Date/Time: Thu, 27 Feb 2025 00:13:02 +0000
1,5 Range Footprint
View Count: 632
[2021-06-10 16:05:35]
User622853 - Posts: 3
hello, my footprint chart in the cl future and in the 6e can no longer be set correctly. It's right in the S&P future. why is that?
Private File
[2021-06-11 16:16:48]
John - SC Support - Posts: 38222
You just need to expand your scale. Since you have those lines that are at prices around 70.8 and 69.20 the overall height is "squished" down. You can still leave your scale setting as Automatic, but you will need to expand the scale in order to see the Numbers Bars. If you reset the scales, you will get what you have now.
In general, refer to the following for scaling Numbers Bars:
Numbers Bars: Scaling a Numbers Bars Chart
