Date/Time: Thu, 27 Feb 2025 00:15:23 +0000
CBOT OCO Error
View Count: 428
[2021-06-10 14:47:36] |
Zazza.83 - Posts: 11 |
I tried to do a CBOT trade. Specifically, I was on the Micro DowJOnes. In my Denali data feed I have the CBOT with the Depth of Market active. I placed the order and immediately as the market entry was processed it gave me two errors, canceling the two OCO orders, one for the stop loss and one for the take profit. I immediately closed the operation thinking there was some problem. Fortunately, the operation closed correctly by clicking on Flatten And Cancel. I wanted to understand where the problem came from. I am attaching the image of the problem. |
![]() Attachment Deleted. |
[2021-06-10 15:36:05] |
CQG gave you an error regarding the order type. What are the order types you used for the Attached Orders? For information about Attached Orders, refer to: Attached Orders Only use a Limit order or a Stop or Stop Limit order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-10 15:36:48
