Date/Time: Thu, 27 Feb 2025 00:36:42 +0000
Chart keeps switching to simulation
View Count: 442
[2021-06-11 14:49:00] |
User227729 - Posts: 3 |
when i uncheck the simulation mode it looks good but when i place a trade it goes back to simulation by its self. The trade window says unset. Date Time Of Last Edit: 2021-06-11 14:52:04
[2021-06-11 15:32:59] |
Sierra_Chart Engineering - Posts: 18577 |
You need to set Sierra Chart to connect to your Trading service. If you are using CQG then follow the instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
