Date/Time: Thu, 27 Feb 2025 00:16:19 +0000
Numbers Bar Calculated Values - Pullback Volume Difference for Time Frames > Day
View Count: 782
[2021-06-09 14:34:15]
User337568 - Posts: 60
Hi:
I am using a minute chart near the complete Globex Session.
I have a Pullback Bar for this dataset.
However, when I use "Numbers Bars Calculated Values" I don't get any High (Low) Pullback Ask/Bid Vol Difference numbers.
Is this because I am going over a day?
I can access this data for the 30 Minute chart, however, I cannot for this higher timeframe.
Both charts show the pullback bar.
I am using "Reset and Accumulate on New or Touch High Low."
- Thank you for creating this higher timeframe Pullback Bar.
[2021-06-09 15:17:54]
John - SC Support - Posts: 38222
The Numbers Bars and Numbers Bars Calculated Values do not work with Historical Data. Therefore, if you are changing to the Daily timeframe in a normal fashion (i.e. selecting the Daily from the control bar), then when you switch to the Daily timeframe the system is defaulting to the Historical data.
If you really want to see this data on a Daily (and higher) timeframe, then you would need to create those bars from the Intraday data. To do this, you would need to ensure that the setting for Chart >> Chart Settings >> Chart Data Type is set to Intraday Chart Only. Then, when you change to a Daily or higher timeframe, it will not change to the Historical data, but will keep the Intraday data to create the bars. Refer to the following:
Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu)
