Date/Time: Thu, 25 Apr 2024 01:39:40 +0000
Default
View Count: 475
[2019-12-14 00:21:47] |
User14953 - Posts: 184 |
Is the default "Region Data Lines State" configurable for new charts? ..so new charts generated don't need be format each and every *%& time lol to take no space for Region Data Lines? Currently doing this -one at a time- for each new chart. Would streamline things signif'ly. Chart, Chart Settings, Advanced Settings 2 tab, Region Data Lines box: for Regions Numbered 2 and 3 the State wanted is "Hidden". This works great when done by hand, but it gets old quick. Thx. (Intended Title for this post was: Default "Region Data Lines State" configurable for new charts? Please Replace the mistake above if can, don't know how to edit it. thx. Date Time Of Last Edit: 2019-12-14 00:30:58
[2019-12-14 05:16:29] |
Sierra_Chart Engineering - Posts: 14076 |
Refer to: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
