Date/Time: Thu, 27 Feb 2025 00:31:14 +0000
Live data without a broker
View Count: 482
[2021-06-10 18:24:36]
alamin287 - Posts: 13
Hello, I hope everyone is well.
I have been trying to get approved by many futures brokers but I just keep getting rejected.
I am currently using package 5 - advanced. I just want live data but for the same package I am currently using, nothing else.
What is the TOTAL cost for this and how do I get this done?
I am trading the E-minis primarily, if i get this done, will i also get live data for the NYMEX exchange or will it just be for the CME?
Thankyou!
[2021-06-10 19:55:17]
mv3trader5 - Posts: 5
If all you need is live data just upgrade to package 11. It's only $10 more than package 5 and gives you live data through Denali. To upgrade you just login, go to Activate Services under the Account Management tab. Under the Available Services section you can choose which package you want.
[2021-06-10 20:11:15]
Thankyou. Will I still get TPO charts? I'm using TPO, VWAP and the footprint. Will I still get all of this?
[2021-06-11 16:56:29]
John - SC Support - Posts: 38222
The information from post #2 is not completely correct. You do have to change your package, but you also need to fill out the agreements and activate the exchanges you want.
In addition, if you do not have a funded futures trading account, then the CME Group rules are that you have to be treated as a Professional and pay the Professional exchange rates. For more information on this, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you have not already tried AMP for a broker, then take a look at this option:
Easy Solution to CME Funded Trading Account Requirement
If you are still interested in using the Denali Exchange Data Feed, then refer to the Setup Instructions for the CME Group here:
Note that the instructions will tell you when and how to change your Service Package. If you do activate the Denali Exchange Data Feed, then you will eventually be on Package 11, which is the same as Package 5, but with the Denali Exchange Data Feed Fee included.
Date Time Of Last Edit: 2021-06-11 16:57:26
