Date/Time: Fri, 29 Mar 2024 15:40:40 +0000
INFO ORDER SIZE
View Count: 1206
[2019-12-12 14:35:48] |
User00111 - Posts: 111 |
How to display the size of an order instead of the size of the fill ?
[2019-12-12 15:42:09] |
This is not clear for us. Specifically what order display are you referring to? For example an active order line on a chart?
[2019-12-12 16:00:54] |
https://www.zonetraderpro.com/delta-strength/ Only Ninja and InvestorRT can do it. Is it possible that in Sierra to reconstruct the tape like the examples shown on the web page zonetraderpro ???? __ A. Date Time Of Last Edit: 2019-12-12 17:13:26
[2019-12-12 22:09:15] |
The reconstructed tape is available when using one of the Sierra Chart Exchange Data Feeds. Just enable this option: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
