Date/Time: Thu, 27 Feb 2025 00:32:09 +0000
market depth
View Count: 505
[2021-06-09 18:09:14] |
Yeager - Posts: 131 |
Hi, I have package 12, but only have full market depth for DAX on eurex. Also, how do I turn on MBO? Many thanks. T |
[2021-06-09 18:51:37] |
John - SC Support - Posts: 38222 |
You should have the full market depth for all symbols traded on the EUREX. You will not have any Market Depth for the CME Group, as the exchange that you activated does not include the Market Depth. If you want to change your selected exchange, you can do so on this page: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed In order to get the MBO, besides needing to be on Package 12 and have an exchange that supports it (the EUREX does, by the way), then you need to go through these instructions: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
