Date/Time: Thu, 27 Feb 2025 00:15:01 +0000
Blank TPO Chart
View Count: 441
[2021-06-10 08:51:48]
User113285 - Posts: 1
I am trying to add the TPO study but the chart is blank. I am using the free symbol of GER30 but as soon as the TPO study is added the whole chart goes blank - I don't even see a price or time axis.
The same is true with the DAX futures symbol too (FDAXM21-EUREX). I am signed up with Denali, but the point being the TPO study is not even showing on the free symbol of GER30 either.
I have attached the chartbook for you to take a look.
Thanks in advance!
attachmentTPO Sample.cht - Attached On 2021-06-10 08:50:44 UTC - Size: 17.27 KB - 286 views
[2021-06-10 10:23:04]
You need to change your Service Package to 11 which includes Advanced Features with the Denali Exchange Data Feed:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
