Date/Time: Thu, 28 Mar 2024 20:19:21 +0000
DVP Duplication
View Count: 555
[2019-12-07 04:21:59] |
stphnlwlsh - Posts: 26 |
2 observations about the draw volume profile tool. I have several VPs drawn manually with the DVP tool. I was rearranging some in the studies window, and duplicated one. When I went to select it from the chart, it was not selectable from the chart. When reviewing the manage chart drawings window to see if the drawing itself had been duplicated, the duplicated profile was not displayed. The only way I could remove it was to remove the accidental duplicate study from the studies window as if it were a study. I did not expect this. Along the same lines (and just to troubleshoot), I tried duplicating a DVP drawing from the manage chart drawings window. This does duplicate the drawing, but it is 100% transparent and cannot be changed despite selecting a different tool config. It is also not displayed in the studies window. Are these observations by design? Definitely not urgent on your list, but figured I'd report nonetheless. |
