 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:37.974 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:37.974 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:37.974 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:38.065 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:38.065 SC Data - All Services | Received logon response. | 2021-06-14 16:05:38.234 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:38.234 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:38.234 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:38.234 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:38.234 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:38.235 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:38.235 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:38.235 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:38.235 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:38.276 DTC Client socket (2) | Closed. | 2021-06-14 16:05:38.276 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:05:43.220 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:43.221 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:43.221 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:05:43.221 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:43.264 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:43.264 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:43.264 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:43.315 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:43.315 SC Data - All Services | Received logon response. | 2021-06-14 16:05:43.925 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:43.925 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:43.925 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:43.925 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:43.925 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:43.925 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:43.925 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:43.925 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:43.926 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:43.968 DTC Client socket (2) | Closed. | 2021-06-14 16:05:43.968 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:05:48.922 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:48.923 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:48.923 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:05:48.923 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:48.967 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:48.967 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:48.968 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:49.033 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:49.033 SC Data - All Services | Received logon response. | 2021-06-14 16:05:49.628 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:49.628 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:49.628 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:49.628 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:49.629 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:49.629 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:49.629 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:49.629 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:49.629 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:49.672 DTC Client socket (2) | Closed. | 2021-06-14 16:05:49.672 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:05:54.623 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:54.624 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:54.624 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:05:54.624 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:54.675 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:54.675 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:54.675 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:54.720 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:54.720 SC Data - All Services | Received logon response. | 2021-06-14 16:05:54.861 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:05:54.861 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:05:54.861 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:05:54.861 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:05:54.861 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:05:54.862 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:05:54.862 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:05:54.862 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:05:54.862 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:05:54.902 DTC Client socket (2) | Closed. | 2021-06-14 16:05:54.903 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:05:59.857 DTC Client socket (2) | Creating socket. | 2021-06-14 16:05:59.858 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:05:59.858 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:05:59.858 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:05:59.909 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:05:59.909 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:05:59.909 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:05:59.978 SC Data - All Services | Sending logon request message. | 2021-06-14 16:05:59.978 SC Data - All Services | Received logon response. | 2021-06-14 16:06:00.139 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:00.139 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:00.139 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:00.139 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:00.139 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:00.140 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:00.140 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:00.140 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:00.140 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:00.182 DTC Client socket (2) | Closed. | 2021-06-14 16:06:00.183 F.US.EPM22 [C][M] #1 | Reloading chart. | 2021-06-14 16:06:04.707 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:06:05.136 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:05.137 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:05.137 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:06:05.137 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:05.181 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:05.181 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:05.181 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:05.254 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:05.254 SC Data - All Services | Received logon response. | 2021-06-14 16:06:05.437 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:05.437 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:05.437 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:05.437 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:05.437 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:05.437 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:05.437 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:05.437 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:05.437 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:05.440 DTC Client socket (2) | Closed. | 2021-06-14 16:06:05.440 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-06-14 16:06:06.980 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:06.981 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:06.981 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:06:06.981 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:07.036 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:07.036 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:07.036 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:07.121 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:07.121 SC Data - All Services | Received logon response. | 2021-06-14 16:06:07.850 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:07.850 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:07.850 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:07.850 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:07.850 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:07.850 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:07.850 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:06:07.850 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:07.851 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:07.909 DTC Client socket (2) | Closed. | 2021-06-14 16:06:07.909 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:06:10.432 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:10.433 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:10.433 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:06:10.433 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:10.478 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:10.478 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:10.478 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:10.521 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:10.521 SC Data - All Services | Received logon response. | 2021-06-14 16:06:10.661 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:10.661 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:10.661 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:10.661 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:10.661 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:10.662 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:10.662 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:10.662 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:10.662 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:10.704 DTC Client socket (2) | Closed. | 2021-06-14 16:06:10.704 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:06:15.650 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:15.651 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:15.651 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:06:15.651 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:15.695 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:15.695 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:15.695 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:15.750 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:15.750 SC Data - All Services | Received logon response. | 2021-06-14 16:06:16.362 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:16.362 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:16.362 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:16.362 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:16.362 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:16.362 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:16.362 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:16.362 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:16.362 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:16.403 DTC Client socket (2) | Closed. | 2021-06-14 16:06:16.403 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:06:21.351 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:21.352 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:21.352 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:06:21.352 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:21.393 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:21.393 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:21.393 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:21.463 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:21.463 SC Data - All Services | Received logon response. | 2021-06-14 16:06:22.071 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:22.071 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:22.071 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:22.071 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:22.071 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:22.072 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:22.072 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:22.072 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:22.072 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:22.111 DTC Client socket (2) | Closed. | 2021-06-14 16:06:22.112 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:06:27.085 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:27.085 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:27.085 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:06:27.085 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:27.133 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:27.133 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:27.133 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:27.214 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:27.214 SC Data - All Services | Received logon response. | 2021-06-14 16:06:27.351 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:27.351 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:27.351 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:27.351 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:27.351 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:27.351 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:27.351 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:27.351 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:27.352 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:27.396 DTC Client socket (2) | Closed. | 2021-06-14 16:06:27.397 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:06:32.352 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:32.353 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:32.353 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:06:32.353 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:32.399 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:32.399 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:32.399 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:32.482 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:32.482 SC Data - All Services | Received logon response. | 2021-06-14 16:06:32.637 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:32.637 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:32.637 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:32.637 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:32.637 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:32.637 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:32.637 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:32.637 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:32.637 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:32.677 DTC Client socket (2) | Closed. | 2021-06-14 16:06:32.677 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:06:37.621 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:37.621 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:37.622 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:06:37.622 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:37.661 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:37.661 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:37.662 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:37.720 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:37.720 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-14 16:06:37.843 DTC Client socket (4) | Creating socket. | 2021-06-14 16:06:37.845 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:06:37.845 DTC Client socket (4) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:06:37.845 SC Data - All Services | Received logon response. | 2021-06-14 16:06:37.873 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:37.873 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:37.873 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:37.873 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:37.873 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:37.874 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:37.874 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:37.874 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:37.874 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:37.895 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:37.895 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:37.895 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:37.910 DTC Client socket (2) | Closed. | 2021-06-14 16:06:37.910 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:37.975 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:37.975 SC Data - All Services | Received logon response. | 2021-06-14 16:06:38.035 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:38.035 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:38.035 SC Data - All Services | Logon error received from server: Maximum connections reached. | 2021-06-14 16:06:38.035 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:38.035 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:06:38.035 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:38.035 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-14 16:06:38.035 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:38.035 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:06:38.087 DTC Client socket (4) | Closed. | 2021-06-14 16:06:38.087 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:06:40.020 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:40.020 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:40.020 DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:06:40.020 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:40.068 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:40.068 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:40.068 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:40.132 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:40.132 SC Data - All Services | Received logon response. | 2021-06-14 16:06:40.848 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:40.848 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:40.848 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:40.848 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:40.848 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:40.848 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:40.848 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:06:40.848 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:40.848 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:40.890 DTC Client socket (2) | Closed. | 2021-06-14 16:06:40.891 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:06:42.879 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:42.879 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:42.879 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:06:42.879 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:42.921 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:42.921 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:42.921 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:42.969 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:42.969 SC Data - All Services | Received logon response. | 2021-06-14 16:06:43.107 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:43.107 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:43.107 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:43.107 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:43.107 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:43.108 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:43.108 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:43.108 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:43.108 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:43.164 DTC Client socket (2) | Closed. | 2021-06-14 16:06:43.164 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:06:48.097 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:48.097 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:48.097 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:06:48.097 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:48.138 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:48.138 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:48.138 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:48.186 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:48.186 SC Data - All Services | Received logon response. | 2021-06-14 16:06:48.797 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:48.797 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:48.797 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:48.797 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:48.797 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:48.797 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:48.797 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:48.797 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:48.797 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:48.837 DTC Client socket (2) | Closed. | 2021-06-14 16:06:48.837 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:06:53.779 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:53.781 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:53.781 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:06:53.781 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:53.832 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:53.832 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:53.832 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:53.878 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:53.878 SC Data - All Services | Received logon response. | 2021-06-14 16:06:54.477 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:54.477 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:54.477 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:54.477 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:54.477 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:54.478 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:54.478 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:54.478 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:54.478 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:54.518 DTC Client socket (2) | Closed. | 2021-06-14 16:06:54.519 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:06:59.464 DTC Client socket (2) | Creating socket. | 2021-06-14 16:06:59.465 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:06:59.465 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:06:59.465 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:06:59.507 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:06:59.507 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:06:59.507 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:06:59.564 SC Data - All Services | Sending logon request message. | 2021-06-14 16:06:59.564 SC Data - All Services | Received logon response. | 2021-06-14 16:06:59.740 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:06:59.740 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:06:59.740 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:06:59.740 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:06:59.740 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:06:59.741 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:06:59.741 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:06:59.741 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:06:59.741 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:06:59.777 DTC Client socket (2) | Closed. | 2021-06-14 16:06:59.777 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:07:04.728 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:04.729 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:04.729 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:07:04.729 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:04.773 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:04.773 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:04.773 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:04.820 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:04.820 SC Data - All Services | Received logon response. | 2021-06-14 16:07:04.976 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:04.976 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:04.976 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:04.976 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:04.976 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:04.976 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:04.976 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:04.976 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:04.977 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:05.014 DTC Client socket (2) | Closed. | 2021-06-14 16:07:05.014 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:07:09.961 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:09.962 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:09.962 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:07:09.962 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:10.009 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:10.009 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:10.009 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:10.062 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:10.062 SC Data - All Services | Received logon response. | 2021-06-14 16:07:10.223 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:10.223 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:10.223 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:10.223 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:10.223 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:10.224 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:10.224 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:10.224 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:10.224 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:10.265 DTC Client socket (2) | Closed. | 2021-06-14 16:07:10.265 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:07:10.835 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:10.836 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:10.836 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:07:10.836 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:10.887 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:10.887 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:10.887 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:10.939 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:10.939 SC Data - All Services | Received logon response. | 2021-06-14 16:07:11.626 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:11.626 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:11.626 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:11.626 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:11.626 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:11.626 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:11.626 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:07:11.626 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:11.626 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:11.672 DTC Client socket (2) | Closed. | 2021-06-14 16:07:11.672 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:07:15.210 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:15.211 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:15.211 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:07:15.211 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:15.291 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:15.291 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:15.291 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:15.362 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:15.362 SC Data - All Services | Received logon response. | 2021-06-14 16:07:15.505 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:15.505 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:15.505 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:15.505 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:15.505 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:15.505 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:15.505 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:15.505 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:15.505 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:15.545 DTC Client socket (2) | Closed. | 2021-06-14 16:07:15.545 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:07:20.493 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:20.494 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:20.495 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:07:20.495 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:20.542 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:20.542 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:20.542 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:20.596 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:20.596 SC Data - All Services | Received logon response. | 2021-06-14 16:07:21.189 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:21.189 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:21.189 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:21.189 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:21.189 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:21.189 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:21.189 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:21.189 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:21.189 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:21.230 DTC Client socket (2) | Closed. | 2021-06-14 16:07:21.230 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:07:26.179 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:26.180 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:26.181 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:07:26.181 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:26.225 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:26.225 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:26.226 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:26.287 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:26.287 SC Data - All Services | Received logon response. | 2021-06-14 16:07:26.883 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:26.883 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:26.883 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:26.883 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:26.883 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:26.884 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:26.884 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:26.884 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:26.884 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:26.926 DTC Client socket (2) | Closed. | 2021-06-14 16:07:26.926 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:07:31.891 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:31.893 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:31.893 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:07:31.893 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:31.936 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:31.936 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:31.936 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:32.000 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:32.000 SC Data - All Services | Received logon response. | 2021-06-14 16:07:32.144 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:32.144 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:32.144 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:32.144 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:32.144 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:32.144 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:32.144 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:32.144 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:32.145 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:32.186 DTC Client socket (2) | Closed. | 2021-06-14 16:07:32.186 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:07:37.141 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:37.142 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:37.142 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:07:37.142 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:37.186 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:37.186 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:37.186 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:37.233 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:37.233 SC Data - All Services | Received logon response. | 2021-06-14 16:07:37.392 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:37.392 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:37.392 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:37.392 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:37.392 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:37.392 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:37.392 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:37.392 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:37.393 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:37.429 DTC Client socket (2) | Closed. | 2021-06-14 16:07:37.429 F.US.EPU21 [C][M] #1 | Reloading chart. | 2021-06-14 16:07:41.459 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:07:42.066 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:42.067 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:42.067 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:07:42.067 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:42.127 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:42.127 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:42.127 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:42.196 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:42.196 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:07:42.392 DTC Client socket (4) | Creating socket. | 2021-06-14 16:07:42.394 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:07:42.394 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:07:42.394 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:42.437 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:42.437 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:42.437 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:42.500 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:42.500 SC Data - All Services | Received logon response. | 2021-06-14 16:07:42.642 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:42.642 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:42.642 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:42.642 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:42.642 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:07:42.642 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:42.642 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:42.642 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:42.643 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:07:42.680 DTC Client socket (4) | Closed. | 2021-06-14 16:07:42.680 SC Data - All Services | Received logon response. | 2021-06-14 16:07:42.918 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:42.918 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:42.918 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:42.918 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:42.918 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:42.918 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:42.918 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:07:42.918 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:42.918 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:42.973 DTC Client socket (2) | Closed. | 2021-06-14 16:07:42.973 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:07:47.637 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:47.638 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:47.638 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:07:47.638 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:47.682 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:47.682 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:47.682 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:47.746 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:47.746 SC Data - All Services | Received logon response. | 2021-06-14 16:07:47.878 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:47.879 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:47.879 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:47.879 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:47.879 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:47.879 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:47.879 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:47.879 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:47.880 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:47.920 DTC Client socket (2) | Closed. | 2021-06-14 16:07:47.920 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:07:52.870 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:52.871 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:52.872 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:07:52.872 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:52.914 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:52.914 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:52.914 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:52.970 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:52.970 SC Data - All Services | Received logon response. | 2021-06-14 16:07:53.580 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:53.580 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:53.580 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:53.580 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:53.580 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:53.581 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:53.581 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:53.581 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:53.581 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:53.621 DTC Client socket (2) | Closed. | 2021-06-14 16:07:53.621 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:07:58.578 DTC Client socket (2) | Creating socket. | 2021-06-14 16:07:58.579 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:07:58.579 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:07:58.579 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:07:58.623 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:07:58.623 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:07:58.623 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:07:58.696 SC Data - All Services | Sending logon request message. | 2021-06-14 16:07:58.696 SC Data - All Services | Received logon response. | 2021-06-14 16:07:59.323 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:07:59.323 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:07:59.323 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:07:59.323 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:07:59.323 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:07:59.324 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:07:59.324 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:07:59.324 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:07:59.324 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:07:59.363 DTC Client socket (2) | Closed. | 2021-06-14 16:07:59.363 F.US.EPU21 [C][M] #1 | Reloading chart. | 2021-06-14 16:08:01.629 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:08:04.308 DTC Client socket (2) | Creating socket. | 2021-06-14 16:08:04.309 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:08:04.309 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:08:04.309 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:04.356 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:04.356 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:04.356 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:04.408 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:04.408 SC Data - All Services | Received logon response. | 2021-06-14 16:08:04.470 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:04.470 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:04.470 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:04.470 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:04.470 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:08:04.471 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:04.471 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:04.471 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:04.471 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:08:04.512 DTC Client socket (2) | Closed. | 2021-06-14 16:08:04.512 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:08:09.463 DTC Client socket (2) | Creating socket. | 2021-06-14 16:08:09.464 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:08:09.464 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:08:09.464 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:09.516 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:09.516 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:09.516 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:09.595 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:09.595 SC Data - All Services | Received logon response. | 2021-06-14 16:08:09.760 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:09.760 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:09.760 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:09.760 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:09.760 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:08:09.761 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:09.761 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:09.761 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:09.761 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:08:09.800 DTC Client socket (2) | Closed. | 2021-06-14 16:08:09.800 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-14 16:08:12.900 DTC Client socket (2) | Creating socket. | 2021-06-14 16:08:12.901 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:08:12.901 DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:08:12.901 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:12.956 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:12.956 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:12.957 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:13.034 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:13.034 SC Data - All Services | Received logon response. | 2021-06-14 16:08:13.800 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:13.800 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:13.800 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:13.800 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:13.800 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:08:13.800 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:13.800 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:08:13.800 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:13.800 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:08:13.849 DTC Client socket (2) | Closed. | 2021-06-14 16:08:13.849 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:08:14.758 DTC Client socket (2) | Creating socket. | 2021-06-14 16:08:14.759 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:08:14.759 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:08:14.759 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:14.802 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:14.802 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:14.802 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:14.878 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:14.878 SC Data - All Services | Received logon response. | 2021-06-14 16:08:15.003 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:15.003 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:15.003 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:15.003 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:15.003 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:08:15.004 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:15.004 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:15.004 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:15.004 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:08:15.040 DTC Client socket (2) | Closed. | 2021-06-14 16:08:15.040 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:08:20.003 DTC Client socket (2) | Creating socket. | 2021-06-14 16:08:20.004 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:08:20.004 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:08:20.004 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:20.047 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:20.047 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:20.047 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:20.126 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:20.126 SC Data - All Services | Received logon response. | 2021-06-14 16:08:20.255 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:20.255 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:20.255 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:20.255 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:20.255 DTC Client socket (2) | CloseSocket call. | 2021-06-14 16:08:20.256 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:20.256 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:20.256 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:20.256 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:08:20.292 DTC Client socket (2) | Closed. | 2021-06-14 16:08:20.292 File >> Disconnect selected. | 2021-06-14 16:08:24.876 CQG WebAPI | Sending Web API Logoff message. | 2021-06-14 16:08:24.890 CQG WebSocket socket (1) | CloseSocket call. | 2021-06-14 16:08:24.890 CQG WebSocket socket (1) | Max send buffers used during socket life: 4 | 2021-06-14 16:08:24.890 CQG WebSocket socket (1) | Max send buffer size during socket life: 309 | 2021-06-14 16:08:24.890 CQG WebSocket | WebSocket closed. | 2021-06-14 16:08:24.890 CQG WebAPI | WebSocket closed. | 2021-06-14 16:08:24.890 CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-06-14 16:08:24.890 DTC Client socket (0) | CloseSocket call. | 2021-06-14 16:08:24.891 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:24.891 DTC Client socket (0) | CloseSocket call. | 2021-06-14 16:08:24.891 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:24.891 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-06-14 16:08:24.891 DTC Client socket (3) | CloseSocket call. | 2021-06-14 16:08:24.891 DTC Client socket (3) | Max send buffers used during socket life: 3 | 2021-06-14 16:08:24.891 DTC Client socket (3) | Max send buffer size during socket life: 360 | 2021-06-14 16:08:24.891 SC DTC Data with Market Depth | Disconnected from the server. | 2021-06-14 16:08:24.891 CQG WebAPI | Disconnected. | 2021-06-14 16:08:24.891 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:24.891 CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2021-06-14 16:08:24.941 CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:24.941 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-06-14 16:08:24.943 DTC Client socket (3) | Closed. | 2021-06-14 16:08:24.943 CQG WebAPI | Connecting to server api.cqg.com | 2021-06-14 16:08:27.880 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-06-14 16:08:27.880 CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2021-06-14 16:08:28.091 CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:08:28.091 CQG WebSocket socket (2) | Connecting to IP: 208.48.16.35. | 2021-06-14 16:08:28.091 CQG WebSocket | Opening WebSocket. | 2021-06-14 16:08:28.138 CQG WebSocket | Sending WebSocket handshake. | 2021-06-14 16:08:28.138 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-06-14 16:08:28.287 CQG WebSocket | Server header | Connection: upgrade | 2021-06-14 16:08:28.287 CQG WebSocket | Server header | Sec-WebSocket-Accept: 6oi9sCTBs/hF4C+h1Hxwx/bhEcM= | 2021-06-14 16:08:28.287 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-06-14 16:08:28.287 CQG WebSocket | Server header | Upgrade: websocket | 2021-06-14 16:08:28.287 CQG WebSocket | Server header | | 2021-06-14 16:08:28.287 CQG WebSocket | Web socket state is now open. | 2021-06-14 16:08:28.287 CQG WebAPI | WebSocket connected. | 2021-06-14 16:08:28.287 CQG WebAPI | Sending market data logon message. | 2021-06-14 16:08:28.287 CQG WebAPI | Base Time: 2021-06-13T01:52:24. 2021-06-13 01:52:24 | 2021-06-14 16:08:28.444 CQG WebAPI | Logon successful. Session Token = Ruuh3i+Us6marM/dO6q4s9hmVb+Ko8UPvqQRNUR+Esg8408Sq3tliyr/FcdtZXoHbEY1/kcuaOT | 2021-06-14 16:08:28.444 CQG WebAPI | Connected to server complete. | 2021-06-14 16:08:28.444 Triggering next historical data download in queue. | 2021-06-14 16:08:28.448 Triggering next historical data download in queue. | 2021-06-14 16:08:28.448 Triggering next historical data download in queue. | 2021-06-14 16:08:28.448 Triggering next historical data download in queue. | 2021-06-14 16:08:28.448 Updated verified funded futures trading account ending date to: 2021-07-14 16:08:28 | 2021-06-14 16:08:28.448 SC DTC Data with Market Depth | Starting real-time market data updates for: UVOL-NYSE. ID: 1 Service code: statscalc | 2021-06-14 16:08:28.455 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2021-06-14 16:08:28.455 SC DTC Data with Market Depth | Requesting security definition data for: UVOL-NYSE. ID: 1 | 2021-06-14 16:08:28.455 Added historical Intraday data request for UVOL-NYSE to the queue. | 2021-06-14 16:08:28.455 Intraday data recording state for symbol UVOL-NYSE is set to download 'Pending'. | 2021-06-14 16:08:28.455 TICK-NYSE[M] 5 Min #6 | Started historical data download for additional symbol UVOL-NYSE. Download ID: 19 | 2021-06-14 16:08:28.455 SC DTC Data with Market Depth | Starting real-time market data updates for: DVOL-NYSE. ID: 2 Service code: statscalc | 2021-06-14 16:08:28.455 SC DTC Data with Market Depth | Requesting security definition data for: DVOL-NYSE. ID: 2 | 2021-06-14 16:08:28.455 Added historical Intraday data request for DVOL-NYSE to the queue. | 2021-06-14 16:08:28.455 Intraday data recording state for symbol DVOL-NYSE is set to download 'Pending'. | 2021-06-14 16:08:28.455 TICK-NYSE[M] 5 Min #6 | Started historical data download for additional symbol DVOL-NYSE. Download ID: 20 | 2021-06-14 16:08:28.455 SC DTC Data with Market Depth | Starting real-time market data updates for: DVOL-NASDAQ. ID: 3 Service code: statscalc | 2021-06-14 16:08:28.455 SC DTC Data with Market Depth | Requesting security definition data for: DVOL-NASDAQ. ID: 3 | 2021-06-14 16:08:28.455 Added historical Intraday data request for DVOL-NASDAQ to the queue. | 2021-06-14 16:08:28.455 Intraday data recording state for symbol DVOL-NASDAQ is set to download 'Pending'. | 2021-06-14 16:08:28.455 TICK-NYSE[M] 5 Min #6 | Started historical data download for additional symbol DVOL-NASDAQ. Download ID: 21 | 2021-06-14 16:08:28.455 SC DTC Data with Market Depth | Starting real-time market data updates for: UVOL-NASDAQ. ID: 4 Service code: statscalc | 2021-06-14 16:08:28.455 SC DTC Data with Market Depth | Requesting security definition data for: UVOL-NASDAQ. ID: 4 | 2021-06-14 16:08:28.455 Added historical Intraday data request for UVOL-NASDAQ to the queue. | 2021-06-14 16:08:28.455 Intraday data recording state for symbol UVOL-NASDAQ is set to download 'Pending'. | 2021-06-14 16:08:28.455 TICK-NYSE[M] 5 Min #6 | Started historical data download for additional symbol UVOL-NASDAQ. Download ID: 22 | 2021-06-14 16:08:28.455 DTC Client socket (3) | Creating socket. | 2021-06-14 16:08:28.455 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-14 16:08:28.455 DTC Client socket (3) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:08:28.455 CQG WebAPI | Sending Trade Accounts request message. | 2021-06-14 16:08:28.461 No download requests in the queue to start downloads for. | 2021-06-14 16:08:28.461 Delaying start of download for UVOL-NYSE | 2021-06-14 16:08:28.461 No download requests in the queue to start downloads for. | 2021-06-14 16:08:28.461 No download requests in the queue to start downloads for. | 2021-06-14 16:08:28.461 Mapping F.US.EPM22 to ESM22. Service code: cme | 2021-06-14 16:08:28.462 SC Data - All Services | Starting real-time market data updates for: F.US.EPM22 (ESM22). ID: 5 Service code: cme | 2021-06-14 16:08:28.462 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:08:28.462 CQG WebAPI | Sending symbol resolution request for F.US.EPM22. ID: 486677 | 2021-06-14 16:08:28.462 SC Data - All Services | Requesting security definition data for: F.US.EPM22 (ESM22). ID: 5 | 2021-06-14 16:08:28.462 Added historical Intraday data request for F.US.EPM22 to the queue. | 2021-06-14 16:08:28.462 Intraday data recording state for symbol F.US.EPM22 is set to download 'Pending'. | 2021-06-14 16:08:28.462 Triggering next historical data download in queue. | 2021-06-14 16:08:28.462 DTC Client socket (4) | Creating socket. | 2021-06-14 16:08:28.462 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:08:28.462 DTC Client socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:08:28.462 SC DTC Data with Market Depth | Network connection to server complete. | 2021-06-14 16:08:28.532 SC DTC Data with Market Depth | Starting socket receive thread. | 2021-06-14 16:08:28.532 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:28.533 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:28.533 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:28.533 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:28.533 CQG WebAPI | Received symbol resolution report for symbol F.US.EPM22. Search Symbol: F.US.EPM22. Request ID: 486677. Contract ID: 1. | 2021-06-14 16:08:28.533 CQG WebAPI | Brokerage name: AMP. Account Name: 141240 | 2021-06-14 16:08:28.533 CQG WebAPI | Sending collateral subscribe request. | 2021-06-14 16:08:28.533 Mapping F.US.EPU21 to ESU21. Service code: cme | 2021-06-14 16:08:28.585 SC Data - All Services | Starting real-time market data updates for: F.US.EPU21 (ESU21). ID: 6 Service code: cme | 2021-06-14 16:08:28.585 CQG WebAPI | Sending symbol resolution request for F.US.EPU21. ID: 486679 | 2021-06-14 16:08:28.585 SC Data - All Services | Requesting security definition data for: F.US.EPU21 (ESU21). ID: 6 | 2021-06-14 16:08:28.585 Added historical Intraday data request for F.US.EPU21 to the queue. | 2021-06-14 16:08:28.585 Intraday data recording state for symbol F.US.EPU21 is set to download 'Pending'. | 2021-06-14 16:08:28.585 Triggering next historical data download in queue. | 2021-06-14 16:08:28.585 CQG WebAPI | Received symbol resolution report for symbol F.US.EPU21. Search Symbol: F.US.EPU21. Request ID: 486679. Contract ID: 2. | 2021-06-14 16:08:28.639 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:28.639 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:28.639 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:28.639 SC DTC Data with Market Depth | Sending logon request message. | 2021-06-14 16:08:28.639 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 7 Service code: statscalc | 2021-06-14 16:08:28.641 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 7 | 2021-06-14 16:08:28.641 Added historical Intraday data request for TICK-NYSE to the queue. | 2021-06-14 16:08:28.641 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2021-06-14 16:08:28.641 Triggering next historical data download in queue. | 2021-06-14 16:08:28.641 SC DTC Data with Market Depth | Starting real-time market data updates for: UDVR-NYSE. ID: 8 Service code: statscalc | 2021-06-14 16:08:28.643 SC DTC Data with Market Depth | Requesting security definition data for: UDVR-NYSE. ID: 8 | 2021-06-14 16:08:28.643 Added historical Intraday data request for UDVR-NYSE to the queue. | 2021-06-14 16:08:28.643 Intraday data recording state for symbol UDVR-NYSE is set to download 'Pending'. | 2021-06-14 16:08:28.643 Triggering next historical data download in queue. | 2021-06-14 16:08:28.643 Mapping MSFT to MSFT. Service code: equities.us | 2021-06-14 16:08:28.657 SC Data - All Services | Starting real-time market data updates for: MSFT (MSFT). ID: 9 Service code: equities.us | 2021-06-14 16:08:28.657 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:08:28.657 CQG WebAPI | Sending symbol resolution request for MSFT. ID: 486680 | 2021-06-14 16:08:28.657 SC Data - All Services | Requesting security definition data for: MSFT (MSFT). ID: 9 | 2021-06-14 16:08:28.657 Added historical Intraday data request for MSFT to the queue. | 2021-06-14 16:08:28.658 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-06-14 16:08:28.658 Triggering next historical data download in queue. | 2021-06-14 16:08:28.658 DTC Client socket (5) | Creating socket. | 2021-06-14 16:08:28.658 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:08:28.658 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:08:28.658 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:28.701 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:28.701 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:28.701 CQG WebAPI | Received symbol resolution report for symbol S.US.MSFT. Search Symbol: MSFT. Request ID: 486680. Contract ID: 3. | 2021-06-14 16:08:28.708 Symbol Error - MSFT is unknown, unavailable, or improperly formatted. Exact match not found for symbol MSFT | 2021-06-14 16:08:28.708 Mapping F.US.ENQM21 to NQM21. Service code: cme | 2021-06-14 16:08:28.751 Mapping F.US.ENQU21 to NQU21. Service code: cme | 2021-06-14 16:08:28.751 SC Data - All Services | Starting real-time market data updates for: F.US.ENQU21 (NQU21). ID: 11 Service code: cme | 2021-06-14 16:08:28.752 CQG WebAPI | Sending symbol resolution request for F.US.ENQU21. ID: 486681 | 2021-06-14 16:08:28.752 SC Data - All Services | Requesting security definition data for: F.US.ENQU21 (NQU21). ID: 11 | 2021-06-14 16:08:28.752 SC Data - All Services | Starting real-time market data updates for: F.US.ENQM21 (NQM21). ID: 10 Service code: cme | 2021-06-14 16:08:28.752 CQG WebAPI | Sending symbol resolution request for F.US.ENQM21. ID: 486682 | 2021-06-14 16:08:28.752 SC Data - All Services | Requesting security definition data for: F.US.ENQM21 (NQM21). ID: 10 | 2021-06-14 16:08:28.752 Added historical Intraday data request for F.US.ENQM21 to the queue. | 2021-06-14 16:08:28.752 Intraday data recording state for symbol F.US.ENQM21 is set to download 'Pending'. | 2021-06-14 16:08:28.752 Triggering next historical data download in queue. | 2021-06-14 16:08:28.752 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU21. Search Symbol: F.US.ENQU21. Request ID: 486681. Contract ID: 4. | 2021-06-14 16:08:28.818 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:28.819 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:28.819 Mapping F.US.RTYM21 to RTYM21. Service code: cme | 2021-06-14 16:08:28.819 Mapping F.US.RTYU21 to RTYU21. Service code: cme | 2021-06-14 16:08:28.819 SC Data - All Services | Starting real-time market data updates for: F.US.RTYU21 (RTYU21). ID: 13 Service code: cme | 2021-06-14 16:08:28.819 CQG WebAPI | Sending symbol resolution request for F.US.RTYU21. ID: 486683 | 2021-06-14 16:08:28.819 SC Data - All Services | Requesting security definition data for: F.US.RTYU21 (RTYU21). ID: 13 | 2021-06-14 16:08:28.819 SC Data - All Services | Starting real-time market data updates for: F.US.RTYM21 (RTYM21). ID: 12 Service code: cme | 2021-06-14 16:08:28.819 CQG WebAPI | Sending symbol resolution request for F.US.RTYM21. ID: 486684 | 2021-06-14 16:08:28.819 SC Data - All Services | Requesting security definition data for: F.US.RTYM21 (RTYM21). ID: 12 | 2021-06-14 16:08:28.819 Added historical Intraday data request for F.US.RTYM21 to the queue. | 2021-06-14 16:08:28.819 Intraday data recording state for symbol F.US.RTYM21 is set to download 'Pending'. | 2021-06-14 16:08:28.819 Triggering next historical data download in queue. | 2021-06-14 16:08:28.819 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQM21. Search Symbol: F.US.ENQM21. Request ID: 486682. Contract ID: 5. | 2021-06-14 16:08:28.849 Mapping TSLA to TSLA. Service code: equities.us | 2021-06-14 16:08:28.849 SC Data - All Services | Starting real-time market data updates for: TSLA (TSLA). ID: 14 Service code: equities.us | 2021-06-14 16:08:28.849 CQG WebAPI | Sending symbol resolution request for TSLA. ID: 486685 | 2021-06-14 16:08:28.849 SC Data - All Services | Requesting security definition data for: TSLA (TSLA). ID: 14 | 2021-06-14 16:08:28.849 Added historical Intraday data request for TSLA to the queue. | 2021-06-14 16:08:28.849 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2021-06-14 16:08:28.849 Triggering next historical data download in queue. | 2021-06-14 16:08:28.849 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYU21. Search Symbol: F.US.RTYU21. Request ID: 486683. Contract ID: 6. | 2021-06-14 16:08:28.873 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYM21. Search Symbol: F.US.RTYM21. Request ID: 486684. Contract ID: 7. | 2021-06-14 16:08:28.873 CQG WebAPI | Received symbol resolution report for symbol S.US.TSLA. Search Symbol: TSLA. Request ID: 486685. Contract ID: 8. | 2021-06-14 16:08:28.897 Symbol Error - TSLA is unknown, unavailable, or improperly formatted. Exact match not found for symbol TSLA | 2021-06-14 16:08:28.897 Mapping AAPL to AAPL. Service code: equities.us | 2021-06-14 16:08:28.920 SC Data - All Services | Starting real-time market data updates for: AAPL (AAPL). ID: 15 Service code: equities.us | 2021-06-14 16:08:28.920 CQG WebAPI | Sending symbol resolution request for AAPL. ID: 486686 | 2021-06-14 16:08:28.920 SC Data - All Services | Requesting security definition data for: AAPL (AAPL). ID: 15 | 2021-06-14 16:08:28.920 Added historical Intraday data request for AAPL to the queue. | 2021-06-14 16:08:28.920 Intraday data recording state for symbol AAPL is set to download 'Pending'. | 2021-06-14 16:08:28.920 Triggering next historical data download in queue. | 2021-06-14 16:08:28.920 CQG WebAPI | Received symbol resolution report for symbol X.US.AAPLA00. Search Symbol: AAPL. Request ID: 486686. Contract ID: 9. | 2021-06-14 16:08:28.981 Symbol Error - AAPL is unknown, unavailable, or improperly formatted. Exact match not found for symbol AAPL | 2021-06-14 16:08:28.981 Mapping F.US.CLEN21 to CLN21. Service code: nymex | 2021-06-14 16:08:29.030 Mapping F.US.CLEQ21 to CLQ21. Service code: nymex | 2021-06-14 16:08:29.030 SC Data - All Services | Starting real-time market data updates for: F.US.CLEQ21 (CLQ21). ID: 17 Service code: nymex | 2021-06-14 16:08:29.030 CQG WebAPI | Sending symbol resolution request for F.US.CLEQ21. ID: 486687 | 2021-06-14 16:08:29.030 SC Data - All Services | Requesting security definition data for: F.US.CLEQ21 (CLQ21). ID: 17 | 2021-06-14 16:08:29.030 SC Data - All Services | Starting real-time market data updates for: F.US.CLEN21 (CLN21). ID: 16 Service code: nymex | 2021-06-14 16:08:29.030 CQG WebAPI | Sending symbol resolution request for F.US.CLEN21. ID: 486688 | 2021-06-14 16:08:29.030 SC Data - All Services | Requesting security definition data for: F.US.CLEN21 (CLN21). ID: 16 | 2021-06-14 16:08:29.030 Added historical Intraday data request for F.US.CLEN21 to the queue. | 2021-06-14 16:08:29.030 Intraday data recording state for symbol F.US.CLEN21 is set to download 'Pending'. | 2021-06-14 16:08:29.030 Triggering next historical data download in queue. | 2021-06-14 16:08:29.030 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ21. Search Symbol: F.US.CLEQ21. Request ID: 486687. Contract ID: 10. | 2021-06-14 16:08:29.085 Mapping F.US.MESM21 to MESM21. Service code: cme | 2021-06-14 16:08:29.086 Mapping F.US.MESU21 to MESU21. Service code: cme | 2021-06-14 16:08:29.086 SC Data - All Services | Starting real-time market data updates for: F.US.MESU21 (MESU21). ID: 19 Service code: cme | 2021-06-14 16:08:29.086 CQG WebAPI | Sending symbol resolution request for F.US.MESU21. ID: 486689 | 2021-06-14 16:08:29.086 SC Data - All Services | Requesting security definition data for: F.US.MESU21 (MESU21). ID: 19 | 2021-06-14 16:08:29.086 SC Data - All Services | Starting real-time market data updates for: F.US.MESM21 (MESM21). ID: 18 Service code: cme | 2021-06-14 16:08:29.086 CQG WebAPI | Sending symbol resolution request for F.US.MESM21. ID: 486690 | 2021-06-14 16:08:29.086 SC Data - All Services | Requesting security definition data for: F.US.MESM21 (MESM21). ID: 18 | 2021-06-14 16:08:29.086 Added historical Intraday data request for F.US.MESM21 to the queue. | 2021-06-14 16:08:29.086 Intraday data recording state for symbol F.US.MESM21 is set to download 'Pending'. | 2021-06-14 16:08:29.086 Triggering next historical data download in queue. | 2021-06-14 16:08:29.086 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN21. Search Symbol: F.US.CLEN21. Request ID: 486688. Contract ID: 11. | 2021-06-14 16:08:29.088 Mapping F.US.EPM21 to ESM21. Service code: cme | 2021-06-14 16:08:29.088 SC Data - All Services | Starting real-time market data updates for: F.US.EPM21 (ESM21). ID: 20 Service code: cme | 2021-06-14 16:08:29.088 CQG WebAPI | Sending symbol resolution request for F.US.EPM21. ID: 486691 | 2021-06-14 16:08:29.088 SC Data - All Services | Requesting security definition data for: F.US.EPM21 (ESM21). ID: 20 | 2021-06-14 16:08:29.088 CQG WebAPI | Received symbol resolution report for symbol F.US.MESU21. Search Symbol: F.US.MESU21. Request ID: 486689. Contract ID: 12. | 2021-06-14 16:08:29.133 CQG WebAPI | Received symbol resolution report for symbol F.US.MESM21. Search Symbol: F.US.MESM21. Request ID: 486690. Contract ID: 13. | 2021-06-14 16:08:29.133 CQG WebAPI | Received symbol resolution report for symbol F.US.EPM21. Search Symbol: F.US.EPM21. Request ID: 486691. Contract ID: 14. | 2021-06-14 16:08:29.133 SC DTC Data with Market Depth | Received logon response. | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Successfully connected. | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Trading is not supported. | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DVOL-NASDAQ | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DVOL-NYSE | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UDVR-NYSE | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UVOL-NASDAQ | 2021-06-14 16:08:29.319 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UVOL-NYSE | 2021-06-14 16:08:29.319 SC Data - All Services | Received logon response. | 2021-06-14 16:08:29.352 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:29.352 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:29.352 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:29.352 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:29.352 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:08:29.353 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:29.353 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:08:29.353 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:29.353 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:08:29.395 DTC Client socket (4) | Closed. | 2021-06-14 16:08:29.395 SC Data - All Services | Received logon response. | 2021-06-14 16:08:29.413 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:29.413 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:29.413 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:29.413 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:29.414 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:08:29.414 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:29.414 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:29.414 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:29.414 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:08:29.453 DTC Client socket (5) | Closed. | 2021-06-14 16:08:29.453 SC DTC Data with Market Depth | Received security definition for symbol DVOL-NASDAQ | 2021-06-14 16:08:29.475 SC DTC Data with Market Depth | Received security definition for symbol DVOL-NYSE | 2021-06-14 16:08:29.475 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2021-06-14 16:08:29.475 SC DTC Data with Market Depth | Received security definition for symbol UDVR-NYSE | 2021-06-14 16:08:29.475 SC DTC Data with Market Depth | Received security definition for symbol UVOL-NASDAQ | 2021-06-14 16:08:29.475 SC DTC Data with Market Depth | Received security definition for symbol UVOL-NYSE | 2021-06-14 16:08:29.475 CQG WebAPI | Sending positions subscribe request. RequestID: 486692 | 2021-06-14 16:08:33.437 CQG WebAPI | Sending orders subscribe request. RequestID: 486693 | 2021-06-14 16:08:33.437 Requesting market depth updates for: F.US.MESM21 if supported. | 2021-06-14 16:08:33.438 Separate subscription for market depth updates not supported. F.US.MESM21 | 2021-06-14 16:08:33.438 HD Request # 19 | Downloading Intraday chart data for UVOL-NYSE to the file UVOL-NYSE.scid. Service: statscalc | 2021-06-14 16:08:34.109 HD Request # 19 | Download start date-time: 2021-06-14 16:08:24.000000. File last date-time: 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:34.110 HD Request # 19 | Using server: ds12.sierracharts.com port 10149 | 2021-06-14 16:08:34.110 Socket (4) | Creating socket. | 2021-06-14 16:08:34.110 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:08:34.110 Socket (4) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:08:34.110 HD Request # 19 | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:34.236 HD Request # 19 | Sending historical data logon request message. | 2021-06-14 16:08:34.236 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:08:34.406 DTC Client socket (5) | Creating socket. | 2021-06-14 16:08:34.407 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:08:34.407 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:08:34.407 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:34.452 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:34.452 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:34.452 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:34.504 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:34.504 HD Request # 19 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:24. Record interval: 1. Symbol: UVOL-NYSE | 2021-06-14 16:08:34.831 HD Request # 19 | Decompressing data. | 2021-06-14 16:08:34.883 HD Request # 19 | Receiving Intraday data for UVOL-NYSE starting at 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:34.884 Socket (4) | CloseSocket call. | 2021-06-14 16:08:34.885 Historical data download thread signaled to stop. | 2021-06-14 16:08:34.885 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:34.885 HD Request # 19 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:34.885 HD Request # 19 | Received 11 records from 2021-06-14 16:08:24.000000 to 2021-06-14 16:08:34.000000 (10.0 seconds) and wrote 11 records for UVOL-NYSE | 2021-06-14 16:08:34.886 HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:34.000000 | 2021-06-14 16:08:34.893 HD Request # 19 | Completion time: 0s | 2021-06-14 16:08:34.893 HD Request # 19 | Intraday data download complete for UVOL-NYSE. Unique request ID: 19 | 2021-06-14 16:08:34.893 Removing historical data download ID 19. | 2021-06-14 16:08:34.893 Real-time Intraday chart data file updates started for UVOL-NYSE | 2021-06-14 16:08:34.893 Opened cached Intraday file: C:\SierraChart\Data\UVOL-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:08:34.893 Intraday chart data file opened for UVOL-NYSE | 2021-06-14 16:08:34.893 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:08:34.893 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol UVOL-NYSE with ID 19 has completed. | 2021-06-14 16:08:34.893 Triggering next historical data download in queue. | 2021-06-14 16:08:34.893 HD Request # 20 | Downloading Intraday chart data for DVOL-NYSE to the file DVOL-NYSE.scid. Service: statscalc | 2021-06-14 16:08:34.893 HD Request # 20 | Download start date-time: 2021-06-14 16:08:24.000000. File last date-time: 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:34.893 HD Request # 20 | Using server: ds4.sierracharts.com port 10150 | 2021-06-14 16:08:34.894 Socket (6) | Creating socket. | 2021-06-14 16:08:34.894 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:08:34.894 Socket (6) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:08:34.894 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:08:34.939 Socket (4) | Closed. | 2021-06-14 16:08:34.939 HD Request # 20 | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:35.005 HD Request # 20 | Sending historical data logon request message. | 2021-06-14 16:08:35.005 SC Data - All Services | Received logon response. | 2021-06-14 16:08:35.140 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:35.140 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:35.140 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:35.140 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:35.140 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:08:35.140 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:35.140 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:35.140 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:35.141 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:08:35.182 DTC Client socket (5) | Closed. | 2021-06-14 16:08:35.182 HD Request # 20 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:24. Record interval: 1. Symbol: DVOL-NYSE | 2021-06-14 16:08:35.591 HD Request # 20 | Decompressing data. | 2021-06-14 16:08:35.643 HD Request # 20 | Receiving Intraday data for DVOL-NYSE starting at 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:35.643 Socket (6) | CloseSocket call. | 2021-06-14 16:08:35.644 Historical data download thread signaled to stop. | 2021-06-14 16:08:35.644 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:35.644 HD Request # 20 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:35.644 HD Request # 20 | Received 12 records from 2021-06-14 16:08:24.000000 to 2021-06-14 16:08:35.000000 (11.0 seconds) and wrote 12 records for DVOL-NYSE | 2021-06-14 16:08:35.644 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:35.000000 | 2021-06-14 16:08:35.649 HD Request # 20 | Completion time: 1s | 2021-06-14 16:08:35.649 HD Request # 20 | Intraday data download complete for DVOL-NYSE. Unique request ID: 20 | 2021-06-14 16:08:35.649 Removing historical data download ID 20. | 2021-06-14 16:08:35.649 Real-time Intraday chart data file updates started for DVOL-NYSE | 2021-06-14 16:08:35.649 Opened cached Intraday file: C:\SierraChart\Data\DVOL-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:08:35.649 Intraday chart data file opened for DVOL-NYSE | 2021-06-14 16:08:35.649 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:08:35.650 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol DVOL-NYSE with ID 20 has completed. | 2021-06-14 16:08:35.650 Triggering next historical data download in queue. | 2021-06-14 16:08:35.650 HD Request # 21 | Downloading Intraday chart data for DVOL-NASDAQ to the file DVOL-NASDAQ.scid. Service: statscalc | 2021-06-14 16:08:35.650 HD Request # 21 | Download start date-time: 2021-06-14 16:08:24.000000. File last date-time: 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:35.650 HD Request # 21 | Using server: ds12.sierracharts.com port 10149 | 2021-06-14 16:08:35.650 Socket (4) | Creating socket. | 2021-06-14 16:08:35.650 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:08:35.650 Socket (4) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:08:35.650 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:08:35.699 Socket (6) | Closed. | 2021-06-14 16:08:35.699 HD Request # 21 | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:35.777 HD Request # 21 | Sending historical data logon request message. | 2021-06-14 16:08:35.778 HD Request # 21 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:24. Record interval: 1. Symbol: DVOL-NASDAQ | 2021-06-14 16:08:35.828 HD Request # 21 | Decompressing data. | 2021-06-14 16:08:35.887 HD Request # 21 | Receiving Intraday data for DVOL-NASDAQ starting at 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:35.888 Socket (4) | CloseSocket call. | 2021-06-14 16:08:35.889 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:35.889 Historical data download thread signaled to stop. | 2021-06-14 16:08:35.889 HD Request # 21 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:35.889 HD Request # 21 | Received 11 records from 2021-06-14 16:08:24.000000 to 2021-06-14 16:08:34.000000 (10.0 seconds) and wrote 11 records for DVOL-NASDAQ | 2021-06-14 16:08:35.890 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:34.000000 | 2021-06-14 16:08:35.897 Added 1 Time and Sales records to Intraday data file for DVOL-NASDAQ after download. | 2021-06-14 16:08:35.897 HD Request # 21 | Completion time: 0s | 2021-06-14 16:08:35.897 HD Request # 21 | Intraday data download complete for DVOL-NASDAQ. Unique request ID: 21 | 2021-06-14 16:08:35.897 Removing historical data download ID 21. | 2021-06-14 16:08:35.897 Real-time Intraday chart data file updates started for DVOL-NASDAQ | 2021-06-14 16:08:35.897 Opened cached Intraday file: C:\SierraChart\Data\DVOL-NASDAQ.scid. Thread ID: 3636 | 2021-06-14 16:08:35.900 Intraday chart data file opened for DVOL-NASDAQ | 2021-06-14 16:08:35.900 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:08:35.900 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol DVOL-NASDAQ with ID 21 has completed. | 2021-06-14 16:08:35.900 Triggering next historical data download in queue. | 2021-06-14 16:08:35.900 HD Request # 22 | Downloading Intraday chart data for UVOL-NASDAQ to the file UVOL-NASDAQ.scid. Service: statscalc | 2021-06-14 16:08:35.900 HD Request # 22 | Download start date-time: 2021-06-14 16:08:24.000000. File last date-time: 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:35.900 HD Request # 22 | Using server: ds4.sierracharts.com port 10150 | 2021-06-14 16:08:35.900 Socket (5) | Creating socket. | 2021-06-14 16:08:35.900 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:08:35.901 Socket (5) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:08:35.901 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:08:35.943 Socket (4) | Closed. | 2021-06-14 16:08:35.943 HD Request # 22 | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:36.008 HD Request # 22 | Sending historical data logon request message. | 2021-06-14 16:08:36.008 HD Request # 22 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:24. Record interval: 1. Symbol: UVOL-NASDAQ | 2021-06-14 16:08:36.062 HD Request # 22 | Decompressing data. | 2021-06-14 16:08:36.115 HD Request # 22 | Receiving Intraday data for UVOL-NASDAQ starting at 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:36.116 Socket (5) | CloseSocket call. | 2021-06-14 16:08:36.116 Historical data download thread signaled to stop. | 2021-06-14 16:08:36.116 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:36.116 HD Request # 22 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:24.000000 | 2021-06-14 16:08:36.116 HD Request # 22 | Received 12 records from 2021-06-14 16:08:24.000000 to 2021-06-14 16:08:35.000000 (11.0 seconds) and wrote 12 records for UVOL-NASDAQ | 2021-06-14 16:08:36.117 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:35.000000 | 2021-06-14 16:08:36.123 HD Request # 22 | Completion time: 1s | 2021-06-14 16:08:36.123 HD Request # 22 | Intraday data download complete for UVOL-NASDAQ. Unique request ID: 22 | 2021-06-14 16:08:36.123 Removing historical data download ID 22. | 2021-06-14 16:08:36.123 Real-time Intraday chart data file updates started for UVOL-NASDAQ | 2021-06-14 16:08:36.123 Opened cached Intraday file: C:\SierraChart\Data\UVOL-NASDAQ.scid. Thread ID: 3636 | 2021-06-14 16:08:36.123 Intraday chart data file opened for UVOL-NASDAQ | 2021-06-14 16:08:36.123 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:08:36.123 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol UVOL-NASDAQ with ID 22 has completed. | 2021-06-14 16:08:36.123 Triggering next historical data download in queue. | 2021-06-14 16:08:36.123 Delaying start of download for F.US.EPM22 | 2021-06-14 16:08:36.123 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:08:36.168 Socket (5) | Closed. | 2021-06-14 16:08:36.169 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:08:40.139 DTC Client socket (4) | Creating socket. | 2021-06-14 16:08:40.140 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:08:40.141 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:08:40.141 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:40.187 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:40.187 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:40.187 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:40.250 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:40.250 SC Data - All Services | Received logon response. | 2021-06-14 16:08:40.408 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:40.408 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:40.408 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:40.408 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:40.408 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:08:40.408 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:40.408 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:40.409 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:40.409 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:08:40.448 DTC Client socket (4) | Closed. | 2021-06-14 16:08:40.448 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:08:45.397 DTC Client socket (4) | Creating socket. | 2021-06-14 16:08:45.398 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:08:45.399 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:08:45.399 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:45.442 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:45.442 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:45.442 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:45.496 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:45.496 SC Data - All Services | Received logon response. | 2021-06-14 16:08:45.639 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:45.639 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:45.639 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:45.639 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:45.639 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:08:45.639 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:45.639 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:45.639 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:45.639 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:08:45.677 DTC Client socket (4) | Closed. | 2021-06-14 16:08:45.677 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:08:50.630 DTC Client socket (4) | Creating socket. | 2021-06-14 16:08:50.631 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:08:50.631 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:08:50.631 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:50.669 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:50.669 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:50.669 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:50.717 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:50.717 SC Data - All Services | Received logon response. | 