Date/Time: Thu, 27 Feb 2025 00:29:18 +0000
Volume by Price label issues
View Count: 530
[2021-06-09 19:41:26] |
SvenSon - Posts: 17 |
Dear SC team, I don't know if this was reported already, but today I found a small bug in the VbP study. If you want to label for example the VPOC or the VA-Lines and set the position to "right", the label appears in the priceladder instead of the right side after the end of the extended line. For a better understanding I attach a screenshot. I hope you guys can easily fix that. Thanks in advance and have a great day. Greetings. Sven :) |
[2021-06-09 20:16:59] |
John - SC Support - Posts: 38222 |
That is not a bug. Refer to the second paragraph here: Volume By Price Study: Extension Line Labels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-09 20:35:55] |
But something is not working correctly, because even if I change to other positions "left edge" the label stays at the priceladder. In the TPO Valuearea Lines Study does this not happen for example. All the labels are set to "right" and they appear on the right side after the line. |
[2021-06-09 20:59:46] |
Sure, we understand that it is not the way you want it to work, or even expect it to. We are just pointing out that what it is doing was a purposeful decision when it was implemented. We are happy to take what you are asking for as a Feature Request. Just keep in mind that as with all Feature Requests, we can not give any time frame for when we might be able to get to the change.
[2021-06-09 21:08:10] |
That is totally fine. I just recognized that and I was kind of confused why this feature behaves differently in VbP than the others, so I wanted to mention it that it might be a small bug which was overseen or so. ( I am not a programmer) :) It would be awesome to treat this as a feature request, but of course take your time. Thank you John and all SC team for your work. |
