Date/Time: Sat, 20 Apr 2024 11:51:25 +0000
[Programming Help] - Buy signal not accurately showing on the chart
View Count: 490
[2020-01-21 07:15:01] |
sourdubber - Posts: 52 |
The spreadsheet formula calls for a buy signal when the Open is ABOVE the Moving average (=B3>AA3). But, as shown in the chart, the signal is triggered even when the Open is EQUAL to the MA (=B3>=AA3). Is this due to a faulty configuration?
[2020-01-21 14:42:32] |
Sawtooth - Posts: 3976 |
Go to the MA study's settings and set the Value Format to 0.001 or smaller and you will see it is not exactly 3323.25.
[2020-01-21 19:42:57] |
Thanks for the reply. You're the best. :) Date Time Of Last Edit: 2020-01-21 19:45:26
