Date/Time: Thu, 27 Feb 2025 00:46:34 +0000
Number bar calculated values
View Count: 522
[2021-06-10 09:30:41] |
User644443 - Posts: 10 |
Hey guys, This is probably not a function as i cannot see anything for it but i will ask anyway. Regarding volume per second in the above mentioned study, is there anyway to lessen the amount of digits the volume per second displays? Very trivial but if i could shorten it i could shrink the screen down further to see more data at once and still see the value. TIA |
[2021-06-11 16:00:18] |
John - SC Support - Posts: 38222 |
The Numbers Bars Calculated Values displays get a little funny, since there are so many different types of values that are in there (integers, floating point, time, etc.). Therefore, there are special controls we have put in place to handle these as best we can. The one thing you can do, but it will impact all Numbers Bars Calculated Values Subgraphs in that particular instance of the study, is to set the Use Default Number Formatting for All Subgraphs input to Yes, and then you can change the Value Format to whatever it want, and all the numbers will be displayed with that many decimal points. Refer to the information for this Input here: Numbers Bars: Numbers Bars Calculated Values Input Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