2021-06-14 16:08:50.865 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:50.865 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:50.865 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:50.865 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:50.865 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:08:50.866 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:50.866 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:50.866 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:50.866 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:08:50.921 DTC Client socket (4) | Closed. | 2021-06-14 16:08:50.921 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:08:55.864 DTC Client socket (4) | Creating socket. | 2021-06-14 16:08:55.864 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:08:55.864 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:08:55.864 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:55.905 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:55.905 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:55.905 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:55.976 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:55.976 SC Data - All Services | Received logon response. | 2021-06-14 16:08:56.134 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:08:56.134 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:08:56.134 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:08:56.134 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:08:56.134 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:08:56.135 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:08:56.135 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:08:56.135 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:56.135 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:08:56.173 DTC Client socket (4) | Closed. | 2021-06-14 16:08:56.173 HD Request # 23 | Downloading Intraday chart data for F.US.EPM22 to the file F.US.EPM22.scid. Service: cme | 2021-06-14 16:08:59.113 HD Request # 23 | Download start date-time: 2021-04-19 16:42:10.000000. File last date-time: 2021-04-19 16:42:10.679000 | 2021-06-14 16:08:59.114 HD Request # 23 | Using server: ds21.sierracharts.com port 10149 | 2021-06-14 16:08:59.114 Socket (4) | Creating socket. | 2021-06-14 16:08:59.114 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:08:59.114 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:08:59.114 HD Request # 23 | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:59.206 HD Request # 23 | Sending historical data logon request message. | 2021-06-14 16:08:59.206 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-06-14 16:08:59.347 DTC Client socket (5) | Creating socket. | 2021-06-14 16:08:59.348 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:08:59.348 DTC Client socket (5) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:08:59.348 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:08:59.392 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:08:59.392 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:08:59.392 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:59.454 SC Data - All Services | Sending logon request message. | 2021-06-14 16:08:59.454 HD Request # 23 | Requesting Intraday data. Start date-time: 2021-04-19 16:42:10. Record interval: 1. Symbol: ESM22 | 2021-06-14 16:08:59.703 HD Request # 23 | Decompressing data. | 2021-06-14 16:08:59.748 HD Request # 23 | Receiving Intraday data for F.US.EPM22 starting at 2021-04-19 16:42:10.679000 | 2021-06-14 16:08:59.748 Socket (4) | CloseSocket call. | 2021-06-14 16:08:59.748 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:08:59.748 Historical data download thread signaled to stop. | 2021-06-14 16:08:59.750 HD Request # 23 | Timestamp of first Intraday data file record written: 2021-04-19 16:42:10.679000 | 2021-06-14 16:08:59.750 HD Request # 23 | Received 1 record from 2021-04-19 16:42:10.679000 to 2021-04-19 16:42:10.679000 (0.0 seconds) and wrote 1 record for F.US.EPM22 | 2021-06-14 16:08:59.750 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2021-04-19 16:42:10.679000 | 2021-06-14 16:08:59.751 HD Request # 23 | Completion time: 0s | 2021-06-14 16:08:59.751 HD Request # 23 | Intraday data download complete for F.US.EPM22. Unique request ID: 23 | 2021-06-14 16:08:59.751 Removing historical data download ID 23. | 2021-06-14 16:08:59.751 Real-time Intraday chart data file updates started for F.US.EPM22 | 2021-06-14 16:08:59.751 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPM22.scid. Thread ID: 3636 | 2021-06-14 16:08:59.752 Intraday chart data file opened for F.US.EPM22 | 2021-06-14 16:08:59.752 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:08:59.752 Triggering next historical data download in queue. | 2021-06-14 16:08:59.752 HD Request # 24 | Downloading Intraday chart data for F.US.EPU21 to the file F.US.EPU21.scid. Service: cme | 2021-06-14 16:08:59.752 HD Request # 24 | Download start date-time: 2021-06-14 16:03:28.000000. File last date-time: 2021-06-14 16:03:28.106000 | 2021-06-14 16:08:59.752 HD Request # 24 | Using server: ds23.sierracharts.com port 10150 | 2021-06-14 16:08:59.752 Socket (6) | Creating socket. | 2021-06-14 16:08:59.752 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:08:59.752 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:08:59.752 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:08:59.796 Socket (4) | Closed. | 2021-06-14 16:08:59.796 HD Request # 24 | Setting DTC encoding to Binary VLS | 2021-06-14 16:08:59.847 HD Request # 24 | Sending historical data logon request message. | 2021-06-14 16:08:59.847 SC Data - All Services | Received logon response. | 2021-06-14 16:09:00.173 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:00.173 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:00.173 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:00.173 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:00.173 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:09:00.173 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:00.173 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:09:00.173 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:00.173 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:09:00.220 DTC Client socket (5) | Closed. | 2021-06-14 16:09:00.220 HD Request # 24 | Requesting Intraday data. Start date-time: 2021-06-14 16:03:28. Record interval: 1. Symbol: ESU21 | 2021-06-14 16:09:00.348 HD Request # 24 | Decompressing data. | 2021-06-14 16:09:00.398 HD Request # 24 | Receiving Intraday data for F.US.EPU21 starting at 2021-06-14 16:03:28.106000 | 2021-06-14 16:09:00.412 Socket (6) | CloseSocket call. | 2021-06-14 16:09:00.413 Historical data download thread signaled to stop. | 2021-06-14 16:09:00.414 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:00.414 HD Request # 24 | Timestamp of first Intraday data file record written: 2021-06-14 16:03:28.106000 | 2021-06-14 16:09:00.414 HD Request # 24 | Received 185 records from 2021-06-14 16:03:28.106000 to 2021-06-14 16:08:59.303000 (5.5 minutes) and wrote 185 records for F.US.EPU21 | 2021-06-14 16:09:00.415 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:59.303000 | 2021-06-14 16:09:00.422 HD Request # 24 | Completion time: 1s | 2021-06-14 16:09:00.422 HD Request # 24 | Intraday data download complete for F.US.EPU21. Unique request ID: 24 | 2021-06-14 16:09:00.422 Removing historical data download ID 24. | 2021-06-14 16:09:00.422 Real-time Intraday chart data file updates started for F.US.EPU21 | 2021-06-14 16:09:00.422 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPU21.scid. Thread ID: 3636 | 2021-06-14 16:09:00.423 Intraday chart data file opened for F.US.EPU21 | 2021-06-14 16:09:00.423 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:00.423 Triggering next historical data download in queue. | 2021-06-14 16:09:00.423 HD Request # 25 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2021-06-14 16:09:00.423 HD Request # 25 | Download start date-time: 2021-06-14 16:08:24.000000. File last date-time: 2021-06-14 16:08:24.000000 | 2021-06-14 16:09:00.423 HD Request # 25 | Using server: ds12.sierracharts.com port 10149 | 2021-06-14 16:09:00.423 Socket (4) | Creating socket. | 2021-06-14 16:09:00.423 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:00.423 Socket (4) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:09:00.423 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:09:00.456 Socket (6) | Closed. | 2021-06-14 16:09:00.456 HD Request # 25 | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:00.550 HD Request # 25 | Sending historical data logon request message. | 2021-06-14 16:09:00.551 HD Request # 25 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:24. Record interval: 1. Symbol: TICK-NYSE | 2021-06-14 16:09:00.602 HD Request # 25 | Decompressing data. | 2021-06-14 16:09:00.664 HD Request # 25 | Receiving Intraday data for TICK-NYSE starting at 2021-06-14 16:08:24.000000 | 2021-06-14 16:09:00.664 Socket (4) | CloseSocket call. | 2021-06-14 16:09:00.666 Historical data download thread signaled to stop. | 2021-06-14 16:09:00.666 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:00.666 HD Request # 25 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:24.000000 | 2021-06-14 16:09:00.666 HD Request # 25 | Received 35 records from 2021-06-14 16:08:24.000000 to 2021-06-14 16:08:58.000000 (34.0 seconds) and wrote 35 records for TICK-NYSE | 2021-06-14 16:09:00.667 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:58.000000 | 2021-06-14 16:09:00.678 Added 2 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2021-06-14 16:09:00.678 HD Request # 25 | Completion time: 0s | 2021-06-14 16:09:00.679 HD Request # 25 | Intraday data download complete for TICK-NYSE. Unique request ID: 25 | 2021-06-14 16:09:00.679 Removing historical data download ID 25. | 2021-06-14 16:09:00.679 Real-time Intraday chart data file updates started for TICK-NYSE | 2021-06-14 16:09:00.679 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:09:00.688 Intraday chart data file opened for TICK-NYSE | 2021-06-14 16:09:00.688 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:00.688 Triggering next historical data download in queue. | 2021-06-14 16:09:00.688 HD Request # 26 | Downloading Intraday chart data for UDVR-NYSE to the file UDVR-NYSE.scid. Service: statscalc | 2021-06-14 16:09:00.688 HD Request # 26 | Download start date-time: 2021-06-14 16:08:24.000000. File last date-time: 2021-06-14 16:08:24.000000 | 2021-06-14 16:09:00.689 HD Request # 26 | Using server: ds4.sierracharts.com port 10150 | 2021-06-14 16:09:00.689 Socket (5) | Creating socket. | 2021-06-14 16:09:00.689 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:09:00.689 Socket (5) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:09:00.689 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:00.722 Socket (4) | Closed. | 2021-06-14 16:09:00.722 HD Request # 26 | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:00.814 HD Request # 26 | Sending historical data logon request message. | 2021-06-14 16:09:00.814 HD Request # 26 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:24. Record interval: 1. Symbol: UDVR-NYSE | 2021-06-14 16:09:00.868 HD Request # 26 | Decompressing data. | 2021-06-14 16:09:00.930 HD Request # 26 | Receiving Intraday data for UDVR-NYSE starting at 2021-06-14 16:08:24.000000 | 2021-06-14 16:09:00.931 Socket (5) | CloseSocket call. | 2021-06-14 16:09:00.931 Historical data download thread signaled to stop. | 2021-06-14 16:09:00.931 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:00.931 HD Request # 26 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:24.000000 | 2021-06-14 16:09:00.931 HD Request # 26 | Received 36 records from 2021-06-14 16:08:24.000000 to 2021-06-14 16:08:59.000000 (35.0 seconds) and wrote 36 records for UDVR-NYSE | 2021-06-14 16:09:00.931 HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:59.000000 | 2021-06-14 16:09:00.935 Added 1 Time and Sales records to Intraday data file for UDVR-NYSE after download. | 2021-06-14 16:09:00.935 HD Request # 26 | Completion time: 0s | 2021-06-14 16:09:00.935 HD Request # 26 | Intraday data download complete for UDVR-NYSE. Unique request ID: 26 | 2021-06-14 16:09:00.935 Removing historical data download ID 26. | 2021-06-14 16:09:00.935 Real-time Intraday chart data file updates started for UDVR-NYSE | 2021-06-14 16:09:00.935 Opened cached Intraday file: C:\SierraChart\Data\UDVR-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:09:00.939 Intraday chart data file opened for UDVR-NYSE | 2021-06-14 16:09:00.939 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:00.939 Triggering next historical data download in queue. | 2021-06-14 16:09:00.939 HD Request # 27 | Downloading Intraday chart data for MSFT to the file MSFT.scid. Service: equities.us | 2021-06-14 16:09:00.939 HD Request # 27 | Download start date-time: 2021-06-14 16:03:59.000000. File last date-time: 2021-06-14 16:03:59.886000 | 2021-06-14 16:09:00.939 HD Request # 27 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2021-06-14 16:09:00.939 Socket (4) | Creating socket. | 2021-06-14 16:09:00.939 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:00.939 Socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:09:00.939 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:09:00.989 Socket (5) | Closed. | 2021-06-14 16:09:00.989 HD Request # 27 | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:01.038 HD Request # 27 | Sending historical data logon request message. | 2021-06-14 16:09:01.038 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:09:01.144 DTC Client socket (5) | Creating socket. | 2021-06-14 16:09:01.145 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:09:01.145 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:09:01.145 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:01.195 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:01.195 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:01.195 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:01.250 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:01.250 HD Request # 27 | Requesting Intraday data. Start date-time: 2021-06-14 16:03:59. Record interval: 1. Symbol: MSFT | 2021-06-14 16:09:01.542 HD Request # 27 | Decompressing data. | 2021-06-14 16:09:01.587 HD Request # 27 | Receiving Intraday data for MSFT starting at 2021-06-14 16:03:59.886000 | 2021-06-14 16:09:01.587 Socket (4) | CloseSocket call. | 2021-06-14 16:09:01.588 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:01.588 Historical data download thread signaled to stop. | 2021-06-14 16:09:01.588 HD Request # 27 | Timestamp of first Intraday data file record written: 2021-06-14 16:03:59.886000 | 2021-06-14 16:09:01.588 HD Request # 27 | Received 150 records from 2021-06-14 16:03:59.886000 to 2021-06-14 16:08:56.656000 (4.9 minutes) and wrote 150 records for MSFT | 2021-06-14 16:09:01.588 HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:56.656000 | 2021-06-14 16:09:01.592 HD Request # 27 | Completion time: 1s | 2021-06-14 16:09:01.592 HD Request # 27 | Intraday data download complete for MSFT. Unique request ID: 27 | 2021-06-14 16:09:01.592 Removing historical data download ID 27. | 2021-06-14 16:09:01.592 Real-time Intraday chart data file updates started for MSFT | 2021-06-14 16:09:01.592 Opened cached Intraday file: C:\SierraChart\Data\MSFT.scid. Thread ID: 3636 | 2021-06-14 16:09:01.592 Intraday chart data file opened for MSFT | 2021-06-14 16:09:01.592 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:01.592 Triggering next historical data download in queue. | 2021-06-14 16:09:01.592 HD Request # 28 | Downloading Intraday chart data for F.US.ENQM21 to the file F.US.ENQM21.scid. Service: cme | 2021-06-14 16:09:01.592 HD Request # 28 | Download start date-time: 2021-06-14 16:04:00.000000. File last date-time: 2021-06-14 16:04:00.061000 | 2021-06-14 16:09:01.592 HD Request # 28 | Using server: ds23.sierracharts.com port 10150 | 2021-06-14 16:09:01.593 Socket (6) | Creating socket. | 2021-06-14 16:09:01.593 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:09:01.593 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:09:01.593 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:01.632 Socket (4) | Closed. | 2021-06-14 16:09:01.632 HD Request # 28 | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:01.697 HD Request # 28 | Sending historical data logon request message. | 2021-06-14 16:09:01.697 HD Request # 28 | Requesting Intraday data. Start date-time: 2021-06-14 16:04:00. Record interval: 1. Symbol: NQM21 | 2021-06-14 16:09:01.744 HD Request # 28 | Decompressing data. | 2021-06-14 16:09:01.788 HD Request # 28 | Receiving Intraday data for F.US.ENQM21 starting at 2021-06-14 16:04:00.061000 | 2021-06-14 16:09:01.793 Socket (6) | CloseSocket call. | 2021-06-14 16:09:01.794 Historical data download thread signaled to stop. | 2021-06-14 16:09:01.794 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:01.794 HD Request # 28 | Timestamp of first Intraday data file record written: 2021-06-14 16:04:00.061000 | 2021-06-14 16:09:01.794 HD Request # 28 | Received 247 records from 2021-06-14 16:04:00.061000 to 2021-06-14 16:08:58.032000 (5.0 minutes) and wrote 247 records for F.US.ENQM21 | 2021-06-14 16:09:01.794 HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:58.032000 | 2021-06-14 16:09:01.798 HD Request # 28 | Completion time: 0s | 2021-06-14 16:09:01.798 HD Request # 28 | Intraday data download complete for F.US.ENQM21. Unique request ID: 28 | 2021-06-14 16:09:01.798 Removing historical data download ID 28. | 2021-06-14 16:09:01.798 Real-time Intraday chart data file updates started for F.US.ENQM21 | 2021-06-14 16:09:01.798 Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQM21.scid. Thread ID: 3636 | 2021-06-14 16:09:01.799 Intraday chart data file opened for F.US.ENQM21 | 2021-06-14 16:09:01.799 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:01.799 Triggering next historical data download in queue. | 2021-06-14 16:09:01.799 HD Request # 29 | Downloading Intraday chart data for F.US.RTYM21 to the file F.US.RTYM21.scid. Service: cme | 2021-06-14 16:09:01.799 HD Request # 29 | Download start date-time: 2021-06-14 16:03:42.000000. File last date-time: 2021-06-14 16:03:42.967000 | 2021-06-14 16:09:01.799 HD Request # 29 | Using server: ds21.sierracharts.com port 10149 | 2021-06-14 16:09:01.799 Socket (4) | Creating socket. | 2021-06-14 16:09:01.799 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:01.799 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:09:01.799 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:09:01.841 Socket (6) | Closed. | 2021-06-14 16:09:01.841 SC Data - All Services | Received logon response. | 2021-06-14 16:09:01.879 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:01.879 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:01.879 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:01.879 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:01.879 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:09:01.879 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:01.879 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:01.879 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:01.880 HD Request # 29 | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:01.909 HD Request # 29 | Sending historical data logon request message. | 2021-06-14 16:09:01.909 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:09:01.917 DTC Client socket (5) | Closed. | 2021-06-14 16:09:01.917 HD Request # 29 | Requesting Intraday data. Start date-time: 2021-06-14 16:03:42. Record interval: 1. Symbol: RTYM21 | 2021-06-14 16:09:01.963 HD Request # 29 | Decompressing data. | 2021-06-14 16:09:02.010 HD Request # 29 | Receiving Intraday data for F.US.RTYM21 starting at 2021-06-14 16:03:42.967000 | 2021-06-14 16:09:02.010 Socket (4) | CloseSocket call. | 2021-06-14 16:09:02.011 Historical data download thread signaled to stop. | 2021-06-14 16:09:02.011 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:02.011 HD Request # 29 | Timestamp of first Intraday data file record written: 2021-06-14 16:03:42.967000 | 2021-06-14 16:09:02.011 HD Request # 29 | Received 53 records from 2021-06-14 16:03:42.967000 to 2021-06-14 16:08:54.114000 (5.2 minutes) and wrote 53 records for F.US.RTYM21 | 2021-06-14 16:09:02.011 HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:54.114000 | 2021-06-14 16:09:02.016 HD Request # 29 | Completion time: 1s | 2021-06-14 16:09:02.016 HD Request # 29 | Intraday data download complete for F.US.RTYM21. Unique request ID: 29 | 2021-06-14 16:09:02.016 Removing historical data download ID 29. | 2021-06-14 16:09:02.016 Real-time Intraday chart data file updates started for F.US.RTYM21 | 2021-06-14 16:09:02.016 Opened cached Intraday file: C:\SierraChart\Data\F.US.RTYM21.scid. Thread ID: 3636 | 2021-06-14 16:09:02.016 Intraday chart data file opened for F.US.RTYM21 | 2021-06-14 16:09:02.017 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:02.017 Triggering next historical data download in queue. | 2021-06-14 16:09:02.017 HD Request # 30 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2021-06-14 16:09:02.017 HD Request # 30 | Download start date-time: 2021-06-14 16:04:00.000000. File last date-time: 2021-06-14 16:04:00.592000 | 2021-06-14 16:09:02.017 HD Request # 30 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2021-06-14 16:09:02.017 Socket (5) | Creating socket. | 2021-06-14 16:09:02.017 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:09:02.017 Socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:09:02.017 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:02.055 Socket (4) | Closed. | 2021-06-14 16:09:02.055 HD Request # 30 | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:02.117 HD Request # 30 | Sending historical data logon request message. | 2021-06-14 16:09:02.117 HD Request # 30 | Requesting Intraday data. Start date-time: 2021-06-14 16:04:00. Record interval: 1. Symbol: TSLA | 2021-06-14 16:09:02.624 HD Request # 30 | Decompressing data. | 2021-06-14 16:09:02.668 HD Request # 30 | Receiving Intraday data for TSLA starting at 2021-06-14 16:04:00.592000 | 2021-06-14 16:09:02.669 Socket (5) | CloseSocket call. | 2021-06-14 16:09:02.670 Historical data download thread signaled to stop. | 2021-06-14 16:09:02.670 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:02.670 HD Request # 30 | Timestamp of first Intraday data file record written: 2021-06-14 16:04:00.592000 | 2021-06-14 16:09:02.671 HD Request # 30 | Received 187 records from 2021-06-14 16:04:00.592000 to 2021-06-14 16:08:57.057000 (4.9 minutes) and wrote 187 records for TSLA | 2021-06-14 16:09:02.671 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:57.057000 | 2021-06-14 16:09:02.683 HD Request # 30 | Completion time: 0s | 2021-06-14 16:09:02.683 HD Request # 30 | Intraday data download complete for TSLA. Unique request ID: 30 | 2021-06-14 16:09:02.683 Removing historical data download ID 30. | 2021-06-14 16:09:02.683 Real-time Intraday chart data file updates started for TSLA | 2021-06-14 16:09:02.683 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 3636 | 2021-06-14 16:09:02.684 Intraday chart data file opened for TSLA | 2021-06-14 16:09:02.684 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:02.684 Triggering next historical data download in queue. | 2021-06-14 16:09:02.684 HD Request # 31 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2021-06-14 16:09:02.684 HD Request # 31 | Download start date-time: 2021-06-14 16:04:03.000000. File last date-time: 2021-06-14 16:04:03.101000 | 2021-06-14 16:09:02.685 HD Request # 31 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2021-06-14 16:09:02.685 Socket (4) | Creating socket. | 2021-06-14 16:09:02.685 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:02.686 Socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:09:02.686 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:09:02.715 Socket (5) | Closed. | 2021-06-14 16:09:02.715 HD Request # 31 | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:02.780 HD Request # 31 | Sending historical data logon request message. | 2021-06-14 16:09:02.780 HD Request # 31 | Requesting Intraday data. Start date-time: 2021-06-14 16:04:03. Record interval: 1. Symbol: AAPL | 2021-06-14 16:09:02.822 HD Request # 31 | Decompressing data. | 2021-06-14 16:09:02.856 HD Request # 31 | Receiving Intraday data for AAPL starting at 2021-06-14 16:04:03.101000 | 2021-06-14 16:09:02.862 Socket (4) | CloseSocket call. | 2021-06-14 16:09:02.862 Historical data download thread signaled to stop. | 2021-06-14 16:09:02.863 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:02.863 HD Request # 31 | Timestamp of first Intraday data file record written: 2021-06-14 16:04:03.101000 | 2021-06-14 16:09:02.863 HD Request # 31 | Received 263 records from 2021-06-14 16:04:03.101000 to 2021-06-14 16:09:02.709000 (5.0 minutes) and wrote 263 records for AAPL | 2021-06-14 16:09:02.863 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:09:02.709000 | 2021-06-14 16:09:02.868 HD Request # 31 | Completion time: 0s | 2021-06-14 16:09:02.868 HD Request # 31 | Intraday data download complete for AAPL. Unique request ID: 31 | 2021-06-14 16:09:02.868 Removing historical data download ID 31. | 2021-06-14 16:09:02.868 Real-time Intraday chart data file updates started for AAPL | 2021-06-14 16:09:02.868 Opened cached Intraday file: C:\SierraChart\Data\AAPL.scid. Thread ID: 3636 | 2021-06-14 16:09:02.868 Intraday chart data file opened for AAPL | 2021-06-14 16:09:02.868 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:02.868 Triggering next historical data download in queue. | 2021-06-14 16:09:02.868 HD Request # 32 | Downloading Intraday chart data for F.US.CLEN21 to the file F.US.CLEN21.scid. Service: nymex | 2021-06-14 16:09:02.868 HD Request # 32 | Download start date-time: 2021-06-14 16:04:02.000000. File last date-time: 2021-06-14 16:04:02.288000 | 2021-06-14 16:09:02.869 HD Request # 32 | Using server: ds23.sierracharts.com port 10150 | 2021-06-14 16:09:02.869 Socket (5) | Creating socket. | 2021-06-14 16:09:02.869 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:09:02.869 Socket (5) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:09:02.869 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:02.903 Socket (4) | Closed. | 2021-06-14 16:09:02.903 HD Request # 32 | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:02.964 HD Request # 32 | Sending historical data logon request message. | 2021-06-14 16:09:02.964 HD Request # 32 | Requesting Intraday data. Start date-time: 2021-06-14 16:04:02. Record interval: 1. Symbol: CLN21 | 2021-06-14 16:09:03.007 HD Request # 32 | Decompressing data. | 2021-06-14 16:09:03.055 HD Request # 32 | Receiving Intraday data for F.US.CLEN21 starting at 2021-06-14 16:04:02.288000 | 2021-06-14 16:09:03.057 Socket (5) | CloseSocket call. | 2021-06-14 16:09:03.057 Historical data download thread signaled to stop. | 2021-06-14 16:09:03.057 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:03.057 HD Request # 32 | Timestamp of first Intraday data file record written: 2021-06-14 16:04:02.288000 | 2021-06-14 16:09:03.057 HD Request # 32 | Received 117 records from 2021-06-14 16:04:02.288000 to 2021-06-14 16:08:59.982000 (5.0 minutes) and wrote 117 records for F.US.CLEN21 | 2021-06-14 16:09:03.057 HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:59.982000 | 2021-06-14 16:09:03.062 HD Request # 32 | Completion time: 1s | 2021-06-14 16:09:03.062 HD Request # 32 | Intraday data download complete for F.US.CLEN21. Unique request ID: 32 | 2021-06-14 16:09:03.062 Removing historical data download ID 32. | 2021-06-14 16:09:03.062 Real-time Intraday chart data file updates started for F.US.CLEN21 | 2021-06-14 16:09:03.062 Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEN21.scid. Thread ID: 3636 | 2021-06-14 16:09:03.062 Intraday chart data file opened for F.US.CLEN21 | 2021-06-14 16:09:03.062 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:03.062 Triggering next historical data download in queue. | 2021-06-14 16:09:03.062 HD Request # 33 | Downloading Intraday chart data for F.US.MESM21 to the file F.US.MESM21.scid. Service: cme | 2021-06-14 16:09:03.062 HD Request # 33 | Download start date-time: 2021-06-14 16:04:04.000000. File last date-time: 2021-06-14 16:04:04.553000 | 2021-06-14 16:09:03.063 HD Request # 33 | Using server: ds21.sierracharts.com port 10149 | 2021-06-14 16:09:03.063 Socket (4) | Creating socket. | 2021-06-14 16:09:03.063 Socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:03.063 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:09:03.063 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:09:03.103 Socket (5) | Closed. | 2021-06-14 16:09:03.103 HD Request # 33 | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:03.158 HD Request # 33 | Sending historical data logon request message. | 2021-06-14 16:09:03.158 HD Request # 33 | Requesting Intraday data. Start date-time: 2021-06-14 16:04:04. Record interval: 1. Symbol: MESM21 | 2021-06-14 16:09:03.202 HD Request # 33 | Decompressing data. | 2021-06-14 16:09:03.245 HD Request # 33 | Receiving Intraday data for F.US.MESM21 starting at 2021-06-14 16:04:04.553000 | 2021-06-14 16:09:03.245 Socket (4) | CloseSocket call. | 2021-06-14 16:09:03.246 Historical data download thread signaled to stop. | 2021-06-14 16:09:03.246 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:03.246 HD Request # 33 | Timestamp of first Intraday data file record written: 2021-06-14 16:04:04.553000 | 2021-06-14 16:09:03.246 HD Request # 33 | Received 83 records from 2021-06-14 16:04:04.553000 to 2021-06-14 16:08:58.426000 (4.9 minutes) and wrote 83 records for F.US.MESM21 | 2021-06-14 16:09:03.246 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:08:58.426000 | 2021-06-14 16:09:03.253 HD Request # 33 | Completion time: 0s | 2021-06-14 16:09:03.253 HD Request # 33 | Intraday data download complete for F.US.MESM21. Unique request ID: 33 | 2021-06-14 16:09:03.253 Removing historical data download ID 33. | 2021-06-14 16:09:03.253 Real-time Intraday chart data file updates started for F.US.MESM21 | 2021-06-14 16:09:03.253 Opened cached Intraday file: C:\SierraChart\Data\F.US.MESM21.scid. Thread ID: 3636 | 2021-06-14 16:09:03.254 Intraday chart data file opened for F.US.MESM21 | 2021-06-14 16:09:03.254 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:09:03.254 Triggering next historical data download in queue. | 2021-06-14 16:09:03.254 No download requests in the queue to start downloads for. | 2021-06-14 16:09:03.254 Socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:03.295 Socket (4) | Closed. | 2021-06-14 16:09:03.295 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:09:06.877 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:06.877 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:06.877 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:09:06.877 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:06.921 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:06.921 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:06.922 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:06.976 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:06.976 SC Data - All Services | Received logon response. | 2021-06-14 16:09:07.571 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:07.571 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:07.571 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:07.571 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:07.571 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:07.571 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:07.572 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:07.572 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:07.572 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:07.611 DTC Client socket (4) | Closed. | 2021-06-14 16:09:07.611 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:09:12.563 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:12.563 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:12.563 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:09:12.563 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:12.608 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:12.608 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:12.609 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:12.664 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:12.664 SC Data - All Services | Received logon response. | 2021-06-14 16:09:12.818 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:12.818 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:12.818 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:12.818 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:12.818 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:12.818 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:12.818 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:12.819 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:12.819 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:12.861 DTC Client socket (4) | Closed. | 2021-06-14 16:09:12.861 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:09:17.811 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:17.813 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:17.813 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:09:17.813 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:17.858 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:17.858 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:17.858 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:17.911 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:17.911 SC Data - All Services | Received logon response. | 2021-06-14 16:09:18.041 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:18.041 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:18.041 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:18.041 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:18.041 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:18.042 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:18.042 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:18.042 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:18.042 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:18.078 DTC Client socket (4) | Closed. | 2021-06-14 16:09:18.079 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:09:23.029 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:23.030 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:23.030 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:09:23.030 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:23.074 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:23.074 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:23.074 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:23.127 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:23.127 SC Data - All Services | Received logon response. | 2021-06-14 16:09:23.266 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:23.266 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:23.266 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:23.266 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:23.266 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:23.267 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:23.267 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:23.267 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:23.267 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:23.306 DTC Client socket (4) | Closed. | 2021-06-14 16:09:23.306 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:09:28.261 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:28.263 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:28.263 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:09:28.263 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:28.305 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:28.305 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:28.306 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:28.363 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:28.363 SC Data - All Services | Received logon response. | 2021-06-14 16:09:28.501 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:28.501 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:28.501 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:28.501 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:28.501 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:28.501 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:28.501 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:28.501 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:28.501 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:28.544 DTC Client socket (4) | Closed. | 2021-06-14 16:09:28.544 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:09:30.152 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:30.152 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:30.152 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:09:30.152 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:30.205 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:30.205 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:30.205 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:30.276 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:30.276 SC Data - All Services | Received logon response. | 2021-06-14 16:09:30.983 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:30.983 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:30.983 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:30.983 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:30.983 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:30.984 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:30.984 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:09:30.984 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:30.984 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:31.039 DTC Client socket (4) | Closed. | 2021-06-14 16:09:31.039 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:09:33.495 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:33.495 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:33.495 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:09:33.495 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:33.538 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:33.538 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:33.538 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:33.595 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:33.595 SC Data - All Services | Received logon response. | 2021-06-14 16:09:34.203 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:34.203 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:34.203 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:34.203 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:34.203 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:34.204 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:34.204 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:34.204 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:34.204 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:34.245 DTC Client socket (4) | Closed. | 2021-06-14 16:09:34.245 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:09:39.196 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:39.197 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:39.197 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:09:39.197 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:39.241 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:39.241 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:39.241 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:39.286 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:39.286 SC Data - All Services | Received logon response. | 2021-06-14 16:09:39.881 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:39.881 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:39.881 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:39.881 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:39.881 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:39.882 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:39.882 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:39.882 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:39.882 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:39.920 DTC Client socket (4) | Closed. | 2021-06-14 16:09:39.920 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:09:44.867 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:44.868 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:44.868 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:09:44.868 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:44.913 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:44.913 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:44.913 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:44.970 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:44.970 SC Data - All Services | Received logon response. | 2021-06-14 16:09:45.126 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:45.126 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:45.126 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:45.126 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:45.126 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:45.127 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:45.127 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:45.127 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:45.127 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:45.165 DTC Client socket (4) | Closed. | 2021-06-14 16:09:45.165 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:09:50.125 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:50.125 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:50.125 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:09:50.125 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:50.166 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:50.166 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:50.166 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:50.238 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:50.239 SC Data - All Services | Received logon response. | 2021-06-14 16:09:50.391 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:50.391 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:50.391 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:50.391 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:50.391 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:50.392 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:50.392 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:50.392 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:50.392 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:50.428 DTC Client socket (4) | Closed. | 2021-06-14 16:09:50.428 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:09:55.384 DTC Client socket (4) | Creating socket. | 2021-06-14 16:09:55.384 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:09:55.384 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:09:55.384 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:09:55.427 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:09:55.427 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:09:55.427 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:09:55.499 SC Data - All Services | Sending logon request message. | 2021-06-14 16:09:55.499 SC Data - All Services | Received logon response. | 2021-06-14 16:09:55.644 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:09:55.644 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:09:55.644 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:09:55.644 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:09:55.644 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:09:55.645 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:09:55.645 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:09:55.645 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:09:55.645 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:09:55.679 DTC Client socket (4) | Closed. | 2021-06-14 16:09:55.680 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:10:00.629 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:00.630 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:00.630 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:10:00.630 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:00.674 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:00.674 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:00.675 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:00.733 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:00.733 SC Data - All Services | Received logon response. | 2021-06-14 16:10:00.888 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:00.888 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:00.888 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:00.888 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:00.888 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:00.888 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:00.889 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:00.889 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:00.889 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:00.932 DTC Client socket (4) | Closed. | 2021-06-14 16:10:00.932 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-14 16:10:00.988 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:00.989 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:00.989 DTC Client socket (4) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:10:00.989 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:01.046 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:01.046 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:01.046 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:01.120 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:01.120 SC Data - All Services | Received logon response. | 2021-06-14 16:10:01.185 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:01.185 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:01.185 SC Data - All Services | Logon error received from server: Maximum connections reached. | 2021-06-14 16:10:01.185 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:01.185 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:01.186 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:01.186 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-14 16:10:01.186 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:01.186 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:01.236 DTC Client socket (4) | Closed. | 2021-06-14 16:10:01.237 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:10:03.191 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:03.191 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:03.191 DTC Client socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:10:03.191 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:03.240 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:03.240 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:03.240 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:03.301 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:03.301 SC Data - All Services | Received logon response. | 2021-06-14 16:10:04.029 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:04.029 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:04.029 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:04.029 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:04.029 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:04.029 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:04.029 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:10:04.029 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:04.030 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:04.074 DTC Client socket (4) | Closed. | 2021-06-14 16:10:04.075 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:10:05.881 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:05.882 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:05.882 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:10:05.882 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:05.924 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:05.924 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:05.925 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:05.971 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:05.971 SC Data - All Services | Received logon response. | 2021-06-14 16:10:06.784 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:06.784 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:06.784 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:06.784 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:06.784 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:06.785 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:06.785 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:06.785 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:06.785 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:06.828 DTC Client socket (4) | Closed. | 2021-06-14 16:10:06.829 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:10:11.785 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:11.786 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:11.787 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:10:11.787 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:11.838 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:11.838 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:11.838 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:11.904 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:11.904 SC Data - All Services | Received logon response. | 2021-06-14 16:10:12.504 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:12.504 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:12.504 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:12.504 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:12.505 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:12.505 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:12.505 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:12.505 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:12.506 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:12.546 DTC Client socket (4) | Closed. | 2021-06-14 16:10:12.546 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:10:17.506 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:17.507 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:17.507 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:10:17.507 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:17.556 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:17.556 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:17.556 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:17.624 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:17.624 SC Data - All Services | Received logon response. | 2021-06-14 16:10:17.775 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:17.775 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:17.775 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:17.775 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:17.775 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:17.776 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:17.776 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:17.776 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:17.776 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:17.814 DTC Client socket (4) | Closed. | 2021-06-14 16:10:17.814 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:10:22.774 DTC Client socket (5) | Creating socket. | 2021-06-14 16:10:22.775 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:10:22.775 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:10:22.775 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:22.820 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:22.820 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:22.820 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:22.881 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:22.881 SC Data - All Services | Received logon response. | 2021-06-14 16:10:23.039 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:23.039 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:23.039 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:23.039 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:23.039 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:10:23.040 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:23.040 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:23.040 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:23.040 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:10:23.077 DTC Client socket (5) | Closed. | 2021-06-14 16:10:23.077 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:10:28.022 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:28.023 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:28.023 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:10:28.024 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:28.063 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:28.063 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:28.063 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:28.129 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:28.129 SC Data - All Services | Received logon response. | 2021-06-14 16:10:28.282 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:28.282 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:28.282 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:28.282 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:28.282 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:28.282 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:28.282 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:28.282 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:28.282 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:28.321 DTC Client socket (4) | Closed. | 2021-06-14 16:10:28.321 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:10:33.272 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:33.273 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:33.273 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:10:33.273 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:33.317 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:33.317 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:33.317 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:33.365 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:33.365 SC Data - All Services | Received logon response. | 2021-06-14 16:10:33.508 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:33.508 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:33.508 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:33.508 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:33.508 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:33.509 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:33.509 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:33.509 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:33.509 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:33.553 DTC Client socket (4) | Closed. | 2021-06-14 16:10:33.553 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:10:34.022 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:34.023 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:34.024 DTC Client socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:10:34.024 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:34.067 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:34.067 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:34.067 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:34.147 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:34.147 SC Data - All Services | Received logon response. | 2021-06-14 16:10:34.853 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:34.853 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:34.853 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:34.853 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:34.853 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:34.854 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:34.854 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:10:34.854 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:34.854 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:34.900 DTC Client socket (4) | Closed. | 2021-06-14 16:10:34.900 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:10:38.515 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:38.515 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:38.515 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:10:38.515 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:38.569 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:38.569 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:38.569 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:38.629 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:38.629 SC Data - All Services | Received logon response. | 2021-06-14 16:10:39.209 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:39.209 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:39.209 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:39.209 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:39.209 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:39.209 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:39.209 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:39.209 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:39.210 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:39.254 DTC Client socket (4) | Closed. | 2021-06-14 16:10:39.254 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:10:44.206 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:44.207 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:44.207 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:10:44.207 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:44.252 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:44.252 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:44.253 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:44.305 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:44.305 SC Data - All Services | Received logon response. | 2021-06-14 16:10:44.912 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:44.912 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:44.912 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:44.912 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:44.912 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:44.913 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:44.913 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:44.913 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:44.913 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:44.959 DTC Client socket (4) | Closed. | 2021-06-14 16:10:44.959 CQG WebSocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-06-14 16:10:48.674 CQG WebSocket socket (1) | Closed. | 2021-06-14 16:10:48.675 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:10:49.915 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:49.916 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:49.917 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:10:49.917 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:49.965 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:49.965 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:49.965 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:50.033 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:50.033 SC Data - All Services | Received logon response. | 2021-06-14 16:10:50.208 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:50.208 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:50.208 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:50.208 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:50.208 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:50.209 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:50.209 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:50.209 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:50.209 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:50.252 DTC Client socket (4) | Closed. | 2021-06-14 16:10:50.253 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:10:55.192 DTC Client socket (4) | Creating socket. | 2021-06-14 16:10:55.193 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:10:55.194 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:10:55.194 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:10:55.241 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:10:55.241 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:10:55.241 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:10:55.305 SC Data - All Services | Sending logon request message. | 2021-06-14 16:10:55.305 SC Data - All Services | Received logon response. | 2021-06-14 16:10:55.448 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:10:55.448 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:10:55.449 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:10:55.449 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:10:55.449 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:10:55.449 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:10:55.449 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:10:55.449 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:10:55.450 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:10:55.493 DTC Client socket (4) | Closed. | 2021-06-14 16:10:55.493 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:11:00.451 DTC Client socket (4) | Creating socket. | 2021-06-14 16:11:00.452 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:11:00.452 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:11:00.452 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:00.500 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:00.500 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:00.500 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:00.566 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:00.566 SC Data - All Services | Received logon response. | 2021-06-14 16:11:00.709 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:00.709 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:00.709 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:00.709 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:00.709 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:11:00.710 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:00.710 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:00.710 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:00.710 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:11:00.753 DTC Client socket (4) | Closed. | 2021-06-14 16:11:00.754 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:11:04.858 DTC Client socket (4) | Creating socket. | 2021-06-14 16:11:04.859 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:11:04.859 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:11:04.859 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:04.923 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:04.923 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:04.923 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:04.995 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:04.995 SC Data - All Services | Received logon response. | 2021-06-14 16:11:05.701 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:05.701 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:05.701 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:05.701 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:05.701 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:11:05.701 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:05.701 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:11:05.701 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:05.702 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:11:05.717 DTC Client socket (5) | Creating socket. | 2021-06-14 16:11:05.718 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:11:05.718 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:11:05.719 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:11:05.759 DTC Client socket (4) | Closed. | 2021-06-14 16:11:05.759 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:05.760 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:05.760 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:05.760 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:05.804 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:05.804 SC Data - All Services | Received logon response. | 2021-06-14 16:11:05.952 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:05.952 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:05.952 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:05.952 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:05.952 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:11:05.953 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:05.953 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:05.953 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:05.953 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:11:05.998 DTC Client socket (5) | Closed. | 2021-06-14 16:11:05.998 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:11:10.956 DTC Client socket (4) | Creating socket. | 2021-06-14 16:11:10.957 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:11:10.957 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:11:10.957 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:11.013 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:11.013 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:11.014 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:11.063 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:11.063 SC Data - All Services | Received logon response. | 2021-06-14 16:11:11.690 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:11.690 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:11.690 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:11.690 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:11.690 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:11:11.691 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:11.691 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:11.691 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:11.691 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:11:11.730 DTC Client socket (4) | Closed. | 2021-06-14 16:11:11.730 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:11:16.685 DTC Client socket (4) | Creating socket. | 2021-06-14 16:11:16.686 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:11:16.686 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:11:16.686 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:16.743 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:16.743 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:16.743 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:16.818 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:16.818 SC Data - All Services | Received logon response. | 2021-06-14 16:11:17.443 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:17.443 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:17.443 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:17.443 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:17.443 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:11:17.444 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:17.444 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:17.444 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:17.444 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:11:17.530 DTC Client socket (4) | Closed. | 2021-06-14 16:11:17.530 CQG WebSocket socket (1) | Deleting network socket now after delay. | 2021-06-14 16:11:18.680 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:11:22.452 DTC Client socket (4) | Creating socket. | 2021-06-14 16:11:22.454 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:11:22.454 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:11:22.454 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:22.497 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:22.497 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:22.497 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:22.570 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:22.570 SC Data - All Services | Received logon response. | 2021-06-14 16:11:22.735 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:22.735 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:22.736 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:22.736 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:22.736 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:11:22.736 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:22.736 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:22.736 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:22.736 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:11:22.780 DTC Client socket (4) | Closed. | 2021-06-14 16:11:22.780 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:11:27.730 DTC Client socket (1) | Creating socket. | 2021-06-14 16:11:27.731 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:11:27.731 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:11:27.731 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:27.786 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:27.786 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:27.786 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:27.851 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:27.851 SC Data - All Services | Received logon response. | 2021-06-14 16:11:28.007 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:28.007 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:28.007 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:28.007 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:28.007 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:11:28.008 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:28.008 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:28.008 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:28.008 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:11:28.068 DTC Client socket (1) | Closed. | 2021-06-14 16:11:28.068 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:11:33.004 DTC Client socket (1) | Creating socket. | 2021-06-14 16:11:33.005 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:11:33.005 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:11:33.005 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:33.070 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:33.070 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:33.070 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:33.142 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:33.142 SC Data - All Services | Received logon response. | 2021-06-14 16:11:33.255 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:33.255 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:33.255 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:33.255 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:33.255 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:11:33.255 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:33.255 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:33.255 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:33.255 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:11:33.300 DTC Client socket (1) | Closed. | 2021-06-14 16:11:33.300 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-14 16:11:35.693 DTC Client socket (1) | Creating socket. | 2021-06-14 16:11:35.694 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:11:35.694 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:11:35.694 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:35.746 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:35.746 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:35.746 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:35.824 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:35.824 SC Data - All Services | Received logon response. | 2021-06-14 16:11:35.888 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:35.888 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:35.888 SC Data - All Services | Logon error received from server: Maximum connections reached. | 2021-06-14 16:11:35.888 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:35.889 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:11:35.890 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:35.890 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:35.890 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-14 16:11:35.890 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:11:35.990 DTC Client socket (1) | Closed. | 2021-06-14 16:11:35.990 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:11:37.883 DTC Client socket (1) | Creating socket. | 2021-06-14 16:11:37.884 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:11:37.885 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:11:37.885 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:37.930 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:37.930 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:37.930 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:37.996 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:37.996 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:11:38.246 DTC Client socket (4) | Creating socket. | 2021-06-14 16:11:38.246 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:11:38.246 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:11:38.246 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:38.286 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:38.286 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:38.286 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:38.337 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:38.337 SC Data - All Services | Received logon response. | 2021-06-14 16:11:38.481 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:38.481 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:38.481 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:38.481 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:38.481 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:11:38.482 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:38.482 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:38.482 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:38.482 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:11:38.519 DTC Client socket (4) | Closed. | 2021-06-14 16:11:38.519 SC Data - All Services | Received logon response. | 2021-06-14 16:11:38.702 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:38.702 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:38.702 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:38.702 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:38.702 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:11:38.703 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:38.703 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:11:38.703 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:38.703 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:11:38.745 DTC Client socket (1) | Closed. | 2021-06-14 16:11:38.745 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:11:43.477 DTC Client socket (1) | Creating socket. | 2021-06-14 16:11:43.477 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:11:43.478 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:11:43.478 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:43.523 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:43.523 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:43.523 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:43.595 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:43.595 SC Data - All Services | Received logon response. | 2021-06-14 16:11:44.226 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:44.226 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:44.226 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:44.226 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:44.226 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:11:44.226 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:44.226 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:44.226 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:44.226 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:11:44.274 DTC Client socket (1) | Closed. | 2021-06-14 16:11:44.274 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:11:49.231 DTC Client socket (1) | Creating socket. | 2021-06-14 16:11:49.232 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:11:49.232 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:11:49.232 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:49.274 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:49.275 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:49.275 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:49.342 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:49.342 SC Data - All Services | Received logon response. | 2021-06-14 16:11:49.954 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:49.954 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:49.954 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:49.954 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:49.954 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:11:49.955 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:49.955 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:49.955 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:49.955 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:11:49.999 DTC Client socket (1) | Closed. | 2021-06-14 16:11:49.999 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:11:54.942 DTC Client socket (1) | Creating socket. | 2021-06-14 16:11:54.943 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:11:54.943 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:11:54.943 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:11:54.988 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:11:54.988 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:11:54.988 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:11:55.034 SC Data - All Services | Sending logon request message. | 2021-06-14 16:11:55.034 SC Data - All Services | Received logon response. | 2021-06-14 16:11:55.197 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:11:55.197 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:11:55.197 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:11:55.197 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:11:55.197 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:11:55.198 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:11:55.198 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:11:55.198 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:11:55.198 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:11:55.236 DTC Client socket (1) | Closed. | 2021-06-14 16:11:55.236 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:12:00.207 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:00.207 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:00.207 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:12:00.207 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:00.253 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:00.253 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:00.253 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:00.303 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:00.303 SC Data - All Services | Received logon response. | 2021-06-14 16:12:00.446 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:00.446 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:00.446 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:00.446 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:00.446 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:00.447 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:00.447 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:00.447 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:00.447 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:00.487 DTC Client socket (1) | Closed. | 2021-06-14 16:12:00.487 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:12:05.441 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:05.442 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:05.442 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:12:05.442 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:05.490 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:05.490 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:05.490 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:05.568 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:05.568 SC Data - All Services | Received logon response. | 2021-06-14 16:12:05.726 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:05.726 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:05.726 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:05.726 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:05.727 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:05.727 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:05.727 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:05.727 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:05.728 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:05.775 DTC Client socket (1) | Closed. | 2021-06-14 16:12:05.775 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:12:08.695 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:08.696 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:08.696 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:12:08.696 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:08.739 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:08.739 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:08.739 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:08.813 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:08.813 SC Data - All Services | Received logon response. | 2021-06-14 16:12:09.517 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:09.517 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:09.517 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:09.517 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:09.517 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:09.517 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:09.517 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:12:09.517 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:09.517 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:09.563 DTC Client socket (1) | Closed. | 2021-06-14 16:12:09.563 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:12:10.708 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:10.709 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:10.709 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:12:10.709 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:10.756 