Date/Time: Thu, 27 Feb 2025 00:08:02 +0000
CRYPTO SYMBOLS CRASHING SOFTWARE
View Count: 688
[2021-06-03 16:17:27]
Dave - Posts: 8
Hey guys,
Every time I load BTCUSD from Bitfinex - any one else have this issue and how to solve it?
[2021-06-03 16:22:50]
Sierra_Chart Engineering - Posts: 18576
You need to be very precise, about the problem you are experiencing. We have no idea what the issue is.
Date Time Of Last Edit: 2021-06-03 16:22:58
[2021-06-08 08:14:40]
Dave - Posts: 8
Step by step account of what happens:
1. I log into sierra chart and open up a work book - AUD/USD
2. I then go into chart settings/find symbol
3. I open Bitfinex or Binance, get symbols and find either ETHUSD or BTCUSD
4. I click apply and wait for it to load. I do this with all time frames and windows that are open.
5. The chart doesn't load all the way often stuck around the 20% mark
6. If I click to try and close the work book or try to make any adjustment it will crash the software (not responding error message appears) and ill have to start over.
7. This only happens with the crypto symbols - forex, gold, oil and the S&P all work fine
Hope that explains it clearer.
[2021-06-08 08:38:25]
What studies (Studies >> Analysis) are on the chart?
Date Time Of Last Edit: 2021-06-08 08:38:44
[2021-06-08 11:34:34]
nosast - Posts: 312
Had similar issues. Start with a blank chart with no studies. At least no volume based studies like VWAP or Profiles. Also set a higher tick size.
[2021-06-09 05:46:20]
Dave - Posts: 8
I use:
VWAP
Market profile blocks
Volume Profile
Time based candlesticks
Cant I use these to make it work?
[2021-06-09 08:33:07]
You need to increase the Chart Tick Size setting to much higher. We recommend making it 100 times higher just to start off with to be on the safe side.
Refer to:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing
So you cannot use an existing chart and change the symbol to a crypto currency symbol.
