Date/Time: Thu, 18 Apr 2024 05:36:16 +0000
NBs - Highlight VWAP
View Count: 649
[2019-12-11 05:15:19] |
nicktrader - Posts: 665 |
Is it possible to add the option in NBs - "Highlight VWAP" (settings similiar to POC) Pls see example (NT) Many thanks Date Time Of Last Edit: 2019-12-11 07:09:16
NB VWAP (NT).png / V - Attached On 2019-12-11 07:08:41 UTC - Size: 335.48 KB - 214 views |
[2019-12-12 04:38:08] |
Is it possible to get a response. I know there is an existing study but this one has two disadvantages 1. Each time you have to adjust if you chance the TF 2. There is no way for setting: "Extension Line until Future Intersection". It would be really great if you could integrate it. |
[2019-12-12 23:01:29] |
These are feature requests. We cannot keep up with all of these.
