Date/Time: Thu, 27 Feb 2025 00:18:07 +0000
Windows 10 Virtual Desktop - Sierra Chart Functionality
View Count: 564
[2021-06-09 16:14:25]
TapeReader - Posts: 89
When I open a virtual desktop in Windows 10, Sierra Chart does not launch when the executable is invoked.
Is there a specific Sierra Chart configuration that I need to implement to use Sierra Chart on additional Windows 10 Virtual Desktops?
[2021-06-09 16:51:03]
John - SC Support - Posts: 38222
We are not seeing an issue with running Sierra Chart in a Virtual Windows Desktop.
But, you need to be aware that you can NOT run Sierra Chart more than once on a single computer. Therefore, you can not run it in more than one virtual desktop. If it is running in one desktop and you try to start the same Sierra Chart program again, it will not start.
