DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
 - Search Board |
 - Control Panel |
 - View My Posts / Threads |
 - Direct Messages
Date/Time: Tue, 04 Nov 2025 11:13:53 +0000
DTC Websocket in browser TLS
View Count: 3126
|   [2020-07-17 12:58:36]     |
| User667559 - Posts: 27 |
                Can someone explain this sentence: When connecting to the DTC Protocol Server in Sierra Chart using a websocket connection from a web browser, it is necessary to install a valid TLS certificate for the domain used. Both the private key and the certificate need to be placed in the /ServerCertificate folder within the Sierra Chart folder. The file names need to be: TLSCertificate.key, TLSCertificate.crt. coming from this page: Data and Trading Communications (DTC) Protocol Server: Web Socket Connections When I open a webpage on 127.0.0.1, what kind of certificate would Sierra need then? And let's say I created a special site dtctrader.com or something and try to connect to Sierra from there, would Sierra need a certificate for dtctrader.com? Can this be self-signed or would the browser dislike this...  |
|   [2020-07-24 20:21:13]     |
                Questions regarding TLS certificates are really outside the scope of the support here. And whether certificates are required or not depends upon the browser. You can try without using certificates and see what happens.
                 Date Time Of Last Edit: 2020-07-24 20:21:24
|   [2021-01-17 10:37:44]     |
| RoadKill - Posts: 38 |
                Well, if using TLS, it is configured on your server, so technically speaking, this is exactly in the scope of your support pages.
|   [2021-02-10 20:03:58]     |
                What we can say is that Open SSL is being used and these files : TLSCertificate.key (Private key) TLSCertificate.crt (Certificate) are specified through these functions respectively: SSL_CTX_use_PrivateKey_file SSL_CTX_use_certificate_file Date Time Of Last Edit: 2021-02-10 20:04:06