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:10.756 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:10.756 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:10.836 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:10.836 SC Data - All Services | Received logon response. | 2021-06-14 16:12:10.975 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:10.975 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:10.975 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:10.975 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:10.975 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:10.975 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:10.975 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:10.975 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:10.976 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:11.019 DTC Client socket (1) | Closed. | 2021-06-14 16:12:11.019 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:12:15.975 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:15.976 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:15.977 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:12:15.977 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:16.027 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:16.027 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:16.027 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:16.096 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:16.096 SC Data - All Services | Received logon response. | 2021-06-14 16:12:16.721 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:16.721 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:16.721 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:16.721 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:16.721 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:16.721 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:16.721 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:16.721 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:16.721 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:16.764 DTC Client socket (1) | Closed. | 2021-06-14 16:12:16.764 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:12:21.716 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:21.717 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:21.717 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:12:21.717 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:21.759 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:21.759 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:21.759 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:21.809 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:21.809 SC Data - All Services | Received logon response. | 2021-06-14 16:12:22.450 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:22.450 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:22.450 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:22.450 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:22.450 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:22.450 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:22.451 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:22.451 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:22.451 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:22.487 DTC Client socket (1) | Closed. | 2021-06-14 16:12:22.487 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:12:27.454 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:27.455 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:27.455 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:12:27.455 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:27.503 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:27.503 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:27.503 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:27.563 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:27.563 SC Data - All Services | Received logon response. | 2021-06-14 16:12:27.696 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:27.696 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:27.696 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:27.696 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:27.696 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:27.697 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:27.697 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:27.697 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:27.697 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:27.736 DTC Client socket (1) | Closed. | 2021-06-14 16:12:27.736 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:12:32.695 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:32.696 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:32.696 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:12:32.696 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:32.749 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:32.749 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:32.749 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:32.812 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:32.812 SC Data - All Services | Received logon response. | 2021-06-14 16:12:32.951 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:32.952 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:32.952 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:32.952 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:32.952 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:32.952 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:32.952 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:32.952 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:32.953 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:32.996 DTC Client socket (1) | Closed. | 2021-06-14 16:12:32.996 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:12:37.953 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:37.953 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:37.953 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:12:37.953 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:37.998 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:37.998 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:37.998 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:38.063 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:38.063 SC Data - All Services | Received logon response. | 2021-06-14 16:12:38.204 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:38.204 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:38.204 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:38.204 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:38.205 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:38.205 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:38.205 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:38.205 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:38.205 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:38.244 DTC Client socket (1) | Closed. | 2021-06-14 16:12:38.244 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:12:39.512 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:39.514 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:39.514 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:12:39.514 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:39.568 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:39.568 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:39.568 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:39.648 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:39.648 SC Data - All Services | Received logon response. | 2021-06-14 16:12:40.368 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:40.368 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:40.368 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:40.368 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:40.368 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:40.369 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:40.369 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:12:40.369 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:40.369 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:40.427 DTC Client socket (1) | Closed. | 2021-06-14 16:12:40.427 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:12:43.195 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:43.196 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:43.196 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:12:43.196 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:43.241 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:43.241 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:43.241 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:43.313 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:43.313 SC Data - All Services | Received logon response. | 2021-06-14 16:12:43.451 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:43.451 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:43.451 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:43.451 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:43.451 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:43.452 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:43.452 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:43.452 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:43.452 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:43.488 DTC Client socket (1) | Closed. | 2021-06-14 16:12:43.488 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:12:48.452 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:48.453 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:48.454 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:12:48.454 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:48.495 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:48.495 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:48.495 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:48.561 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:48.561 SC Data - All Services | Received logon response. | 2021-06-14 16:12:49.173 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:49.173 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:49.173 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:49.173 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:49.173 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:49.174 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:49.174 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:49.174 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:49.174 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:49.213 DTC Client socket (1) | Closed. | 2021-06-14 16:12:49.213 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:12:54.166 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:54.167 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:54.167 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:12:54.167 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:54.208 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:54.208 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:54.208 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:12:54.261 SC Data - All Services | Sending logon request message. | 2021-06-14 16:12:54.261 SC Data - All Services | Received logon response. | 2021-06-14 16:12:54.889 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:12:54.889 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:12:54.889 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:12:54.889 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:12:54.889 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:12:54.890 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:12:54.890 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:12:54.890 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:12:54.890 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:12:54.935 DTC Client socket (1) | Closed. | 2021-06-14 16:12:54.935 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:12:59.894 DTC Client socket (1) | Creating socket. | 2021-06-14 16:12:59.896 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:12:59.896 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:12:59.896 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:12:59.940 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:12:59.940 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:12:59.941 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:00.000 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:00.000 SC Data - All Services | Received logon response. | 2021-06-14 16:13:00.155 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:00.155 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:00.155 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:00.155 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:00.155 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:00.156 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:00.156 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:00.156 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:00.156 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:00.193 DTC Client socket (1) | Closed. | 2021-06-14 16:13:00.193 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:13:05.155 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:05.156 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:05.156 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:13:05.156 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:05.200 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:05.200 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:05.200 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:05.262 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:05.262 SC Data - All Services | Received logon response. | 2021-06-14 16:13:05.412 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:05.412 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:05.413 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:05.413 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:05.413 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:05.413 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:05.413 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:05.413 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:05.414 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:05.453 DTC Client socket (1) | Closed. | 2021-06-14 16:13:05.453 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-14 16:13:10.373 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:10.374 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:10.374 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:13:10.374 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:13:10.404 DTC Client socket (4) | Creating socket. | 2021-06-14 16:13:10.405 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:13:10.405 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:13:10.405 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:10.428 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:10.428 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:10.429 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:10.449 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:10.449 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:10.449 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:10.501 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:10.501 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:10.501 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:10.502 SC Data - All Services | Received logon response. | 2021-06-14 16:13:10.643 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:10.643 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:10.643 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:10.643 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:10.643 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:13:10.644 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:10.644 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:10.644 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:10.644 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:13:10.681 DTC Client socket (4) | Closed. | 2021-06-14 16:13:10.681 SC Data - All Services | Received logon response. | 2021-06-14 16:13:11.289 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:11.289 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:11.289 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:11.289 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:11.289 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:11.290 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:11.290 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:13:11.290 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:11.290 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:11.340 DTC Client socket (1) | Closed. | 2021-06-14 16:13:11.340 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:13:15.637 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:15.638 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:15.639 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:13:15.639 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:15.694 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:15.694 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:15.694 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:15.744 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:15.744 SC Data - All Services | Received logon response. | 2021-06-14 16:13:15.887 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:15.887 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:15.887 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:15.887 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:15.887 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:15.888 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:15.888 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:15.888 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:15.888 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:15.925 DTC Client socket (1) | Closed. | 2021-06-14 16:13:15.925 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:13:20.886 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:20.887 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:20.887 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:13:20.887 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:20.934 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:20.934 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:20.934 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:21.003 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:21.003 SC Data - All Services | Received logon response. | 2021-06-14 16:13:21.627 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:21.627 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:21.627 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:21.627 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:21.627 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:21.627 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:21.627 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:21.627 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:21.628 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:21.673 DTC Client socket (1) | Closed. | 2021-06-14 16:13:21.673 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:13:26.619 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:26.620 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:26.620 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:13:26.620 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:26.664 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:26.664 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:26.664 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:26.726 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:26.727 SC Data - All Services | Received logon response. | 2021-06-14 16:13:27.322 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:27.322 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:27.322 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:27.322 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:27.322 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:27.323 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:27.323 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:27.323 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:27.323 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:27.373 DTC Client socket (1) | Closed. | 2021-06-14 16:13:27.374 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:13:32.321 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:32.322 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:32.322 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:13:32.322 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:32.367 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:32.367 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:32.367 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:32.438 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:32.438 SC Data - All Services | Received logon response. | 2021-06-14 16:13:32.539 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:32.539 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:32.539 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:32.539 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:32.539 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:32.539 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:32.539 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:32.539 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:32.540 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:32.579 DTC Client socket (1) | Closed. | 2021-06-14 16:13:32.579 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:13:37.538 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:37.539 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:37.539 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:13:37.539 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:37.584 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:37.584 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:37.584 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:37.641 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:37.641 SC Data - All Services | Received logon response. | 2021-06-14 16:13:37.782 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:37.783 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:37.783 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:37.783 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:37.783 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:37.783 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:37.783 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:37.783 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:37.784 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:37.825 DTC Client socket (1) | Closed. | 2021-06-14 16:13:37.825 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2021-06-14 16:13:41.272 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:41.272 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:41.273 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:13:41.273 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:41.319 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:41.319 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:41.319 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:41.394 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:41.394 SC Data - All Services | Received logon response. | 2021-06-14 16:13:42.098 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:42.098 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:42.098 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:42.098 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:42.098 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:42.099 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:42.099 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:13:42.099 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:42.099 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:42.153 DTC Client socket (1) | Closed. | 2021-06-14 16:13:42.153 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:13:42.772 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:42.773 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:42.773 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:13:42.773 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:42.819 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:42.819 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:42.819 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:42.876 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:42.876 SC Data - All Services | Received logon response. | 2021-06-14 16:13:43.023 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:43.023 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:43.023 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:43.023 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:43.023 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:43.023 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:43.024 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:43.024 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:43.024 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:43.059 DTC Client socket (1) | Closed. | 2021-06-14 16:13:43.060 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:13:48.025 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:48.026 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:48.026 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:13:48.026 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:48.071 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:48.071 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:48.072 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:48.142 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:48.142 SC Data - All Services | Received logon response. | 2021-06-14 16:13:48.284 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:48.284 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:48.284 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:48.284 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:48.284 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:48.285 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:48.285 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:48.285 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:48.285 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:48.322 DTC Client socket (1) | Closed. | 2021-06-14 16:13:48.322 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:13:53.280 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:53.280 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:53.280 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:13:53.280 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:53.333 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:53.333 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:53.333 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:53.407 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:53.407 SC Data - All Services | Received logon response. | 2021-06-14 16:13:53.984 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:53.984 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:53.985 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:53.985 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:53.985 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:53.985 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:53.985 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:53.985 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:53.985 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:54.031 DTC Client socket (1) | Closed. | 2021-06-14 16:13:54.031 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:13:58.980 DTC Client socket (1) | Creating socket. | 2021-06-14 16:13:58.980 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:13:58.980 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:13:58.980 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:13:59.029 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:13:59.029 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:13:59.030 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:13:59.100 SC Data - All Services | Sending logon request message. | 2021-06-14 16:13:59.100 SC Data - All Services | Received logon response. | 2021-06-14 16:13:59.697 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:13:59.697 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:13:59.697 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:13:59.697 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:13:59.697 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:13:59.698 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:13:59.698 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:13:59.698 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:13:59.698 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:13:59.746 DTC Client socket (1) | Closed. | 2021-06-14 16:13:59.746 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:14:04.687 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:04.689 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:04.689 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:14:04.689 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:04.732 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:04.732 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:04.733 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:04.782 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:04.782 SC Data - All Services | Received logon response. | 2021-06-14 16:14:04.921 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:04.921 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:04.921 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:04.921 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:04.921 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:04.922 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:04.922 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:04.922 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:04.922 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:04.962 DTC Client socket (1) | Closed. | 2021-06-14 16:14:04.962 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:14:09.921 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:09.923 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:09.923 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:14:09.923 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:09.969 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:09.969 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:09.969 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:10.027 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:10.027 SC Data - All Services | Received logon response. | 2021-06-14 16:14:10.164 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:10.164 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:10.164 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:10.164 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:10.164 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:10.164 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:10.164 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:10.164 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:10.165 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:10.202 DTC Client socket (1) | Closed. | 2021-06-14 16:14:10.202 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-06-14 16:14:12.083 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:12.083 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:12.083 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:14:12.083 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:12.132 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:12.132 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:12.132 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:12.198 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:12.198 SC Data - All Services | Received logon response. | 2021-06-14 16:14:12.901 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:12.901 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:12.901 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:12.901 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:12.901 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:12.902 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:12.902 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:14:12.902 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:12.902 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:12.944 DTC Client socket (1) | Closed. | 2021-06-14 16:14:12.944 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:14:15.146 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:15.147 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:15.147 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:14:15.147 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:15.191 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:15.191 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:15.191 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:15.256 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:15.256 SC Data - All Services | Received logon response. | 2021-06-14 16:14:15.394 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:15.394 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:15.394 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:15.394 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:15.394 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:15.394 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:15.394 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:15.394 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:15.394 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:15.436 DTC Client socket (1) | Closed. | 2021-06-14 16:14:15.436 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:14:20.385 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:20.385 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:20.385 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:14:20.385 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:20.425 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:20.425 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:20.425 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:20.472 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:20.472 SC Data - All Services | Received logon response. | 2021-06-14 16:14:20.597 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:20.597 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:20.597 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:20.597 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:20.597 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:20.598 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:20.598 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:20.598 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:20.598 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:20.634 DTC Client socket (1) | Closed. | 2021-06-14 16:14:20.634 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:14:25.597 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:25.597 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:25.597 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:14:25.597 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:25.646 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:25.646 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:25.646 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:25.687 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:25.687 SC Data - All Services | Received logon response. | 2021-06-14 16:14:26.296 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:26.296 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:26.297 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:26.297 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:26.297 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:26.297 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:26.297 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:26.297 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:26.297 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:26.340 DTC Client socket (1) | Closed. | 2021-06-14 16:14:26.340 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:14:31.292 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:31.293 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:31.293 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:14:31.293 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:31.356 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:31.356 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:31.356 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:31.518 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:31.518 SC Data - All Services | Received logon response. | 2021-06-14 16:14:32.150 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:32.150 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:32.150 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:32.150 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:32.150 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:32.151 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:32.151 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:32.151 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:32.151 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:32.262 DTC Client socket (1) | Closed. | 2021-06-14 16:14:32.262 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:14:37.157 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:37.158 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:37.158 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:14:37.158 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:37.203 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:37.203 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:37.203 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:37.249 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:37.249 SC Data - All Services | Received logon response. | 2021-06-14 16:14:37.406 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:37.406 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:37.406 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:37.406 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:37.406 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:37.407 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:37.407 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:37.407 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:37.407 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:37.447 DTC Client socket (1) | Closed. | 2021-06-14 16:14:37.447 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:14:42.403 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:42.404 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:42.405 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:14:42.405 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:42.449 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:42.449 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:42.449 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:42.520 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:42.520 SC Data - All Services | Received logon response. | 2021-06-14 16:14:42.672 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:42.672 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:42.672 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:42.672 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:42.672 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:42.673 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:42.673 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:42.673 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:42.673 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:42.718 DTC Client socket (1) | Closed. | 2021-06-14 16:14:42.718 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:14:42.892 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:42.892 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:42.892 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:14:42.892 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:42.944 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:42.944 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:42.944 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:43.023 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:43.023 SC Data - All Services | Received logon response. | 2021-06-14 16:14:43.744 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:43.744 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:43.744 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:43.744 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:43.744 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:43.744 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:43.744 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:14:43.744 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:43.744 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:43.801 DTC Client socket (1) | Closed. | 2021-06-14 16:14:43.801 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:14:47.669 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:47.670 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:47.670 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:14:47.670 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:47.713 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:47.713 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:47.713 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:47.787 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:47.787 SC Data - All Services | Received logon response. | 2021-06-14 16:14:47.957 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:47.957 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:47.958 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:47.958 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:47.958 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:47.959 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:47.959 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:47.959 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:47.959 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:47.997 DTC Client socket (1) | Closed. | 2021-06-14 16:14:47.997 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:14:52.972 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:52.973 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:52.973 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:14:52.973 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:53.020 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:53.020 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:53.020 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:53.077 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:53.077 SC Data - All Services | Received logon response. | 2021-06-14 16:14:53.232 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:53.232 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:53.232 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:53.232 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:53.232 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:53.232 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:53.232 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:53.232 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:53.233 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:53.270 DTC Client socket (1) | Closed. | 2021-06-14 16:14:53.270 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:14:58.227 DTC Client socket (1) | Creating socket. | 2021-06-14 16:14:58.227 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:14:58.227 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:14:58.227 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:14:58.269 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:14:58.269 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:14:58.269 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:14:58.353 SC Data - All Services | Sending logon request message. | 2021-06-14 16:14:58.353 SC Data - All Services | Received logon response. | 2021-06-14 16:14:58.986 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:14:58.986 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:14:58.986 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:14:58.986 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:14:58.986 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:14:58.986 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:14:58.986 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:14:58.986 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:14:58.986 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:14:59.028 DTC Client socket (1) | Closed. | 2021-06-14 16:14:59.028 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:15:03.984 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:03.984 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:03.984 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:15:03.984 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:04.025 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:04.025 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:04.025 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:04.073 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:04.073 SC Data - All Services | Received logon response. | 2021-06-14 16:15:04.719 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:04.719 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:04.719 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:04.719 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:04.719 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:04.720 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:04.720 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:04.720 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:04.720 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:04.765 DTC Client socket (1) | Closed. | 2021-06-14 16:15:04.765 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:15:09.716 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:09.716 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:09.717 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:15:09.717 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:09.761 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:09.761 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:09.761 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:09.815 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:09.815 SC Data - All Services | Received logon response. | 2021-06-14 16:15:09.977 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:09.977 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:09.977 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:09.977 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:09.977 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:09.978 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:09.978 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:09.978 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:09.978 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:10.017 DTC Client socket (1) | Closed. | 2021-06-14 16:15:10.017 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:15:13.748 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:13.749 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:13.749 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:15:13.749 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:13.802 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:13.802 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:13.802 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:13.867 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:13.867 SC Data - All Services | Received logon response. | 2021-06-14 16:15:14.645 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:14.645 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:14.645 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:14.645 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:14.645 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:14.646 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:14.646 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:15:14.646 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:14.646 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:14.696 DTC Client socket (1) | Closed. | 2021-06-14 16:15:14.696 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:15:14.960 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:14.961 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:14.961 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:15:14.961 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:15.006 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:15.006 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:15.006 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:15.057 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:15.057 SC Data - All Services | Received logon response. | 2021-06-14 16:15:15.199 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:15.199 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:15.199 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:15.199 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:15.199 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:15.200 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:15.200 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:15.200 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:15.200 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:15.238 DTC Client socket (1) | Closed. | 2021-06-14 16:15:15.238 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:15:20.179 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:20.179 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:20.179 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:15:20.179 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:20.221 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:20.221 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:20.221 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:20.284 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:20.284 SC Data - All Services | Received logon response. | 2021-06-14 16:15:20.408 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:20.408 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:20.408 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:20.409 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:20.409 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:20.409 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:20.409 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:20.409 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:20.410 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:20.451 DTC Client socket (1) | Closed. | 2021-06-14 16:15:20.451 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:15:25.404 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:25.405 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:25.406 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:15:25.406 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:25.451 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:25.451 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:25.451 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:25.497 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:25.497 SC Data - All Services | Received logon response. | 2021-06-14 16:15:25.639 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:25.639 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:25.639 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:25.639 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:25.639 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:25.639 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:25.639 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:25.640 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:25.640 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:25.678 DTC Client socket (1) | Closed. | 2021-06-14 16:15:25.678 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:15:30.635 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:30.636 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:30.636 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:15:30.637 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:30.682 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:30.682 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:30.682 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:30.751 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:30.751 SC Data - All Services | Received logon response. | 2021-06-14 16:15:31.362 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:31.362 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:31.362 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:31.362 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:31.362 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:31.362 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:31.362 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:31.362 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:31.362 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:31.404 DTC Client socket (1) | Closed. | 2021-06-14 16:15:31.404 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:15:36.356 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:36.356 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:36.356 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:15:36.356 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:36.404 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:36.405 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:36.405 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:36.454 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:36.454 SC Data - All Services | Received logon response. | 2021-06-14 16:15:37.069 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:37.069 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:37.069 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:37.069 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:37.069 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:37.070 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:37.070 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:37.070 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:37.070 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:37.110 DTC Client socket (1) | Closed. | 2021-06-14 16:15:37.110 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:15:42.059 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:42.060 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:42.060 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:15:42.060 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:42.104 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:42.104 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:42.104 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:42.157 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:42.157 SC Data - All Services | Received logon response. | 2021-06-14 16:15:42.314 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:42.314 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:42.314 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:42.314 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:42.314 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:42.314 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:42.314 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:42.314 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:42.315 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:42.355 DTC Client socket (1) | Closed. | 2021-06-14 16:15:42.355 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2021-06-14 16:15:44.645 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:44.646 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:44.646 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:15:44.646 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:44.693 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:44.693 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:44.693 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:44.742 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:44.742 SC Data - All Services | Received logon response. | 2021-06-14 16:15:45.430 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:45.430 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:45.430 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:45.430 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:45.430 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:45.431 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:45.431 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:15:45.431 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:45.431 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:45.473 DTC Client socket (1) | Closed. | 2021-06-14 16:15:45.473 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:15:47.306 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:47.307 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:47.307 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:15:47.307 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:47.350 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:47.350 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:47.350 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:47.395 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:47.395 SC Data - All Services | Received logon response. | 2021-06-14 16:15:47.536 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:47.536 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:47.536 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:47.536 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:47.536 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:47.537 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:47.537 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:47.537 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:47.537 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:47.576 DTC Client socket (1) | Closed. | 2021-06-14 16:15:47.576 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:15:52.529 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:52.531 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:52.531 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:15:52.531 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:52.575 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:52.575 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:52.575 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:52.625 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:52.625 SC Data - All Services | Received logon response. | 2021-06-14 16:15:52.781 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:52.781 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:52.781 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:52.781 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:52.781 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:52.781 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:52.781 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:52.781 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:52.781 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:52.820 DTC Client socket (1) | Closed. | 2021-06-14 16:15:52.820 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:15:57.778 DTC Client socket (1) | Creating socket. | 2021-06-14 16:15:57.779 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:15:57.779 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:15:57.779 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:15:57.832 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:15:57.832 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:15:57.832 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:15:57.889 SC Data - All Services | Sending logon request message. | 2021-06-14 16:15:57.889 SC Data - All Services | Received logon response. | 2021-06-14 16:15:58.046 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:15:58.046 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:15:58.046 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:15:58.046 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:15:58.046 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:15:58.047 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:15:58.047 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:15:58.047 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:15:58.047 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:15:58.086 DTC Client socket (1) | Closed. | 2021-06-14 16:15:58.086 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:16:03.044 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:03.045 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:03.045 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:16:03.045 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:03.094 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:03.094 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:03.095 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:03.156 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:03.156 SC Data - All Services | Received logon response. | 2021-06-14 16:16:03.768 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:03.768 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:03.768 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:03.768 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:03.768 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:03.769 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:03.769 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:03.769 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:03.769 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:03.812 DTC Client socket (1) | Closed. | 2021-06-14 16:16:03.812 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:16:08.769 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:08.770 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:08.770 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:16:08.770 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:08.814 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:08.814 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:08.814 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:08.888 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:08.888 SC Data - All Services | Received logon response. | 2021-06-14 16:16:09.512 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:09.512 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:09.512 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:09.512 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:09.512 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:09.513 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:09.513 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:09.513 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:09.513 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:09.557 DTC Client socket (1) | Closed. | 2021-06-14 16:16:09.557 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:16:14.505 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:14.506 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:14.506 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:16:14.506 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:14.550 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:14.550 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:14.550 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:14.626 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:14.626 SC Data - All Services | Received logon response. | 2021-06-14 16:16:14.753 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:14.753 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:14.753 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:14.753 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:14.753 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:14.753 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:14.753 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:14.753 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:14.754 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:14.793 DTC Client socket (1) | Closed. | 2021-06-14 16:16:14.793 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-06-14 16:16:15.437 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:15.438 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:15.438 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:16:15.438 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:15.491 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:15.491 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:15.491 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:15.544 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:15.544 SC Data - All Services | Received logon response. | 2021-06-14 16:16:16.251 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:16.251 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:16.251 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:16.251 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:16.251 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:16.252 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:16.252 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:16:16.252 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:16.252 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:16.308 DTC Client socket (1) | Closed. | 2021-06-14 16:16:16.308 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:16:19.739 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:19.739 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:19.739 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:16:19.739 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:19.783 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:19.783 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:19.784 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:19.842 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:19.842 SC Data - All Services | Received logon response. | 2021-06-14 16:16:19.949 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:19.949 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:19.949 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:19.949 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:19.949 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:19.950 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:19.950 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:19.950 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:19.951 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:19.991 DTC Client socket (1) | Closed. | 2021-06-14 16:16:19.991 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:16:24.956 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:24.957 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:24.958 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:16:24.958 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:25.003 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:25.003 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:25.003 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:25.064 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:25.064 SC Data - All Services | Received logon response. | 2021-06-14 16:16:25.205 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:25.205 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:25.205 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:25.205 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:25.205 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:25.206 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:25.206 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:25.206 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:25.206 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:25.244 DTC Client socket (1) | Closed. | 2021-06-14 16:16:25.244 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:16:30.200 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:30.201 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:30.201 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:16:30.201 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:30.240 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:30.240 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:30.240 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:30.288 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:30.288 SC Data - All Services | Received logon response. | 2021-06-14 16:16:30.442 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:30.442 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:30.442 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:30.442 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:30.442 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:30.443 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:30.443 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:30.443 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:30.443 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:30.480 DTC Client socket (1) | Closed. | 2021-06-14 16:16:30.480 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:16:35.439 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:35.440 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:35.440 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:16:35.440 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:35.485 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:35.485 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:35.485 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:35.533 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:35.533 SC Data - All Services | Received logon response. | 2021-06-14 16:16:36.143 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:36.143 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:36.143 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:36.143 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:36.144 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:36.144 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:36.144 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:36.144 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:36.145 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:36.184 DTC Client socket (1) | Closed. | 2021-06-14 16:16:36.185 The message log has been sent to support. | 2021-06-14 16:16:37.402 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2021-06-14 16:16:37.402 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2021-06-14 16:16:37.403 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 95.216.233.104. | 2021-06-14 16:16:37.403 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2021-06-14 16:16:39.107 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2021-06-14 16:16:39.354 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:39.355 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:39.488 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-06-14 16:16:39.488 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:16:41.144 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:41.144 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:41.144 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:16:41.144 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:41.185 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:41.185 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:41.186 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:41.242 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:41.242 SC Data - All Services | Received logon response. | 2021-06-14 16:16:41.855 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:41.855 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:41.855 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:41.855 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:41.855 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:41.855 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:41.855 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:41.855 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:41.855 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:41.895 DTC Client socket (1) | Closed. | 2021-06-14 16:16:41.895 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:16:46.246 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:46.247 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:46.247 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:16:46.248 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:46.308 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:46.308 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:46.308 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:46.374 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:46.374 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:16:46.839 DTC Client socket (4) | Creating socket. | 2021-06-14 16:16:46.841 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:16:46.841 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:16:46.841 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:46.887 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:46.887 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:46.887 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:46.937 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:46.937 SC Data - All Services | Received logon response. | 2021-06-14 16:16:47.061 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:47.061 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:47.062 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:47.062 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:47.062 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:47.062 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:47.062 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:16:47.062 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:47.063 SC Data - All Services | Received logon response. | 2021-06-14 16:16:47.083 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:47.083 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:47.083 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:47.083 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:47.083 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:16:47.084 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:47.084 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:47.084 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:47.084 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:47.117 DTC Client socket (1) | Closed. | 2021-06-14 16:16:47.117 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:16:47.119 DTC Client socket (4) | Closed. | 2021-06-14 16:16:47.119 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:16:52.080 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:52.081 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:52.081 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:16:52.081 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:52.131 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:52.131 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:52.131 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:52.198 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:52.198 SC Data - All Services | Received logon response. | 2021-06-14 16:16:52.352 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:52.352 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:52.352 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:52.352 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:52.352 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:52.353 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:52.353 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:52.353 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:52.353 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:52.400 DTC Client socket (1) | Closed. | 2021-06-14 16:16:52.400 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:16:57.334 DTC Client socket (1) | Creating socket. | 2021-06-14 16:16:57.335 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:16:57.335 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:16:57.335 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:16:57.382 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:16:57.382 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:16:57.382 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:16:57.438 SC Data - All Services | Sending logon request message. | 2021-06-14 16:16:57.438 SC Data - All Services | Received logon response. | 2021-06-14 16:16:57.594 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:16:57.594 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:16:57.594 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:16:57.594 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:16:57.594 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:16:57.594 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:16:57.594 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:16:57.594 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:16:57.594 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:16:57.631 DTC Client socket (1) | Closed. | 2021-06-14 16:16:57.632 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:17:02.590 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:02.591 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:02.591 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:17:02.592 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:02.641 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:02.642 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:02.642 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:02.710 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:02.710 SC Data - All Services | Received logon response. | 2021-06-14 16:17:02.850 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:02.851 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:02.851 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:02.851 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:02.851 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:02.851 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:02.851 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:02.851 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:02.851 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:02.891 DTC Client socket (1) | Closed. | 2021-06-14 16:17:02.891 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:17:07.845 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:07.845 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:07.845 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:17:07.845 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:07.924 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:07.924 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:07.924 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:08.005 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:08.005 SC Data - All Services | Received logon response. | 2021-06-14 16:17:08.644 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:08.644 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:08.644 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:08.644 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:08.644 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:08.645 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:08.645 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:08.645 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:08.645 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:08.687 DTC Client socket (1) | Closed. | 2021-06-14 16:17:08.687 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:17:13.633 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:13.634 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:13.634 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:17:13.634 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:13.673 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:13.673 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:13.673 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:13.736 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:13.736 SC Data - All Services | Received logon response. | 2021-06-14 16:17:14.348 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:14.348 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:14.348 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:14.348 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:14.348 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:14.349 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:14.349 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:14.349 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:14.349 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:14.391 DTC Client socket (1) | Closed. | 2021-06-14 16:17:14.391 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:17:17.055 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:17.056 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:17.056 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:17:17.056 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:17.108 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:17.108 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:17.108 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:17.197 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:17.197 SC Data - All Services | Received logon response. | 2021-06-14 16:17:17.257 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:17.257 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:17.257 SC Data - All Services | Logon error received from server: Maximum connections reached. | 2021-06-14 16:17:17.257 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:17.258 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:17.258 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:17.258 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-14 16:17:17.258 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:17.259 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:17.309 DTC Client socket (1) | Closed. | 2021-06-14 16:17:17.309 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:17:19.260 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:19.261 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:19.261 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:17:19.262 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:19.305 