Date/Time: Fri, 29 Mar 2024 00:56:40 +0000
Why there is a quite change when use symbol Volume Multiplier?
View Count: 471
[2019-12-12 13:51:29] |
User784341 - Posts: 6 |
When using Numberbars the Ask/Bid volume value was very large, SC has the Volume Multiplier to change the large number to a small one. But when a 0.0001 Volume Multiplier is used , the ask/bid volume of the same position can change a lot. To list a case: 73.0K --> 5/82.8K --> 7 /63.7K -- >5.9 So Why there is a quite change when use symbol Volume Multiplier? |
[2019-12-12 15:59:41] |
The explanation for this is described here: Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
