Date/Time: Sat, 21 Dec 2024 17:57:26 +0000
Brazil & Emerging Markets Data
View Count: 1379
[2014-01-05 17:37:05] |
user511 - Posts: 5 |
Hello I would like to get data from the BM&F exchange For example, prices of Petrobras (PETR4) and Vale (VALE3) into Sierra Chart. Can you advise how it's possible? I assume use an external data , as not available on SC Historical Data. Thanks & Regards, |
[2014-01-06 00:24:49] |
We are checking on this.
[2015-03-18 04:05:20] |
These symbols currently are not supported.
[2015-03-18 08:09:32] |
ganz - Posts: 1048 |
SC Support btw FYI: http://moex.com/a1558 |