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:19.305 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:19.305 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:17:19.338 DTC Client socket (4) | Creating socket. | 2021-06-14 16:17:19.339 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:17:19.339 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:17:19.339 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:19.368 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:19.368 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:19.382 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:19.382 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:19.382 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:19.440 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:19.440 SC Data - All Services | Received logon response. | 2021-06-14 16:17:19.585 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:19.585 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:19.585 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:19.585 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:19.585 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:17:19.586 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:19.586 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:19.586 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:19.586 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:17:19.625 DTC Client socket (4) | Closed. | 2021-06-14 16:17:19.625 SC Data - All Services | Received logon response. | 2021-06-14 16:17:20.072 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:20.072 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:20.072 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:20.072 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:20.072 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:20.072 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:20.072 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:17:20.072 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:20.072 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:20.118 DTC Client socket (1) | Closed. | 2021-06-14 16:17:20.119 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:17:24.577 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:24.579 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:24.579 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:17:24.579 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:24.627 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:24.627 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:24.627 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:24.671 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:24.671 SC Data - All Services | Received logon response. | 2021-06-14 16:17:24.755 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:24.755 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:24.755 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:24.755 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:24.755 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:24.756 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:24.756 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:24.756 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:24.756 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:24.795 DTC Client socket (1) | Closed. | 2021-06-14 16:17:24.795 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:17:29.764 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:29.765 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:29.765 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:17:29.765 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:29.807 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:29.807 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:29.807 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:29.877 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:29.877 SC Data - All Services | Received logon response. | 2021-06-14 16:17:30.046 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:30.046 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:30.046 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:30.046 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:30.046 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:30.047 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:30.047 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:30.047 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:30.047 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:30.089 DTC Client socket (1) | Closed. | 2021-06-14 16:17:30.089 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:17:35.040 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:35.041 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:35.041 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:17:35.041 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:35.094 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:35.094 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:35.094 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:35.153 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:35.153 SC Data - All Services | Received logon response. | 2021-06-14 16:17:35.291 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:35.291 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:35.291 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:35.291 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:35.291 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:35.291 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:35.291 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:35.291 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:35.291 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:35.335 DTC Client socket (1) | Closed. | 2021-06-14 16:17:35.335 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:17:40.275 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:40.275 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:40.275 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:17:40.275 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:40.315 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:40.315 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:40.316 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:40.375 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:40.375 SC Data - All Services | Received logon response. | 2021-06-14 16:17:41.019 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:41.019 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:41.019 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:41.019 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:41.019 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:41.020 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:41.020 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:41.020 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:41.020 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:41.055 DTC Client socket (1) | Closed. | 2021-06-14 16:17:41.055 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:17:46.004 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:46.005 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:46.006 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:17:46.006 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:46.051 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:46.051 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:46.051 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:46.136 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:46.136 SC Data - All Services | Received logon response. | 2021-06-14 16:17:46.765 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:46.765 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:46.765 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:46.765 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:46.765 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:46.766 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:46.766 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:46.766 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:46.766 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:46.808 DTC Client socket (1) | Closed. | 2021-06-14 16:17:46.808 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:17:50.078 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:50.079 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:50.079 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:17:50.079 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:50.124 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:50.124 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:50.124 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:50.196 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:50.196 SC Data - All Services | Received logon response. | 2021-06-14 16:17:50.899 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:50.899 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:50.899 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:50.899 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:50.899 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:50.900 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:50.900 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:17:50.900 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:50.900 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:50.942 DTC Client socket (1) | Closed. | 2021-06-14 16:17:50.942 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:17:51.767 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:51.767 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:51.767 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:17:51.767 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:51.807 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:51.807 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:51.808 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:51.876 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:51.876 SC Data - All Services | Received logon response. | 2021-06-14 16:17:52.014 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:52.014 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:52.014 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:52.015 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:52.015 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:52.015 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:52.015 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:52.015 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:52.015 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:52.053 DTC Client socket (1) | Closed. | 2021-06-14 16:17:52.053 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:17:56.997 DTC Client socket (1) | Creating socket. | 2021-06-14 16:17:56.997 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:17:56.997 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:17:56.997 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:17:57.038 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:17:57.038 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:17:57.038 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:17:57.091 SC Data - All Services | Sending logon request message. | 2021-06-14 16:17:57.091 SC Data - All Services | Received logon response. | 2021-06-14 16:17:57.233 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:17:57.233 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:17:57.233 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:17:57.233 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:17:57.233 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:17:57.233 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:17:57.233 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:17:57.233 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:17:57.233 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:17:57.278 DTC Client socket (1) | Closed. | 2021-06-14 16:17:57.278 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:18:02.237 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:02.238 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:02.238 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:18:02.238 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:02.279 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:02.279 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:02.279 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:02.343 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:02.343 SC Data - All Services | Received logon response. | 2021-06-14 16:18:02.485 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:02.485 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:02.485 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:02.485 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:02.485 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:02.485 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:02.485 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:02.485 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:02.486 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:02.521 DTC Client socket (1) | Closed. | 2021-06-14 16:18:02.521 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:18:07.458 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:07.458 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:07.458 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:18:07.458 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:07.501 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:07.501 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:07.501 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:07.572 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:07.572 SC Data - All Services | Received logon response. | 2021-06-14 16:18:07.730 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:07.730 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:07.730 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:07.730 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:07.730 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:07.731 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:07.731 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:07.731 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:07.731 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:07.767 DTC Client socket (1) | Closed. | 2021-06-14 16:18:07.767 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:18:12.707 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:12.708 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:12.708 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:18:12.708 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:12.751 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:12.751 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:12.751 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:12.815 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:12.815 SC Data - All Services | Received logon response. | 2021-06-14 16:18:13.407 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:13.407 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:13.407 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:13.407 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:13.407 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:13.408 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:13.408 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:13.408 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:13.408 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:13.448 DTC Client socket (1) | Closed. | 2021-06-14 16:18:13.448 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:18:18.397 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:18.397 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:18.397 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:18:18.397 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:18.438 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:18.438 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:18.438 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:18.493 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:18.493 SC Data - All Services | Received logon response. | 2021-06-14 16:18:19.100 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:19.100 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:19.100 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:19.100 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:19.101 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:19.101 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:19.101 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:19.101 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:19.101 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:19.140 DTC Client socket (1) | Closed. | 2021-06-14 16:18:19.140 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:18:20.896 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:20.896 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:20.897 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:18:20.897 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:20.959 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:20.959 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:20.959 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:21.048 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:21.048 SC Data - All Services | Received logon response. | 2021-06-14 16:18:21.823 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:21.823 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:21.823 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:21.823 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:21.823 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:21.824 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:21.824 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:18:21.824 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:21.824 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:21.880 DTC Client socket (1) | Closed. | 2021-06-14 16:18:21.880 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:18:24.090 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:24.097 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:24.097 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:18:24.097 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:24.145 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:24.145 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:24.145 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:24.222 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:24.222 SC Data - All Services | Received logon response. | 2021-06-14 16:18:24.394 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:24.394 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:24.395 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:24.395 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:24.395 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:24.395 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:24.395 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:24.395 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:24.396 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:24.438 DTC Client socket (1) | Closed. | 2021-06-14 16:18:24.439 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:18:29.396 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:29.396 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:29.397 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:18:29.397 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:29.442 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:29.442 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:29.442 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:29.510 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:29.510 SC Data - All Services | Received logon response. | 2021-06-14 16:18:29.666 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:29.666 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:29.666 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:29.666 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:29.666 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:29.667 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:29.667 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:29.667 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:29.667 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:29.704 DTC Client socket (1) | Closed. | 2021-06-14 16:18:29.704 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:18:34.674 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:34.675 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:34.676 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:18:34.676 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:34.718 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:34.719 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:34.719 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:34.781 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:34.781 SC Data - All Services | Received logon response. | 2021-06-14 16:18:34.922 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:34.922 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:34.922 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:34.922 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:34.922 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:34.922 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:34.922 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:34.922 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:34.922 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:34.959 DTC Client socket (1) | Closed. | 2021-06-14 16:18:34.959 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:18:39.928 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:39.928 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:39.929 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:18:39.929 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:39.971 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:39.971 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:39.971 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:40.021 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:40.021 SC Data - All Services | Received logon response. | 2021-06-14 16:18:40.159 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:40.159 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:40.159 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:40.159 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:40.159 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:40.159 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:40.159 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:40.159 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:40.160 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:40.199 DTC Client socket (1) | Closed. | 2021-06-14 16:18:40.199 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:18:45.147 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:45.148 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:45.148 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:18:45.148 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:45.199 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:45.199 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:45.199 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:45.249 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:45.249 SC Data - All Services | Received logon response. | 2021-06-14 16:18:45.873 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:45.873 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:45.873 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:45.873 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:45.873 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:45.874 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:45.874 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:45.874 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:45.874 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:45.921 DTC Client socket (1) | Closed. | 2021-06-14 16:18:45.922 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:18:50.877 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:50.878 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:50.878 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:18:50.878 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:50.925 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:50.925 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:50.926 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:50.979 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:50.979 SC Data - All Services | Received logon response. | 2021-06-14 16:18:51.606 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:51.606 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:51.606 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:51.606 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:51.606 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:51.607 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:51.607 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:51.607 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:51.607 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:51.649 DTC Client socket (1) | Closed. | 2021-06-14 16:18:51.649 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-14 16:18:51.828 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:51.829 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:51.829 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:18:51.829 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:51.888 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:51.888 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:51.888 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:51.968 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:51.968 SC Data - All Services | Received logon response. | 2021-06-14 16:18:52.733 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:52.733 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:52.733 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:52.733 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:52.733 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:52.733 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:52.733 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:18:52.733 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:52.733 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:52.788 DTC Client socket (1) | Closed. | 2021-06-14 16:18:52.788 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:18:56.589 DTC Client socket (1) | Creating socket. | 2021-06-14 16:18:56.590 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:18:56.590 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:18:56.590 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:18:56.636 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:18:56.636 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:18:56.637 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:18:56.688 SC Data - All Services | Sending logon request message. | 2021-06-14 16:18:56.688 SC Data - All Services | Received logon response. | 2021-06-14 16:18:56.842 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:18:56.842 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:18:56.843 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:18:56.843 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:18:56.843 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:18:56.843 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:18:56.843 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:18:56.843 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:18:56.843 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:18:56.884 DTC Client socket (1) | Closed. | 2021-06-14 16:18:56.884 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:19:01.835 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:01.836 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:01.836 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:19:01.836 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:01.892 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:01.892 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:01.892 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:01.939 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:01.939 SC Data - All Services | Received logon response. | 2021-06-14 16:19:02.065 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:02.065 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:02.065 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:02.065 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:02.065 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:02.066 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:02.066 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:02.066 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:02.066 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:02.108 DTC Client socket (1) | Closed. | 2021-06-14 16:19:02.108 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:19:07.074 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:07.074 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:07.074 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:19:07.074 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:07.115 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:07.115 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:07.115 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:07.189 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:07.189 SC Data - All Services | Received logon response. | 2021-06-14 16:19:07.345 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:07.345 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:07.345 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:07.345 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:07.345 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:07.346 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:07.346 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:07.346 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:07.346 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:07.385 DTC Client socket (1) | Closed. | 2021-06-14 16:19:07.385 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:19:12.337 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:12.337 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:12.337 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:19:12.337 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:12.377 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:12.377 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:12.377 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:12.438 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:12.438 SC Data - All Services | Received logon response. | 2021-06-14 16:19:12.571 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:12.571 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:12.571 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:12.571 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:12.571 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:12.572 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:12.572 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:12.572 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:12.572 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:12.611 DTC Client socket (1) | Closed. | 2021-06-14 16:19:12.611 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:19:17.569 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:17.570 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:17.570 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:19:17.570 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:17.614 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:17.614 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:17.614 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:17.660 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:17.660 SC Data - All Services | Received logon response. | 2021-06-14 16:19:18.264 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:18.264 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:18.264 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:18.264 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:18.264 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:18.265 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:18.265 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:18.265 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:18.265 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:18.306 DTC Client socket (1) | Closed. | 2021-06-14 16:19:18.306 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:19:22.722 DTC Client socket (4) | Creating socket. | 2021-06-14 16:19:22.724 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:19:22.724 DTC Client socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:19:22.724 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:22.769 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:22.769 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:22.770 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:22.830 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:22.830 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:19:23.256 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:23.257 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:23.257 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:19:23.257 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:23.300 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:23.300 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:23.300 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:23.353 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:23.353 SC Data - All Services | Received logon response. | 2021-06-14 16:19:23.518 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:23.518 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:23.518 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:23.518 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:23.518 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:19:23.518 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:23.518 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:19:23.518 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:23.518 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:19:23.562 DTC Client socket (4) | Closed. | 2021-06-14 16:19:23.562 SC Data - All Services | Received logon response. | 2021-06-14 16:19:23.979 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:23.979 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:23.979 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:23.979 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:23.979 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:23.980 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:23.980 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:23.980 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:23.980 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:24.020 DTC Client socket (1) | Closed. | 2021-06-14 16:19:24.020 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:19:28.978 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:28.978 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:28.978 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:19:28.978 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:29.020 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:29.020 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:29.020 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:29.092 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:29.092 SC Data - All Services | Received logon response. | 2021-06-14 16:19:29.235 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:29.235 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:29.235 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:29.235 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:29.235 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:29.236 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:29.236 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:29.236 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:29.236 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:29.273 DTC Client socket (1) | Closed. | 2021-06-14 16:19:29.273 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:19:34.230 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:34.231 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:34.231 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:19:34.231 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:34.279 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:34.279 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:34.279 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:34.344 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:34.344 SC Data - All Services | Received logon response. | 2021-06-14 16:19:34.485 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:34.485 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:34.485 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:34.485 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:34.485 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:34.485 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:34.485 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:34.485 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:34.485 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:34.525 DTC Client socket (1) | Closed. | 2021-06-14 16:19:34.525 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:19:39.485 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:39.486 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:39.486 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:19:39.486 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:39.525 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:39.525 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:39.525 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:39.592 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:39.592 SC Data - All Services | Received logon response. | 2021-06-14 16:19:39.748 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:39.748 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:39.748 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:39.748 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:39.748 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:39.749 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:39.749 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:39.749 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:39.749 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:39.787 DTC Client socket (1) | Closed. | 2021-06-14 16:19:39.788 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:19:44.747 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:44.748 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:44.748 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:19:44.748 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:44.787 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:44.787 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:44.788 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:44.840 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:44.840 SC Data - All Services | Received logon response. | 2021-06-14 16:19:44.976 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:44.976 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:44.976 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:44.976 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:44.976 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:44.977 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:44.977 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:44.977 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:44.977 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:45.014 DTC Client socket (1) | Closed. | 2021-06-14 16:19:45.014 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:19:49.965 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:49.966 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:49.966 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:19:49.966 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:50.010 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:50.010 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:50.010 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:50.062 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:50.062 SC Data - All Services | Received logon response. | 2021-06-14 16:19:50.688 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:50.688 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:50.688 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:50.688 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:50.688 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:50.689 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:50.689 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:50.689 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:50.689 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:50.729 DTC Client socket (1) | Closed. | 2021-06-14 16:19:50.729 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:19:53.516 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:53.516 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:53.516 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:19:53.516 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:53.562 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:53.562 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:53.562 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:53.631 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:53.631 SC Data - All Services | Received logon response. | 2021-06-14 16:19:54.354 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:54.354 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:54.354 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:54.354 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:54.354 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:54.354 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:54.354 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:19:54.354 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:54.354 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:54.401 DTC Client socket (1) | Closed. | 2021-06-14 16:19:54.401 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:19:55.663 DTC Client socket (1) | Creating socket. | 2021-06-14 16:19:55.663 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:19:55.663 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:19:55.663 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:19:55.714 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:19:55.714 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:19:55.714 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:19:55.763 SC Data - All Services | Sending logon request message. | 2021-06-14 16:19:55.763 SC Data - All Services | Received logon response. | 2021-06-14 16:19:56.388 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:19:56.389 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:19:56.389 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:19:56.389 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:19:56.389 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:19:56.389 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:19:56.389 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:19:56.389 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:19:56.389 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:19:56.431 DTC Client socket (1) | Closed. | 2021-06-14 16:19:56.431 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:20:01.385 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:01.385 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:01.385 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:20:01.385 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:01.427 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:01.427 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:01.428 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:01.502 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:01.502 SC Data - All Services | Received logon response. | 2021-06-14 16:20:01.649 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:01.649 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:01.649 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:01.649 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:01.649 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:01.650 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:01.650 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:01.650 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:01.650 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:01.689 DTC Client socket (1) | Closed. | 2021-06-14 16:20:01.689 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:20:06.649 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:06.651 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:06.651 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:20:06.651 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:06.694 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:06.694 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:06.694 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:06.746 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:06.746 SC Data - All Services | Received logon response. | 2021-06-14 16:20:06.885 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:06.885 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:06.885 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:06.885 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:06.885 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:06.885 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:06.885 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:06.885 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:06.886 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:06.921 DTC Client socket (1) | Closed. | 2021-06-14 16:20:06.921 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:20:11.885 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:11.885 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:11.886 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:20:11.886 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:11.931 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:11.931 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:11.931 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:12.000 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:12.000 SC Data - All Services | Received logon response. | 2021-06-14 16:20:12.144 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:12.144 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:12.144 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:12.144 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:12.144 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:12.145 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:12.145 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:12.145 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:12.145 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:12.182 DTC Client socket (1) | Closed. | 2021-06-14 16:20:12.182 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:20:17.139 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:17.140 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:17.141 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:20:17.141 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:17.189 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:17.190 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:17.190 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:17.253 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:17.253 SC Data - All Services | Received logon response. | 2021-06-14 16:20:17.377 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:17.377 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:17.377 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:17.377 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:17.377 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:17.377 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:17.377 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:17.377 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:17.377 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:17.415 DTC Client socket (1) | Closed. | 2021-06-14 16:20:17.415 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:20:22.373 DTC Client socket (4) | Creating socket. | 2021-06-14 16:20:22.373 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:20:22.373 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:20:22.373 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:22.418 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:22.418 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:22.418 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:22.467 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:22.467 SC Data - All Services | Received logon response. | 2021-06-14 16:20:23.049 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:23.049 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:23.049 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:23.049 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:23.049 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:20:23.049 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:23.050 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:23.050 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:23.050 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:20:23.092 DTC Client socket (4) | Closed. | 2021-06-14 16:20:23.092 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:20:24.348 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:24.349 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:24.349 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:20:24.349 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:24.406 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:24.406 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:24.406 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:24.468 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:24.468 SC Data - All Services | Received logon response. | 2021-06-14 16:20:25.188 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:25.188 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:25.188 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:25.188 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:25.188 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:25.188 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:25.188 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:20:25.189 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:25.189 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:25.246 DTC Client socket (1) | Closed. | 2021-06-14 16:20:25.246 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:20:28.050 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:28.051 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:28.051 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:20:28.051 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:28.092 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:28.092 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:28.092 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:28.159 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:28.159 SC Data - All Services | Received logon response. | 2021-06-14 16:20:28.788 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:28.788 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:28.788 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:28.788 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:28.788 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:28.789 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:28.789 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:28.789 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:28.789 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:28.833 DTC Client socket (1) | Closed. | 2021-06-14 16:20:28.833 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:20:33.783 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:33.784 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:33.784 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:20:33.784 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:33.825 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:33.825 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:33.825 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:33.873 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:33.873 SC Data - All Services | Received logon response. | 2021-06-14 16:20:34.032 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:34.032 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:34.032 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:34.032 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:34.032 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:34.033 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:34.033 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:34.033 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:34.033 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:34.071 DTC Client socket (1) | Closed. | 2021-06-14 16:20:34.071 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:20:39.030 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:39.032 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:39.032 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:20:39.032 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:39.079 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:39.079 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:39.079 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:39.140 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:39.140 SC Data - All Services | Received logon response. | 2021-06-14 16:20:39.282 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:39.282 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:39.282 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:39.282 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:39.282 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:39.283 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:39.283 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:39.283 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:39.283 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:39.320 DTC Client socket (1) | Closed. | 2021-06-14 16:20:39.320 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:20:44.285 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:44.286 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:44.286 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:20:44.286 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:44.347 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:44.347 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:44.347 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:44.405 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:44.405 SC Data - All Services | Received logon response. | 2021-06-14 16:20:44.564 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:44.564 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:44.564 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:44.564 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:44.564 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:44.564 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:44.564 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:44.564 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:44.565 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:44.603 DTC Client socket (1) | Closed. | 2021-06-14 16:20:44.603 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:20:49.537 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:49.538 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:49.538 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:20:49.538 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:49.584 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:49.584 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:49.584 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:49.648 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:49.648 SC Data - All Services | Received logon response. | 2021-06-14 16:20:49.789 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:49.789 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:49.789 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:49.789 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:49.789 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:49.790 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:49.790 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:49.790 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:49.790 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:49.828 DTC Client socket (1) | Closed. | 2021-06-14 16:20:49.828 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:20:54.801 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:54.802 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:54.802 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:20:54.802 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:54.847 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:54.847 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:54.848 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:54.912 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:54.912 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-14 16:20:55.192 DTC Client socket (4) | Creating socket. | 2021-06-14 16:20:55.192 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:20:55.192 DTC Client socket (4) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:20:55.192 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:55.251 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:55.251 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:55.251 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:55.336 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:55.336 SC Data - All Services | Received logon response. | 2021-06-14 16:20:55.401 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:55.401 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:55.401 SC Data - All Services | Logon error received from server: Maximum connections reached. | 2021-06-14 16:20:55.401 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:55.401 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:20:55.402 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:55.402 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-14 16:20:55.402 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:55.402 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:20:55.453 DTC Client socket (4) | Closed. | 2021-06-14 16:20:55.454 SC Data - All Services | Received logon response. | 2021-06-14 16:20:55.455 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:55.455 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:55.455 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:55.455 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:55.456 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:55.456 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:55.456 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:20:55.456 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:55.457 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:55.500 DTC Client socket (1) | Closed. | 2021-06-14 16:20:55.500 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:20:57.399 DTC Client socket (1) | Creating socket. | 2021-06-14 16:20:57.400 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:20:57.400 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:20:57.400 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:20:57.443 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:20:57.443 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:20:57.443 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:20:57.510 SC Data - All Services | Sending logon request message. | 2021-06-14 16:20:57.510 SC Data - All Services | Received logon response. | 2021-06-14 16:20:58.216 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:20:58.216 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:20:58.216 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:20:58.216 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:20:58.216 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:20:58.217 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:20:58.217 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:20:58.217 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:20:58.217 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:20:58.259 DTC Client socket (1) | Closed. | 2021-06-14 16:20:58.259 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:21:00.446 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:00.447 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:00.447 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:21:00.447 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:00.490 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:00.491 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:00.491 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:00.692 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:00.692 SC Data - All Services | Received logon response. | 2021-06-14 16:21:01.326 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:01.326 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:01.326 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:01.326 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:01.326 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:01.327 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:01.327 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:01.327 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:01.327 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:01.366 DTC Client socket (1) | Closed. | 2021-06-14 16:21:01.366 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:21:06.303 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:06.304 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:06.304 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:21:06.304 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:06.345 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:06.345 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:06.345 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:06.405 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:06.405 SC Data - All Services | Received logon response. | 2021-06-14 16:21:06.546 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:06.546 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:06.546 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:06.546 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:06.546 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:06.547 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:06.547 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:06.547 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:06.547 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:06.581 DTC Client socket (1) | Closed. | 2021-06-14 16:21:06.581 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:21:11.546 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:11.547 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:11.547 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:21:11.547 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:11.593 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:11.593 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:11.594 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:11.658 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:11.658 SC Data - All Services | Received logon response. | 2021-06-14 16:21:11.786 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:11.786 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:11.786 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:11.786 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:11.786 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:11.787 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:11.787 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:11.787 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:11.787 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:11.829 DTC Client socket (1) | Closed. | 2021-06-14 16:21:11.829 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:21:16.781 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:16.782 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:16.782 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:21:16.782 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:16.822 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:16.822 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:16.822 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:16.874 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:16.874 SC Data - All Services | Received logon response. | 2021-06-14 16:21:17.029 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:17.029 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:17.029 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:17.029 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:17.029 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:17.029 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:17.029 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:17.029 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:17.029 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:17.067 DTC Client socket (1) | Closed. | 2021-06-14 16:21:17.068 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:21:22.011 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:22.012 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:22.012 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:21:22.012 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:22.056 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:22.056 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:22.056 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:22.101 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:22.101 SC Data - All Services | Received logon response. | 2021-06-14 16:21:22.260 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:22.260 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:22.260 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:22.260 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:22.260 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:22.261 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:22.261 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:22.261 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:22.262 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:22.303 DTC Client socket (1) | Closed. | 2021-06-14 16:21:22.303 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:21:27.260 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:27.261 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:27.261 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:21:27.261 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:27.314 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:27.314 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:27.314 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:27.373 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:27.373 SC Data - All Services | Received logon response. | 2021-06-14 16:21:27.984 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:27.984 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:27.984 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:27.984 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:27.984 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:27.984 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:27.984 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:27.984 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:27.985 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:28.022 DTC Client socket (1) | Closed. | 2021-06-14 16:21:28.022 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:21:28.213 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:28.214 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:28.214 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:21:28.214 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:28.262 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:28.262 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:28.262 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:28.318 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:28.318 SC Data - All Services | Received logon response. | 2021-06-14 16:21:29.021 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:29.021 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:29.021 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:29.021 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:29.021 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:29.022 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:29.022 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:21:29.022 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:29.022 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:29.064 DTC Client socket (1) | Closed. | 2021-06-14 16:21:29.064 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:21:32.978 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:32.979 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:32.979 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:21:32.979 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:33.023 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:33.023 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:33.023 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:33.089 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:33.089 SC Data - All Services | Received logon response. | 2021-06-14 16:21:33.702 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:33.702 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:33.702 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:33.702 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:33.702 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:33.702 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:33.703 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:33.703 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:33.703 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:33.743 DTC Client socket (1) | Closed. | 2021-06-14 16:21:33.743 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:21:38.695 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:38.696 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:38.696 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:21:38.696 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:38.740 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:38.740 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:38.740 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:38.812 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:38.812 SC Data - All Services | Received logon response. | 2021-06-14 16:21:38.960 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:38.960 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:38.960 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:38.960 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:38.960 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:38.961 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:38.961 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:38.961 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:38.962 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:38.999 DTC Client socket (1) | Closed. | 2021-06-14 16:21:38.999 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:21:43.959 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:43.959 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:43.959 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:21:43.959 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:44.008 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:44.008 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:44.008 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:44.086 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:44.086 SC Data - All Services | Received logon response. | 2021-06-14 16:21:44.264 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:44.264 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:44.264 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:44.264 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:44.264 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:44.265 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:44.265 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:44.265 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:44.265 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:44.307 DTC Client socket (1) | Closed. | 2021-06-14 16:21:44.307 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:21:49.255 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:49.256 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:49.256 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:21:49.256 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:49.298 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:49.298 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:49.298 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:49.365 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:49.365 SC Data - All Services | Received logon response. | 2021-06-14 16:21:49.516 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:49.516 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:49.516 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:49.516 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:49.516 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:49.518 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:49.518 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:49.518 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:49.518 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:49.554 DTC Client socket (1) | Closed. | 2021-06-14 16:21:49.554 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:21:54.516 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:54.516 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:54.517 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:21:54.517 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:54.564 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:54.564 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:54.564 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:54.629 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:54.629 SC Data - All Services | Received logon response. | 2021-06-14 16:21:54.801 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:54.801 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:54.801 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:54.801 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:54.801 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:54.802 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:54.802 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:21:54.802 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:54.802 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:54.841 DTC Client socket (1) | Closed. | 2021-06-14 16:21:54.841 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:21:59.005 DTC Client socket (1) | Creating socket. | 2021-06-14 16:21:59.006 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:21:59.006 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:21:59.006 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:59.064 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:59.064 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:59.064 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:59.125 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:59.125 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:21:59.806 DTC Client socket (4) | Creating socket. | 2021-06-14 16:21:59.807 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:21:59.807 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:21:59.807 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:21:59.852 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:21:59.852 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:21:59.853 SC Data - All Services | Received logon response. | 2021-06-14 16:21:59.861 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:21:59.861 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:21:59.861 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:21:59.861 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:21:59.861 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:21:59.862 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:21:59.862 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:21:59.862 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:21:59.862 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:21:59.906 SC Data - All Services | Sending logon request message. | 2021-06-14 16:21:59.906 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:21:59.918 DTC Client socket (1) | Closed. | 2021-06-14 16:21:59.918 SC Data - All Services | Received logon response. | 2021-06-14 16:22:00.548 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:00.548 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:00.548 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:00.548 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:00.548 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:22:00.548 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:00.548 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:00.548 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:00.548 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:22:00.604 DTC Client socket (4) | Closed. | 2021-06-14 16:22:00.604 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:22:05.541 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:05.541 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:05.541 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:22:05.541 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:05.582 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:05.582 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:05.582 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:05.636 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:05.636 SC Data - All Services | Received logon response. | 2021-06-14 16:22:06.270 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:06.270 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:06.270 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:06.270 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:06.270 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:06.271 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:06.271 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:06.271 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:06.271 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:06.311 DTC Client socket (1) | Closed. | 2021-06-14 16:22:06.311 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:22:11.255 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:11.255 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:11.255 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:22:11.255 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:11.296 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:11.296 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:11.296 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:11.343 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:11.343 SC Data - All Services | Received logon response. | 2021-06-14 16:22:11.484 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:11.485 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:11.485 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:11.485 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:11.485 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:11.485 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:11.485 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:11.485 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:11.485 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:11.527 DTC Client socket (1) | Closed. | 2021-06-14 16:22:11.527 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:22:16.477 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:16.477 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:16.477 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:22:16.477 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:16.522 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:16.522 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:16.522 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:16.580 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:16.580 SC Data - All Services | Received logon response. | 2021-06-14 16:22:16.725 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:16.725 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:16.725 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:16.725 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:16.725 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:16.726 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:16.726 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:16.726 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:16.726 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:16.764 DTC Client socket (1) | Closed. | 2021-06-14 16:22:16.765 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:22:21.717 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:21.718 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:21.718 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:22:21.718 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:21.763 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:21.763 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:21.763 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:21.812 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:21.812 SC Data - All Services | Received logon response. | 2021-06-14 16:22:21.961 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:21.961 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:21.961 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:21.961 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:21.961 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:21.962 