Date/Time: Thu, 25 Apr 2024 04:18:22 +0000
WiFi Functionality?
View Count: 1163
[2019-12-05 22:13:56] |
No, there is no problem at all. Generally Wi-Fi is very fast. You can even use a satellite connection and just use the low bandwidth mode.
[2021-07-14 09:10:42] |
Sierra_Chart Engineering - Posts: 14076 |
We need you to post on the Support Board with your active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart. If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
