Date/Time: Fri, 19 Apr 2024 08:16:54 +0000
replay erroe
View Count: 498
[2019-12-12 12:53:21] |
User632902 - Posts: 1 |
Hi, I ve got problem with replay mode on SierraChart. I can easily rewind chart to the past but its not moving forward, just stuck in one place. I tried to reinstall but i didnt help. |
[2019-12-12 15:48:03] |
The first thing we want you to do is to re-download the data in the chart: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. And then follow the instructions starting at step 10 here: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
