Date/Time: Thu, 25 Apr 2024 10:30:54 +0000
How to start a Volume Price profile n bars back
View Count: 490
[2020-01-19 17:56:17] |
mtomas - Posts: 21 |
i have a profile that is right aligned that measures the last 100 bars. I want to place another profile left aligned that measures 100 bars BUT starting from the 200th bar back so that it maintains a profile from 200the bar back to the 100th bar back, just like my current profile that measure 100 bar back and constantly drop and adds a bar to maintain the 100 bar count, same concept but start bar is bar -200 with bar count of 100... is this possible, what settings should i adjust? thanks (please do not send me a link to the Volume Profile study help content, im looking for the specific answer on how to do this. thanks) if i choose 'One Period Based on Bar count' and set the 'Number of Periods Back to Reference' to 200, that way it would build a 100 bar count profile starting at the 200th bar back.... but it resets to 0 and shows the same 100 count profile. Date Time Of Last Edit: 2020-01-19 18:05:32
[2020-01-21 07:05:59] |
What you are looking for will be supported in the next release of Sierra Chart.
