Date/Time: Thu, 25 Apr 2024 10:27:11 +0000
Corrupt Spreadsheet files
View Count: 476
[2020-01-22 13:02:14] |
User48838 - Posts: 112 |
Over the weekend my spreadsheets seem to have gotten corrupted. When I went to the Backup folder for the files from last week they seem to be corrupted as well. All of the formulas I entered are missing. Any hope I can find non corrupt backups? |
[2020-01-22 15:55:43] |
I was able to get the files back from a friend i had shared them with IN the Spreadsheet dialogue box the spreadsheet name had been changed from Number to Name, not sure if that is part of the issue or not. |
[2020-01-26 09:32:20] |
All of the formulas I entered are missing. It might be related to this setting:Spreadsheet Study Inputs: Formula Source Sheet Number The solution in this case is to correct the Spreadsheet Study settings, save the Chartbook, Close the Chartbook, close the Spreadsheet without saving it, restore a backup of the spreadsheet. Then reopen the Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
