Date/Time: Thu, 27 Feb 2025 02:10:50 +0000
NYSE/NASDAQ opening/market on close buy/sell imbalances
View Count: 396
[2021-06-14 12:18:28] |
User241092 - Posts: 1 |
Good day! I was wondering if your NYSE/NASDAQ data feed provides historical data on opening/closing imbalances. Thank you.
[2021-06-14 21:21:51] |
Sierra_Chart Engineering - Posts: 18577 |
If you are referring to historical Bid Volume and Ask Volume which can be used with the Numbers Bars study, yes that is provided with US equities data. You can test it now by using this service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-14 21:22:14
