Date/Time: Sat, 20 Apr 2024 10:50:46 +0000
2 Questions
View Count: 529
[2019-12-13 10:13:19] |
User288300 - Posts: 7 |
Hi I have 2 questions: 1. How do I set the chart to refresh periodically for the FDAX this instrument gets the data but not real time on my one up account 2. What is the Alarm formular to get an alarm if the AskV-BidV % in the numbersbar calc value study closes the bar between +2% and -2%, here is what I came up with, but it is not working properly.. =AND(SG11 < 5, SG11 > -5) Thank you!!! |
[2019-12-14 05:30:30] |
1. You would need to ask your broker about the data. You get your data from Rithmic, not from Sierra Chart. 2. The reason the formula does not work is that the value is output as a Percentage by default, which means that it is internally converted to a string format, therefore it is not valid for alerts. Refer to the information here for what you need to do in order to use the value in an Alert Formula: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
