Date/Time: Thu, 25 Apr 2024 02:21:01 +0000
VBP Will Not Allow Me To Change The Tick Size On The VBP Setting
View Count: 506
[2020-01-20 15:50:07] |
User240019 - Posts: 112 |
SC will not let me drop the tick setting on VBP below 5 ticks. I'm trying to create a new chart to make my current, very bloated one, more efficient, and every new VBP requires 5 ticks. can't go up, can't go down. It doesn't seem to matter how many days the chart is pulling or the session times, or the type of volume profile configuration. I simply cannot change it to 1 tick per bar. |
[2020-01-20 15:57:07] |
Additionally, I upgraded to 2036, and the problem persists. I've copied a known good configuration to this chart and it simply will not allow me to change the tick size. It keeps snapping back to 5 ticks. I've checked with another user on the his build and they aren't having the problem.
[2020-01-20 16:02:00] |
Never mind, I found the configuration. It's the volume at price multiple in the chart settings.
[2020-01-20 20:29:52] |
For reference, this is covered in this section of the documentation: Volume By Price Study: Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
