Date/Time: Thu, 27 Feb 2025 00:32:42 +0000
Display spans
View Count: 580
[2021-06-10 20:03:19]
TraderTom - Posts: 25
Recently I had to reinstall Sierra chart because the system disk of the computer went out. On this Windows 10 machine I have Sierra Chart on two main displays side by side. I do not see a dual display symbol in the window top right min and max commands. But the problem is that whenever the computer is locked and then unlocked the program is all on only one screen. I have to move it to the right screen and expand its size to two screens again. Previously I did not have to do that, the program remained spanned across the two screens. How do I restore this feature?
Tom Ellis
[2021-06-11 16:47:22]
John - SC Support - Posts: 38222
There is no special control that we have for this. If it worked previously, but does not now, then most likely there was a change in the Operating System for how it handles this kind of setup.
Another possibility is that you were not "stretching" the one instance across the monitors, but were running another instance of Sierra Chart on the second monitor. Refer to the following:
File Menu: New Instance (File)
