Date/Time: Fri, 19 Apr 2024 06:20:35 +0000
Adding Text or Symbol Name to Thin DOMs
View Count: 634
[2019-12-13 20:09:31] |
ycomp - Posts: 274 |
Without making the DOM in the attached photo any wider, would there be any way I could add some text to it so i can write the contract symbol on the DOM? I use a Symbol indicator but you can see in this photo (top left) most of it is cut off... I really don't want to make the dom wider though so I was wondering if there was some way to do this |
Clipboard01.png / V - Attached On 2019-12-13 20:07:50 UTC - Size: 12.05 KB - 208 views |
[2019-12-13 23:09:09] |
No other way to do this.
[2019-12-13 23:17:35] |
T44 - Posts: 363 |
I put the symbol name as the title of the price column. (it would appear directly to the left of "buy" and "sell" on the top row of your DOM) It's in the select columns configuration box. Date Time Of Last Edit: 2019-12-13 23:18:13
[2019-12-14 13:55:58] |
thanks i'll have a look at that
[2019-12-14 18:10:15] |
T44 - Posts: 363 |
You're welcome.
10205-2019-12-14-1809.png / V - Attached On 2019-12-14 18:09:38 UTC - Size: 22.88 KB - 209 views 10204-2019-12-14-1808.png / V - Attached On 2019-12-14 18:09:41 UTC - Size: 9.57 KB - 209 views |
[2019-12-14 18:14:18] |
hey, could you send me a chartbook with that dom? I like the coloring