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:21.962 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:21.962 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:21.962 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:22.000 DTC Client socket (1) | Closed. | 2021-06-14 16:22:22.000 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:22:26.967 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:26.968 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:26.968 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:22:26.968 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:27.013 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:27.013 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:27.013 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:27.067 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:27.067 SC Data - All Services | Received logon response. | 2021-06-14 16:22:27.223 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:27.223 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:27.223 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:27.223 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:27.223 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:27.223 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:27.223 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:27.223 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:27.223 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:27.262 DTC Client socket (1) | Closed. | 2021-06-14 16:22:27.263 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-14 16:22:29.854 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:29.854 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:29.854 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:22:29.854 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:29.912 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:29.912 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:29.913 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:29.969 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:29.969 SC Data - All Services | Received logon response. | 2021-06-14 16:22:30.035 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:30.035 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:30.035 SC Data - All Services | Logon error received from server: Maximum connections reached. | 2021-06-14 16:22:30.035 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:30.035 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:30.036 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:30.036 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-14 16:22:30.036 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:30.037 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:30.091 DTC Client socket (1) | Closed. | 2021-06-14 16:22:30.091 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2021-06-14 16:22:32.024 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:32.025 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:32.026 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:22:32.026 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:32.075 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:32.075 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:32.075 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:32.148 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:32.148 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:22:32.223 DTC Client socket (4) | Creating socket. | 2021-06-14 16:22:32.224 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:22:32.224 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:22:32.224 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:32.269 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:32.269 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:32.270 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:32.344 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:32.344 SC Data - All Services | Received logon response. | 2021-06-14 16:22:32.846 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:32.846 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:32.846 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:32.846 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:32.846 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:32.847 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:32.847 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:22:32.847 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:32.847 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:32.889 DTC Client socket (1) | Closed. | 2021-06-14 16:22:32.889 SC Data - All Services | Received logon response. | 2021-06-14 16:22:32.969 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:32.969 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:32.969 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:32.969 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:32.970 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:22:32.970 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:32.970 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:32.970 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:32.970 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:22:33.010 DTC Client socket (4) | Closed. | 2021-06-14 16:22:33.010 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:22:37.974 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:37.974 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:37.974 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:22:37.974 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:38.027 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:38.027 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:38.027 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:38.108 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:38.108 SC Data - All Services | Received logon response. | 2021-06-14 16:22:38.729 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:38.729 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:38.729 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:38.729 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:38.729 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:38.729 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:38.729 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:38.729 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:38.729 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:38.769 DTC Client socket (1) | Closed. | 2021-06-14 16:22:38.770 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:22:43.724 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:43.724 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:43.724 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:22:43.724 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:43.770 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:43.770 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:43.770 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:43.844 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:43.844 SC Data - All Services | Received logon response. | 2021-06-14 16:22:43.964 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:43.964 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:43.964 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:43.964 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:43.964 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:43.965 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:43.965 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:43.965 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:43.965 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:44.007 DTC Client socket (1) | Closed. | 2021-06-14 16:22:44.007 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:22:48.962 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:48.963 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:48.963 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:22:48.963 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:49.009 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:49.009 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:49.009 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:49.063 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:49.063 SC Data - All Services | Received logon response. | 2021-06-14 16:22:49.222 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:49.222 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:49.222 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:49.222 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:49.222 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:49.222 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:49.222 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:49.222 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:49.223 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:49.262 DTC Client socket (1) | Closed. | 2021-06-14 16:22:49.262 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:22:54.227 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:54.228 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:54.228 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:22:54.228 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:54.279 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:54.279 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:54.279 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:54.347 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:54.347 SC Data - All Services | Received logon response. | 2021-06-14 16:22:54.502 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:54.502 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:54.502 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:54.502 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:54.502 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:54.502 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:54.503 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:54.503 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:54.503 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:54.545 DTC Client socket (1) | Closed. | 2021-06-14 16:22:54.545 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:22:59.507 DTC Client socket (1) | Creating socket. | 2021-06-14 16:22:59.507 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:22:59.507 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:22:59.507 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:22:59.554 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:22:59.554 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:22:59.554 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:22:59.613 SC Data - All Services | Sending logon request message. | 2021-06-14 16:22:59.613 SC Data - All Services | Received logon response. | 2021-06-14 16:22:59.754 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:22:59.754 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:22:59.754 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:22:59.754 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:22:59.754 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:22:59.754 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:22:59.754 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:22:59.754 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:22:59.754 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:22:59.794 DTC Client socket (1) | Closed. | 2021-06-14 16:22:59.794 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:23:02.847 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:02.848 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:02.848 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:23:02.848 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:02.892 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:02.892 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:02.892 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:02.956 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:02.956 SC Data - All Services | Received logon response. | 2021-06-14 16:23:03.643 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:03.643 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:03.643 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:03.643 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:03.643 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:03.643 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:03.643 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:23:03.643 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:03.643 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:03.687 DTC Client socket (1) | Closed. | 2021-06-14 16:23:03.688 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:23:04.748 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:04.749 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:04.750 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:23:04.750 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:04.798 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:04.798 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:04.798 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:04.845 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:04.845 SC Data - All Services | Received logon response. | 2021-06-14 16:23:05.453 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:05.453 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:05.453 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:05.453 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:05.453 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:05.453 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:05.453 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:05.453 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:05.454 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:05.494 DTC Client socket (1) | Closed. | 2021-06-14 16:23:05.494 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:23:10.453 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:10.454 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:10.454 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:23:10.454 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:10.503 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:10.503 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:10.503 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:10.576 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:10.576 SC Data - All Services | Received logon response. | 2021-06-14 16:23:11.196 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:11.196 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:11.196 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:11.196 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:11.196 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:11.197 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:11.197 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:11.197 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:11.197 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:11.237 DTC Client socket (1) | Closed. | 2021-06-14 16:23:11.237 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:23:16.200 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:16.200 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:16.200 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:23:16.200 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:16.241 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:16.241 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:16.241 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:16.312 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:16.312 SC Data - All Services | Received logon response. | 2021-06-14 16:23:16.457 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:16.457 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:16.457 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:16.457 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:16.457 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:16.457 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:16.457 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:16.457 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:16.458 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:16.529 DTC Client socket (1) | Closed. | 2021-06-14 16:23:16.529 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:23:21.460 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:21.460 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:21.460 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:23:21.460 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:21.508 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:21.508 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:21.508 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:21.559 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:21.559 SC Data - All Services | Received logon response. | 2021-06-14 16:23:21.703 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:21.703 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:21.703 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:21.703 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:21.703 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:21.704 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:21.704 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:21.704 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:21.704 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:21.744 DTC Client socket (1) | Closed. | 2021-06-14 16:23:21.745 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:23:26.706 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:26.706 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:26.706 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:23:26.706 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:26.748 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:26.748 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:26.748 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:26.815 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:26.815 SC Data - All Services | Received logon response. | 2021-06-14 16:23:26.960 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:26.960 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:26.960 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:26.960 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:26.960 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:26.961 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:26.961 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:26.961 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:26.961 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:27.000 DTC Client socket (1) | Closed. | 2021-06-14 16:23:27.000 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:23:31.960 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:31.961 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:31.961 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:23:31.961 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:32.001 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:32.001 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:32.001 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:32.071 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:32.071 SC Data - All Services | Received logon response. | 2021-06-14 16:23:32.227 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:32.227 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:32.227 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:32.227 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:32.227 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:32.228 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:32.228 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:32.228 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:32.228 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:32.269 DTC Client socket (1) | Closed. | 2021-06-14 16:23:32.269 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:23:33.640 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:33.641 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:33.641 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:23:33.641 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:33.700 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:33.700 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:33.700 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:33.783 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:33.783 SC Data - All Services | Received logon response. | 2021-06-14 16:23:34.504 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:34.504 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:34.504 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:34.504 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:34.504 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:34.505 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:34.505 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:23:34.505 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:34.505 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:34.565 DTC Client socket (1) | Closed. | 2021-06-14 16:23:34.565 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:23:37.240 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:37.241 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:37.241 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:23:37.241 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:37.284 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:37.284 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:37.284 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:37.344 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:37.344 SC Data - All Services | Received logon response. | 2021-06-14 16:23:37.968 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:37.968 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:37.968 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:37.968 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:37.968 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:37.968 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:37.968 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:37.968 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:37.968 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:38.009 DTC Client socket (1) | Closed. | 2021-06-14 16:23:38.009 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:23:42.963 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:42.963 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:42.963 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:23:42.963 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:43.017 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:43.017 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:43.017 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:43.089 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:43.089 SC Data - All Services | Received logon response. | 2021-06-14 16:23:43.700 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:43.700 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:43.700 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:43.700 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:43.700 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:43.700 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:43.701 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:43.701 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:43.701 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:43.742 DTC Client socket (1) | Closed. | 2021-06-14 16:23:43.742 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:23:48.703 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:48.704 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:48.704 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:23:48.704 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:48.758 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:48.758 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:48.758 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:48.813 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:48.814 SC Data - All Services | Received logon response. | 2021-06-14 16:23:48.961 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:48.961 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:48.961 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:48.961 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:48.961 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:48.962 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:48.962 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:48.962 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:48.962 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:49.002 DTC Client socket (1) | Closed. | 2021-06-14 16:23:49.002 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:23:53.943 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:53.944 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:53.944 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:23:53.944 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:53.989 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:53.989 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:53.990 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:54.048 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:54.048 SC Data - All Services | Received logon response. | 2021-06-14 16:23:54.188 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:54.188 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:54.188 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:54.188 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:54.188 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:54.188 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:54.188 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:54.188 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:54.188 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:54.227 DTC Client socket (1) | Closed. | 2021-06-14 16:23:54.227 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:23:59.192 DTC Client socket (1) | Creating socket. | 2021-06-14 16:23:59.194 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:23:59.194 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:23:59.194 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:23:59.239 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:23:59.239 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:23:59.239 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:23:59.285 SC Data - All Services | Sending logon request message. | 2021-06-14 16:23:59.285 SC Data - All Services | Received logon response. | 2021-06-14 16:23:59.421 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:23:59.421 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:23:59.421 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:23:59.421 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:23:59.421 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:23:59.422 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:23:59.422 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:23:59.422 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:23:59.422 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:23:59.463 DTC Client socket (1) | Closed. | 2021-06-14 16:23:59.463 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:24:04.427 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:04.427 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:04.427 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:24:04.427 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:04.470 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:04.470 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:04.470 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:24:04.489 DTC Client socket (4) | Creating socket. | 2021-06-14 16:24:04.489 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:24:04.489 DTC Client socket (4) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:24:04.489 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:04.529 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:04.529 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:04.544 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:04.544 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:04.544 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:04.619 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:04.619 SC Data - All Services | Received logon response. | 2021-06-14 16:24:04.672 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:04.672 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:04.672 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:04.672 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:04.672 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:04.672 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:04.672 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:04.672 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:04.673 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:04.711 DTC Client socket (1) | Closed. | 2021-06-14 16:24:04.711 SC Data - All Services | Received logon response. | 2021-06-14 16:24:05.407 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:05.407 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:05.407 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:05.407 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:05.407 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:24:05.407 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:05.407 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:24:05.407 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:05.408 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:24:05.457 DTC Client socket (4) | Closed. | 2021-06-14 16:24:05.457 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:24:09.669 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:09.669 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:09.669 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:24:09.669 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:09.714 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:09.714 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:09.714 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:09.781 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:09.781 SC Data - All Services | Received logon response. | 2021-06-14 16:24:10.406 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:10.406 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:10.406 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:10.406 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:10.406 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:10.406 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:10.406 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:10.406 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:10.406 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:10.448 DTC Client socket (1) | Closed. | 2021-06-14 16:24:10.448 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:24:15.408 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:15.408 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:15.408 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:24:15.408 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:15.450 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:15.450 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:15.450 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:15.513 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:15.513 SC Data - All Services | Received logon response. | 2021-06-14 16:24:16.132 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:16.132 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:16.132 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:16.132 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:16.132 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:16.132 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:16.132 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:16.132 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:16.132 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:16.176 DTC Client socket (1) | Closed. | 2021-06-14 16:24:16.176 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:24:21.127 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:21.128 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:21.129 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:24:21.129 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:21.174 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:21.174 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:21.174 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:21.220 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:21.220 SC Data - All Services | Received logon response. | 2021-06-14 16:24:21.360 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:21.360 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:21.360 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:21.360 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:21.360 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:21.360 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:21.360 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:21.360 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:21.360 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:21.398 DTC Client socket (1) | Closed. | 2021-06-14 16:24:21.398 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:24:26.341 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:26.342 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:26.342 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:24:26.342 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:26.390 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:26.390 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:26.390 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:26.459 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:26.459 SC Data - All Services | Received logon response. | 2021-06-14 16:24:26.533 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:26.533 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:26.533 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:26.533 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:26.533 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:26.533 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:26.533 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:26.533 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:26.533 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:26.571 DTC Client socket (1) | Closed. | 2021-06-14 16:24:26.572 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:24:31.535 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:31.535 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:31.536 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:24:31.536 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:31.579 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:31.579 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:31.579 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:31.655 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:31.655 SC Data - All Services | Received logon response. | 2021-06-14 16:24:31.813 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:31.814 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:31.814 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:31.814 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:31.814 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:31.814 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:31.814 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:31.814 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:31.815 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:31.853 DTC Client socket (1) | Closed. | 2021-06-14 16:24:31.853 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2021-06-14 16:24:35.402 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:35.402 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:35.402 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:24:35.403 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:35.632 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:35.632 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:35.632 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:35.710 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:35.710 SC Data - All Services | Received logon response. | 2021-06-14 16:24:36.450 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:36.450 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:36.450 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:36.450 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:36.450 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:36.451 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:36.451 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:24:36.451 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:36.451 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:36.498 DTC Client socket (1) | Closed. | 2021-06-14 16:24:36.498 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:24:36.802 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:36.803 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:36.803 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:24:36.803 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:36.901 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:36.901 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:36.901 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:37.065 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:37.065 SC Data - All Services | Received logon response. | 2021-06-14 16:24:37.273 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:37.273 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:37.273 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:37.273 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:37.273 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:37.274 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:37.274 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:37.274 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:37.274 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:37.313 DTC Client socket (1) | Closed. | 2021-06-14 16:24:37.313 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:24:42.292 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:42.293 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:42.293 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:24:42.293 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:42.337 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:42.337 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:42.337 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:42.405 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:42.405 SC Data - All Services | Received logon response. | 2021-06-14 16:24:43.036 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:43.036 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:43.036 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:43.036 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:43.036 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:43.036 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:43.036 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:43.036 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:43.036 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:43.107 DTC Client socket (1) | Closed. | 2021-06-14 16:24:43.107 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:24:48.039 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:48.039 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:48.040 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:24:48.040 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:48.081 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:48.081 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:48.081 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:48.141 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:48.141 SC Data - All Services | Received logon response. | 2021-06-14 16:24:48.752 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:48.752 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:48.752 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:48.752 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:48.753 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:48.753 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:48.753 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:48.753 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:48.754 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:48.793 DTC Client socket (1) | Closed. | 2021-06-14 16:24:48.793 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:24:53.739 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:53.740 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:53.740 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:24:53.740 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:53.786 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:53.787 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:53.787 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:53.843 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:53.843 SC Data - All Services | Received logon response. | 2021-06-14 16:24:54.002 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:54.002 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:54.002 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:54.002 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:54.002 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:54.002 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:54.002 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:54.002 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:54.002 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:54.040 DTC Client socket (1) | Closed. | 2021-06-14 16:24:54.040 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:24:58.997 DTC Client socket (1) | Creating socket. | 2021-06-14 16:24:58.998 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:24:58.998 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:24:58.998 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:24:59.043 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:24:59.043 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:24:59.044 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:24:59.113 SC Data - All Services | Sending logon request message. | 2021-06-14 16:24:59.113 SC Data - All Services | Received logon response. | 2021-06-14 16:24:59.254 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:24:59.254 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:24:59.254 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:24:59.254 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:24:59.254 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:24:59.255 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:24:59.255 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:24:59.255 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:24:59.255 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:24:59.292 DTC Client socket (1) | Closed. | 2021-06-14 16:24:59.292 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:25:04.252 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:04.252 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:04.252 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:25:04.252 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:04.296 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:04.296 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:04.296 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:04.345 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:04.345 SC Data - All Services | Received logon response. | 2021-06-14 16:25:04.485 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:04.485 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:04.485 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:04.485 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:04.485 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:04.486 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:04.486 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:04.486 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:04.486 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:04.522 DTC Client socket (1) | Closed. | 2021-06-14 16:25:04.522 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:25:06.452 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:06.453 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:06.453 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:25:06.453 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:06.501 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:06.501 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:06.501 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:06.557 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:06.557 SC Data - All Services | Received logon response. | 2021-06-14 16:25:07.262 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:07.263 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:07.263 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:07.263 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:07.263 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:07.263 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:07.263 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:25:07.263 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:07.263 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:07.307 DTC Client socket (1) | Closed. | 2021-06-14 16:25:07.308 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:25:09.477 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:09.478 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:09.478 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:25:09.478 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:09.522 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:09.522 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:09.522 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:09.569 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:09.569 SC Data - All Services | Received logon response. | 2021-06-14 16:25:09.731 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:09.731 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:09.731 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:09.731 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:09.731 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:09.731 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:09.731 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:09.731 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:09.731 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:09.770 DTC Client socket (1) | Closed. | 2021-06-14 16:25:09.770 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:25:14.737 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:14.738 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:14.738 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:25:14.738 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:14.785 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:14.785 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:14.785 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:14.842 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:14.842 SC Data - All Services | Received logon response. | 2021-06-14 16:25:15.468 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:15.468 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:15.468 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:15.468 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:15.468 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:15.468 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:15.468 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:15.468 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:15.468 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:15.508 DTC Client socket (1) | Closed. | 2021-06-14 16:25:15.508 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:25:20.477 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:20.477 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:20.478 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:25:20.478 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:20.521 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:20.521 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:20.521 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:20.588 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:20.588 SC Data - All Services | Received logon response. | 2021-06-14 16:25:21.201 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:21.201 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:21.201 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:21.201 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:21.202 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:21.202 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:21.202 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:21.202 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:21.202 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:21.243 DTC Client socket (1) | Closed. | 2021-06-14 16:25:21.243 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:25:26.208 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:26.209 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:26.209 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:25:26.209 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:26.255 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:26.255 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:26.256 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:26.312 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:26.312 SC Data - All Services | Received logon response. | 2021-06-14 16:25:26.467 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:26.467 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:26.467 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:26.467 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:26.467 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:26.467 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:26.467 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:26.467 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:26.467 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:26.508 DTC Client socket (1) | Closed. | 2021-06-14 16:25:26.508 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:25:31.458 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:31.459 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:31.459 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:25:31.459 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:31.503 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:31.503 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:31.503 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:31.569 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:31.569 SC Data - All Services | Received logon response. | 2021-06-14 16:25:31.729 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:31.729 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:31.729 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:31.729 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:31.729 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:31.730 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:31.730 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:31.730 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:31.730 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:31.780 DTC Client socket (1) | Closed. | 2021-06-14 16:25:31.780 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:25:36.736 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:36.737 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:36.737 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:25:36.737 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:36.782 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:36.782 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:36.782 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:36.842 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:36.842 SC Data - All Services | Received logon response. | 2021-06-14 16:25:37.001 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:37.001 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:37.001 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:37.001 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:37.001 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:37.001 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:37.001 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:37.001 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:37.002 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:37.039 DTC Client socket (1) | Closed. | 2021-06-14 16:25:37.039 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:25:37.257 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:37.258 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:37.258 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:25:37.258 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:37.318 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:37.318 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:37.318 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:37.402 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:37.402 SC Data - All Services | Received logon response. | 2021-06-14 16:25:38.137 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:38.137 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:38.137 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:38.137 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:38.137 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:38.138 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:38.138 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:25:38.138 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:38.138 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:38.196 DTC Client socket (1) | Closed. | 2021-06-14 16:25:38.196 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:25:42.007 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:42.008 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:42.008 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:25:42.008 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:42.057 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:42.057 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:42.057 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:42.102 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:42.102 SC Data - All Services | Received logon response. | 2021-06-14 16:25:42.256 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:42.256 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:42.256 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:42.256 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:42.256 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:42.256 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:42.256 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:42.256 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:42.256 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:42.295 DTC Client socket (1) | Closed. | 2021-06-14 16:25:42.295 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:25:47.246 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:47.247 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:47.247 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:25:47.247 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:47.288 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:47.288 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:47.288 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:47.344 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:47.344 SC Data - All Services | Received logon response. | 2021-06-14 16:25:47.968 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:47.968 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:47.969 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:47.969 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:47.969 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:47.969 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:47.969 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:47.969 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:47.969 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:48.011 DTC Client socket (1) | Closed. | 2021-06-14 16:25:48.011 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:25:52.967 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:52.967 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:52.967 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:25:52.967 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:53.009 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:53.009 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:53.009 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:53.070 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:53.070 SC Data - All Services | Received logon response. | 2021-06-14 16:25:53.690 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:53.690 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:53.690 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:53.690 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:53.690 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:53.690 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:53.690 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:53.690 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:53.690 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:53.730 DTC Client socket (1) | Closed. | 2021-06-14 16:25:53.730 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:25:58.691 DTC Client socket (1) | Creating socket. | 2021-06-14 16:25:58.692 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:25:58.692 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:25:58.693 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:25:58.760 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:25:58.760 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:25:58.760 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:25:58.814 SC Data - All Services | Sending logon request message. | 2021-06-14 16:25:58.814 SC Data - All Services | Received logon response. | 2021-06-14 16:25:58.978 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:25:58.978 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:25:58.978 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:25:58.978 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:25:58.978 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:25:58.979 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:25:58.979 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:25:58.979 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:25:58.979 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:25:59.023 DTC Client socket (1) | Closed. | 2021-06-14 16:25:59.024 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:26:03.970 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:03.971 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:03.971 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:26:03.971 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:04.016 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:04.016 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:04.016 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:04.057 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:04.057 SC Data - All Services | Received logon response. | 2021-06-14 16:26:04.197 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:04.197 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:04.197 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:04.197 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:04.197 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:04.197 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:04.197 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:04.197 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:04.197 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:04.235 DTC Client socket (1) | Closed. | 2021-06-14 16:26:04.235 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:26:08.136 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:08.137 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:08.137 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:26:08.137 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:08.190 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:08.190 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:08.190 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:08.269 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:08.269 SC Data - All Services | Received logon response. | 2021-06-14 16:26:09.053 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:09.053 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:09.053 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:09.053 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:09.053 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:09.053 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:09.054 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:26:09.054 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:09.054 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:09.109 DTC Client socket (1) | Closed. | 2021-06-14 16:26:09.109 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:26:09.178 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:09.179 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:09.179 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:26:09.179 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:09.230 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:09.230 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:09.230 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:09.281 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:09.281 SC Data - All Services | Received logon response. | 2021-06-14 16:26:09.413 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:09.413 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:09.413 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:09.413 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:09.413 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:09.414 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:09.414 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:09.414 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:09.414 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:09.453 DTC Client socket (1) | Closed. | 2021-06-14 16:26:09.453 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:26:14.421 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:14.421 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:14.422 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:26:14.422 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:14.463 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:14.463 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:14.463 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:14.539 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:14.539 SC Data - All Services | Received logon response. | 2021-06-14 16:26:14.692 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:14.692 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:14.692 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:14.692 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:14.692 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:14.693 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:14.693 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:14.693 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:14.693 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:14.732 DTC Client socket (1) | Closed. | 2021-06-14 16:26:14.732 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:26:19.697 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:19.697 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:19.697 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:26:19.697 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:19.741 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:19.741 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:19.741 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:19.811 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:19.811 SC Data - All Services | Received logon response. | 2021-06-14 16:26:20.439 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:20.439 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:20.439 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:20.439 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:20.439 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:20.440 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:20.440 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:20.440 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:20.440 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:20.480 DTC Client socket (1) | Closed. | 2021-06-14 16:26:20.480 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:26:25.430 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:25.430 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:25.430 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:26:25.430 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:25.475 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:25.475 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:25.475 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:25.534 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:25.534 SC Data - All Services | Received logon response. | 2021-06-14 16:26:26.129 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:26.129 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:26.129 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:26.129 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:26.129 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:26.129 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:26.129 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:26.129 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:26.130 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:26.172 DTC Client socket (1) | Closed. | 2021-06-14 16:26:26.172 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:26:31.120 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:31.121 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:31.121 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:26:31.121 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:31.161 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:31.161 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:31.161 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:31.218 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:31.218 SC Data - All Services | Received logon response. | 2021-06-14 16:26:31.361 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:31.361 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:31.361 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:31.361 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:31.361 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:31.361 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:31.361 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:31.361 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:31.361 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:31.402 DTC Client socket (1) | Closed. | 2021-06-14 16:26:31.402 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:26:36.359 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:36.359 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:36.360 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:26:36.360 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:36.401 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:36.401 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:36.402 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:36.448 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:36.448 SC Data - All Services | Received logon response. | 2021-06-14 16:26:36.605 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:36.605 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:36.605 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:36.605 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:36.605 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:36.606 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:36.606 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:36.606 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:36.606 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:36.641 DTC Client socket (1) | Closed. | 2021-06-14 16:26:36.641 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2021-06-14 16:26:39.055 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:39.056 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:39.056 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:26:39.056 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:39.101 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:39.101 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:39.101 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:39.150 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:39.150 SC Data - All Services | Received logon response. | 2021-06-14 16:26:39.852 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:39.852 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:39.852 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:39.852 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:39.852 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:39.853 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:39.853 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:26:39.853 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:39.853 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:39.896 DTC Client socket (1) | Closed. | 2021-06-14 16:26:39.896 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:26:41.591 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:41.592 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:41.592 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:26:41.592 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:41.637 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:41.637 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:41.637 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:41.691 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:41.691 SC Data - All Services | Received logon response. | 2021-06-14 16:26:41.749 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:41.749 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:41.749 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:41.749 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:41.749 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:41.749 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:41.750 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:41.750 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:41.