Date/Time: Thu, 25 Apr 2024 16:54:56 +0000
Data Cost
View Count: 665
[2019-12-13 21:43:12] |
gymjack - Posts: 20 |
I have been using TD Ameritrade data which I understand will no longer be available. I have been paying for use of Sierra chart and I am somewhat confused as to pricing of available data. I do not trade futures or forex and need basic historical and real time data only. I plan on trading through my existing brokerage Fidelity. From the on line info on SC it appears that Denali Or Basic SC data would be the most cost effective. First question, do my fees for use of SC cover any data service? Secondly, is there anyone I can speak with regarding the details of the differences of the data services? Jack Drucker |
[2019-12-13 23:43:43] |
Sierra Chart does support Interactive Brokers for stock trading: Interactive Brokers Trading Service What you pay for Sierra Chart is not going to include real time US equities data. But it does include historical US equities data. Yes we could have a call with you. For real-time US equities data you need to use this data feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-13 23:44:06
[2019-12-15 17:55:38] |
Thank you for the clarification. Does this mean that the historical data is included in my cost for use of the sierrachart platform. Also from the trading services dropdown choices, is the correct choice for use of the historical data "SC Data - All Services[data]?"
[2019-12-15 23:26:05] |
Yes this is all correct.
