Date/Time: Sat, 23 Nov 2024 21:31:58 +0000
Volume profile for selected bars
View Count: 1306
[2020-07-14 18:33:45]
manfretto - Posts: 117
is it possible to calculate volume profile for only selected group of bars shown on the chart?
[2020-07-15 05:10:46]
Yes, you can do this by setting the appropriate parameters for start and end date and time Inputs. But the easier way is to use the Draw Volume Profile Tool. Refer to the information here:
Volume By Price Study: Draw Volume Profile
Just be aware that the Draw Volume Profile only works with Package 5 of Sierra Chart. You are already on Package 5, so you should not have any trouble.
[2020-07-15 09:27:06]
I only find issue to set the ending range to stick to the most right bar that extend to the right when new bar is created.
I have read "Tool usage" section, paragraph 4 which I assume talk about it but cannot understand how to make it.
[2020-07-16 02:37:46]
Sierra_Chart Engineering - Posts: 17152
The problem is that the Drawn Volume Profile is always using a Start Date/Time and End Date/Time. You are wanting a Volume by Price setup that uses a Volume Graph Period Type of Start Date/Time to End.
Therefore, to do this, you need to save a Study Collection that uses a Volume Graph Period Type of Start Date/Time to End and select this Study Collection to use with the Draw Volume Profile configuration.
Refer to the information for the Volume Graph Period Type here:
Volume By Price Study: Volume Graph Period Type
Date Time Of Last Edit: 2020-07-16 02:38:29
[2024-07-19 21:58:55]
BB_King - Posts: 2
Hi, why I am getting message for Draw Volume Profile that my Service Package doesn't support this function when I have Service Package 10
[2024-07-22 13:18:33]
You need to be on one of the "Advanced" Packages to have access to the Drawn Volume Profile feature. Refer to the information on the packages at the following link:
Description of Service Packages and Pricing: Packages
