Date/Time: Thu, 27 Feb 2025 00:19:41 +0000
maximum limit of drawings in chartbook?
View Count: 421
[2021-06-10 20:37:04] |
whats1thingnow - Posts: 407 |
hi support, this particular chartbook runs without any lag or issues during market hours however, when i'm updating durings after market closes, it keeps on freezing on me i cannot share a message log because when it happens, the program just freezes (i don't see a new line in the message log anyway) no keyboard shortcuts work, nor right clicking, and i have to use windows task manager to force shutdown since this only happens when i'm adding drawings (usually when adding 'extending rentangle', then right click 'modify text'), is there a maximum limit for the number of drawings on a chart/chartbook? i have many drawings across multiple charts. then the above drawings are also automatically shown in a consolidated drawings chart thank you Date Time Of Last Edit: 2021-06-10 20:50:44
[2021-06-10 22:12:27] |
is there a maximum limit for the number of drawings on a chart/chartbook? No.
