Date/Time: Thu, 28 Mar 2024 23:34:24 +0000
How to adjust back contracts.
View Count: 530
[2019-12-12 16:38:53] |
User731023 - Posts: 128 |
I am using 2021 now. (Was on 1831) It does not have the click through to adjust back contracts. How do you do it now? Thanks PS Have to adjust because old rollover is wrong. No problem doing it before. |
Attachment Deleted. |
[2019-12-12 22:13:53] |
Refer to the documentation here: Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
