Date/Time: Fri, 19 Apr 2024 12:43:34 +0000
Global profit management and backtesting
View Count: 531
[2019-12-05 00:15:21] |
User623552 - Posts: 69 |
Hi, I'd like to backtest over a year on the sierra chart simulator. I need the global profit management running each back-tested day, as a trailing profit stop, and also to close all trades at the end of each day. However it doesn't seem to work correctly during back-testing. Is this a known issue? Thanks |
[2019-12-05 04:54:19] |
Yes it will not work properly for back testing.
