Date/Time: Thu, 27 Feb 2025 00:42:45 +0000
CME Historical Data Change after 7/15
View Count: 459
[2021-06-09 13:07:48] |
User895823 - Posts: 3 |
Regarding your pop-up message (system, notification 6/3/21) I've upgraded my charts to v2268. After June 15 will I still get ALL my charts as usual? (what about Historical Daily data - just the Daily timeframe effected?) Also what is "New Instance" (ie File + New Instance)- never used it? Just want to make sure that I will have all my charts - I just don't want a problem not getting my charts. Please explain. Thanks |
[2021-06-09 14:16:07] |
John - SC Support - Posts: 38222 |
Since you have updated to version 2268, you are fine. You will not have any issues. The File >> New Instance option starts a new instance of Sierra Chart. It is a completely separate instance, so any changes made in that sub-instance are only for the sub-instance and do not effect the main instance (or other sub-instances) of Sierra Chart. For more information, refer to the following: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Instructions For Sharing Data Using Sub Instances (Easiest And Recommended Method) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
