Date/Time: Sat, 20 Apr 2024 08:16:37 +0000
[Programming Help] - Can't hide one RSI if you use it twice?
View Count: 475
[2019-12-14 01:25:27] |
J4yTr4der - Posts: 20 |
I'm testing an idea that uses one RSI setting for entry, and a completely different RSI setting for exit. So I duplicated my RSI and changed the settings for the Exit RSI. But now, I can't hide the first (Entry) RSI, because if I do it also hides the second (exit) RSI. I can hide the exit however, and still see the entry. Is there a bug here? To make things even weirder... I changed the order of the studies, moving the Exit RSI above the Entry RSI. Now, if they are both NOT hidden then I get a blank space where the studies were. If I hide the first (Exit) RSI, then it becomes visible. If I hide both studies, they both disappear completely and leave no space behind. If I hide only the second (Entry) RSI, then the blank space returns. What gives here? Additionally, this is only happening on my Win7 VM (Parallels Desktop) and not on my actual Win 10 PC. Very odd. Date Time Of Last Edit: 2019-12-14 01:47:58
