Date/Time: Thu, 27 Feb 2025 00:19:07 +0000
Failed to activate the 'CBOE Indices' exchange
View Count: 469
[2021-06-11 16:12:03]
Eric Fraenkel - Posts: 4
When trying to activate the "CBOE Indicies" service I receive a message "To enable the exchange at least one Real-time Data Connection must be currently active and enabled for Auto-Renewal". I'm using Denali Data Feed level 11 and have signed up for the quarterly rate. Also paying for CBOE and CME and NYMEX and COMEX real time data. I don't understand what I'm doing wrong?
Thanks in advance for your help.
[2021-06-11 19:07:00]
John - SC Support - Posts: 38222
Your statement says that you are trying to activate the CBOE Indices, which is part of the Sierra Chart Exchange Data Feed (it is NOT part of the Denali Exchange Data Feed). Therefore, if you are really wanting the CBOE Indices, you will need to follow these instructions:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
If, on the other hand, you are trying to actually activate the CBOE Futures Exchange (CFE), then that is part of the Denali Exchange Data Feed, and you will need to do the following to activate this exchange:
- Complete the agreements here:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements_CFE
- Activate the exchange here:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedCFE
