Date/Time: Thu, 27 Feb 2025 00:36:49 +0000
[Programming Help] - Cumulative Delta Bars Volume
View Count: 514
[2021-06-14 08:02:14] |
TeaTreeElle - Posts: 3 |
Hello, I have an account with AMP and am having issues with the Cumulative Delta Volume indicator. Essentially, when price is clearly moving, I have sections of the Cumulative Delta indicator just flat (showing a flat line with no volume or movement whatsoever). A colleague of mine who trades with a different broker but uses Sierra is seeing Cumulative Delta that is clearly accurate. I believe that I might have seen somewhere on this message board that this could be more of an issue with AMP users. Could you clarify if that is, indeed, the case? Thank you, Christina |
