Date/Time: Thu, 27 Feb 2025 00:29:58 +0000
Alerts not working
View Count: 784
[2021-06-11 11:37:26] |
User820638 - Posts: 21 |
Hi, I have tried setting up alerts. I set up in both global settings and as well as on the actual chart drawing properties but the alert doesn't fire. No sound or email. Should I be doing something extra? Thanks |
[2021-06-11 18:04:40] |
John - SC Support - Posts: 38222 |
We assume you are trying to create a Chart Drawing Alert, by selecting Alerts for the drawing itself. In which case, are you selecting the option at the top for Enable Alert for Chart Drawing? Refer to the following: Chart Drawing Tools: Chart Drawing Alerts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
