Date/Time: Thu, 18 Apr 2024 11:03:55 +0000
Getting disconnected
View Count: 673
[2019-12-12 15:37:12] |
User256257 - Posts: 4 |
I'm consistently getting disconnected when there is a lot of orders coming in to the market. I saw in the support board others are having problems with disconnections. Is there a checklist of things I get check on my end to make sure my set up is ok. Thanks. Mike.
[2019-12-12 15:43:34] |
We see you are using Transact and this is a Transact specific issue.The best solution is to use this data feed: Denali Exchange Data Feed You can still trade with Transact when using this data feed. But Transact did contact us about this issue, this morning and there is one small change they want us to make to make the reconnection more graceful and fast. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-12 15:43:57
[2019-12-13 13:55:43] |
fobglobal - Posts: 51 |
Hi: I just want to know if you already made the small change requested by transact. Is in the v2025? Thanks |
[2019-12-13 18:29:23] |
No it will be out in version 2026 in about 15 minutes.
