Date/Time: Thu, 27 Feb 2025 00:40:44 +0000
process for getting a custom study listed in the store
View Count: 459
[2021-06-09 16:11:58] |
User785302 - Posts: 8 |
Hello What is the process for getting a custom study listed in the store? Also, what is the process for getting listed as a systems programmer? |
[2021-06-09 16:44:01] |
John - SC Support - Posts: 38222 |
First, you have to get setup as a Developer/Distributor for a Custom Study. To do this, you need to start an Account Support Ticket and let us know what Account Name will be the controller of the study(s) and also the name you want to give to your study (note that simple names are not acceptable, it has to have enough to be obviously associated with you/your company). Once you are setup to have the study, then you can control your access to the Store through the study control panel. It will make sense once you get going through the process. As to getting listed on our Developer page, just start another Account Support Ticket making that request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
