Date/Time: Sat, 20 Apr 2024 00:07:13 +0000
Pyramiding positions in ACSIL
View Count: 635
[2020-01-19 19:36:26] |
sugart - Posts: 25 |
How do we acquire multiple positions (Pyramiding) using ACSIL? For example, in an ACSIL Trading system (Long only), I would like to have 3 max positions, which are acquired separately using three buy signals at subsequent times and then are sold together (close all positions) using one sell signal. Thanks. |
[2020-01-21 06:59:59] |
Yes this is fully supported. Refer to: Automated Trading Management: Unmanaged Automated Trading And then you just need to perform the actions using the appropriate ACSIL functions to accomplish exactly what you want. Refer to: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