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:41.795 DTC Client socket (1) | Closed. | 2021-06-14 16:26:41.795 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:26:46.749 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:46.750 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:46.750 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:26:46.750 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:46.800 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:46.800 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:46.800 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:46.843 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:46.843 SC Data - All Services | Received logon response. | 2021-06-14 16:26:46.984 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:46.984 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:46.984 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:46.984 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:46.984 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:46.985 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:46.985 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:46.985 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:46.985 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:47.023 DTC Client socket (1) | Closed. | 2021-06-14 16:26:47.023 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:26:51.973 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:51.974 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:51.974 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:26:51.974 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:52.019 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:52.019 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:52.019 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:52.094 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:52.094 SC Data - All Services | Received logon response. | 2021-06-14 16:26:52.738 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:52.738 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:52.738 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:52.738 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:52.738 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:52.739 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:52.739 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:52.739 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:52.739 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:52.792 DTC Client socket (1) | Closed. | 2021-06-14 16:26:52.792 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:26:57.733 DTC Client socket (1) | Creating socket. | 2021-06-14 16:26:57.734 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:26:57.734 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:26:57.734 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:26:57.778 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:26:57.778 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:26:57.778 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:26:57.837 SC Data - All Services | Sending logon request message. | 2021-06-14 16:26:57.837 SC Data - All Services | Received logon response. | 2021-06-14 16:26:58.456 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:26:58.456 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:26:58.456 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:26:58.456 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:26:58.456 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:26:58.457 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:26:58.457 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:26:58.457 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:26:58.457 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:26:58.501 DTC Client socket (1) | Closed. | 2021-06-14 16:26:58.501 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:27:03.451 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:03.452 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:03.452 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:27:03.452 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:03.495 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:03.495 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:03.495 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:03.563 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:03.563 SC Data - All Services | Received logon response. | 2021-06-14 16:27:03.706 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:03.706 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:03.707 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:03.707 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:03.707 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:03.707 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:03.707 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:03.707 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:03.708 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:03.746 DTC Client socket (1) | Closed. | 2021-06-14 16:27:03.746 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:27:08.693 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:08.694 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:08.694 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:27:08.694 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:08.740 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:08.740 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:08.741 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:08.807 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:08.807 SC Data - All Services | Received logon response. | 2021-06-14 16:27:08.948 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:08.948 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:08.948 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:08.948 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:08.948 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:08.949 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:08.949 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:08.949 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:08.949 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:08.992 DTC Client socket (1) | Closed. | 2021-06-14 16:27:08.992 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:27:09.834 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:09.835 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:09.835 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:27:09.835 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:09.892 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:09.892 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:09.892 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:09.950 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:09.950 SC Data - All Services | Received logon response. | 2021-06-14 16:27:10.671 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:10.671 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:10.671 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:10.671 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:10.671 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:10.672 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:10.672 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:27:10.672 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:10.672 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:10.717 DTC Client socket (1) | Closed. | 2021-06-14 16:27:10.717 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:27:13.955 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:13.956 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:13.956 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:27:13.956 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:14.000 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:14.000 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:14.000 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:14.063 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:14.063 SC Data - All Services | Received logon response. | 2021-06-14 16:27:14.188 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:14.188 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:14.188 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:14.188 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:14.188 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:14.189 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:14.190 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:14.190 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:14.190 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:14.229 DTC Client socket (1) | Closed. | 2021-06-14 16:27:14.229 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:27:19.188 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:19.190 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:19.190 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:27:19.190 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:19.230 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:19.230 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:19.230 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:19.300 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:19.300 SC Data - All Services | Received logon response. | 2021-06-14 16:27:19.442 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:19.442 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:19.442 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:19.442 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:19.442 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:19.442 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:19.442 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:19.442 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:19.442 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:19.482 DTC Client socket (1) | Closed. | 2021-06-14 16:27:19.482 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:27:24.437 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:24.438 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:24.438 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:27:24.438 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:24.480 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:24.480 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:24.480 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:24.530 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:24.531 SC Data - All Services | Received logon response. | 2021-06-14 16:27:25.141 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:25.141 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:25.141 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:25.141 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:25.141 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:25.141 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:25.141 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:25.142 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:25.142 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:25.182 DTC Client socket (1) | Closed. | 2021-06-14 16:27:25.182 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:27:30.135 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:30.137 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:30.137 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:27:30.137 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:30.182 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:30.182 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:30.182 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:30.243 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:30.243 SC Data - All Services | Received logon response. | 2021-06-14 16:27:30.855 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:30.855 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:30.855 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:30.855 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:30.855 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:30.856 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:30.856 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:30.856 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:30.856 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:30.897 DTC Client socket (1) | Closed. | 2021-06-14 16:27:30.897 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:27:35.852 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:35.853 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:35.853 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:27:35.853 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:35.897 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:35.897 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:35.897 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:35.968 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:35.968 SC Data - All Services | Received logon response. | 2021-06-14 16:27:36.108 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:36.108 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:36.108 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:36.108 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:36.108 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:36.108 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:36.108 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:36.108 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:36.108 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:36.146 DTC Client socket (1) | Closed. | 2021-06-14 16:27:36.146 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-06-14 16:27:40.672 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:40.672 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:40.672 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:27:40.672 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:40.731 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:40.731 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:40.731 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:40.814 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:40.814 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:27:41.109 DTC Client socket (4) | Creating socket. | 2021-06-14 16:27:41.110 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:27:41.110 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:27:41.110 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:41.154 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:41.154 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:41.154 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:41.230 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:41.230 SC Data - All Services | Received logon response. | 2021-06-14 16:27:41.376 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:41.376 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:41.376 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:41.377 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:41.377 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:27:41.377 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:41.377 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:41.377 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:41.378 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:27:41.422 DTC Client socket (4) | Closed. | 2021-06-14 16:27:41.422 SC Data - All Services | Received logon response. | 2021-06-14 16:27:41.533 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:41.533 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:41.533 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:41.533 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:41.533 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:41.534 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:41.534 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:27:41.534 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:41.534 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:41.589 DTC Client socket (1) | Closed. | 2021-06-14 16:27:41.589 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:27:46.373 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:46.374 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:46.375 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:27:46.375 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:46.423 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:46.423 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:46.423 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:46.469 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:46.469 SC Data - All Services | Received logon response. | 2021-06-14 16:27:46.609 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:46.609 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:46.609 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:46.609 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:46.609 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:46.610 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:46.610 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:46.610 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:46.610 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:46.650 DTC Client socket (1) | Closed. | 2021-06-14 16:27:46.650 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:27:51.604 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:51.605 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:51.605 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:27:51.605 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:51.653 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:51.653 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:51.653 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:51.725 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:51.725 SC Data - All Services | Received logon response. | 2021-06-14 16:27:51.884 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:51.884 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:51.884 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:51.884 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:51.884 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:51.884 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:51.885 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:51.885 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:51.885 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:51.921 DTC Client socket (1) | Closed. | 2021-06-14 16:27:51.921 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:27:56.883 DTC Client socket (1) | Creating socket. | 2021-06-14 16:27:56.884 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:27:56.885 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:27:56.885 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:27:56.931 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:27:56.931 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:27:56.931 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:27:56.998 SC Data - All Services | Sending logon request message. | 2021-06-14 16:27:56.998 SC Data - All Services | Received logon response. | 2021-06-14 16:27:57.609 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:27:57.609 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:27:57.609 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:27:57.609 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:27:57.609 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:27:57.610 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:27:57.610 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:27:57.610 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:27:57.610 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:27:57.649 DTC Client socket (1) | Closed. | 2021-06-14 16:27:57.649 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:28:02.609 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:02.610 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:02.610 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:28:02.610 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:02.656 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:02.656 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:02.656 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:02.716 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:02.716 SC Data - All Services | Received logon response. | 2021-06-14 16:28:03.365 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:03.365 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:03.365 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:03.365 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:03.365 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:03.367 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:03.367 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:03.367 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:03.368 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:03.408 DTC Client socket (1) | Closed. | 2021-06-14 16:28:03.408 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:28:08.355 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:08.356 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:08.356 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:28:08.356 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:08.401 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:08.401 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:08.402 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:08.467 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:08.467 SC Data - All Services | Received logon response. | 2021-06-14 16:28:08.632 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:08.632 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:08.632 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:08.632 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:08.632 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:08.633 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:08.633 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:08.633 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:08.633 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:08.673 DTC Client socket (1) | Closed. | 2021-06-14 16:28:08.673 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:28:11.522 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:11.523 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:11.523 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:28:11.523 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:11.586 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:11.586 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:11.586 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:11.672 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:11.672 SC Data - All Services | Received logon response. | 2021-06-14 16:28:11.734 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:11.734 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:11.734 SC Data - All Services | Logon error received from server: Maximum connections reached. | 2021-06-14 16:28:11.734 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:11.734 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:11.734 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:11.734 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-14 16:28:11.734 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:11.734 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:11.786 DTC Client socket (1) | Closed. | 2021-06-14 16:28:11.786 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:28:13.620 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:13.621 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:13.621 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:28:13.621 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:13.664 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:13.664 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:13.664 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:13.723 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:13.723 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:28:13.730 DTC Client socket (4) | Creating socket. | 2021-06-14 16:28:13.730 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:28:13.730 DTC Client socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:28:13.730 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:13.779 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:13.779 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:13.779 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:13.837 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:13.837 SC Data - All Services | Received logon response. | 2021-06-14 16:28:13.886 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:13.886 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:13.886 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:13.886 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:13.886 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:13.887 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:13.887 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:13.887 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:13.887 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:13.926 DTC Client socket (1) | Closed. | 2021-06-14 16:28:13.926 SC Data - All Services | Received logon response. | 2021-06-14 16:28:14.544 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:14.544 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:14.544 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:14.544 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:14.544 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:28:14.545 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:14.545 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:28:14.545 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:14.545 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:28:14.590 DTC Client socket (4) | Closed. | 2021-06-14 16:28:14.590 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:28:18.893 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:18.894 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:18.894 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:28:18.894 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:18.938 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:18.938 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:18.938 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:19.000 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:19.000 SC Data - All Services | Received logon response. | 2021-06-14 16:28:19.155 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:19.155 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:19.155 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:19.155 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:19.155 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:19.155 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:19.155 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:19.155 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:19.155 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:19.192 DTC Client socket (1) | Closed. | 2021-06-14 16:28:19.192 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:28:24.141 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:24.142 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:24.143 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:28:24.143 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:24.188 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:24.188 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:24.188 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:24.238 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:24.238 SC Data - All Services | Received logon response. | 2021-06-14 16:28:24.378 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:24.378 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:24.378 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:24.378 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:24.378 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:24.379 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:24.379 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:24.379 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:24.379 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:24.423 DTC Client socket (1) | Closed. | 2021-06-14 16:28:24.423 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:28:29.374 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:29.375 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:29.376 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:28:29.376 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:29.424 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:29.424 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:29.425 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:29.470 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:29.470 SC Data - All Services | Received logon response. | 2021-06-14 16:28:30.093 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:30.093 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:30.093 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:30.093 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:30.093 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:30.094 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:30.094 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:30.094 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:30.094 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:30.144 DTC Client socket (1) | Closed. | 2021-06-14 16:28:30.144 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:28:35.091 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:35.092 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:35.093 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:28:35.093 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:35.139 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:35.139 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:35.140 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:35.187 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:35.187 SC Data - All Services | Received logon response. | 2021-06-14 16:28:35.781 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:35.781 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:35.781 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:35.781 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:35.782 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:35.782 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:35.783 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:35.783 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:35.783 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:35.824 DTC Client socket (1) | Closed. | 2021-06-14 16:28:35.824 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:28:40.780 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:40.781 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:40.781 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:28:40.781 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:40.827 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:40.827 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:40.827 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:40.879 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:40.879 SC Data - All Services | Received logon response. | 2021-06-14 16:28:41.018 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:41.018 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:41.018 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:41.018 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:41.018 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:41.018 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:41.018 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:41.018 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:41.019 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:41.064 DTC Client socket (1) | Closed. | 2021-06-14 16:28:41.064 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-06-14 16:28:44.544 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:44.545 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:44.546 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:28:44.546 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:44.592 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:44.592 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:44.592 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:44.659 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:44.659 SC Data - All Services | Received logon response. | 2021-06-14 16:28:45.356 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:45.356 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:45.356 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:45.356 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:45.356 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:45.357 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:45.357 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:45.357 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:28:45.357 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:45.498 DTC Client socket (1) | Closed. | 2021-06-14 16:28:45.499 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:28:46.017 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:46.018 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:46.018 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:28:46.018 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:46.063 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:46.063 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:46.063 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:46.117 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:46.117 SC Data - All Services | Received logon response. | 2021-06-14 16:28:46.265 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:46.265 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:46.265 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:46.265 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:46.265 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:46.265 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:46.265 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:46.265 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:46.266 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:46.306 DTC Client socket (1) | Closed. | 2021-06-14 16:28:46.306 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:28:51.250 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:51.250 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:51.251 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:28:51.251 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:51.300 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:51.300 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:51.300 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:51.372 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:51.372 SC Data - All Services | Received logon response. | 2021-06-14 16:28:51.518 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:51.518 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:51.518 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:51.518 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:51.518 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:51.519 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:51.519 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:51.519 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:51.519 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:51.556 DTC Client socket (1) | Closed. | 2021-06-14 16:28:51.556 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:28:56.510 DTC Client socket (1) | Creating socket. | 2021-06-14 16:28:56.510 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:28:56.510 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:28:56.511 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:28:56.555 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:28:56.555 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:28:56.555 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:28:56.617 SC Data - All Services | Sending logon request message. | 2021-06-14 16:28:56.617 SC Data - All Services | Received logon response. | 2021-06-14 16:28:56.756 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:28:56.756 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:28:56.756 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:28:56.756 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:28:56.756 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:28:56.756 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:28:56.756 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:28:56.756 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:28:56.756 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:28:56.801 DTC Client socket (1) | Closed. | 2021-06-14 16:28:56.801 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:29:01.739 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:01.739 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:01.739 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:29:01.739 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:01.782 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:01.782 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:01.782 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:01.842 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:01.842 SC Data - All Services | Received logon response. | 2021-06-14 16:29:02.459 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:02.459 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:02.459 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:02.459 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:02.459 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:02.459 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:02.459 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:02.459 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:02.459 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:02.503 DTC Client socket (1) | Closed. | 2021-06-14 16:29:02.504 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:29:07.451 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:07.451 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:07.451 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:29:07.451 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:07.491 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:07.491 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:07.491 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:07.554 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:07.554 SC Data - All Services | Received logon response. | 2021-06-14 16:29:08.154 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:08.154 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:08.154 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:08.154 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:08.154 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:08.155 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:08.155 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:08.155 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:08.155 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:08.194 DTC Client socket (1) | Closed. | 2021-06-14 16:29:08.194 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:29:13.145 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:13.146 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:13.146 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:29:13.146 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:13.189 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:13.189 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:13.189 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:13.251 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:13.251 SC Data - All Services | Received logon response. | 2021-06-14 16:29:13.390 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:13.390 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:13.390 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:13.390 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:13.390 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:13.391 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:13.391 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:13.391 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:13.391 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:13.434 DTC Client socket (1) | Closed. | 2021-06-14 16:29:13.434 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-06-14 16:29:15.350 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:15.351 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:15.351 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:29:15.351 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:15.407 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:15.407 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:15.407 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:15.473 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:15.473 SC Data - All Services | Received logon response. | 2021-06-14 16:29:16.193 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:16.193 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:16.193 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:16.193 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:16.193 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:16.193 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:16.193 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:29:16.194 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:16.194 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:16.246 DTC Client socket (1) | Closed. | 2021-06-14 16:29:16.247 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:29:18.381 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:18.382 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:18.382 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:29:18.383 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:18.425 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:18.425 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:18.426 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:18.470 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:18.470 SC Data - All Services | Received logon response. | 2021-06-14 16:29:18.568 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:18.568 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:18.568 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:18.568 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:18.568 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:18.569 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:18.570 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:18.570 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:18.570 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:18.609 DTC Client socket (1) | Closed. | 2021-06-14 16:29:18.609 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:29:23.571 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:23.572 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:23.572 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:29:23.572 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:23.613 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:23.613 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:23.613 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:23.656 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:23.656 SC Data - All Services | Received logon response. | 2021-06-14 16:29:23.799 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:23.799 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:23.799 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:23.799 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:23.799 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:23.800 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:23.800 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:23.800 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:23.800 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:23.841 DTC Client socket (1) | Closed. | 2021-06-14 16:29:23.842 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:29:28.788 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:28.789 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:28.789 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:29:28.789 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:28.830 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:28.830 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:28.831 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:28.902 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:28.902 SC Data - All Services | Received logon response. | 2021-06-14 16:29:29.046 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:29.046 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:29.046 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:29.046 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:29.046 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:29.047 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:29.047 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:29.047 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:29.047 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:29.082 DTC Client socket (1) | Closed. | 2021-06-14 16:29:29.083 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:29:34.037 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:34.038 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:34.038 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:29:34.038 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:34.095 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:34.095 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:34.095 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:34.156 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:34.156 SC Data - All Services | Received logon response. | 2021-06-14 16:29:34.772 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:34.772 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:34.772 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:34.772 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:34.772 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:34.773 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:34.773 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:34.773 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:34.773 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:34.814 DTC Client socket (1) | Closed. | 2021-06-14 16:29:34.814 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:29:39.770 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:39.771 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:39.772 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:29:39.772 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:39.816 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:39.816 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:39.816 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:39.866 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:39.866 SC Data - All Services | Received logon response. | 2021-06-14 16:29:40.507 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:40.507 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:40.507 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:40.508 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:40.508 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:40.508 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:40.508 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:40.508 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:40.508 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:40.550 DTC Client socket (1) | Closed. | 2021-06-14 16:29:40.550 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:29:45.519 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:45.520 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:45.520 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:29:45.520 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:45.564 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:45.565 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:45.565 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:45.626 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:45.626 SC Data - All Services | Received logon response. | 2021-06-14 16:29:45.763 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:45.763 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:45.763 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:45.763 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:45.763 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:45.763 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:45.763 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:45.763 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:45.763 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:45.799 DTC Client socket (1) | Closed. | 2021-06-14 16:29:45.799 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:29:46.206 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:46.207 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:46.207 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:29:46.207 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:46.261 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:46.261 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:46.261 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:46.336 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:46.336 SC Data - All Services | Received logon response. | 2021-06-14 16:29:47.180 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:47.180 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:47.180 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:47.180 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:47.180 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:47.181 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:47.181 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:29:47.181 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:47.181 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:47.230 DTC Client socket (1) | Closed. | 2021-06-14 16:29:47.231 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:29:50.752 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:50.754 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:50.754 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:29:50.754 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:50.796 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:50.796 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:50.796 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:50.856 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:50.856 SC Data - All Services | Received logon response. | 2021-06-14 16:29:50.948 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:50.948 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:50.948 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:50.948 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:50.948 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:50.949 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:50.949 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:50.949 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:50.949 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:50.990 DTC Client socket (1) | Closed. | 2021-06-14 16:29:50.990 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:29:55.939 DTC Client socket (1) | Creating socket. | 2021-06-14 16:29:55.940 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:29:55.940 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:29:55.940 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:29:55.984 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:29:55.984 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:29:55.984 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:29:56.032 SC Data - All Services | Sending logon request message. | 2021-06-14 16:29:56.032 SC Data - All Services | Received logon response. | 2021-06-14 16:29:56.164 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:29:56.164 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:29:56.164 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:29:56.164 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:29:56.164 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:29:56.165 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:29:56.165 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:29:56.165 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:29:56.165 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:29:56.202 DTC Client socket (1) | Closed. | 2021-06-14 16:29:56.202 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:30:01.157 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:01.158 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:01.158 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:30:01.158 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:01.202 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:01.202 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:01.202 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:01.255 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:01.255 SC Data - All Services | Received logon response. | 2021-06-14 16:30:01.385 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:01.385 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:01.385 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:01.385 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:01.385 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:01.386 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:01.386 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:01.386 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:01.386 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:01.421 DTC Client socket (1) | Closed. | 2021-06-14 16:30:01.421 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:30:06.368 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:06.368 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:06.368 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:30:06.368 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:06.414 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:06.414 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:06.414 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:06.469 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:06.469 SC Data - All Services | Received logon response. | 2021-06-14 16:30:07.482 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:07.482 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:07.482 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:07.482 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:07.482 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:07.483 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:07.483 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:07.483 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:07.483 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:07.525 DTC Client socket (1) | Closed. | 2021-06-14 16:30:07.525 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:30:12.486 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:12.487 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:12.487 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:30:12.487 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:12.531 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:12.531 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:12.531 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:12.591 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:12.591 SC Data - All Services | Received logon response. | 2021-06-14 16:30:13.230 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:13.230 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:13.230 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:13.230 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:13.230 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:13.230 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:13.230 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:13.230 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:13.231 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:13.271 DTC Client socket (1) | Closed. | 2021-06-14 16:30:13.271 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:30:17.168 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:17.169 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:17.170 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:30:17.170 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:17.215 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:17.215 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:17.215 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:17.272 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:17.272 SC Data - All Services | Received logon response. | 2021-06-14 16:30:17.959 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:17.959 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:17.959 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:17.959 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:17.959 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:17.960 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:17.960 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:30:17.960 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:17.960 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:18.003 DTC Client socket (1) | Closed. | 2021-06-14 16:30:18.003 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:30:18.215 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:18.215 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:18.215 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:30:18.215 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:18.263 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:18.263 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:18.263 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:18.313 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:18.313 SC Data - All Services | Received logon response. | 2021-06-14 16:30:18.449 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:18.449 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:18.449 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:18.449 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:18.449 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:18.450 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:18.450 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:18.450 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:18.450 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:18.490 DTC Client socket (1) | Closed. | 2021-06-14 16:30:18.490 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:30:23.447 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:23.448 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:23.448 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:30:23.449 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:23.493 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:23.493 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:23.493 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:23.564 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:23.564 SC Data - All Services | Received logon response. | 2021-06-14 16:30:23.719 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:23.719 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:23.719 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:23.719 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:23.719 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:23.720 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:23.720 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:23.720 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:23.720 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:23.758 DTC Client socket (1) | Closed. | 2021-06-14 16:30:23.758 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:30:28.727 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:28.728 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:28.728 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:30:28.728 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:28.769 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:28.769 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:28.769 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:28.842 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:28.842 SC Data - All Services | Received logon response. | 2021-06-14 16:30:28.985 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:28.985 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:28.985 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:28.985 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:28.985 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:28.985 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:28.985 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:28.985 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:28.986 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:29.022 DTC Client socket (1) | Closed. | 2021-06-14 16:30:29.022 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:30:33.987 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:33.988 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:33.988 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:30:33.988 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:34.034 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:34.034 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:34.034 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:34.090 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:34.090 SC Data - All Services | Received logon response. | 2021-06-14 16:30:34.232 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:34.232 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:34.232 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:34.232 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:34.232 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:34.232 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:34.232 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:34.232 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:34.233 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:34.277 DTC Client socket (1) | Closed. | 2021-06-14 16:30:34.277 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:30:39.212 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:39.212 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:39.212 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:30:39.212 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:39.256 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:39.256 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:39.257 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:39.314 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:39.314 SC Data - All Services | Received logon response. | 2021-06-14 16:30:39.938 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:39.938 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:39.938 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:39.938 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:39.938 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:39.938 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:39.938 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:39.938 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:39.939 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:39.978 DTC Client socket (1) | Closed. | 2021-06-14 16:30:39.979 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:30:44.929 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:44.930 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:44.930 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:30:44.931 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:44.972 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:44.972 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:44.972 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:45.040 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:45.040 SC Data - All Services | Received logon response. | 2021-06-14 16:30:45.669 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:45.669 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:45.669 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:45.669 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:45.669 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:45.669 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:45.669 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:45.669 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:45.670 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:45.711 DTC Client socket (1) | Closed. | 2021-06-14 16:30:45.711 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:30:47.949 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:47.950 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:47.950 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:30:47.950 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:47.994 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:47.994 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:47.994 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:48.066 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:48.066 SC Data - All Services | Received logon response. | 2021-06-14 16:30:48.756 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:48.756 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:48.756 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:48.756 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:48.756 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:48.757 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:48.757 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:30:48.757 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:48.757 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:48.802 DTC Client socket (1) | Closed. | 2021-06-14 16:30:48.802 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:30:50.668 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:50.668 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:50.668 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:30:50.668 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:50.708 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:50.708 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:50.708 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:50.780 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:50.780 SC Data - All Services | Received logon response. | 2021-06-14 16:30:50.921 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:50.921 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:50.921 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:50.921 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:50.921 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:50.922 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:50.922 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:50.922 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:50.922 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:50.959 DTC Client socket (1) | Closed. | 2021-06-14 16:30:50.959 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:30:55.917 DTC Client socket (1) | Creating socket. | 2021-06-14 16:30:55.918 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:30:55.918 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:30:55.918 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:30:55.964 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:30:55.964 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:30:55.964 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:30:56.012 SC Data - All Services | Sending logon request message. | 2021-06-14 16:30:56.012 SC Data - All Services | Received logon response. | 2021-06-14 16:30:56.168 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:30:56.168 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:30:56.168 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:30:56.168 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:30:56.168 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:30:56.168 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:30:56.168 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:30:56.168 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:30:56.168 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:30:56.205 DTC Client socket (1) | Closed. | 2021-06-14 16:30:56.205 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:31:01.170 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:01.170 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:01.171 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:31:01.171 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:01.212 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:01.212 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:01.213 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:01.280 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:01.280 SC Data - All Services | Received logon response. | 2021-06-14 16:31:01.419 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:01.419 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:01.419 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:01.419 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:01.419 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:01.419 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:01.420 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:01.420 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:01.420 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:01.456 DTC Client socket (1) | Closed. | 2021-06-14 16:31:01.456 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:31:06.423 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:06.424 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:06.424 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:31:06.424 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:06.464 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:06.464 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:06.464 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:06.515 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:06.515 SC Data - All Services | Received logon response. | 2021-06-14 16:31:06.659 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:06.659 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:06.659 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:06.659 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:06.659 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:06.660 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:06.660 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:06.660 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:06.660 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:06.696 DTC Client socket (1) | Closed. | 2021-06-14 16:31:06.696 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:31:11.649 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:11.649 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:11.649 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:31:11.649 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:11.691 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:11.691 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:11.691 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:11.748 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:11.748 SC Data - All Services | Received logon response. | 2021-06-14 16:31:12.342 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:12.342 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:12.342 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:12.342 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:12.342 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:12.343 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:12.343 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:12.343 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:12.343 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:12.382 DTC Client socket (1) | Closed. | 2021-06-14 16:31:12.382 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:31:17.331 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:17.332 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:17.332 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:31:17.332 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:17.378 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:17.378 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:17.379 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:17.448 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:17.448 SC Data - All Services | Received logon response. | 2021-06-14 16:31:18.079 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:18.079 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:18.079 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:18.079 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:18.079 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:18.080 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:18.080 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:18.080 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:18.080 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:18.122 DTC Client socket (1) | Closed. | 2021-06-14 16:31:18.122 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-06-14 16:31:18.746 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:18.747 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:18.747 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:31:18.747 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:18.806 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:18.806 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:18.806 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:18.888 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:18.888 SC Data - All Services | Received logon response. | 2021-06-14 16:31:19.608 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:19.608 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:19.608 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:19.608 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:19.608 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:19.608 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:19.608 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:31:19.608 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:19.608 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:19.673 DTC Client socket (1) | Closed. | 2021-06-14 16:31:19.673 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:31:23.077 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:23.077 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:23.077 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:31:23.077 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:23.117 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:23.117 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:23.117 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:23.184 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:23.184 SC Data - All Services | Received logon response. | 2021-06-14 16:31:23.333 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:23.333 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:23.333 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:23.333 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:23.333 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:23.334 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:23.334 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:23.334 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:23.334 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:23.372 DTC Client socket (1) | Closed. | 2021-06-14 16:31:23.372 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:31:28.340 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:28.340 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:28.340 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:31:28.340 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:28.385 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:28.385 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:28.385 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:28.430 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:28.430 SC Data - All Services | Received logon response. | 2021-06-14 16:31:28.570 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:28.570 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:28.570 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:28.570 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:28.570 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:28.571 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:28.571 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:28.571 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:28.571 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:28.608 DTC Client socket (1) | Closed. | 2021-06-14 16:31:28.608 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:31:33.557 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:33.558 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:33.558 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:31:33.558 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:33.602 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:33.602 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:33.603 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:33.655 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:33.655 SC Data - All Services | Received logon response. | 2021-06-14 16:31:33.793 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:33.793 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:33.793 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:33.793 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:33.793 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:33.793 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:33.793 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:33.793 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:33.794 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:33.830 DTC Client socket (1) | Closed. | 2021-06-14 16:31:33.830 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:31:38.800 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:38.801 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:38.801 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:31:38.801 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:38.841 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:38.841 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:38.841 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:38.905 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:38.905 SC Data - All Services | Received logon response. | 2021-06-14 16:31:39.031 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:39.031 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:39.031 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:39.031 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:39.031 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:39.032 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:39.032 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:39.032 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:39.032 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:39.071 DTC Client socket (1) | Closed. | 2021-06-14 16:31:39.071 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:31:44.022 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:44.023 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:44.023 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:31:44.023 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:44.065 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:44.065 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:44.065 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:44.122 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:44.122 SC Data - All Services | Received logon response. | 2021-06-14 16:31:44.747 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:44.747 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:44.747 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:44.747 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:44.747 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:44.748 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:44.748 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:44.748 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:44.748 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:44.787 DTC Client socket (1) | Closed. | 2021-06-14 16:31:44.787 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:31:49.601 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:49.602 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:49.602 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:31:49.602 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:49.653 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:49.653 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:49.654 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:49.734 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:49.734 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:31:49.741 DTC Client socket (4) | Creating socket. | 2021-06-14 16:31:49.742 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:31:49.742 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:31:49.742 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:49.788 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:49.788 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:49.788 SC Data - All Services | Received logon response. | 2021-06-14 16:31:49.791 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:49.791 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:49.791 SC Data - All Services | Logon error received from server: Maximum connections reached. | 2021-06-14 16:31:49.791 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:49.791 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:49.792 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:49.792 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-14 16:31:49.792 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:49.792 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:49.844 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:49.845 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:49.848 DTC Client socket (1) | Closed. | 2021-06-14 16:31:49.849 SC Data - All Services | Received logon response. | 2021-06-14 16:31:50.469 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:50.469 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:50.469 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:50.469 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:50.469 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:31:50.469 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:50.469 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:50.469 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:50.470 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:31:50.512 DTC Client socket (4) | Closed. | 2021-06-14 16:31:50.512 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2021-06-14 16:31:51.793 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:51.794 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:51.794 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:31:51.794 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:51.842 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:51.842 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:51.842 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:51.895 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:51.895 SC Data - All Services | Received logon response. | 2021-06-14 16:31:52.585 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:52.585 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:52.585 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:52.585 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:52.585 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:52.585 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:52.585 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:31:52.585 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:52.585 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:52.636 DTC Client socket (1) | Closed. | 2021-06-14 16:31:52.636 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:31:55.471 DTC Client socket (1) | Creating socket. | 2021-06-14 16:31:55.471 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:31:55.471 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:31:55.471 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:31:55.514 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:31:55.514 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:31:55.514 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:31:55.562 SC Data - All Services | Sending logon request message. | 2021-06-14 16:31:55.562 SC Data - All Services | Received logon response. | 2021-06-14 16:31:55.707 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:31:55.707 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:31:55.707 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:31:55.707 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:31:55.707 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:31:55.708 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:31:55.708 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:31:55.708 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:31:55.708 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:31:55.746 DTC Client socket (1) | Closed. | 2021-06-14 16:31:55.746 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:32:00.710 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:00.711 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:00.711 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:32:00.711 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:00.757 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:00.758 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:00.758 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:00.821 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:00.821 SC Data - All Services | Received logon response. | 2021-06-14 16:32:00.978 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:00.978 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:00.978 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:00.979 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:00.979 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:00.979 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:00.979 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:00.979 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:00.979 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:01.017 DTC Client socket (1) | Closed. | 2021-06-14 16:32:01.017 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:32:05.959 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:05.960 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:05.960 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:32:05.960 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:06.003 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:06.003 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:06.004 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:06.060 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:06.060 SC Data - All Services | Received logon response. | 2021-06-14 16:32:06.209 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:06.209 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:06.209 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:06.209 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:06.209 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:06.209 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:06.209 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:06.209 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:06.209 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:06.246 DTC Client socket (1) | Closed. | 2021-06-14 16:32:06.246 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:32:11.221 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:11.222 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:11.222 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:32:11.222 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:11.271 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:11.271 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:11.272 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:11.322 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:11.322 SC Data - All Services | Received logon response. | 2021-06-14 16:32:11.496 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:11.496 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:11.496 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:11.496 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:11.496 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:11.496 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:11.496 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:11.497 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:11.497 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:11.540 DTC Client socket (1) | Closed. | 2021-06-14 16:32:11.540 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:32:16.493 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:16.493 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:16.493 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:32:16.493 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:16.533 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:16.533 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:16.534 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:16.591 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:16.591 SC Data - All Services | Received logon response. | 2021-06-14 16:32:17.201 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:17.201 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:17.201 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:17.201 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:17.201 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:17.201 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:17.201 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:17.202 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:17.202 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:17.241 DTC Client socket (1) | Closed. | 2021-06-14 16:32:17.241 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:32:22.202 DTC Client socket (4) | Creating socket. | 2021-06-14 16:32:22.202 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:32:22.202 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:32:22.202 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:22.240 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:22.240 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:22.240 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:22.306 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:22.306 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:32:22.584 DTC Client socket (5) | Creating socket. | 2021-06-14 16:32:22.584 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:32:22.585 DTC Client socket (5) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:32:22.585 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:22.634 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:22.634 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:22.634 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:22.689 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:22.689 SC Data - All Services | Received logon response. | 2021-06-14 16:32:22.969 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:22.969 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:22.969 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:22.969 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:22.970 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:32:22.970 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:22.970 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:22.970 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:22.971 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:32:23.017 DTC Client socket (4) | Closed. | 2021-06-14 16:32:23.017 SC Data - All Services | Received logon response. | 2021-06-14 16:32:23.377 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:23.378 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:23.378 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:23.378 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:23.378 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:32:23.378 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:23.378 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:32:23.378 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:23.379 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:32:23.422 DTC Client socket (5) | Closed. | 2021-06-14 16:32:23.423 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:32:27.962 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:27.963 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:27.963 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:32:27.963 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:28.005 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:28.005 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:28.005 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:28.060 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:28.060 SC Data - All Services | Received logon response. | 2021-06-14 16:32:28.186 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:28.186 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:28.186 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:28.186 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:28.186 