Date/Time: Thu, 27 Feb 2025 00:39:53 +0000
premiums
View Count: 416
[2021-06-11 17:31:47] |
User379557 - Posts: 37 |
The "find a symbol" has premiums-the spread between futures and cash index. How much does real time data for the premiums cost to add that to my current service? thank you- |
[2021-06-11 19:38:45] |
John - SC Support - Posts: 38222 |
That is really an old feature that is no longer supported. To get this data, use the Custom Calculated Symbol. Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
