Date/Time: Thu, 27 Feb 2025 00:19:51 +0000
Tick distance from current price to line tool
View Count: 657
[2021-06-12 08:34:38] |
User153971 - Posts: 23 |
Is there a way to see the number of ticks from a line tool (at a set price) to the current market price that automatically updates the number of ticks when the market price changes? I know that you can use the chart calculator tool but this is a manual process and I would have to keep moving the tool each time the market changes price.
[2021-06-13 02:20:34] |
You might be able to do this using this study: Spreadsheet Formula Since it is possible to make reference to Chart Drawings: Study/Chart Alerts And Scanning: Referencing Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