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:28.187 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:28.187 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:28.187 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:28.187 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:28.222 DTC Client socket (1) | Closed. | 2021-06-14 16:32:28.222 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:32:33.182 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:33.183 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:33.183 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:32:33.183 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:33.233 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:33.233 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:33.233 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:33.283 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:33.283 SC Data - All Services | Received logon response. | 2021-06-14 16:32:33.441 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:33.441 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:33.441 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:33.441 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:33.441 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:33.442 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:33.442 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:33.442 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:33.442 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:33.477 DTC Client socket (1) | Closed. | 2021-06-14 16:32:33.477 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:32:38.457 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:38.458 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:38.458 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:32:38.458 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:38.502 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:38.502 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:38.502 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:38.560 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:38.560 SC Data - All Services | Received logon response. | 2021-06-14 16:32:38.687 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:38.687 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:38.687 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:38.687 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:38.687 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:38.687 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:38.687 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:38.688 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:38.688 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:38.725 DTC Client socket (1) | Closed. | 2021-06-14 16:32:38.725 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:32:43.671 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:43.672 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:43.673 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:32:43.673 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:43.719 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:43.719 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:43.719 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:43.791 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:43.791 SC Data - All Services | Received logon response. | 2021-06-14 16:32:43.950 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:43.950 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:43.950 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:43.950 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:43.950 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:43.951 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:43.951 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:43.951 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:43.951 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:43.989 DTC Client socket (1) | Closed. | 2021-06-14 16:32:43.989 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:32:48.929 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:48.930 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:48.930 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:32:48.930 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:48.985 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:48.985 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:48.985 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:49.060 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:49.060 SC Data - All Services | Received logon response. | 2021-06-14 16:32:49.687 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:49.687 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:49.687 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:49.687 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:49.687 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:49.688 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:49.688 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:49.688 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:49.688 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:49.730 DTC Client socket (1) | Closed. | 2021-06-14 16:32:49.730 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-06-14 16:32:53.372 DTC Client socket (1) | Creating socket. | 2021-06-14 16:32:53.373 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:32:53.373 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:32:53.373 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:53.507 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:53.507 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:53.507 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:53.651 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:53.651 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:32:54.667 DTC Client socket (4) | Creating socket. | 2021-06-14 16:32:54.667 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:32:54.668 DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:32:54.668 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:32:54.739 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:32:54.739 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:32:54.739 SC Data - All Services | Received logon response. | 2021-06-14 16:32:54.754 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:54.754 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:54.754 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:54.754 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:54.754 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:32:54.755 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:54.755 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:32:54.755 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:54.755 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:32:54.801 SC Data - All Services | Sending logon request message. | 2021-06-14 16:32:54.801 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:32:54.906 DTC Client socket (1) | Closed. | 2021-06-14 16:32:54.906 SC Data - All Services | Received logon response. | 2021-06-14 16:32:55.415 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:32:55.416 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:32:55.416 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:32:55.416 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:32:55.416 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:32:55.416 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:32:55.416 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:32:55.417 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:32:55.417 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:32:55.454 DTC Client socket (4) | Closed. | 2021-06-14 16:32:55.454 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:33:00.419 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:00.420 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:00.420 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:33:00.420 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:00.468 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:00.468 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:00.468 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:00.531 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:00.531 SC Data - All Services | Received logon response. | 2021-06-14 16:33:00.686 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:00.686 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:00.686 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:00.686 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:00.686 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:00.686 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:00.687 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:00.687 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:00.687 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:00.746 DTC Client socket (1) | Closed. | 2021-06-14 16:33:00.746 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:33:05.683 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:05.684 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:05.685 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:33:05.685 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:05.728 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:05.728 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:05.728 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:05.799 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:05.799 SC Data - All Services | Received logon response. | 2021-06-14 16:33:05.952 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:05.952 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:05.952 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:05.952 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:05.952 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:05.953 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:05.953 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:05.953 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:05.953 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:05.991 DTC Client socket (1) | Closed. | 2021-06-14 16:33:05.991 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:33:10.945 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:10.946 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:10.946 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:33:10.946 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:10.989 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:10.989 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:10.989 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:11.061 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:11.061 SC Data - All Services | Received logon response. | 2021-06-14 16:33:11.220 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:11.220 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:11.220 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:11.220 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:11.220 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:11.221 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:11.221 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:11.221 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:11.221 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:11.256 DTC Client socket (1) | Closed. | 2021-06-14 16:33:11.257 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:33:16.210 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:16.211 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:16.211 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:33:16.211 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:16.254 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:16.254 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:16.254 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:16.314 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:16.314 SC Data - All Services | Received logon response. | 2021-06-14 16:33:16.390 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:16.390 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:16.390 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:16.390 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:16.390 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:16.391 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:16.391 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:16.391 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:16.391 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:16.432 DTC Client socket (1) | Closed. | 2021-06-14 16:33:16.432 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:33:21.382 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:21.383 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:21.384 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:33:21.384 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:21.428 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:21.428 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:21.428 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:21.498 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:21.498 SC Data - All Services | Received logon response. | 2021-06-14 16:33:22.107 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:22.107 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:22.107 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:22.107 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:22.107 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:22.108 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:22.108 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:22.108 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:22.108 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:22.147 DTC Client socket (1) | Closed. | 2021-06-14 16:33:22.147 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:33:24.750 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:24.755 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:24.755 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:33:24.755 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:24.818 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:24.818 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:24.818 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:24.905 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:24.905 SC Data - All Services | Received logon response. | 2021-06-14 16:33:25.701 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:25.701 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:25.701 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:25.701 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:25.701 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:25.701 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:25.701 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:33:25.701 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:25.701 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:25.754 DTC Client socket (1) | Closed. | 2021-06-14 16:33:25.754 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:33:27.106 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:27.107 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:27.107 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:33:27.107 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:27.148 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:27.148 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:27.148 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:27.198 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:27.198 SC Data - All Services | Received logon response. | 2021-06-14 16:33:27.794 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:27.794 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:27.794 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:27.794 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:27.794 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:27.795 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:27.795 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:27.795 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:27.795 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:27.836 DTC Client socket (1) | Closed. | 2021-06-14 16:33:27.836 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:33:32.792 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:32.793 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:32.794 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:33:32.794 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:32.837 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:32.837 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:32.838 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:32.907 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:32.907 SC Data - All Services | Received logon response. | 2021-06-14 16:33:33.062 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:33.062 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:33.062 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:33.062 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:33.062 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:33.062 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:33.062 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:33.062 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:33.062 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:33.100 DTC Client socket (1) | Closed. | 2021-06-14 16:33:33.100 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:33:38.059 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:38.059 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:38.059 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:33:38.059 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:38.102 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:38.102 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:38.102 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:38.153 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:38.153 SC Data - All Services | Received logon response. | 2021-06-14 16:33:38.293 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:38.293 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:38.293 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:38.293 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:38.293 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:38.294 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:38.294 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:38.294 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:38.294 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:38.332 DTC Client socket (1) | Closed. | 2021-06-14 16:33:38.332 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:33:43.293 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:43.293 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:43.293 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:33:43.294 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:43.340 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:43.340 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:43.340 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:43.404 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:43.404 SC Data - All Services | Received logon response. | 2021-06-14 16:33:43.559 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:43.559 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:43.559 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:43.559 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:43.559 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:43.560 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:43.560 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:43.560 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:43.560 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:43.599 DTC Client socket (1) | Closed. | 2021-06-14 16:33:43.599 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:33:48.557 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:48.557 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:48.557 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:33:48.557 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:48.599 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:48.599 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:48.599 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:48.669 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:48.669 SC Data - All Services | Received logon response. | 2021-06-14 16:33:48.824 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:48.824 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:48.824 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:48.824 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:48.824 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:48.824 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:48.824 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:48.824 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:48.824 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:48.861 DTC Client socket (1) | Closed. | 2021-06-14 16:33:48.861 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:33:53.829 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:53.830 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:53.830 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:33:53.830 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:53.874 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:53.874 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:53.874 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:53.937 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:53.937 SC Data - All Services | Received logon response. | 2021-06-14 16:33:54.582 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:54.582 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:54.582 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:54.582 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:54.582 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:54.582 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:54.582 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:33:54.582 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:54.582 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:54.623 DTC Client socket (1) | Closed. | 2021-06-14 16:33:54.623 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2021-06-14 16:33:55.688 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:55.689 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:55.689 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:33:55.689 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:55.738 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:55.738 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:55.738 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:55.789 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:55.789 SC Data - All Services | Received logon response. | 2021-06-14 16:33:56.491 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:33:56.491 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:33:56.491 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:33:56.491 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:33:56.491 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:33:56.492 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:33:56.492 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:33:56.492 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:33:56.492 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:33:56.539 DTC Client socket (1) | Closed. | 2021-06-14 16:33:56.539 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:33:59.579 DTC Client socket (1) | Creating socket. | 2021-06-14 16:33:59.580 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:33:59.580 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:33:59.580 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:33:59.633 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:33:59.633 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:33:59.633 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:33:59.726 SC Data - All Services | Sending logon request message. | 2021-06-14 16:33:59.726 SC Data - All Services | Received logon response. | 2021-06-14 16:34:00.354 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:00.354 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:00.354 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:00.354 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:00.354 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:00.355 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:00.355 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:00.355 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:00.355 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:00.396 DTC Client socket (1) | Closed. | 2021-06-14 16:34:00.396 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:34:05.354 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:05.355 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:05.355 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:34:05.355 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:05.403 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:05.403 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:05.403 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:05.470 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:05.470 SC Data - All Services | Received logon response. | 2021-06-14 16:34:05.631 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:05.631 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:05.631 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:05.631 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:05.631 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:05.632 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:05.632 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:05.632 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:05.632 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:05.683 DTC Client socket (1) | Closed. | 2021-06-14 16:34:05.683 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:34:10.631 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:10.632 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:10.632 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:34:10.632 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:10.677 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:10.677 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:10.677 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:10.731 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:10.731 SC Data - All Services | Received logon response. | 2021-06-14 16:34:10.845 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:10.845 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:10.845 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:10.845 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:10.845 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:10.845 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:10.845 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:10.845 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:10.845 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:10.885 DTC Client socket (1) | Closed. | 2021-06-14 16:34:10.885 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:34:15.832 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:15.833 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:15.833 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:34:15.833 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:15.879 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:15.879 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:15.879 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:15.936 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:15.936 SC Data - All Services | Received logon response. | 2021-06-14 16:34:16.092 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:16.092 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:16.092 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:16.092 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:16.092 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:16.093 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:16.093 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:16.093 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:16.093 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:16.131 DTC Client socket (1) | Closed. | 2021-06-14 16:34:16.131 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:34:21.095 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:21.095 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:21.095 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:34:21.095 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:21.145 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:21.145 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:21.145 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:21.210 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:21.210 SC Data - All Services | Received logon response. | 2021-06-14 16:34:21.349 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:21.349 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:21.349 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:21.349 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:21.349 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:21.349 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:21.349 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:21.349 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:21.350 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:21.388 DTC Client socket (1) | Closed. | 2021-06-14 16:34:21.388 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:34:26.351 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:26.351 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:26.351 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:34:26.351 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:26.401 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:26.401 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:26.401 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:26.469 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:26.469 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-06-14 16:34:26.501 DTC Client socket (4) | Creating socket. | 2021-06-14 16:34:26.502 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:34:26.502 DTC Client socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:34:26.502 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:26.551 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:26.551 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:26.551 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:26.619 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:26.619 SC Data - All Services | Received logon response. | 2021-06-14 16:34:27.076 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:27.076 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:27.076 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:27.076 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:27.076 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:27.077 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:27.077 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:27.077 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:27.077 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:27.127 DTC Client socket (1) | Closed. | 2021-06-14 16:34:27.127 SC Data - All Services | Received logon response. | 2021-06-14 16:34:27.319 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:27.319 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:27.319 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:27.319 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:27.319 DTC Client socket (4) | CloseSocket call. | 2021-06-14 16:34:27.319 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:27.320 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:34:27.320 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:27.320 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-06-14 16:34:27.361 DTC Client socket (4) | Closed. | 2021-06-14 16:34:27.362 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:34:32.081 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:32.082 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:32.082 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:34:32.082 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:32.129 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:32.129 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:32.129 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:32.181 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:32.181 SC Data - All Services | Received logon response. | 2021-06-14 16:34:32.757 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:32.757 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:32.757 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:32.757 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:32.757 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:32.758 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:32.758 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:32.758 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:32.758 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:32.798 DTC Client socket (1) | Closed. | 2021-06-14 16:34:32.798 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:34:37.763 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:37.764 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:37.765 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:34:37.765 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:37.814 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:37.814 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:37.814 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:37.873 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:37.873 SC Data - All Services | Received logon response. | 2021-06-14 16:34:38.033 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:38.033 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:38.033 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:38.033 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:38.033 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:38.034 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:38.034 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:38.034 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:38.034 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:38.069 DTC Client socket (1) | Closed. | 2021-06-14 16:34:38.069 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:34:43.020 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:43.021 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:43.022 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:34:43.022 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:43.107 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:43.107 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:43.108 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:43.150 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:43.150 SC Data - All Services | Received logon response. | 2021-06-14 16:34:43.313 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:43.313 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:43.313 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:43.313 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:43.313 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:43.313 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:43.314 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:43.314 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:43.314 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:43.351 DTC Client socket (1) | Closed. | 2021-06-14 16:34:43.351 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:34:48.303 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:48.304 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:48.304 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:34:48.304 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:48.346 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:48.346 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:48.346 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:48.409 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:48.409 SC Data - All Services | Received logon response. | 2021-06-14 16:34:48.546 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:48.546 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:48.546 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:48.546 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:48.546 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:48.546 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:48.546 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:48.546 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:48.546 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:48.584 DTC Client socket (1) | Closed. | 2021-06-14 16:34:48.584 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:34:53.539 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:53.540 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:53.540 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:34:53.540 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:53.590 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:53.590 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:53.590 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:53.655 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:53.655 SC Data - All Services | Received logon response. | 2021-06-14 16:34:53.796 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:53.796 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:53.796 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:53.796 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:53.796 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:53.797 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:53.797 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:53.797 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:53.797 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:53.838 DTC Client socket (1) | Closed. | 2021-06-14 16:34:53.839 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-06-14 16:34:57.319 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:57.320 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:57.320 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:34:57.320 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:57.385 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:57.385 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:57.385 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:57.449 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:57.449 SC Data - All Services | Received logon response. | 2021-06-14 16:34:58.171 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:58.171 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:58.171 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:58.171 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:58.172 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:58.172 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:58.172 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:34:58.172 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:58.173 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:58.227 DTC Client socket (1) | Closed. | 2021-06-14 16:34:58.228 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:34:58.796 DTC Client socket (1) | Creating socket. | 2021-06-14 16:34:58.797 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:34:58.797 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:34:58.797 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:34:58.838 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:34:58.838 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:34:58.838 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:34:58.905 SC Data - All Services | Sending logon request message. | 2021-06-14 16:34:58.905 SC Data - All Services | Received logon response. | 2021-06-14 16:34:59.499 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:34:59.499 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:34:59.499 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:34:59.499 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:34:59.499 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:34:59.500 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:34:59.500 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:34:59.500 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:34:59.500 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:34:59.541 DTC Client socket (1) | Closed. | 2021-06-14 16:34:59.542 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:35:04.489 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:04.490 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:04.490 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:35:04.490 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:04.539 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:04.539 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:04.539 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:04.634 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:04.634 SC Data - All Services | Received logon response. | 2021-06-14 16:35:05.257 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:05.257 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:05.257 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:05.257 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:05.257 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:05.258 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:05.258 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:05.258 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:05.259 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:05.300 DTC Client socket (1) | Closed. | 2021-06-14 16:35:05.300 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:35:10.257 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:10.258 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:10.258 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:35:10.258 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:10.302 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:10.302 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:10.302 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:10.374 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:10.374 SC Data - All Services | Received logon response. | 2021-06-14 16:35:10.519 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:10.519 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:10.519 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:10.519 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:10.519 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:10.519 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:10.520 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:10.520 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:10.520 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:10.559 DTC Client socket (1) | Closed. | 2021-06-14 16:35:10.559 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:35:15.506 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:15.507 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:15.507 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:35:15.507 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:15.551 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:15.551 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:15.551 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:15.610 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:15.610 SC Data - All Services | Received logon response. | 2021-06-14 16:35:15.751 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:15.751 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:15.751 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:15.751 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:15.751 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:15.752 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:15.752 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:15.752 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:15.752 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:15.790 DTC Client socket (1) | Closed. | 2021-06-14 16:35:15.790 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:35:20.744 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:20.745 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:20.745 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:35:20.745 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:20.789 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:20.789 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:20.789 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:20.841 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:20.841 SC Data - All Services | Received logon response. | 2021-06-14 16:35:20.984 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:20.984 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:20.984 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:20.984 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:20.984 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:20.985 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:20.985 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:20.985 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:20.985 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:21.031 DTC Client socket (1) | Closed. | 2021-06-14 16:35:21.031 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:35:25.980 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:25.982 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:25.982 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:35:25.982 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:26.026 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:26.026 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:26.026 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:26.085 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:26.085 SC Data - All Services | Received logon response. | 2021-06-14 16:35:26.229 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:26.229 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:26.229 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:26.229 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:26.229 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:26.230 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:26.230 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:26.230 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:26.230 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:26.267 DTC Client socket (1) | Closed. | 2021-06-14 16:35:26.267 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:35:28.168 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:28.169 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:28.169 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:35:28.169 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:28.225 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:28.225 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:28.225 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:28.301 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:28.301 SC Data - All Services | Received logon response. | 2021-06-14 16:35:29.086 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:29.086 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:29.086 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:29.086 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:29.086 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:29.086 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:29.086 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:35:29.086 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:29.086 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:29.140 DTC Client socket (1) | Closed. | 2021-06-14 16:35:29.140 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:35:31.231 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:31.231 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:31.231 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:35:31.231 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:31.284 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:31.284 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:31.284 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:31.343 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:31.343 SC Data - All Services | Received logon response. | 2021-06-14 16:35:31.978 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:31.978 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:31.978 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:31.978 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:31.979 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:31.979 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:31.979 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:31.979 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:31.980 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:32.022 DTC Client socket (1) | Closed. | 2021-06-14 16:35:32.022 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:35:36.972 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:36.972 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:36.973 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:35:36.973 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:37.014 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:37.014 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:37.014 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:37.060 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:37.060 SC Data - All Services | Received logon response. | 2021-06-14 16:35:37.663 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:37.663 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:37.663 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:37.663 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:37.663 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:37.664 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:37.664 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:37.664 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:37.664 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:37.710 DTC Client socket (1) | Closed. | 2021-06-14 16:35:37.710 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:35:42.658 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:42.659 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:42.659 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:35:42.659 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:42.707 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:42.707 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:42.707 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:42.781 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:42.781 SC Data - All Services | Received logon response. | 2021-06-14 16:35:42.940 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:42.940 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:42.940 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:42.940 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:42.940 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:42.940 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:42.940 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:42.941 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:42.941 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:42.978 DTC Client socket (1) | Closed. | 2021-06-14 16:35:42.978 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:35:47.941 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:47.942 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:47.942 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:35:47.942 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:48.008 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:48.008 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:48.008 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:48.072 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:48.072 SC Data - All Services | Received logon response. | 2021-06-14 16:35:48.231 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:48.231 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:48.231 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:48.232 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:48.232 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:48.232 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:48.232 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:48.232 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:48.233 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:48.269 DTC Client socket (1) | Closed. | 2021-06-14 16:35:48.269 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:35:53.221 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:53.221 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:53.221 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:35:53.221 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:53.270 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:53.270 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:53.270 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:53.343 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:53.343 SC Data - All Services | Received logon response. | 2021-06-14 16:35:53.474 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:53.474 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:53.474 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:53.474 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:53.474 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:53.474 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:53.474 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:53.474 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:53.475 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:53.516 DTC Client socket (1) | Closed. | 2021-06-14 16:35:53.516 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:35:58.457 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:58.458 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:58.459 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:35:58.459 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:58.510 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:58.510 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:58.511 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:58.573 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:58.573 SC Data - All Services | Received logon response. | 2021-06-14 16:35:58.769 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:58.769 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:58.769 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:58.769 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:58.769 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:58.769 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:58.769 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:35:58.770 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:58.770 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:58.813 DTC Client socket (1) | Closed. | 2021-06-14 16:35:58.813 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2021-06-14 16:35:59.077 DTC Client socket (1) | Creating socket. | 2021-06-14 16:35:59.078 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:35:59.078 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:35:59.078 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:35:59.130 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:35:59.130 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:35:59.130 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:35:59.191 SC Data - All Services | Sending logon request message. | 2021-06-14 16:35:59.191 SC Data - All Services | Received logon response. | 2021-06-14 16:35:59.880 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:35:59.880 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:35:59.880 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:35:59.880 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:35:59.880 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:35:59.881 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:35:59.881 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:35:59.881 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:35:59.881 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:35:59.925 DTC Client socket (1) | Closed. | 2021-06-14 16:35:59.925 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:36:03.764 DTC Client socket (1) | Creating socket. | 2021-06-14 16:36:03.765 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:36:03.765 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:36:03.765 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:03.810 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:03.810 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:03.810 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:03.875 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:03.875 SC Data - All Services | Received logon response. | 2021-06-14 16:36:04.437 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:04.437 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:04.437 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:04.437 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:04.437 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:36:04.437 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:04.437 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:04.437 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:04.438 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:36:04.477 DTC Client socket (1) | Closed. | 2021-06-14 16:36:04.477 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:36:09.433 DTC Client socket (1) | Creating socket. | 2021-06-14 16:36:09.434 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:36:09.434 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:36:09.434 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:09.483 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:09.483 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:09.483 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:09.545 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:09.545 SC Data - All Services | Received logon response. | 2021-06-14 16:36:10.109 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:10.109 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:10.109 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:10.109 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:10.109 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:36:10.110 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:10.110 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:10.110 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:10.111 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:36:10.153 DTC Client socket (1) | Closed. | 2021-06-14 16:36:10.153 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:36:15.099 DTC Client socket (1) | Creating socket. | 2021-06-14 16:36:15.100 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:36:15.100 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:36:15.100 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:15.186 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:15.186 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:15.186 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:15.258 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:15.258 SC Data - All Services | Received logon response. | 2021-06-14 16:36:15.423 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:15.423 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:15.423 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:15.423 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:15.423 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:36:15.423 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:15.423 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:15.423 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:15.423 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:36:15.554 DTC Client socket (1) | Closed. | 2021-06-14 16:36:15.554 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:36:20.412 DTC Client socket (1) | Creating socket. | 2021-06-14 16:36:20.412 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:36:20.412 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:36:20.412 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:20.456 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:20.456 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:20.456 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:20.515 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:20.515 SC Data - All Services | Received logon response. | 2021-06-14 16:36:20.656 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:20.656 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:20.656 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:20.656 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:20.656 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:36:20.656 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:20.656 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:20.656 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:20.656 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:36:20.701 DTC Client socket (1) | Closed. | 2021-06-14 16:36:20.701 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:36:25.657 DTC Client socket (1) | Creating socket. | 2021-06-14 16:36:25.658 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:36:25.658 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:36:25.658 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:25.704 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:25.704 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:25.705 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:25.783 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:25.783 SC Data - All Services | Received logon response. | 2021-06-14 16:36:25.965 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:25.965 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:25.965 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:25.965 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:25.965 DTC Client socket (1) | CloseSocket call. | 2021-06-14 16:36:25.965 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:25.965 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:25.965 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:25.965 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:36:26.015 DTC Client socket (1) | Closed. | 2021-06-14 16:36:26.016 File >> Disconnect selected. | 2021-06-14 16:36:29.187 CQG WebAPI | Sending Web API Logoff message. | 2021-06-14 16:36:29.201 CQG WebSocket socket (2) | CloseSocket call. | 2021-06-14 16:36:29.201 CQG WebSocket | WebSocket closed. | 2021-06-14 16:36:29.201 CQG WebAPI | WebSocket closed. | 2021-06-14 16:36:29.201 CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-06-14 16:36:29.201 DTC Client socket (0) | CloseSocket call. | 2021-06-14 16:36:29.202 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:29.202 DTC Client socket (0) | CloseSocket call. | 2021-06-14 16:36:29.202 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:29.202 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-06-14 16:36:29.202 DTC Client socket (3) | CloseSocket call. | 2021-06-14 16:36:29.203 SC DTC Data with Market Depth | Disconnected from the server. | 2021-06-14 16:36:29.203 CQG WebAPI | Disconnected. | 2021-06-14 16:36:29.203 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:29.203 CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2021-06-14 16:36:29.250 CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:29.250 CQG WebAPI | Connecting to server api.cqg.com | 2021-06-14 16:36:32.164 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-06-14 16:36:32.164 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-06-14 16:36:32.222 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:36:32.222 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2021-06-14 16:36:32.222 CQG WebSocket | Opening WebSocket. | 2021-06-14 16:36:32.278 CQG WebSocket | Sending WebSocket handshake. | 2021-06-14 16:36:32.278 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-06-14 16:36:32.457 CQG WebSocket | Server header | Connection: upgrade | 2021-06-14 16:36:32.457 CQG WebSocket | Server header | Sec-WebSocket-Accept: 5fNSusQCXq3Cc9r5qtcwtZnheh4= | 2021-06-14 16:36:32.457 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-06-14 16:36:32.457 CQG WebSocket | Server header | Upgrade: websocket | 2021-06-14 16:36:32.457 CQG WebSocket | Server header | | 2021-06-14 16:36:32.457 CQG WebSocket | Web socket state is now open. | 2021-06-14 16:36:32.457 CQG WebAPI | WebSocket connected. | 2021-06-14 16:36:32.457 CQG WebAPI | Sending market data logon message. | 2021-06-14 16:36:32.457 CQG WebAPI | Base Time: 2021-06-13T01:52:24. 2021-06-13 01:52:24 | 2021-06-14 16:36:32.629 CQG WebAPI | Logon successful. Session Token = OQ6EVQxTe0t/BcocOohoojeQT4/qKqNBY1gxBm4kNU0SpjYWJb8Rv+cphQ9rMgLSwqrIIsbTNOw | 2021-06-14 16:36:32.629 CQG WebAPI | Connected to server complete. | 2021-06-14 16:36:32.629 Triggering next historical data download in queue. | 2021-06-14 16:36:32.629 Triggering next historical data download in queue. | 2021-06-14 16:36:32.629 Triggering next historical data download in queue. | 2021-06-14 16:36:32.629 Triggering next historical data download in queue. | 2021-06-14 16:36:32.629 Updated verified funded futures trading account ending date to: 2021-07-14 16:36:32 | 2021-06-14 16:36:32.629 SC DTC Data with Market Depth | Starting real-time market data updates for: UVOL-NYSE. ID: 1 Service code: statscalc | 2021-06-14 16:36:32.635 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2021-06-14 16:36:32.635 SC DTC Data with Market Depth | Requesting security definition data for: UVOL-NYSE. ID: 1 | 2021-06-14 16:36:32.635 Added historical Intraday data request for UVOL-NYSE to the queue. | 2021-06-14 16:36:32.635 Intraday data recording state for symbol UVOL-NYSE is set to download 'Pending'. | 2021-06-14 16:36:32.635 TICK-NYSE[M] 5 Min #6 | Started historical data download for additional symbol UVOL-NYSE. Download ID: 34 | 2021-06-14 16:36:32.635 SC DTC Data with Market Depth | Starting real-time market data updates for: DVOL-NYSE. ID: 2 Service code: statscalc | 2021-06-14 16:36:32.635 SC DTC Data with Market Depth | Requesting security definition data for: DVOL-NYSE. ID: 2 | 2021-06-14 16:36:32.635 Added historical Intraday data request for DVOL-NYSE to the queue. | 2021-06-14 16:36:32.635 Intraday data recording state for symbol DVOL-NYSE is set to download 'Pending'. | 2021-06-14 16:36:32.635 TICK-NYSE[M] 5 Min #6 | Started historical data download for additional symbol DVOL-NYSE. Download ID: 35 | 2021-06-14 16:36:32.635 SC DTC Data with Market Depth | Starting real-time market data updates for: DVOL-NASDAQ. ID: 3 Service code: statscalc | 2021-06-14 16:36:32.635 SC DTC Data with Market Depth | Requesting security definition data for: DVOL-NASDAQ. ID: 3 | 2021-06-14 16:36:32.635 Added historical Intraday data request for DVOL-NASDAQ to the queue. | 2021-06-14 16:36:32.635 Intraday data recording state for symbol DVOL-NASDAQ is set to download 'Pending'. | 2021-06-14 16:36:32.635 TICK-NYSE[M] 5 Min #6 | Started historical data download for additional symbol DVOL-NASDAQ. Download ID: 36 | 2021-06-14 16:36:32.635 SC DTC Data with Market Depth | Starting real-time market data updates for: UVOL-NASDAQ. ID: 4 Service code: statscalc | 2021-06-14 16:36:32.635 SC DTC Data with Market Depth | Requesting security definition data for: UVOL-NASDAQ. ID: 4 | 2021-06-14 16:36:32.635 Added historical Intraday data request for UVOL-NASDAQ to the queue. | 2021-06-14 16:36:32.636 Intraday data recording state for symbol UVOL-NASDAQ is set to download 'Pending'. | 2021-06-14 16:36:32.636 TICK-NYSE[M] 5 Min #6 | Started historical data download for additional symbol UVOL-NASDAQ. Download ID: 37 | 2021-06-14 16:36:32.636 CQG WebAPI | Sending Trade Accounts request message. | 2021-06-14 16:36:32.641 No download requests in the queue to start downloads for. | 2021-06-14 16:36:32.641 Delaying start of download for UVOL-NYSE | 2021-06-14 16:36:32.641 No download requests in the queue to start downloads for. | 2021-06-14 16:36:32.641 No download requests in the queue to start downloads for. | 2021-06-14 16:36:32.641 Mapping F.US.EPM22 to ESM22. Service code: cme | 2021-06-14 16:36:32.642 SC Data - All Services | Starting real-time market data updates for: F.US.EPM22 (ESM22). ID: 5 Service code: cme | 2021-06-14 16:36:32.642 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-14 16:36:32.642 CQG WebAPI | Sending symbol resolution request for F.US.EPM22. ID: 486695 | 2021-06-14 16:36:32.642 SC Data - All Services | Requesting security definition data for: F.US.EPM22 (ESM22). ID: 5 | 2021-06-14 16:36:32.642 Added historical Intraday data request for F.US.EPM22 to the queue. | 2021-06-14 16:36:32.642 Intraday data recording state for symbol F.US.EPM22 is set to download 'Pending'. | 2021-06-14 16:36:32.642 Triggering next historical data download in queue. | 2021-06-14 16:36:32.642 DTC Client socket (4) | Creating socket. | 2021-06-14 16:36:32.733 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-14 16:36:32.733 DTC Client socket (4) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:36:32.733 DTC Client socket (5) | Creating socket. | 2021-06-14 16:36:32.733 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:36:32.733 DTC Client socket (5) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:36:32.733 CQG WebAPI | Received symbol resolution report for symbol F.US.EPM22. Search Symbol: F.US.EPM22. Request ID: 486695. Contract ID: 1. | 2021-06-14 16:36:32.740 CQG WebAPI | Brokerage name: AMP. Account Name: 141240 | 2021-06-14 16:36:32.740 CQG WebAPI | Sending collateral subscribe request. | 2021-06-14 16:36:32.740 Mapping F.US.EPU21 to ESU21. Service code: cme | 2021-06-14 16:36:32.768 SC Data - All Services | Starting real-time market data updates for: F.US.EPU21 (ESU21). ID: 6 Service code: cme | 2021-06-14 16:36:32.768 CQG WebAPI | Sending symbol resolution request for F.US.EPU21. ID: 486697 | 2021-06-14 16:36:32.768 SC Data - All Services | Requesting security definition data for: F.US.EPU21 (ESU21). ID: 6 | 2021-06-14 16:36:32.768 Added historical Intraday data request for F.US.EPU21 to the queue. | 2021-06-14 16:36:32.768 Intraday data recording state for symbol F.US.EPU21 is set to download 'Pending'. | 2021-06-14 16:36:32.768 Triggering next historical data download in queue. | 2021-06-14 16:36:32.768 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:32.820 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:32.820 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:32.820 SC DTC Data with Market Depth | Network connection to server complete. | 2021-06-14 16:36:32.820 SC DTC Data with Market Depth | Starting socket receive thread. | 2021-06-14 16:36:32.820 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:32.820 CQG WebAPI | Received symbol resolution report for symbol F.US.EPU21. Search Symbol: F.US.EPU21. Request ID: 486697. Contract ID: 2. | 2021-06-14 16:36:32.824 SC DTC Data with Market Depth | Starting real-time market data updates for: UDVR-NYSE. ID: 7 Service code: statscalc | 2021-06-14 16:36:32.828 SC DTC Data with Market Depth | Requesting security definition data for: UDVR-NYSE. ID: 7 | 2021-06-14 16:36:32.828 Added historical Intraday data request for UDVR-NYSE to the queue. | 2021-06-14 16:36:32.828 Intraday data recording state for symbol UDVR-NYSE is set to download 'Pending'. | 2021-06-14 16:36:32.828 Triggering next historical data download in queue. | 2021-06-14 16:36:32.828 Mapping MSFT to MSFT. Service code: equities.us | 2021-06-14 16:36:32.829 SC Data - All Services | Starting real-time market data updates for: MSFT (MSFT). ID: 8 Service code: equities.us | 2021-06-14 16:36:32.829 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:36:32.829 CQG WebAPI | Sending symbol resolution request for MSFT. ID: 486698 | 2021-06-14 16:36:32.829 SC Data - All Services | Requesting security definition data for: MSFT (MSFT). ID: 8 | 2021-06-14 16:36:32.829 Added historical Intraday data request for MSFT to the queue. | 2021-06-14 16:36:32.829 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-06-14 16:36:32.829 Triggering next historical data download in queue. | 2021-06-14 16:36:32.829 DTC Client socket (6) | Creating socket. | 2021-06-14 16:36:32.829 DTC Client socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:36:32.830 DTC Client socket (6) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:36:32.830 Mapping F.US.ENQM21 to NQM21. Service code: cme | 2021-06-14 16:36:32.851 Mapping F.US.ENQU21 to NQU21. Service code: cme | 2021-06-14 16:36:32.851 SC Data - All Services | Starting real-time market data updates for: F.US.ENQU21 (NQU21). ID: 10 Service code: cme | 2021-06-14 16:36:32.852 CQG WebAPI | Sending symbol resolution request for F.US.ENQU21. ID: 486699 | 2021-06-14 16:36:32.852 SC Data - All Services | Requesting security definition data for: F.US.ENQU21 (NQU21). ID: 10 | 2021-06-14 16:36:32.852 SC Data - All Services | Starting real-time market data updates for: F.US.ENQM21 (NQM21). ID: 9 Service code: cme | 2021-06-14 16:36:32.852 CQG WebAPI | Sending symbol resolution request for F.US.ENQM21. ID: 486700 | 2021-06-14 16:36:32.852 SC Data - All Services | Requesting security definition data for: F.US.ENQM21 (NQM21). ID: 9 | 2021-06-14 16:36:32.852 Added historical Intraday data request for F.US.ENQM21 to the queue. | 2021-06-14 16:36:32.852 Intraday data recording state for symbol F.US.ENQM21 is set to download 'Pending'. | 2021-06-14 16:36:32.852 Triggering next historical data download in queue. | 2021-06-14 16:36:32.852 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:32.919 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:32.919 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:32.919 CQG WebAPI | Received symbol resolution report for symbol S.US.MSFT. Search Symbol: MSFT. Request ID: 486698. Contract ID: 3. | 2021-06-14 16:36:32.919 Symbol Error - MSFT is unknown, unavailable, or improperly formatted. Exact match not found for symbol MSFT | 2021-06-14 16:36:32.919 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:32.942 SC DTC Data with Market Depth | Sending logon request message. | 2021-06-14 16:36:32.942 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:32.942 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:32.942 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU21. Search Symbol: F.US.ENQU21. Request ID: 486699. Contract ID: 4. | 2021-06-14 16:36:32.942 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQM21. Search Symbol: F.US.ENQM21. Request ID: 486700. Contract ID: 5. | 2021-06-14 16:36:32.942 Mapping F.US.RTYM21 to RTYM21. Service code: cme | 2021-06-14 16:36:32.942 Mapping F.US.RTYU21 to RTYU21. Service code: cme | 2021-06-14 16:36:32.942 SC Data - All Services | Starting real-time market data updates for: F.US.RTYU21 (RTYU21). ID: 12 Service code: cme | 2021-06-14 16:36:32.942 CQG WebAPI | Sending symbol resolution request for F.US.RTYU21. ID: 486701 | 2021-06-14 16:36:32.942 SC Data - All Services | Requesting security definition data for: F.US.RTYU21 (RTYU21). ID: 12 | 2021-06-14 16:36:32.942 SC Data - All Services | Starting real-time market data updates for: F.US.RTYM21 (RTYM21). ID: 11 Service code: cme | 2021-06-14 16:36:32.942 CQG WebAPI | Sending symbol resolution request for F.US.RTYM21. ID: 486702 | 2021-06-14 16:36:32.942 SC Data - All Services | Requesting security definition data for: F.US.RTYM21 (RTYM21). ID: 11 | 2021-06-14 16:36:32.942 Added historical Intraday data request for F.US.RTYM21 to the queue. | 2021-06-14 16:36:32.942 Intraday data recording state for symbol F.US.RTYM21 is set to download 'Pending'. | 2021-06-14 16:36:32.942 Triggering next historical data download in queue. | 2021-06-14 16:36:32.942 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:32.975 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:32.975 Mapping TSLA to TSLA. Service code: equities.us | 2021-06-14 16:36:32.976 SC Data - All Services | Starting real-time market data updates for: TSLA (TSLA). ID: 13 Service code: equities.us | 2021-06-14 16:36:32.976 CQG WebAPI | Sending symbol resolution request for TSLA. ID: 486703 | 2021-06-14 16:36:32.976 SC Data - All Services | Requesting security definition data for: TSLA (TSLA). ID: 13 | 2021-06-14 16:36:32.976 Added historical Intraday data request for TSLA to the queue. | 2021-06-14 16:36:32.976 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2021-06-14 16:36:32.976 Triggering next historical data download in queue. | 2021-06-14 16:36:32.976 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYU21. Search Symbol: F.US.RTYU21. Request ID: 486701. Contract ID: 6. | 2021-06-14 16:36:33.002 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYM21. Search Symbol: F.US.RTYM21. Request ID: 486702. Contract ID: 7. | 2021-06-14 16:36:33.003 CQG WebAPI | Received symbol resolution report for symbol S.US.TSLA. Search Symbol: TSLA. Request ID: 486703. Contract ID: 8. | 2021-06-14 16:36:33.028 Symbol Error - TSLA is unknown, unavailable, or improperly formatted. Exact match not found for symbol TSLA | 2021-06-14 16:36:33.028 Mapping AAPL to AAPL. Service code: equities.us | 2021-06-14 16:36:33.053 SC Data - All Services | Starting real-time market data updates for: AAPL (AAPL). ID: 14 Service code: equities.us | 2021-06-14 16:36:33.053 CQG WebAPI | Sending symbol resolution request for AAPL. ID: 486704 | 2021-06-14 16:36:33.053 SC Data - All Services | Requesting security definition data for: AAPL (AAPL). ID: 14 | 2021-06-14 16:36:33.053 Added historical Intraday data request for AAPL to the queue. | 2021-06-14 16:36:33.053 Intraday data recording state for symbol AAPL is set to download 'Pending'. | 2021-06-14 16:36:33.053 Triggering next historical data download in queue. | 2021-06-14 16:36:33.053 CQG WebAPI | Received symbol resolution report for symbol X.US.AAPLA00. Search Symbol: AAPL. Request ID: 486704. Contract ID: 9. | 2021-06-14 16:36:33.116 Symbol Error - AAPL is unknown, unavailable, or improperly formatted. Exact match not found for symbol AAPL | 2021-06-14 16:36:33.116 Mapping F.US.CLEN21 to CLN21. Service code: nymex | 2021-06-14 16:36:33.166 Mapping F.US.CLEQ21 to CLQ21. Service code: nymex | 2021-06-14 16:36:33.167 SC Data - All Services | Starting real-time market data updates for: F.US.CLEQ21 (CLQ21). ID: 16 Service code: nymex | 2021-06-14 16:36:33.167 CQG WebAPI | Sending symbol resolution request for F.US.CLEQ21. ID: 486705 | 2021-06-14 16:36:33.167 SC Data - All Services | Requesting security definition data for: F.US.CLEQ21 (CLQ21). ID: 16 | 2021-06-14 16:36:33.167 SC Data - All Services | Starting real-time market data updates for: F.US.CLEN21 (CLN21). ID: 15 Service code: nymex | 2021-06-14 16:36:33.167 CQG WebAPI | Sending symbol resolution request for F.US.CLEN21. ID: 486706 | 2021-06-14 16:36:33.167 SC Data - All Services | Requesting security definition data for: F.US.CLEN21 (CLN21). ID: 15 | 2021-06-14 16:36:33.167 Added historical Intraday data request for F.US.CLEN21 to the queue. | 2021-06-14 16:36:33.167 Intraday data recording state for symbol F.US.CLEN21 is set to download 'Pending'. | 2021-06-14 16:36:33.167 Triggering next historical data download in queue. | 2021-06-14 16:36:33.167 DTC Client socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:36:33.194 SC Data - All Services | Received logon response. | 2021-06-14 16:36:33.219 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:33.219 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:33.219 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:33.219 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:33.219 DTC Client socket (6) | CloseSocket call. | 2021-06-14 16:36:33.220 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:33.220 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:33.220 DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-14 16:36:33.220 DTC Client socket (6) | Closed. | 2021-06-14 16:36:33.220 Mapping F.US.MESM21 to MESM21. Service code: cme | 2021-06-14 16:36:33.220 Mapping F.US.MESU21 to MESU21. Service code: cme | 2021-06-14 16:36:33.220 SC Data - All Services | Starting real-time market data updates for: F.US.MESU21 (MESU21). ID: 18 Service code: cme | 2021-06-14 16:36:33.220 CQG WebAPI | Sending symbol resolution request for F.US.MESU21. ID: 486707 | 2021-06-14 16:36:33.220 SC Data - All Services | Requesting security definition data for: F.US.MESU21 (MESU21). ID: 18 | 2021-06-14 16:36:33.220 SC Data - All Services | Starting real-time market data updates for: F.US.MESM21 (MESM21). ID: 17 Service code: cme | 2021-06-14 16:36:33.220 CQG WebAPI | Sending symbol resolution request for F.US.MESM21. ID: 486708 | 2021-06-14 16:36:33.220 SC Data - All Services | Requesting security definition data for: F.US.MESM21 (MESM21). ID: 17 | 2021-06-14 16:36:33.220 Added historical Intraday data request for F.US.MESM21 to the queue. | 2021-06-14 16:36:33.220 Intraday data recording state for symbol F.US.MESM21 is set to download 'Pending'. | 2021-06-14 16:36:33.220 Triggering next historical data download in queue. | 2021-06-14 16:36:33.220 Mapping F.US.EPM21 to ESM21. Service code: cme | 2021-06-14 16:36:33.221 SC Data - All Services | Starting real-time market data updates for: F.US.EPM21 (ESM21). ID: 19 Service code: cme | 2021-06-14 16:36:33.221 CQG WebAPI | Sending symbol resolution request for F.US.EPM21. ID: 486709 | 2021-06-14 16:36:33.221 SC Data - All Services | Requesting security definition data for: F.US.EPM21 (ESM21). ID: 19 | 2021-06-14 16:36:33.221 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 20 Service code: statscalc | 2021-06-14 16:36:33.231 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 20 | 2021-06-14 16:36:33.231 Added historical Intraday data request for TICK-NYSE to the queue. | 2021-06-14 16:36:33.231 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2021-06-14 16:36:33.231 Triggering next historical data download in queue. | 2021-06-14 16:36:33.231 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ21. Search Symbol: F.US.CLEQ21. Request ID: 486705. Contract ID: 10. | 2021-06-14 16:36:33.235 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN21. Search Symbol: F.US.CLEN21. Request ID: 486706. Contract ID: 11. | 2021-06-14 16:36:33.235 CQG WebAPI | Received symbol resolution report for symbol