Date/Time: Thu, 27 Feb 2025 00:38:00 +0000
I have problems doing Rollover with ticks chart
View Count: 479
[2021-06-11 15:05:06] |
User333384 - Posts: 10 |
Hi. I am trying to do the rollover of the MESM21 to MESU21. When I do it, the new chart is quite extrange. It compresses from June 4 to June 10 in short part of the chart. I do not know what to do. I trade using ticks charts and They are not working properly with sierrachart. I asked to friends who use ninjatrader and they are not having those problems with ticks charts http://www.sierrachart.com/image.php?Image=1623423668237.png |
[2021-06-13 07:27:29] |
Sierra_Chart Engineering - Posts: 18577 |
You will need to use the Denali Exchange Data Feed for data for Continuous Futures Contract charts. CQG does not provide the necessary data for this. Documentation and instructions: Denali Exchange Data Feed This is only 10 USD per month more. You will need to change to Service Package 10. There is also the cost of the exchange fee, but you are already paying that through CQG. So you just need to cancel that through CQG and then you pay the exchange fee to Sierra Chart instead. This is the solution. Please do not waste any further time with substandard CQG data. It is not going to work for you. You need to follow our instructions. If you need help setting up the Denali data feed, just let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-13 07:28:43
