Date/Time: Fri, 19 Apr 2024 20:49:16 +0000
data problem
View Count: 430
[2020-01-21 09:03:15] |
User44790 - Posts: 20 |
good morning..I have problem with data streaming from yesterday..very often frozen..Ihave to use disconnect and then connect to download data...can you help me with this..thank you very much ..JH
[2020-01-21 10:30:24] |
If this is in regards to Gain Capital, refer to: Announcement Regarding Gain Capital Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