F.US.MESU21. Search Symbol: F.US.MESU21. Request ID: 486707. Contract ID: 12. | 2021-06-14 16:36:33.278 CQG WebAPI | Received symbol resolution report for symbol F.US.MESM21. Search Symbol: F.US.MESM21. Request ID: 486708. Contract ID: 13. | 2021-06-14 16:36:33.278 CQG WebAPI | Received symbol resolution report for symbol F.US.EPM21. Search Symbol: F.US.EPM21. Request ID: 486709. Contract ID: 14. | 2021-06-14 16:36:33.294 SC DTC Data with Market Depth | Received logon response. | 2021-06-14 16:36:33.630 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-06-14 16:36:33.630 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:33.630 SC DTC Data with Market Depth | Successfully connected. | 2021-06-14 16:36:33.630 SC DTC Data with Market Depth | Trading is not supported. | 2021-06-14 16:36:33.630 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DVOL-NASDAQ | 2021-06-14 16:36:33.630 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DVOL-NYSE | 2021-06-14 16:36:33.631 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2021-06-14 16:36:33.631 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UDVR-NYSE | 2021-06-14 16:36:33.631 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UVOL-NASDAQ | 2021-06-14 16:36:33.631 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UVOL-NYSE | 2021-06-14 16:36:33.631 SC Data - All Services | Received logon response. | 2021-06-14 16:36:33.672 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:33.672 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:33.672 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:33.672 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:33.672 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:36:33.673 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:33.673 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:36:33.673 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:33.674 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:36:33.731 DTC Client socket (5) | Closed. | 2021-06-14 16:36:33.731 SC DTC Data with Market Depth | Received security definition for symbol DVOL-NASDAQ | 2021-06-14 16:36:33.817 SC DTC Data with Market Depth | Received security definition for symbol DVOL-NYSE | 2021-06-14 16:36:33.817 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2021-06-14 16:36:33.817 SC DTC Data with Market Depth | Received security definition for symbol UDVR-NYSE | 2021-06-14 16:36:33.817 SC DTC Data with Market Depth | Received security definition for symbol UVOL-NASDAQ | 2021-06-14 16:36:33.817 SC DTC Data with Market Depth | Received security definition for symbol UVOL-NYSE | 2021-06-14 16:36:33.817 CQG WebAPI | Sending positions subscribe request. RequestID: 486710 | 2021-06-14 16:36:37.621 CQG WebAPI | Sending orders subscribe request. RequestID: 486711 | 2021-06-14 16:36:37.622 Requesting market depth updates for: F.US.MESM21 if supported. | 2021-06-14 16:36:37.622 Separate subscription for market depth updates not supported. F.US.MESM21 | 2021-06-14 16:36:37.622 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:36:38.220 DTC Client socket (5) | Creating socket. | 2021-06-14 16:36:38.221 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:36:38.222 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:36:38.222 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:38.270 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:38.270 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:38.270 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:38.309 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:38.309 HD Request # 34 | Downloading Intraday chart data for UVOL-NYSE to the file UVOL-NYSE.scid. Service: statscalc | 2021-06-14 16:36:38.830 HD Request # 34 | Download start date-time: 2021-06-14 16:36:28.000000. File last date-time: 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:38.830 HD Request # 34 | Using server: ds12.sierracharts.com port 10150 | 2021-06-14 16:36:38.830 Socket (6) | Creating socket. | 2021-06-14 16:36:38.830 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:36:38.830 Socket (6) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:36:38.830 SC Data - All Services | Received logon response. | 2021-06-14 16:36:38.955 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:38.955 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:38.955 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:38.955 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:38.955 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:36:38.956 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:38.956 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:38.956 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:38.956 HD Request # 34 | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:38.959 HD Request # 34 | Sending historical data logon request message. | 2021-06-14 16:36:38.959 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:36:39.002 DTC Client socket (5) | Closed. | 2021-06-14 16:36:39.002 HD Request # 34 | Requesting Intraday data. Start date-time: 2021-06-14 16:36:28. Record interval: 1. Symbol: UVOL-NYSE | 2021-06-14 16:36:39.541 HD Request # 34 | Decompressing data. | 2021-06-14 16:36:39.597 HD Request # 34 | Receiving Intraday data for UVOL-NYSE starting at 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:39.598 Socket (6) | CloseSocket call. | 2021-06-14 16:36:39.598 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:39.598 Historical data download thread signaled to stop. | 2021-06-14 16:36:39.598 HD Request # 34 | Timestamp of first Intraday data file record written: 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:39.599 HD Request # 34 | Received 11 records from 2021-06-14 16:36:28.000000 to 2021-06-14 16:36:38.000000 (10.0 seconds) and wrote 11 records for UVOL-NYSE | 2021-06-14 16:36:39.599 HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:36:38.000000 | 2021-06-14 16:36:39.604 Added 1 Time and Sales records to Intraday data file for UVOL-NYSE after download. | 2021-06-14 16:36:39.604 HD Request # 34 | Completion time: 1s | 2021-06-14 16:36:39.604 HD Request # 34 | Intraday data download complete for UVOL-NYSE. Unique request ID: 34 | 2021-06-14 16:36:39.604 Removing historical data download ID 34. | 2021-06-14 16:36:39.604 Real-time Intraday chart data file updates started for UVOL-NYSE | 2021-06-14 16:36:39.604 Opened cached Intraday file: C:\SierraChart\Data\UVOL-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:36:39.609 Intraday chart data file opened for UVOL-NYSE | 2021-06-14 16:36:39.609 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:36:39.609 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol UVOL-NYSE with ID 34 has completed. | 2021-06-14 16:36:39.609 Triggering next historical data download in queue. | 2021-06-14 16:36:39.609 HD Request # 35 | Downloading Intraday chart data for DVOL-NYSE to the file DVOL-NYSE.scid. Service: statscalc | 2021-06-14 16:36:39.609 HD Request # 35 | Download start date-time: 2021-06-14 16:36:28.000000. File last date-time: 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:39.609 HD Request # 35 | Using server: ds4.sierracharts.com port 10149 | 2021-06-14 16:36:39.609 Socket (5) | Creating socket. | 2021-06-14 16:36:39.610 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:36:39.610 Socket (5) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:36:39.610 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:36:39.661 Socket (6) | Closed. | 2021-06-14 16:36:39.661 HD Request # 35 | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:39.719 HD Request # 35 | Sending historical data logon request message. | 2021-06-14 16:36:39.719 HD Request # 35 | Requesting Intraday data. Start date-time: 2021-06-14 16:36:28. Record interval: 1. Symbol: DVOL-NYSE | 2021-06-14 16:36:40.297 HD Request # 35 | Decompressing data. | 2021-06-14 16:36:40.347 HD Request # 35 | Receiving Intraday data for DVOL-NYSE starting at 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:40.347 Socket (5) | CloseSocket call. | 2021-06-14 16:36:40.348 Historical data download thread signaled to stop. | 2021-06-14 16:36:40.348 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:40.348 HD Request # 35 | Timestamp of first Intraday data file record written: 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:40.348 HD Request # 35 | Received 11 records from 2021-06-14 16:36:28.000000 to 2021-06-14 16:36:38.000000 (10.0 seconds) and wrote 11 records for DVOL-NYSE | 2021-06-14 16:36:40.348 HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:36:38.000000 | 2021-06-14 16:36:40.352 Added 2 Time and Sales records to Intraday data file for DVOL-NYSE after download. | 2021-06-14 16:36:40.352 HD Request # 35 | Completion time: 1s | 2021-06-14 16:36:40.353 HD Request # 35 | Intraday data download complete for DVOL-NYSE. Unique request ID: 35 | 2021-06-14 16:36:40.353 Removing historical data download ID 35. | 2021-06-14 16:36:40.353 Real-time Intraday chart data file updates started for DVOL-NYSE | 2021-06-14 16:36:40.353 Opened cached Intraday file: C:\SierraChart\Data\DVOL-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:36:40.357 Intraday chart data file opened for DVOL-NYSE | 2021-06-14 16:36:40.357 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:36:40.357 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol DVOL-NYSE with ID 35 has completed. | 2021-06-14 16:36:40.357 Triggering next historical data download in queue. | 2021-06-14 16:36:40.357 HD Request # 36 | Downloading Intraday chart data for DVOL-NASDAQ to the file DVOL-NASDAQ.scid. Service: statscalc | 2021-06-14 16:36:40.357 HD Request # 36 | Download start date-time: 2021-06-14 16:36:28.000000. File last date-time: 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:40.357 HD Request # 36 | Using server: ds12.sierracharts.com port 10150 | 2021-06-14 16:36:40.357 Socket (6) | Creating socket. | 2021-06-14 16:36:40.357 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:36:40.357 Socket (6) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:36:40.357 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:36:40.401 Socket (5) | Closed. | 2021-06-14 16:36:40.401 HD Request # 36 | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:40.476 HD Request # 36 | Sending historical data logon request message. | 2021-06-14 16:36:40.476 HD Request # 36 | Requesting Intraday data. Start date-time: 2021-06-14 16:36:28. Record interval: 1. Symbol: DVOL-NASDAQ | 2021-06-14 16:36:40.536 HD Request # 36 | Decompressing data. | 2021-06-14 16:36:40.590 HD Request # 36 | Receiving Intraday data for DVOL-NASDAQ starting at 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:40.590 Socket (6) | CloseSocket call. | 2021-06-14 16:36:40.591 Historical data download thread signaled to stop. | 2021-06-14 16:36:40.591 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:40.591 HD Request # 36 | Timestamp of first Intraday data file record written: 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:40.591 HD Request # 36 | Received 11 records from 2021-06-14 16:36:28.000000 to 2021-06-14 16:36:38.000000 (10.0 seconds) and wrote 11 records for DVOL-NASDAQ | 2021-06-14 16:36:40.591 HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:36:38.000000 | 2021-06-14 16:36:40.596 Added 2 Time and Sales records to Intraday data file for DVOL-NASDAQ after download. | 2021-06-14 16:36:40.596 HD Request # 36 | Completion time: 0s | 2021-06-14 16:36:40.596 HD Request # 36 | Intraday data download complete for DVOL-NASDAQ. Unique request ID: 36 | 2021-06-14 16:36:40.596 Removing historical data download ID 36. | 2021-06-14 16:36:40.596 Real-time Intraday chart data file updates started for DVOL-NASDAQ | 2021-06-14 16:36:40.596 Opened cached Intraday file: C:\SierraChart\Data\DVOL-NASDAQ.scid. Thread ID: 3636 | 2021-06-14 16:36:40.599 Intraday chart data file opened for DVOL-NASDAQ | 2021-06-14 16:36:40.599 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:36:40.599 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol DVOL-NASDAQ with ID 36 has completed. | 2021-06-14 16:36:40.599 Triggering next historical data download in queue. | 2021-06-14 16:36:40.599 HD Request # 37 | Downloading Intraday chart data for UVOL-NASDAQ to the file UVOL-NASDAQ.scid. Service: statscalc | 2021-06-14 16:36:40.599 HD Request # 37 | Download start date-time: 2021-06-14 16:36:28.000000. File last date-time: 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:40.599 HD Request # 37 | Using server: ds4.sierracharts.com port 10149 | 2021-06-14 16:36:40.599 Socket (5) | Creating socket. | 2021-06-14 16:36:40.599 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:36:40.599 Socket (5) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:36:40.599 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:36:40.663 Socket (6) | Closed. | 2021-06-14 16:36:40.663 HD Request # 37 | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:40.714 HD Request # 37 | Sending historical data logon request message. | 2021-06-14 16:36:40.714 HD Request # 37 | Requesting Intraday data. Start date-time: 2021-06-14 16:36:28. Record interval: 1. Symbol: UVOL-NASDAQ | 2021-06-14 16:36:40.772 HD Request # 37 | Decompressing data. | 2021-06-14 16:36:40.838 HD Request # 37 | Receiving Intraday data for UVOL-NASDAQ starting at 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:40.838 Socket (5) | CloseSocket call. | 2021-06-14 16:36:40.839 Historical data download thread signaled to stop. | 2021-06-14 16:36:40.839 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:40.839 HD Request # 37 | Timestamp of first Intraday data file record written: 2021-06-14 16:36:28.000000 | 2021-06-14 16:36:40.839 HD Request # 37 | Received 11 records from 2021-06-14 16:36:28.000000 to 2021-06-14 16:36:38.000000 (10.0 seconds) and wrote 11 records for UVOL-NASDAQ | 2021-06-14 16:36:40.839 HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:36:38.000000 | 2021-06-14 16:36:40.842 Added 2 Time and Sales records to Intraday data file for UVOL-NASDAQ after download. | 2021-06-14 16:36:40.842 HD Request # 37 | Completion time: 0s | 2021-06-14 16:36:40.842 HD Request # 37 | Intraday data download complete for UVOL-NASDAQ. Unique request ID: 37 | 2021-06-14 16:36:40.842 Removing historical data download ID 37. | 2021-06-14 16:36:40.842 Real-time Intraday chart data file updates started for UVOL-NASDAQ | 2021-06-14 16:36:40.842 Opened cached Intraday file: C:\SierraChart\Data\UVOL-NASDAQ.scid. Thread ID: 3636 | 2021-06-14 16:36:40.845 Intraday chart data file opened for UVOL-NASDAQ | 2021-06-14 16:36:40.845 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:36:40.845 TICK-NYSE[M] 5 Min #6 | Historical data download for additional symbol UVOL-NASDAQ with ID 37 has completed. | 2021-06-14 16:36:40.845 Triggering next historical data download in queue. | 2021-06-14 16:36:40.845 Delaying start of download for F.US.EPM22 | 2021-06-14 16:36:40.845 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:36:40.896 Socket (5) | Closed. | 2021-06-14 16:36:40.896 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:36:43.946 DTC Client socket (5) | Creating socket. | 2021-06-14 16:36:43.946 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:36:43.947 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:36:43.947 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:43.994 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:43.994 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:43.994 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:44.046 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:44.046 SC Data - All Services | Received logon response. | 2021-06-14 16:36:44.658 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:44.658 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:44.658 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:44.658 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:44.658 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:36:44.659 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:44.659 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:44.659 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:44.659 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:36:44.704 DTC Client socket (5) | Closed. | 2021-06-14 16:36:44.704 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:36:49.649 DTC Client socket (5) | Creating socket. | 2021-06-14 16:36:49.649 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:36:49.649 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:36:49.650 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:49.722 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:49.722 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:49.722 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:49.788 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:49.788 SC Data - All Services | Received logon response. | 2021-06-14 16:36:49.920 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:49.920 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:49.920 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:49.920 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:49.920 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:36:49.921 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:49.921 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:49.921 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:49.921 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:36:49.972 DTC Client socket (5) | Closed. | 2021-06-14 16:36:49.972 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:36:54.918 DTC Client socket (5) | Creating socket. | 2021-06-14 16:36:54.918 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:36:54.918 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:36:54.918 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:36:54.959 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:36:54.959 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:36:54.959 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:36:55.026 SC Data - All Services | Sending logon request message. | 2021-06-14 16:36:55.026 SC Data - All Services | Received logon response. | 2021-06-14 16:36:55.164 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:36:55.164 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:36:55.164 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:36:55.164 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:36:55.164 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:36:55.164 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:36:55.164 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:36:55.164 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:36:55.164 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:36:55.201 DTC Client socket (5) | Closed. | 2021-06-14 16:36:55.201 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:37:00.161 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:00.161 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:00.162 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:37:00.162 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:00.203 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:00.203 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:00.203 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:00.247 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:00.247 SC Data - All Services | Received logon response. | 2021-06-14 16:37:00.396 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:00.396 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:00.396 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:00.396 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:00.396 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:00.397 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:00.397 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:00.397 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:00.397 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:00.433 DTC Client socket (5) | Closed. | 2021-06-14 16:37:00.433 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-06-14 16:37:03.663 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:03.664 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:03.664 DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:37:03.664 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:03.723 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:03.723 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:03.723 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:03.790 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:03.790 HD Request # 38 | Downloading Intraday chart data for F.US.EPM22 to the file F.US.EPM22.scid. Service: cme | 2021-06-14 16:37:03.851 HD Request # 38 | Download start date-time: 2021-04-19 16:42:10.000000. File last date-time: 2021-04-19 16:42:10.679000 | 2021-06-14 16:37:03.853 HD Request # 38 | Using server: ds23.sierracharts.com port 10150 | 2021-06-14 16:37:03.853 Socket (6) | Creating socket. | 2021-06-14 16:37:03.853 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:37:03.854 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:37:03.854 HD Request # 38 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:03.955 HD Request # 38 | Sending historical data logon request message. | 2021-06-14 16:37:03.955 HD Request # 38 | Requesting Intraday data. Start date-time: 2021-04-19 16:42:10. Record interval: 1. Symbol: ESM22 | 2021-06-14 16:37:04.458 HD Request # 38 | Decompressing data. | 2021-06-14 16:37:04.502 HD Request # 38 | Receiving Intraday data for F.US.EPM22 starting at 2021-04-19 16:42:10.679000 | 2021-06-14 16:37:04.503 Socket (6) | CloseSocket call. | 2021-06-14 16:37:04.503 Historical data download thread signaled to stop. | 2021-06-14 16:37:04.504 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:04.504 HD Request # 38 | Timestamp of first Intraday data file record written: 2021-04-19 16:42:10.679000 | 2021-06-14 16:37:04.504 HD Request # 38 | Received 1 record from 2021-04-19 16:42:10.679000 to 2021-04-19 16:42:10.679000 (0.0 seconds) and wrote 1 record for F.US.EPM22 | 2021-06-14 16:37:04.504 HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2021-04-19 16:42:10.679000 | 2021-06-14 16:37:04.506 HD Request # 38 | Completion time: 1s | 2021-06-14 16:37:04.506 HD Request # 38 | Intraday data download complete for F.US.EPM22. Unique request ID: 38 | 2021-06-14 16:37:04.506 Removing historical data download ID 38. | 2021-06-14 16:37:04.506 Real-time Intraday chart data file updates started for F.US.EPM22 | 2021-06-14 16:37:04.506 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPM22.scid. Thread ID: 3636 | 2021-06-14 16:37:04.506 Intraday chart data file opened for F.US.EPM22 | 2021-06-14 16:37:04.506 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:04.506 Triggering next historical data download in queue. | 2021-06-14 16:37:04.507 HD Request # 39 | Downloading Intraday chart data for F.US.EPU21 to the file F.US.EPU21.scid. Service: cme | 2021-06-14 16:37:04.508 HD Request # 39 | Download start date-time: 2021-06-14 16:08:59.000000. File last date-time: 2021-06-14 16:08:59.303000 | 2021-06-14 16:37:04.509 HD Request # 39 | Using server: ds21.sierracharts.com port 10149 | 2021-06-14 16:37:04.509 Socket (7) | Creating socket. | 2021-06-14 16:37:04.509 Socket (7) | New receive buffer size: 5242880 | 2021-06-14 16:37:04.510 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:37:04.510 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:37:04.552 Socket (6) | Closed. | 2021-06-14 16:37:04.552 SC Data - All Services | Received logon response. | 2021-06-14 16:37:04.573 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:04.573 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:04.573 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:04.573 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:04.573 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:04.573 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:04.573 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:37:04.573 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:04.573 HD Request # 39 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:04.607 HD Request # 39 | Sending historical data logon request message. | 2021-06-14 16:37:04.607 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:04.623 DTC Client socket (5) | Closed. | 2021-06-14 16:37:04.623 HD Request # 39 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:59. Record interval: 1. Symbol: ESU21 | 2021-06-14 16:37:05.105 HD Request # 39 | Decompressing data. | 2021-06-14 16:37:05.146 HD Request # 39 | Receiving Intraday data for F.US.EPU21 starting at 2021-06-14 16:08:59.303000 | 2021-06-14 16:37:05.199 Socket (7) | CloseSocket call. | 2021-06-14 16:37:05.200 Historical data download thread signaled to stop. | 2021-06-14 16:37:05.200 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:05.200 HD Request # 39 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:59.303000 | 2021-06-14 16:37:05.200 HD Request # 39 | Received 921 records from 2021-06-14 16:08:59.303000 to 2021-06-14 16:37:01.141000 (28.0 minutes) and wrote 921 records for F.US.EPU21 | 2021-06-14 16:37:05.200 HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:37:01.141000 | 2021-06-14 16:37:05.205 HD Request # 39 | Completion time: 1s | 2021-06-14 16:37:05.205 HD Request # 39 | Intraday data download complete for F.US.EPU21. Unique request ID: 39 | 2021-06-14 16:37:05.205 Removing historical data download ID 39. | 2021-06-14 16:37:05.205 Real-time Intraday chart data file updates started for F.US.EPU21 | 2021-06-14 16:37:05.205 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPU21.scid. Thread ID: 3636 | 2021-06-14 16:37:05.205 Intraday chart data file opened for F.US.EPU21 | 2021-06-14 16:37:05.205 HD Request # 39 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:05.205 Triggering next historical data download in queue. | 2021-06-14 16:37:05.205 HD Request # 40 | Downloading Intraday chart data for UDVR-NYSE to the file UDVR-NYSE.scid. Service: statscalc | 2021-06-14 16:37:05.205 HD Request # 40 | Download start date-time: 2021-06-14 16:36:28.000000. File last date-time: 2021-06-14 16:36:28.000000 | 2021-06-14 16:37:05.205 HD Request # 40 | Using server: ds12.sierracharts.com port 10150 | 2021-06-14 16:37:05.205 Socket (5) | Creating socket. | 2021-06-14 16:37:05.205 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:05.206 Socket (5) | Connecting to IP: 204.15.197.14. | 2021-06-14 16:37:05.206 Socket (7) | Socket gracefully closed by remote side. | 2021-06-14 16:37:05.243 Socket (7) | Closed. | 2021-06-14 16:37:05.243 HD Request # 40 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:05.335 HD Request # 40 | Sending historical data logon request message. | 2021-06-14 16:37:05.335 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:37:05.382 DTC Client socket (6) | Creating socket. | 2021-06-14 16:37:05.383 DTC Client socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:37:05.383 DTC Client socket (6) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:37:05.383 HD Request # 40 | Requesting Intraday data. Start date-time: 2021-06-14 16:36:28. Record interval: 1. Symbol: UDVR-NYSE | 2021-06-14 16:37:05.391 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:05.430 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:05.430 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:05.430 HD Request # 40 | Decompressing data. | 2021-06-14 16:37:05.447 HD Request # 40 | Receiving Intraday data for UDVR-NYSE starting at 2021-06-14 16:36:28.000000 | 2021-06-14 16:37:05.448 Socket (5) | CloseSocket call. | 2021-06-14 16:37:05.449 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:05.449 Historical data download thread signaled to stop. | 2021-06-14 16:37:05.449 HD Request # 40 | Timestamp of first Intraday data file record written: 2021-06-14 16:36:28.000000 | 2021-06-14 16:37:05.449 HD Request # 40 | Received 38 records from 2021-06-14 16:36:28.000000 to 2021-06-14 16:37:05.000000 (37.0 seconds) and wrote 38 records for UDVR-NYSE | 2021-06-14 16:37:05.449 HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:37:05.000000 | 2021-06-14 16:37:05.458 HD Request # 40 | Completion time: 0s | 2021-06-14 16:37:05.458 HD Request # 40 | Intraday data download complete for UDVR-NYSE. Unique request ID: 40 | 2021-06-14 16:37:05.458 Removing historical data download ID 40. | 2021-06-14 16:37:05.458 Real-time Intraday chart data file updates started for UDVR-NYSE | 2021-06-14 16:37:05.458 Opened cached Intraday file: C:\SierraChart\Data\UDVR-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:37:05.458 Intraday chart data file opened for UDVR-NYSE | 2021-06-14 16:37:05.458 HD Request # 40 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:05.458 Triggering next historical data download in queue. | 2021-06-14 16:37:05.458 HD Request # 41 | Downloading Intraday chart data for MSFT to the file MSFT.scid. Service: equities.us | 2021-06-14 16:37:05.458 HD Request # 41 | Download start date-time: 2021-06-14 16:08:56.000000. File last date-time: 2021-06-14 16:08:56.656000 | 2021-06-14 16:37:05.459 HD Request # 41 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2021-06-14 16:37:05.459 Socket (7) | Creating socket. | 2021-06-14 16:37:05.460 Socket (7) | New receive buffer size: 5242880 | 2021-06-14 16:37:05.460 Socket (7) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:37:05.460 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:05.492 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:05.492 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:05.503 Socket (5) | Closed. | 2021-06-14 16:37:05.503 HD Request # 41 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:05.555 HD Request # 41 | Sending historical data logon request message. | 2021-06-14 16:37:05.555 SC Data - All Services | Received logon response. | 2021-06-14 16:37:05.567 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:05.567 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:05.567 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:05.567 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:05.567 DTC Client socket (6) | CloseSocket call. | 2021-06-14 16:37:05.567 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:05.567 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:05.567 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:05.567 DTC Client socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:37:05.606 DTC Client socket (6) | Closed. | 2021-06-14 16:37:05.606 HD Request # 41 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:56. Record interval: 1. Symbol: MSFT | 2021-06-14 16:37:06.061 HD Request # 41 | Decompressing data. | 2021-06-14 16:37:06.163 HD Request # 41 | Receiving Intraday data for MSFT starting at 2021-06-14 16:08:56.656000 | 2021-06-14 16:37:06.209 Socket (7) | CloseSocket call. | 2021-06-14 16:37:06.213 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:06.213 Historical data download thread signaled to stop. | 2021-06-14 16:37:06.213 HD Request # 41 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:56.656000 | 2021-06-14 16:37:06.213 HD Request # 41 | Received 772 records from 2021-06-14 16:08:56.656000 to 2021-06-14 16:37:05.380000 (28.1 minutes) and wrote 772 records for MSFT | 2021-06-14 16:37:06.214 HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:37:05.380000 | 2021-06-14 16:37:06.227 HD Request # 41 | Completion time: 1s | 2021-06-14 16:37:06.227 HD Request # 41 | Intraday data download complete for MSFT. Unique request ID: 41 | 2021-06-14 16:37:06.227 Removing historical data download ID 41. | 2021-06-14 16:37:06.227 Real-time Intraday chart data file updates started for MSFT | 2021-06-14 16:37:06.227 Opened cached Intraday file: C:\SierraChart\Data\MSFT.scid. Thread ID: 3636 | 2021-06-14 16:37:06.228 Intraday chart data file opened for MSFT | 2021-06-14 16:37:06.228 HD Request # 41 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:06.228 Triggering next historical data download in queue. | 2021-06-14 16:37:06.228 HD Request # 42 | Downloading Intraday chart data for F.US.ENQM21 to the file F.US.ENQM21.scid. Service: cme | 2021-06-14 16:37:06.228 HD Request # 42 | Download start date-time: 2021-06-14 16:08:58.000000. File last date-time: 2021-06-14 16:08:58.032000 | 2021-06-14 16:37:06.229 HD Request # 42 | Using server: ds21.sierracharts.com port 10150 | 2021-06-14 16:37:06.229 Socket (5) | Creating socket. | 2021-06-14 16:37:06.229 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:06.229 Socket (5) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:37:06.229 Socket (7) | Socket gracefully closed by remote side. | 2021-06-14 16:37:06.256 Socket (7) | Closed. | 2021-06-14 16:37:06.256 HD Request # 42 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:06.316 HD Request # 42 | Sending historical data logon request message. | 2021-06-14 16:37:06.316 HD Request # 42 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:58. Record interval: 1. Symbol: NQM21 | 2021-06-14 16:37:06.817 HD Request # 42 | Decompressing data. | 2021-06-14 16:37:06.869 HD Request # 42 | Receiving Intraday data for F.US.ENQM21 starting at 2021-06-14 16:08:58.032000 | 2021-06-14 16:37:06.922 Socket (5) | CloseSocket call. | 2021-06-14 16:37:06.925 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:06.925 Historical data download thread signaled to stop. | 2021-06-14 16:37:06.925 HD Request # 42 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:58.032000 | 2021-06-14 16:37:06.925 HD Request # 42 | Received 1107 records from 2021-06-14 16:08:58.032000 to 2021-06-14 16:37:05.069000 (28.1 minutes) and wrote 1107 records for F.US.ENQM21 | 2021-06-14 16:37:06.926 HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:37:05.069000 | 2021-06-14 16:37:06.932 HD Request # 42 | Completion time: 0s | 2021-06-14 16:37:06.932 HD Request # 42 | Intraday data download complete for F.US.ENQM21. Unique request ID: 42 | 2021-06-14 16:37:06.932 Removing historical data download ID 42. | 2021-06-14 16:37:06.932 Real-time Intraday chart data file updates started for F.US.ENQM21 | 2021-06-14 16:37:06.932 Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQM21.scid. Thread ID: 3636 | 2021-06-14 16:37:06.932 Intraday chart data file opened for F.US.ENQM21 | 2021-06-14 16:37:06.932 HD Request # 42 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:06.932 Triggering next historical data download in queue. | 2021-06-14 16:37:06.932 HD Request # 43 | Downloading Intraday chart data for F.US.RTYM21 to the file F.US.RTYM21.scid. Service: cme | 2021-06-14 16:37:06.932 HD Request # 43 | Download start date-time: 2021-06-14 16:08:54.000000. File last date-time: 2021-06-14 16:08:54.114000 | 2021-06-14 16:37:06.933 HD Request # 43 | Using server: ds23.sierracharts.com port 10149 | 2021-06-14 16:37:06.934 Socket (6) | Creating socket. | 2021-06-14 16:37:06.934 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:37:06.934 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:37:06.934 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:06.976 Socket (5) | Closed. | 2021-06-14 16:37:06.976 HD Request # 43 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:07.052 HD Request # 43 | Sending historical data logon request message. | 2021-06-14 16:37:07.052 HD Request # 43 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:54. Record interval: 1. Symbol: RTYM21 | 2021-06-14 16:37:07.551 HD Request # 43 | Decompressing data. | 2021-06-14 16:37:07.595 HD Request # 43 | Receiving Intraday data for F.US.RTYM21 starting at 2021-06-14 16:08:54.114000 | 2021-06-14 16:37:07.603 Socket (6) | CloseSocket call. | 2021-06-14 16:37:07.606 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:07.606 Historical data download thread signaled to stop. | 2021-06-14 16:37:07.606 HD Request # 43 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:54.114000 | 2021-06-14 16:37:07.607 HD Request # 43 | Received 252 records from 2021-06-14 16:08:54.114000 to 2021-06-14 16:36:18.196000 (27.4 minutes) and wrote 252 records for F.US.RTYM21 | 2021-06-14 16:37:07.607 HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:36:18.196000 | 2021-06-14 16:37:07.618 HD Request # 43 | Completion time: 1s | 2021-06-14 16:37:07.618 HD Request # 43 | Intraday data download complete for F.US.RTYM21. Unique request ID: 43 | 2021-06-14 16:37:07.618 Removing historical data download ID 43. | 2021-06-14 16:37:07.618 Real-time Intraday chart data file updates started for F.US.RTYM21 | 2021-06-14 16:37:07.618 Opened cached Intraday file: C:\SierraChart\Data\F.US.RTYM21.scid. Thread ID: 3636 | 2021-06-14 16:37:07.618 Intraday chart data file opened for F.US.RTYM21 | 2021-06-14 16:37:07.618 HD Request # 43 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:07.618 Triggering next historical data download in queue. | 2021-06-14 16:37:07.618 HD Request # 44 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2021-06-14 16:37:07.619 HD Request # 44 | Download start date-time: 2021-06-14 16:08:57.000000. File last date-time: 2021-06-14 16:08:57.057000 | 2021-06-14 16:37:07.619 HD Request # 44 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2021-06-14 16:37:07.619 Socket (5) | Creating socket. | 2021-06-14 16:37:07.620 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:07.620 Socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:37:07.620 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:37:07.649 Socket (6) | Closed. | 2021-06-14 16:37:07.649 HD Request # 44 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:07.709 HD Request # 44 | Sending historical data logon request message. | 2021-06-14 16:37:07.709 HD Request # 44 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:57. Record interval: 1. Symbol: TSLA | 2021-06-14 16:37:08.212 HD Request # 44 | Decompressing data. | 2021-06-14 16:37:08.252 HD Request # 44 | Receiving Intraday data for TSLA starting at 2021-06-14 16:08:57.057000 | 2021-06-14 16:37:08.304 Socket (5) | CloseSocket call. | 2021-06-14 16:37:08.307 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:08.307 Historical data download thread signaled to stop. | 2021-06-14 16:37:08.307 HD Request # 44 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:57.057000 | 2021-06-14 16:37:08.307 HD Request # 44 | Received 840 records from 2021-06-14 16:08:57.057000 to 2021-06-14 16:37:06.229000 (28.2 minutes) and wrote 840 records for TSLA | 2021-06-14 16:37:08.307 HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:37:06.229000 | 2021-06-14 16:37:08.312 HD Request # 44 | Completion time: 1s | 2021-06-14 16:37:08.312 HD Request # 44 | Intraday data download complete for TSLA. Unique request ID: 44 | 2021-06-14 16:37:08.312 Removing historical data download ID 44. | 2021-06-14 16:37:08.312 Real-time Intraday chart data file updates started for TSLA | 2021-06-14 16:37:08.312 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 3636 | 2021-06-14 16:37:08.312 Intraday chart data file opened for TSLA | 2021-06-14 16:37:08.312 HD Request # 44 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:08.312 Triggering next historical data download in queue. | 2021-06-14 16:37:08.312 HD Request # 45 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2021-06-14 16:37:08.312 HD Request # 45 | Download start date-time: 2021-06-14 16:09:02.000000. File last date-time: 2021-06-14 16:09:02.709000 | 2021-06-14 16:37:08.312 HD Request # 45 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2021-06-14 16:37:08.312 Socket (6) | Creating socket. | 2021-06-14 16:37:08.312 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:37:08.312 Socket (6) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:37:08.312 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:08.347 Socket (5) | Closed. | 2021-06-14 16:37:08.347 HD Request # 45 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:08.412 HD Request # 45 | Sending historical data logon request message. | 2021-06-14 16:37:08.412 HD Request # 45 | Requesting Intraday data. Start date-time: 2021-06-14 16:09:02. Record interval: 1. Symbol: AAPL | 2021-06-14 16:37:08.454 HD Request # 45 | Decompressing data. | 2021-06-14 16:37:08.498 HD Request # 45 | Receiving Intraday data for AAPL starting at 2021-06-14 16:09:02.709000 | 2021-06-14 16:37:08.592 Socket (6) | CloseSocket call. | 2021-06-14 16:37:08.598 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:08.598 Historical data download thread signaled to stop. | 2021-06-14 16:37:08.598 HD Request # 45 | Timestamp of first Intraday data file record written: 2021-06-14 16:09:02.709000 | 2021-06-14 16:37:08.598 HD Request # 45 | Received 1359 records from 2021-06-14 16:09:02.709000 to 2021-06-14 16:37:05.377000 (28.0 minutes) and wrote 1359 records for AAPL | 2021-06-14 16:37:08.599 HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:37:05.377000 | 2021-06-14 16:37:08.607 HD Request # 45 | Completion time: 0s | 2021-06-14 16:37:08.607 HD Request # 45 | Intraday data download complete for AAPL. Unique request ID: 45 | 2021-06-14 16:37:08.607 Removing historical data download ID 45. | 2021-06-14 16:37:08.607 Real-time Intraday chart data file updates started for AAPL | 2021-06-14 16:37:08.607 Opened cached Intraday file: C:\SierraChart\Data\AAPL.scid. Thread ID: 3636 | 2021-06-14 16:37:08.607 Intraday chart data file opened for AAPL | 2021-06-14 16:37:08.607 HD Request # 45 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:08.607 Triggering next historical data download in queue. | 2021-06-14 16:37:08.607 HD Request # 46 | Downloading Intraday chart data for F.US.CLEN21 to the file F.US.CLEN21.scid. Service: nymex | 2021-06-14 16:37:08.607 HD Request # 46 | Download start date-time: 2021-06-14 16:08:59.000000. File last date-time: 2021-06-14 16:08:59.982000 | 2021-06-14 16:37:08.607 HD Request # 46 | Using server: ds21.sierracharts.com port 10150 | 2021-06-14 16:37:08.607 Socket (5) | Creating socket. | 2021-06-14 16:37:08.608 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:08.608 Socket (5) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:37:08.608 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:37:08.644 Socket (6) | Closed. | 2021-06-14 16:37:08.644 HD Request # 46 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:08.704 HD Request # 46 | Sending historical data logon request message. | 2021-06-14 16:37:08.704 HD Request # 46 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:59. Record interval: 1. Symbol: CLN21 | 2021-06-14 16:37:08.755 HD Request # 46 | Decompressing data. | 2021-06-14 16:37:08.799 HD Request # 46 | Receiving Intraday data for F.US.CLEN21 starting at 2021-06-14 16:08:59.982000 | 2021-06-14 16:37:08.845 Socket (5) | CloseSocket call. | 2021-06-14 16:37:08.848 Historical data download thread signaled to stop. | 2021-06-14 16:37:08.848 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:08.849 HD Request # 46 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:59.982000 | 2021-06-14 16:37:08.849 HD Request # 46 | Received 769 records from 2021-06-14 16:08:59.982000 to 2021-06-14 16:37:04.249000 (28.1 minutes) and wrote 769 records for F.US.CLEN21 | 2021-06-14 16:37:08.849 HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:37:04.249000 | 2021-06-14 16:37:08.857 HD Request # 46 | Completion time: 0s | 2021-06-14 16:37:08.858 HD Request # 46 | Intraday data download complete for F.US.CLEN21. Unique request ID: 46 | 2021-06-14 16:37:08.858 Removing historical data download ID 46. | 2021-06-14 16:37:08.858 Real-time Intraday chart data file updates started for F.US.CLEN21 | 2021-06-14 16:37:08.858 Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEN21.scid. Thread ID: 3636 | 2021-06-14 16:37:08.858 Intraday chart data file opened for F.US.CLEN21 | 2021-06-14 16:37:08.858 HD Request # 46 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:08.858 Triggering next historical data download in queue. | 2021-06-14 16:37:08.858 HD Request # 47 | Downloading Intraday chart data for F.US.MESM21 to the file F.US.MESM21.scid. Service: cme | 2021-06-14 16:37:08.858 HD Request # 47 | Download start date-time: 2021-06-14 16:08:58.000000. File last date-time: 2021-06-14 16:08:58.426000 | 2021-06-14 16:37:08.859 HD Request # 47 | Using server: ds23.sierracharts.com port 10149 | 2021-06-14 16:37:08.859 Socket (6) | Creating socket. | 2021-06-14 16:37:08.859 Socket (6) | New receive buffer size: 5242880 | 2021-06-14 16:37:08.859 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:37:08.859 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:08.898 Socket (5) | Closed. | 2021-06-14 16:37:08.898 HD Request # 47 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:08.957 HD Request # 47 | Sending historical data logon request message. | 2021-06-14 16:37:08.957 HD Request # 47 | Requesting Intraday data. Start date-time: 2021-06-14 16:08:58. Record interval: 1. Symbol: MESM21 | 2021-06-14 16:37:08.998 HD Request # 47 | Decompressing data. | 2021-06-14 16:37:09.042 HD Request # 47 | Receiving Intraday data for F.US.MESM21 starting at 2021-06-14 16:08:58.426000 | 2021-06-14 16:37:09.055 Socket (6) | CloseSocket call. | 2021-06-14 16:37:09.058 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:09.058 Historical data download thread signaled to stop. | 2021-06-14 16:37:09.059 HD Request # 47 | Timestamp of first Intraday data file record written: 2021-06-14 16:08:58.426000 | 2021-06-14 16:37:09.059 HD Request # 47 | Received 425 records from 2021-06-14 16:08:58.426000 to 2021-06-14 16:37:05.488000 (28.1 minutes) and wrote 425 records for F.US.MESM21 | 2021-06-14 16:37:09.060 HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:37:05.488000 | 2021-06-14 16:37:09.070 HD Request # 47 | Completion time: 1s | 2021-06-14 16:37:09.070 HD Request # 47 | Intraday data download complete for F.US.MESM21. Unique request ID: 47 | 2021-06-14 16:37:09.070 Removing historical data download ID 47. | 2021-06-14 16:37:09.070 Real-time Intraday chart data file updates started for F.US.MESM21 | 2021-06-14 16:37:09.070 Opened cached Intraday file: C:\SierraChart\Data\F.US.MESM21.scid. Thread ID: 3636 | 2021-06-14 16:37:09.070 Intraday chart data file opened for F.US.MESM21 | 2021-06-14 16:37:09.070 HD Request # 47 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:09.070 Triggering next historical data download in queue. | 2021-06-14 16:37:09.070 HD Request # 48 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2021-06-14 16:37:09.070 HD Request # 48 | Download start date-time: 2021-06-14 16:36:28.000000. File last date-time: 2021-06-14 16:36:28.000000 | 2021-06-14 16:37:09.071 HD Request # 48 | Using server: ds4.sierracharts.com port 10150 | 2021-06-14 16:37:09.071 Socket (5) | Creating socket. | 2021-06-14 16:37:09.071 Socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:09.071 Socket (5) | Connecting to IP: 192.81.56.146. | 2021-06-14 16:37:09.071 Socket (6) | Socket gracefully closed by remote side. | 2021-06-14 16:37:09.101 Socket (6) | Closed. | 2021-06-14 16:37:09.101 HD Request # 48 | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:09.182 HD Request # 48 | Sending historical data logon request message. | 2021-06-14 16:37:09.182 HD Request # 48 | Requesting Intraday data. Start date-time: 2021-06-14 16:36:28. Record interval: 1. Symbol: TICK-NYSE | 2021-06-14 16:37:09.768 HD Request # 48 | Decompressing data. | 2021-06-14 16:37:09.817 HD Request # 48 | Receiving Intraday data for TICK-NYSE starting at 2021-06-14 16:36:28.000000 | 2021-06-14 16:37:09.824 Socket (5) | CloseSocket call. | 2021-06-14 16:37:09.825 Historical data download thread signaled to stop. | 2021-06-14 16:37:09.825 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:09.825 HD Request # 48 | Timestamp of first Intraday data file record written: 2021-06-14 16:36:28.000000 | 2021-06-14 16:37:09.825 HD Request # 48 | Received 41 records from 2021-06-14 16:36:28.000000 to 2021-06-14 16:37:08.000000 (40.0 seconds) and wrote 41 records for TICK-NYSE | 2021-06-14 16:37:09.825 HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2021-06-14 16:37:08.000000 | 2021-06-14 16:37:09.830 Added 1 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2021-06-14 16:37:09.830 HD Request # 48 | Completion time: 0s | 2021-06-14 16:37:09.830 HD Request # 48 | Intraday data download complete for TICK-NYSE. Unique request ID: 48 | 2021-06-14 16:37:09.830 Removing historical data download ID 48. | 2021-06-14 16:37:09.830 Real-time Intraday chart data file updates started for TICK-NYSE | 2021-06-14 16:37:09.830 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 3636 | 2021-06-14 16:37:09.833 Intraday chart data file opened for TICK-NYSE | 2021-06-14 16:37:09.833 HD Request # 48 | Enabling Intraday chart updating for symbol. | 2021-06-14 16:37:09.833 Triggering next historical data download in queue. | 2021-06-14 16:37:09.833 No download requests in the queue to start downloads for. | 2021-06-14 16:37:09.833 Socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:09.879 Socket (5) | Closed. | 2021-06-14 16:37:09.879 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:37:10.564 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:10.564 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:10.564 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:37:10.564 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:10.605 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:10.605 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:10.605 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:10.654 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:10.654 SC Data - All Services | Received logon response. | 2021-06-14 16:37:11.262 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:11.262 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:11.262 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:11.262 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:11.262 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:11.263 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:11.263 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:11.263 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:11.263 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:11.303 DTC Client socket (5) | Closed. | 2021-06-14 16:37:11.303 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:37:16.269 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:16.269 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:16.269 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:37:16.269 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:16.312 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:16.312 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:16.312 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:16.361 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:16.361 SC Data - All Services | Received logon response. | 2021-06-14 16:37:16.971 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:16.972 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:16.972 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:16.972 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:16.972 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:16.972 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:16.972 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:16.972 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:16.973 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:17.012 DTC Client socket (5) | Closed. | 2021-06-14 16:37:17.012 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:37:21.972 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:21.974 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:21.974 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:37:21.974 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:22.016 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:22.016 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:22.016 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:22.091 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:22.091 SC Data - All Services | Received logon response. | 2021-06-14 16:37:22.233 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:22.233 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:22.233 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:22.233 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:22.234 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:22.234 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:22.234 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:22.234 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:22.234 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:22.272 DTC Client socket (5) | Closed. | 2021-06-14 16:37:22.272 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:37:27.211 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:27.212 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:27.212 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:37:27.212 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:27.263 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:27.263 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:27.263 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:27.337 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:27.337 SC Data - All Services | Received logon response. | 2021-06-14 16:37:27.480 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:27.480 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:27.480 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:27.481 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:27.481 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:27.481 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:27.481 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:27.481 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:27.482 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:27.524 DTC Client socket (5) | Closed. | 2021-06-14 16:37:27.524 The message log has been sent to support. | 2021-06-14 16:37:29.191 * HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (5) | Creating socket. Using TLS 1.2. | 2021-06-14 16:37:29.191 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (5) | New receive buffer size: 32768 | 2021-06-14 16:37:29.192 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (5) | Connecting to IP: 95.216.233.104. | 2021-06-14 16:37:29.192 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2021-06-14 16:37:31.419 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (5) | CloseSocket call. | 2021-06-14 16:37:31.666 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:31.666 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:31.799 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (5) | Closed. | 2021-06-14 16:37:31.799 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:37:32.479 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:32.480 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:32.480 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:37:32.480 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:32.525 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:32.525 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:32.525 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:32.590 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:32.590 SC Data - All Services | Received logon response. | 2021-06-14 16:37:32.751 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:32.751 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:32.751 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:32.751 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:32.751 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:32.751 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:32.751 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:32.752 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:32.752 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:32.793 DTC Client socket (5) | Closed. | 2021-06-14 16:37:32.793 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10048 | 2021-06-14 16:37:34.574 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:34.575 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:34.575 DTC Client socket (5) | Connecting to IP: 204.15.197.13. | 2021-06-14 16:37:34.575 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:34.641 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:34.641 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:34.642 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:34.696 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:34.696 SC Data - All Services | Received logon response. | 2021-06-14 16:37:35.477 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:35.477 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:35.477 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:35.477 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:35.477 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:35.478 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:35.478 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:37:35.478 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:35.478 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:35.535 DTC Client socket (5) | Closed. | 2021-06-14 16:37:35.535 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:37:37.742 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:37.743 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:37.743 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:37:37.743 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:37.786 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:37.786 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:37.786 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:37.850 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:37.850 SC Data - All Services | Received logon response. | 2021-06-14 16:37:38.012 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:38.012 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:38.012 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:38.012 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:38.012 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:38.013 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:38.013 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:38.013 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:38.013 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:38.052 DTC Client socket (5) | Closed. | 2021-06-14 16:37:38.052 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:37:42.993 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:42.994 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:42.994 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:37:42.994 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:43.039 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:43.039 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:43.039 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:43.094 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:43.094 SC Data - All Services | Received logon response. | 2021-06-14 16:37:43.703 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:43.703 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:43.703 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:43.703 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:43.704 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:43.704 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:43.704 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:43.704 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:43.705 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:43.745 DTC Client socket (5) | Closed. | 2021-06-14 16:37:43.745 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:37:48.686 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:48.687 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:48.687 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:37:48.687 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:48.731 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:48.731 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:48.731 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:48.786 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:48.786 SC Data - All Services | Received logon response. | 2021-06-14 16:37:49.419 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:49.419 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:49.419 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:49.419 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:49.419 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:49.419 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:49.419 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:49.420 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:49.420 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:49.459 DTC Client socket (5) | Closed. | 2021-06-14 16:37:49.459 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:37:54.420 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:54.420 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:54.420 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:37:54.420 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:54.465 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:54.465 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:54.465 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:54.534 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:54.534 SC Data - All Services | Received logon response. | 2021-06-14 16:37:54.669 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:54.669 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:54.669 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:54.669 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:54.669 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:54.669 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:54.669 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:54.669 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:54.669 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:54.709 DTC Client socket (5) | Closed. | 2021-06-14 16:37:54.709 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:37:59.656 DTC Client socket (5) | Creating socket. | 2021-06-14 16:37:59.657 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:37:59.657 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:37:59.657 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:37:59.698 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:37:59.698 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:37:59.698 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:37:59.761 SC Data - All Services | Sending logon request message. | 2021-06-14 16:37:59.761 SC Data - All Services | Received logon response. | 2021-06-14 16:37:59.912 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:37:59.912 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:37:59.912 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:37:59.912 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:37:59.912 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:37:59.913 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:37:59.913 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:37:59.913 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:37:59.913 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:37:59.955 DTC Client socket (5) | Closed. | 2021-06-14 16:37:59.955 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:38:04.908 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:04.909 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:04.909 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:38:04.909 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:04.954 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:04.954 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:04.954 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:05.000 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:05.000 SC Data - All Services | Received logon response. | 2021-06-14 16:38:05.154 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:05.154 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:05.154 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:05.154 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:05.154 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:05.155 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:05.155 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:05.155 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:05.155 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:05.189 DTC Client socket (5) | Closed. | 2021-06-14 16:38:05.189 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2021-06-14 16:38:05.469 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:05.470 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:05.470 DTC Client socket (5) | Connecting to IP: 216.1.90.129. | 2021-06-14 16:38:05.470 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:05.518 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:05.518 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:05.518 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:05.580 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:05.580 SC Data - All Services | Received logon response. | 2021-06-14 16:38:06.269 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:06.269 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:06.269 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:06.269 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:06.269 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:06.270 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:06.270 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:38:06.270 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:06.270 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:06.313 DTC Client socket (5) | Closed. | 2021-06-14 16:38:06.313 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:38:10.158 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:10.159 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:10.159 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:38:10.159 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:10.206 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:10.206 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:10.206 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:10.253 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:10.253 SC Data - All Services | Received logon response. | 2021-06-14 16:38:10.408 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:10.408 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:10.408 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:10.408 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:10.408 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:10.408 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:10.409 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:10.409 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:10.409 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:10.449 DTC Client socket (5) | Closed. | 2021-06-14 16:38:10.449 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:38:15.402 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:15.403 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:15.403 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:38:15.403 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:15.449 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:15.449 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:15.449 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:15.502 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:15.502 SC Data - All Services | Received logon response. | 2021-06-14 16:38:16.112 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:16.112 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:16.112 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:16.112 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:16.112 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:16.113 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:16.113 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:16.113 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:16.114 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:16.158 DTC Client socket (5) | Closed. | 2021-06-14 16:38:16.158 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:38:21.109 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:21.110 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:21.110 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:38:21.110 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:21.163 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:21.163 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:21.163 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:21.221 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:21.221 SC Data - All Services | Received logon response. | 2021-06-14 16:38:21.830 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:21.831 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:21.831 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:21.831 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:21.831 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:21.831 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:21.831 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:21.831 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:21.832 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:21.876 DTC Client socket (5) | Closed. | 2021-06-14 16:38:21.876 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:38:26.817 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:26.818 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:26.818 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:38:26.818 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:26.859 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:26.859 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:26.859 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:26.904 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:26.904 SC Data - All Services | Received logon response. | 2021-06-14 16:38:27.051 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:27.051 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:27.051 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:27.051 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:27.051 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:27.052 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:27.052 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:27.052 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:27.052 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:27.095 DTC Client socket (5) | Closed. | 2021-06-14 16:38:27.095 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:38:32.054 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:32.054 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:32.054 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:38:32.054 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:32.101 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:32.101 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:32.101 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:32.161 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:32.161 SC Data - All Services | Received logon response. | 2021-06-14 16:38:32.330 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:32.330 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:32.330 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:32.330 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:32.330 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:32.330 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:32.330 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:32.330 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:32.330 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:32.367 DTC Client socket (5) | Closed. | 2021-06-14 16:38:32.367 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-06-14 16:38:36.260 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:36.261 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:36.262 DTC Client socket (5) | Connecting to IP: 216.1.90.130. | 2021-06-14 16:38:36.262 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:36.338 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:36.338 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:36.338 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:36.442 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:36.442 SC Data - All Services | Received logon response. | 2021-06-14 16:38:37.160 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:37.160 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:37.160 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:37.160 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:37.160 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:37.161 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:37.161 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:38:37.161 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:37.161 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:37.204 DTC Client socket (5) | Closed. | 2021-06-14 16:38:37.204 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:38:37.321 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:37.321 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:37.321 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:38:37.321 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:37.366 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:37.366 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:37.366 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:37.438 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:37.438 SC Data - All Services | Received logon response. | 2021-06-14 16:38:37.588 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:37.588 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:37.588 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:37.588 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:37.588 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:37.589 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:37.589 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:37.589 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:37.589 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:37.636 DTC Client socket (5) | Closed. | 2021-06-14 16:38:37.636 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:38:42.594 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:42.595 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:42.595 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:38:42.595 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:42.651 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:42.651 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:42.651 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:42.707 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:42.707 SC Data - All Services | Received logon response. | 2021-06-14 16:38:42.847 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:42.847 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:42.847 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:42.847 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:42.847 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:42.848 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:42.848 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:42.848 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:42.848 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:42.895 DTC Client socket (5) | Closed. | 2021-06-14 16:38:42.895 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:38:47.837 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:47.838 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:47.838 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:38:47.838 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:47.886 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:47.886 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:47.886 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:47.938 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:47.938 SC Data - All Services | Received logon response. | 2021-06-14 16:38:48.530 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:48.530 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:48.530 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:48.530 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:48.530 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:48.531 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:48.531 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:48.531 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:48.531 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:48.572 DTC Client socket (5) | Closed. | 2021-06-14 16:38:48.572 CQG WebSocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-06-14 16:38:49.097 CQG WebSocket socket (2) | Closed. | 2021-06-14 16:38:49.097 DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-06-14 16:38:49.097 DTC Client socket (3) | Closed. | 2021-06-14 16:38:49.097 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:38:53.529 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:53.530 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:53.531 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:38:53.531 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:53.578 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:53.578 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:53.578 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:53.649 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:53.649 SC Data - All Services | Received logon response. | 2021-06-14 16:38:54.290 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:54.290 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:54.290 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:54.290 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:54.290 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:54.290 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:54.290 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:54.290 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:54.291 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:54.333 DTC Client socket (5) | Closed. | 2021-06-14 16:38:54.333 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:38:59.286 DTC Client socket (5) | Creating socket. | 2021-06-14 16:38:59.287 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:38:59.288 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:38:59.288 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:38:59.336 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:38:59.336 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:38:59.337 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:38:59.404 SC Data - All Services | Sending logon request message. | 2021-06-14 16:38:59.404 SC Data - All Services | Received logon response. | 2021-06-14 16:38:59.546 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:38:59.546 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:38:59.546 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:38:59.546 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:38:59.546 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:38:59.547 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:38:59.547 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:38:59.547 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:38:59.547 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:38:59.593 DTC Client socket (5) | Closed. | 2021-06-14 16:38:59.593 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-06-14 16:39:04.546 DTC Client socket (5) | Creating socket. | 2021-06-14 16:39:04.547 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:39:04.547 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-06-14 16:39:04.547 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:39:04.598 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:39:04.598 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:39:04.598 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:39:04.680 SC Data - All Services | Sending logon request message. | 2021-06-14 16:39:04.680 SC Data - All Services | Received logon response. | 2021-06-14 16:39:04.823 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:39:04.823 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:39:04.823 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:39:04.823 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:39:04.823 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:39:04.823 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:39:04.823 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-06-14 16:39:04.823 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:39:04.824 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:39:04.868 DTC Client socket (5) | Closed. | 2021-06-14 16:39:04.868 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-06-14 16:39:07.168 DTC Client socket (5) | Creating socket. | 2021-06-14 16:39:07.168 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:39:07.168 DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2021-06-14 16:39:07.168 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:39:07.226 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:39:07.226 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:39:07.226 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-14 16:39:07.311 SC Data - All Services | Sending logon request message. | 2021-06-14 16:39:07.311 SC Data - All Services | Received logon response. | 2021-06-14 16:39:08.032 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-06-14 16:39:08.032 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-14 16:39:08.032 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-06-14 16:39:08.032 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-14 16:39:08.032 DTC Client socket (5) | CloseSocket call. | 2021-06-14 16:39:08.033 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:39:08.034 SC Data - All Services | Disconnected from the server. | 2021-06-14 16:39:08.034 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-06-14 16:39:08.034 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-14 16:39:08.102 DTC Client socket (5) | Closed. | 2021-06-14 16:39:08.102 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-06-14 16:39:09.810 DTC Client socket (5) | Creating socket. | 2021-06-14 16:39:09.811 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-14 16:39:09.812 DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2021-06-14 16:39:09.812 SC Data - All Services | Network connection to server complete. | 2021-06-14 16:39:09.856 SC Data - All Services | Starting socket receive thread. | 2021-06-14 16:39:09.856 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-14 16:39:09.856 |
[2021-06-14 17:43:24] |
John - SC Support - Posts: 38222 |
This is the problem: SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
You have another connection to the data feeds somewhere. It could be another installation on the same computer or another computer elsewhere that is still connected. You will need to get that other connection removed by exiting Sierra Chart and then you can get your data to the installation of Sierra Chart from which you posted this log. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
