Date/Time: Sat, 20 Apr 2024 04:44:22 +0000
2 Bugs/Issue: QuoteBoard and Linked Chart v2026
View Count: 572
[2019-12-13 22:41:34] |
TedMar - Posts: 189 |
Easy to reproduce with SC Datafeed 1. Load QuoteBoard and Link them with Chart 2. Add few Stock Symbols. in Example. SPY , QQQ , FB and select them 1 time to load history 3. Select QQQ in QouteBoard , Draw or write a Text in Chart. in Example static text "THIS IS QQQ" 4. Select again SPY check data is loaded in Chart, now select Edit -> Translate Symbols to Current Service BUG 1: Now u can see Text from QQQ in SPY and other Symbols 5. DoubleClick on SPY in QuoteBoard BUG 2: All other Symbols in Quteboard are now deleted :-O Date Time Of Last Edit: 2019-12-13 23:29:50
[2019-12-14 00:35:02] |
Sierra_Chart Engineering - Posts: 14017 |
1. This is not a bug. Refer to: Chart Drawing Tools: Showing or Hiding Drawings for Different Symbols 2. This will be corrected in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-14 00:53:32] |
1. This is not a bug. Refer to: Chart Drawing Tools: Showing or Hiding Drawings for Different Symbols NO difference , BUG 1 is still valide . |
[2019-12-14 04:32:15] |
1. We now understand what you are saying. We did not pay close enough attention to this at first.
