Date/Time: Thu, 27 Feb 2025 02:37:35 +0000
Compile Example Studies4.cpp
View Count: 563
[2021-06-10 14:38:59]
User230940 - Posts: 121
I would like to compile the studies4.cpp.
I add a SCDLLName Part to the cpp and tried to compile. But this failed, because of missing link.
What do i have to do to create the studies4.cpp for my own?
Thanks for your help.
best regards
carsten
[2021-06-15 05:34:15]
Sierra_Chart Engineering - Posts: 18577
You need to extract out of that file, specifically the study function that you require. Refer to:
How to Build an Advanced Custom Study from Source Code
If you are wanting to use the Candlestick Patterns Finder study, then refer to:
CandleStick Patterns Finder: Changing Source Code
Date Time Of Last Edit: 2021-06-15 05:34:53
[2021-06-15 08:08:26]
OK.
I add to the includes:
#include "CandleStickPatternNames.cpp"
Now I use for Studies4.cpp
#include "sierrachart.h"
#include "CandleStickPatternNames.h"
Now it compiled without failure. You could state this more clear in the documentations. Or provide the possible to add additional files to compile with. The include of a cpp file is not the 100% correct way, if I remind myself right.
thanks
carsten
