Date/Time: Sat, 20 Apr 2024 16:22:32 +0000
DOM KEEPS MOVING UP AND DOWN
View Count: 643
[2020-01-24 15:22:08] |
sjbenn85 - Posts: 11 |
My DOM keeps moving up and down. The price is ok, the DOM just keeps fluctuating up and down and i cannot trade, please help. Additionally, the DOMs which are doing this are a brighter red and blue than the others???? Thank you and Regards Simon |
[2020-01-24 19:32:19] |
There are different constant range scale methods which can be used for the Trading DOM and they are documented here: Chart Scale and Scale Adjusting: Constant Range Scale Modes Try the different ones and use one that works well for you. And refer to: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
